G& A: n$ p- B- ~% K5 V4 m0 u5 k8 E w. q4 u# g
Fly Back Diodes / Flying Wheel Diodes / Catch Diodes
@% ]! b( ]; E4 _/ [ wThe diodes represented in the H-Bridge are called “fly back diodes”. These diodes provide a path for the current to dissipate when the motor switches from on to off. Since the shaft of the motor itself is spinning, stopping the motor without those diodes in place, will cause a large spike in current that could potentially burn out the MOSFETs of the H-Bridge.
, \3 Y6 j* u; `% |) v- O7 a1 p" X
5 L. [0 k# }. }* _5 F8 I4 j |
