Digital signal processing (DSP) refers to anything that can be done to a
, l$ C: ?8 c! k, I( gsignal using code on a computer or DSP chip. To reduce certain
( C4 e% ~, E' S& I: j3 U/ `- lsinusoidal frequency components in a signal in amplitude, digital filtering
* z# O/ p7 o% j+ W( Z& I7 wis done. One may want to obtain the integral of a signal. If the signal3 y5 B$ h' e9 t+ S
comes from a tachometer, the integral gives the position. If the signal is
/ t) ^0 o. _4 i- B/ R6 Snoisy, then filtering the signal to reduce the amplitudes of the noise
, N' I9 K' W& E8 O1 Y/ Ffrequencies improves signal quality. For example, noise may occur from4 O' M; _2 `4 }# v3 C u
wind or rain at an outdoor music presentation. F iltering out sinusoidal
- \. W/ g. f2 A$ X$ N5 ncomponents of the signal that occur at frequencies that cannot be: r: L/ U8 v0 |3 T: Z
produced by the music itself results in recording the music with little wind0 ]; J# A8 W; d6 s& C
and rain noise. Sometimes the signal is corrupted not by noise, but by5 o3 f( \: Y; F! m5 S- G) Z7 ^
other signal frequencies that are of no present interest. If the signal is an6 |% o' y) ~& z5 W
electronic measurement of a brain wave obtained by using probes applied' F: [7 I& E: |
externally to the head, other electronic signals are picked up by the: D: P" ~. {: i! X! \4 u; q
probes, but the physician may be interested only in signals occurring at a
: |, d0 d; {) y) P' ^4 U6 T& F# p2 \particular frequency. By using digital filtering, the signals of interest only8 e8 D; d( \% N3 E) ~6 } |
can be presented to the physician. |
