查看: 3244|回复: 1
[仿真讨论] “”More signal conductors than terminals can adversely affect the terminal ...
发表于 2018-3-8 16:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
HFSS运行SI仿真时,如果提示如下的log:
[info] Discrete solution,process hf3d: Port '1' has 3 signal conductors with 1 terminals.wave port的边缘是peRFect E,从这句提示可以推断出:跟wave port边缘接触的conductor软件指定为terminal,在wave port范围内同时跟边缘没有接触的conductor软件指定为signal,明显这里把信号线两旁的GND也当做是signal,因此当前的波端口设置是错误的)More signal conductors than terminals can adversely affect the terminaltransformations. Please verify conducting boundaries and objects are correctlyassigned and touch the port.(这句提示我们应该仔细检查导体边界条件,也就是该如何将信号线两旁的GND设置为terminal,跟perfect E接触)5 B0 ^9 a/ N. w3 U* @: Z
正确的做法是:除信号线之外的所有conductor都必须与wave port的边缘(perfect E)相连接," S$ s) d/ b& x& G
7 \# B& t& b' M关注“ANSYS电磁仿真”了解详情' k0 G) L8 A, o! `  J
: n" ]  c6 a% x7 ]8 V, ?
2 A$ [0 |1 q2 e
' e0 g. Y$ L# M
. G5 `, z9 x4 [3 h3 r9 `
; ]3 g) P& ~5 ?: h
: j3 ?" [7 {  [9 S. d, K
; k8 u0 w& |3 u5 `5 C" m8 S$ m: Y5 L- S$ W  I
6 N0 v% J+ f" ~) C! a
GMT+8, 2025-7-26 21:05 , Processed in 0.125000 second(s), 26 queries , Gzip On.
