查看: 720|回复: 3
原点设置到两条线交点上面
发表于 2016-11-5 11:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
defun( set_origin ()
   popup = axlUIPopupDefine(nil (list
     (list "Done" `axlFinishEnteRFun)
         (list "Cancel" `axlcancelEnterFun)))
         axlUIPopupSet(popup)
   axlClearSelSet()
   axlSetFindFilter( ?enabled list("noall" "CLINESEGS") ?onButtons list("noall" "CLINESEGS"))
   axlSingleSelectPoint()
        cline1 = car(axlGetSelSet())
        axlClearSelSet()
        axlHighlightObject(cline1)
        when(cline1
                cline2 = car(axlGetSelSet())
                axlClearSelSet()
                axlDehighlightObject(cline1)
        when(cline1 && cline2 && cline1->layer == cline2->layer
                point = axl_ol_ol2(cline1->startEnd cline2->startEnd)
              axlDBChangeDesignOrigin(list(minus(xCoord(car(point))) minus(yCoord(car(point)))))
axlCmdRegister("Origin" 'set_origin)
有个问题需要解决:当两天线交点在延长线上面时,原点不会设置到延长线交点上@deargds
发表于 2016-11-7 13:31 | 只看该作者
axl_ol_ol2这个只能求出实交点,使用下面这个函数试一下,使用方法如下:
line_intersect(cline1->startEnd cline2->startEnd)
  1. defun( line_intersect (line1 line2)
  2. prog((x0 y0 x1 y1 x2 y2 x3 y3 x y)
  3.         x0 = xCoord(nth(0 line1))
  4.         y0 = yCoord(nth(0 line1))
  5.         x1 = xCoord(nth(1 line1))
  6.         y1 = yCoord(nth(1 line1))
  7.         x2 = xCoord(nth(0 line2))
  8.         y2 = yCoord(nth(0 line2))
  9.         x3 = xCoord(nth(1 line2))
  10.         y3 = yCoord(nth(1 line2))
  11.         y = car(errset(((y0-y1)*(y3-y2)*x0 + (y3-y2)*(x1-x0)*y0 + (y1-y0)*(y3-y2)*x2 + (x2-x3)*(y1-y0)*y2 ) / ((x1-x0)*(y3-y2) + (y0-y1)*(x3-x2))))
  12.         if(y then
  13.                 x = x2 + (x3-x2)*(y-y2) / (y3-y2)
  14.                 return(list(x y))
  15.         else
  16.                 return(nil)
  17.         )
  18. )
  19. )
  20. ;deargds
  21. ;www.eda365.com
复制代码
GMT+8, 2025-8-21 05:07 , Processed in 0.109375 second(s), 23 queries , Gzip On.
