查看: 1054|回复: 6
Bond wire crossing near die , far die
发表于 2018-1-11 17:49 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
DIE1 and DIE2 bonded in Different profiles. In model 1, the bond wires are crossing near DIE as highlighted in M1 picture. Is this bondable ?In model 2, Bond wires are crossing far DIE  as highlighted in M2 picture Is this bondable without short?
8 A- p9 P/ {3 p* z, f5 b$ e) ?+ rExpert pleas guide me on this6 G; o8 G7 Q7 ^% l+ l
0 S7 [" |% T5 {
# f0 x% e2 v8 @3 H) E! f# P1 UBlue Color - Profile 39 E- @7 J/ l+ R: z7 P: @
Red Color - Profile 2; [9 r1 r3 L( R: ]/ Y, `
White Color - Profile 1! j8 e; m' G- j  \$ c
* U7 n9 I1 q' T: {6 r9 ^6 h  O
6 M" y& |  M( v
, l; f( H/ F& p# h1 |7 ]9 L/ h% m4 I& \) v
- {- |  r$ q: b0 h
发表于 2018-1-13 13:18 | 只看该作者
Hi, case by case, in gerneral ,it constraint by wirebond diameter ,height profile , and lenth of the wire bond.  all this can be confirmed by different package factory. So you should determind which package assembly factory. max length less than 3000um is acceptble.
 楼主| 发表于 2018-1-18 14:25 | 只看该作者
Thanks amao!!- o0 J. W  D4 a) e7 i8 X# a
For my case , wire dia is 20u and the wire max length is 4300um in 2D , What's the problem in greater then 3000um bond wire length ?
发表于 2018-3-17 21:41 | 只看该作者
20u 最多2500um, 再长容易出现wire sweep。
* B5 ~; [$ \& G9 H3 z+ S* l) U2 `Transfer模封时,线会被模流冲弯的。很容易短路。
& {5 D4 I5 M; D2 ?, U
7 }: V6 ?' t: c# O6 ~当然了,除非有钱可以换成Compression-M, 模流小,金线可以再长点。
4 f  e; w# p" u8 U( E- n0 X& n+ Y3 G+ a; p# ]% q, }$ L  ?. f
    2024-4-29 15:07
  • 签到天数: 466 天
    [LV.9]以坛为家II
    发表于 2020-5-17 15:37 | 只看该作者
    ;P;P;P当个版主不容易啊   没准有洋人来问问题
    GMT+8, 2025-9-10 02:17 , Processed in 0.125000 second(s), 26 queries , Gzip On.
