查看: 1614|回复: 4
Viewdraw求教
发表于 2017-2-6 09:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
最近打算使用BCM56960的芯片做一个设计,但是给的参考设计只有pdf的原理图以及如图所示一个文件夹,因为不想着做原理图符号,毕竟一个符号有好几千个pin,容易出错。想咨询一下论坛的高手们,该图片所示内容可以转化为cadence16.5格式的原理图符号么? 6 D& O3 ?9 G4 ]( ^+ N& ]
; n+ _! H& B' y  U% E4 n5 C
发表于 2017-2-6 11:06 | 只看该作者
) I4 Z8 ^! L' q* G) q
6 q4 B4 [( B3 F3 Q- f阿貍狗 ViewDraw Translator
8 C& m2 G, ?0 j
5 _. Z7 N0 k; D/ g0 z* M2 ^/ U1 y沒用過,不知藥效如何,請自行承擔後果!% U  s* W$ ^7 N/ ]1 `6 W
- G  I( ^# T+ z
" V' \5 g" A4 f' \/ X! ^) F
8 B/ [$ z6 c5 L; Q/ j2 u, I& ~http://cadencecom.vo.llnwd.net/v1/orcad/viewreader91.zip& Q( E; q- {$ B8 z# d# Z
" u8 K7 ?/ n$ i; n) u: cOrCAD - Viewlogic Translator
, }  }# A' k: H* x: k/ F! ZYou can use the OrCAD ViewReader to convert Viewlogic ViewDraw designs in OrCAD Capture versions 7.2, 9.0, 9.1, 9.2, 9.2.1, 10.X, and 15.7.  T! }, Y# b9 n% _* s9 X9 _, _2 c
0 [& q2 M- K' J/ [- I4 f' O9 p* Q6 T6 N- h2 I7 M2 Y' ^/ A* v
If you are an OrCAD Capture 9.2 user, please remember to do the following:' b8 D! ~; c1 W; f) F/ d
  • Select the OrCAD Capture v9.10 option on the first installation dialog box. The ViewReader is the same for Release 9.1, 9.2, 9.2.1, 10.X and 15.7
  • Do not install the ViewReader in your OrCAD Capture directory. The ViewReader contains files that will overwrite files you need to use OrCAD Capture
    ( k: G$ l2 P; v! x! W
发表于 2017-2-6 14:51 | 只看该作者
IN2FAB's Viewlogic database conversion tools are the only way of translating Viewlogic and Viewldraw libraries directly in to the Cadence toolset.
  }% K" e# M3 E% `
* S* E9 z* `, I; V: L% lhttp://www.in2fab.com/viewdraw.html
0 n* }& \; \2 v& g( `
  }5 X4 K# I% _/ |$ u' _
' n) Y* B, R0 W- ?& Q+ Q% F3 ?
 楼主| 发表于 2017-2-7 15:36 | 只看该作者
) y# Z. s7 R9 \% k4 L( X* R: M
GMT+8, 2025-8-20 17:08 , Processed in 0.140625 second(s), 26 queries , Gzip On.
