Maxim 的觀點& [6 ~, s& ?& V. M- A; l! w
放電間隙(Spark Gap)的動作速度太慢,不足以保護電路。3 {$ b5 B6 i G: Q% Q
( H( g) g; t& G! {& O$ E4 W, n
原文:
: Q! \( p0 w+ {1 V1 PESD pulses can easily arc from one trace to another when the spacing between traces is narrow. Increasing the spacing between the circuit board traces or surrounding signal lines with a separate return plane is helpful in preventing ESD energy from arcing between pins. Arcing occurs slowly compared with ESD rise time, so air spark gaps alone will not protect circuitry from ESD. 10 mil spark gap would have 300us activation delay.9 X8 p' d+ A7 P: h/ O. i
9 j0 h: }8 J) f, m
$ z7 \; l0 \0 T/ _
3 P5 B" d! k8 V& L3 ?# ?3 p7 g" l) N, S: D4 K: g
, [' N2 `+ e0 }
