% [, i0 G, B/ m: f* e% y
& N% W% U1 V# b8 D7 @: HWhat will happen if I bias the collector and emitter of an NPN Transistor inversely?) R4 q+ j/ @7 ^( E
If you use the transistor in reverse, the emitter becomes the collector and the collector becomes the emitter, and its quite simple to see what happens:
0 G& \# h6 i# X/ m+ k8 X2 Z0 f) v" h$ p; S$ \; c+ Z
- As the collector doping is less than the emitter doping, the hole current in the collector (now the emitter) increases, leading to lower beta.
- The voltage withstand capability goes down, as now the BE junction is reverse biased, and the emitter is not constructed for high withstand voltage.
- The effect of the thin basis remains. For that reason, if the forward beta is high, then the reverse beta will also be higher.
; E! O7 \$ Y" _; v+ x
/ x' E, f, l- I% ]3 e貼個洋文兒嚇唬人一下!( F3 v z+ I5 A1 V
; z: D" O8 N. [& P
! h" {# L% i& p% b. \
