这种帖不能沉啊,后面的人去别沉了啊!我看了楼主的想法肯定是可以通过SKILL实现的,你已经写好了光绘层叠设置了,下面自动出DRILL和光绘那就简单多了,你可以用录制的方法进行录制一套完整的出光绘的SCR文件,然后通过SKILL调用。) Q' d+ {* p% ?0 U4 u- b' w7 Y) U: R
下面的程序希望能给LZ带来帮助,当然如果LZ有更好的方法实现也是可以的啊!LZ是否可以给我加50个威望啊!^_^
( O0 m3 I: l2 c& g1 _+ @3 nif( axlVersion('version) > 15.0 then7 z& D5 M" p* Y
   fprintf(camoutfile "nctape_full \n")  b% U: Y; d. M$ ~0 l0 ^
   fprintf(camoutfile "setwindow form.nc_drill\n")
3 V4 L' n9 a2 A' C   if( drill == t then" i4 a2 V8 e5 ^# Y) T$ W
     fprintf(camoutfile "FORM nc_drill auto_tool_select YES \n")7 _5 _  g6 E+ q4 V0 [8 {
  C- Z- T8 ?% b6 \   if( unit == "millimeters" || drill == t then
+ A( x3 h2 @5 i( ]" o! k9 B2 Z" K. o1 d( ]    fprintf(camoutfile "FORM nc_drill parameters\n")1 q; Y) E; g% F# D  n( j3 @/ g
    fprintf(camoutfile "setwindow form.nc_parameters\n")
( m: c0 a; n- p9 x9 j  L# S    if( unit == "millimeters" then
& J) d( B3 t+ j  E+ D; T+ u      fprintf(camoutfile "FORM nc_parameters decimal_places 5\n")
+ l, B, J/ A6 t4 x' B      fprintf(camoutfile "FORM nc_parameters metric_units YES\n")
; ]: ~. t: X0 q! X) Z& _4 P    )
" t' C; u% }. X+ Q4 h    if( drill == t  then/ ~# O1 K7 R" c; U5 L4 ^, E
      fprintf(camoutfile "FORM nc_parameters enhanced_format YES\n")3 |8 t$ e) H' l/ s, A8 p% Y
    )4 c  d# t  M) b; S6 }* U& r
    fprintf(camoutfile "FORM nc_parameters done\n")' g6 Y  R  ~$ V
    fprintf(camoutfile "setwindow form.nc_drill\n") : _( ^4 D0 v0 I0 }. P
   )  0 I! ]* Z4 e9 s; \5 M; B
   fprintf(camoutfile "FORM nc_drill tape_name %s.drl\n" name)
# L5 Q8 A  C9 B5 E% b1 Y   fprintf(camoutfile "FORM nc_drill execute  \n")3 U2 c' n/ A! `1 O3 e
   fprintf(camoutfile "FORM nc_drill close  \n")
( q0 q, Q5 g2 g5 g/ @9 ^7 D   )
! `4 M5 q: d' L; N! |* F1 v)
$ l- ?3 x0 s, h/ wfprintf(camoutfile "setwindow pcb\n")
3 r# J& u% V4 c/ V8 Xfprintf(camoutfile "film param \n")5 T: N6 T- ^0 E. w& k) j3 W0 Z
fprintf(camoutfile "setwindow form.film_control\n")$ r& B' w2 }, D* N. K# q; l
fprintf(camoutfile "FORM film_control general_parameters \n")
; X! W0 s6 \  L& ?7 ofprintf(camoutfile "FORM film_control format_dec_places 5\n")& J6 }" ^9 T7 O+ P. L; W
if( unit == "millimeters" then ) N6 S3 o& G5 n+ k) S
   fprintf(camoutfile "FORM film_control units_metric YES\n"), G! D* C' b, w" Q
). g- D4 j0 p1 U# H4 ]4 ]
if( rs274_x == t fprintf(camoutfile "FORM film_control gerber_rs274x YES\n"))  8 b! L; P. t2 a+ c9 F* E0 n4 B5 k  r
fprintf(camoutfile "FORM film_control apertures  \n")
, I) d9 r. ^3 Z, E) yfprintf(camoutfile "setwindow form.apt_wheels\n")# w$ P. L% ?; @
fprintf(camoutfile "FORM apt_wheels 1 delete  \n")
  n6 D, ^3 b& P' P4 D: Y3 Ffprintf(camoutfile "FORM apt_wheels add_wheel  \n")) D. ]! w4 p7 X9 u" e
fprintf(camoutfile "FORM apt_wheels 1 edit  \n")* N* W( R5 s$ p5 E
fprintf(camoutfile "setwindow form.apt_stations\n")9 z$ `3 s: J- Y- y6 Y9 N4 v
if( unit == "millimeters" then , }* h: k4 X8 \! ?3 F& {
   fprintf(camoutfile "FORM apt_stations metric_units YES\n"), {; F! k4 E' t* D- e' V" J
; I3 z: Y' f. rfprintf(camoutfile "FORM apt_stations auto Without Rotation \n")- d$ u& X* _/ R6 x/ C
fprintf(camoutfile "FORM apt_stations sort By Station \n")
: A/ r6 f9 q2 Dfprintf(camoutfile "FORM apt_stations apt_done  \n")
) i, J( a* E1 Y) Z+ P$ b% w9 ifprintf(camoutfile "setwindow form.apt_wheels\n")
2 `9 W" e2 B! B  r& T, F7 Sfprintf(camoutfile "FORM apt_wheels done  \n")7 u; ]/ @# b8 U6 S5 {
fprintf(camoutfile "setwindow form.film_control\n"): ~8 [6 n  S# Q; c
fprintf(camoutfile "FORM film_control film_control\n")
: w/ f- w. a& N7 d+ e, L" rfprintf(camoutfile "FORM film_control select_all \n") ( q7 h! ?4 O# l" A& P2 f( Z1 X4 f
if( check_drc == t then  M2 |+ Y  z0 O5 d% U2 J! l) h
  fprintf(camoutfile "FORM film_control database_check YES\n")
1 P% }: f# Q, Z6 @& R8 z! j4 Telse% A& L9 k8 b! E# {% K: b
  fprintf(camoutfile "FORM film_control database_check NO\n")
2 k9 K  I+ ?7 e. P& T)
& S. z* r4 F  u* g5 S1 b% s: o3 `fprintf(camoutfile "FORM film_control create  \n")
/ r0 s5 o" e) Pfprintf(camoutfile "FORM film_control ok \n")* v) M( y2 p  x* ~  _/ I) v- U  M
close(camoutfile)
9 y% d5 }) h4 k  \" AaxlShell("setwindow pcb")
9 f! |- ~5 p9 o: h) n5 RaxlShell("replay ./camoutfile.scr") |
