查看: 933|回复: 5
move silk to center
    擦汗
    2024-5-15 15:49
  • 签到天数: 314 天
    [LV.8]以坛为家I
    发表于 2016-8-3 17:41 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    有一个move silk to bodycenter的skill,但是他提的text坐标是左下角坐标,移动之后有时候还是会有遮挡器件丝印的问题,求获取text的中心坐标办法
    发表于 2016-8-4 08:12 | 只看该作者
    axlDBAltOrigin
    擦汗
    2024-5-15 15:49
  • 签到天数: 314 天
    [LV.8]以坛为家I
     楼主| 发表于 2016-8-5 14:07 | 只看该作者
    axlCmdRegister( "r2c" 'RefDestoCenter ?cmdType "interactive" ?doneCmd  'ps_RefDestoCenterstop ?cancelCmd 'ps_RefDestoCenterstop )
    procedure( RefDestoCenter( )
            let(
                    ( lLayer_name
                            PI
                            ps_RefDestoCenter_From_file
                            sPackageLayer
                            bStop
                            lBlock
                            bSym
                            bLayer
                            lSym
                            lText
                            bText_status
                            dShape
                            dShape_temp
                            fDelta_y
                            fSym_center_x
                            fSym_center_y
                            fSym_left_x
                            fSym_left_y
                            fSym_right_x
                            fSym_right_y
                            fSym_x
                            fSym_y
                            fSym_xy
                            fText_rot
                            lShape
                            lSym_shape_box
                            rText_orient
                    if( compareTime("Dec 12 16:35:55 2020" getCurrentTime() )>0 && compareTime("Aug 10 16:35:55 2009" getCurrentTime() )<0 then
                            PI = 3.1415926
                            bStop = t
                            lBlock
                            lLayer_name = list( "Assembly TOP" "SilkScreen TOP" "Assembly BOTTOM" "SilkScreen BOTTOM" "Move All" )
                            ps_RefDestoCenter_From_file = strcat( axlTempDirectory() "./ps_RefDestoCenter_From.form" )
                ; create the Move RefDes To Body Center form
                ps_RefDestoCenter_From = outfile( ps_RefDestoCenter_From_file "w" )
                      fprintf( ps_RefDestoCenter_From "FILE_TYPE=FORM_DEFN VERSION=2\n" )
                            fprintf( ps_RefDestoCenter_From "FORM\n" )
                            fprintf( ps_RefDestoCenter_From "FIXED\n" )
                            fprintf( ps_RefDestoCenter_From "PORT 29 20\n" )
                            fprintf( ps_RefDestoCenter_From "HEADER \"ps_RefDestoCenter\"\n" )
                            fprintf( ps_RefDestoCenter_From "POPUP <select_layer_name_p>" )
                            fprintf( ps_RefDestoCenter_From "\"a\"\"a\"" )
                            fprintf( ps_RefDestoCenter_From "\n" )
                            fprintf( ps_RefDestoCenter_From "TILE\n" )
                      fprintf( ps_RefDestoCenter_From "TEXT \"Select visible layer:\"\n" )
                            fprintf( ps_RefDestoCenter_From "TLOC 2 1\n" )
                            fprintf( ps_RefDestoCenter_From "ENDTEXT\n" )
                             fprintf( ps_RefDestoCenter_From "FIELD select_layer_name\n" )
                       fprintf( ps_RefDestoCenter_From "FLOC 11 3\n" )
                       fprintf( ps_RefDestoCenter_From "ENUMSET 13\n" )
                       fprintf( ps_RefDestoCenter_From "POP \"select_layer_name_p\"\n" )
                       fprintf( ps_RefDestoCenter_From "ENDFIELD\n" )
                            fprintf( ps_RefDestoCenter_From "TEXT \"Move mode:\"\n" )
                            fprintf( ps_RefDestoCenter_From "TLOC 2 5\n" )
                            fprintf( ps_RefDestoCenter_From "FIELD Layer_mode\n" )
                       fprintf( ps_RefDestoCenter_From "FLOC 11 5\n" )
                      fprintf( ps_RefDestoCenter_From "CHECKLIST \"By Layer\" \"radioLabel\"\n" )
                            fprintf( ps_RefDestoCenter_From "FIELD Sym_mode\n" )
                      fprintf( ps_RefDestoCenter_From "FLOC 11 7\n" )
                      fprintf( ps_RefDestoCenter_From "CHECKLIST \"By Symbol\" \"radioLabel\"\n" )
                            fprintf( ps_RefDestoCenter_From "FIELD aspcRun\n" )
                            fprintf( ps_RefDestoCenter_From "FLOC 16 9\n" )
                            fprintf( ps_RefDestoCenter_From "MENUBUTTON \"Run\" 11 3\n" )
                            fprintf( ps_RefDestoCenter_From "FIELD aspcHelp\n" )
                            fprintf( ps_RefDestoCenter_From "FLOC 2 9\n" )
                            fprintf( ps_RefDestoCenter_From "MENUBUTTON \"Help\" 11 3\n" )
                            fprintf( ps_RefDestoCenter_From "ENDTILE\n" )
                            fprintf( ps_RefDestoCenter_From "ENDFORM\n" )
                            close( ps_RefDestoCenter_From )
                            ps_RefDestoCenter_From = axlFormCreate( (gensym) ps_RefDestoCenter_From_file '(e inner) 'ps_RefDestoCenter_Routine t )
                            ps_RefDestoCenter_From = axlMiniStatusLoad( (gensym) ps_RefDestoCenter_From_file  'ps_RefDestoCenter_Routine )
                            ; set default value to form field
                            axlFormBuildPopup( ps_RefDestoCenter_From "select_layer_name" lLayer_name )
                            axlFormSetField( ps_RefDestoCenter_From "select_layer_name" "Assembly TOP" )
                            axlFormSetField( ps_RefDestoCenter_From "Sym_mode" t )
                            axlFormSetFieldVisible( ps_RefDestoCenter_From "aspcRun" 0 )
                            axlFormDisplay( ps_RefDestoCenter_From )
                            deleteFile( ps_RefDestoCenter_From_file )
                            ; default visible layer is Assembly Top
                            axlVisibleDesign( nil )
                            axlVisibleLayer( "Board Geometry/Assembly_TOP" t )
                            axlVisibleLayer( "Board Geometry/Outline" t )
                            axlVisibleLayer( "Drawing Format/Title_Block" t )
                            axlVisibleLayer( "Drawing Format/Outline" t )
                            axlVisibleLayer( "Package Geometry/Assembly_Top" t )
                            axlVisibleLayer( "Ref Des/Assembly_Top" t )
                            axlVisibleLayer( "Pin/Top" t )
                            axlFlushDisplay()
                            sPackageLayer = "PACKAGE GEOMETRY/PLACE_BOUND_BOTTOM"
                            axlMsgPut( "Please select a symbol to move its Refdes in By Symbol mode;" )
                            axlMsgPut( "or select a layer to move all the Refdes in By Layer mode!" )
                            while( bStop
                                            bSym = axlFormGetField( ps_RefDestoCenter_From "Sym_mode" )
                                            bLayer = !bSym
                                            while( bStop && bSym
                                                            axlSetFindFilter(?enabled '("NOALL" "symbols" ) ?onButtons '("symbols" ))
                                                            axlMsgPut( "Please select a symbol to Move its Refdes." )
                                                            if(        axlSelect() then
        lSym = axlGetSelSet( )
        axlClearSelSet()
        axlSetFindFilter( ?enabled ( list "NOALL"  "TEXT" ) ?onButtons ( list "NOALL" "TEXT" ) )
        lText = axlGetSelSet( axlAddSelectAll( ) )
        axlClearSelSet()
        ; get text block info, store them in a list
        ; if some block text are not rotate 0, 90, 180 or 270 degree, then need to re-create a some block text
        ; and get its block info
        lBlock = nil
        foreach( dText lText
        unless( member( dText->textBlock lBlock )
        lBlock = cons( dText->textBlock lBlock )
        if( dText->rotation == 0.0 || dText->rotation == 180.0
        then
        fDelta_y = ( cadadr( dText->bBox ) - cadar( dText->bBox ) )*0.32
        else
        if( dText->rotation == 90.0 || dText->rotation == 270.0
        then
        fDelta_y = ( caadr( dText->bBox ) - caar( dText->bBox ) )*0.32
        else
        rText_orient = make_axlTextOrientation(
        ?textBlock dText->textBlock, ?rotation 0.0,
        ?mirrored dText->isMirrored, ?justify dText->justify
        bText_status = caar( axlDBCreateText( dText->text, 0:0, rText_orient, dText->layer, nil )        )
        fDelta_y =         ( cadadr( bText_status->bBox ) - cadar( bText_status->bBox ) )*0.32
        axlDeleteObject( list( bText_status ) )
        ); end if
        lBlock = cons( fDelta_y lBlock )
        ); end foreach
        lBlock = reverse( lBlock )
        ; move RefDes to Symbol Body Center
        foreach( dSym lSym
        lShape = nil
        unless( dSym->isMirrored
        sPackageLayer = "PACKAGE GEOMETRY/PLACE_BOUND_TOP"
        foreach( dChild dSym->children
        when( dChild->objType == "shape" && dChild->layer == sPackageLayer
        lShape = cons( dChild        lShape )
        ); end foreach child
        ; when one symbol got more than one place boundry shapes,
        ; need to find the largest one.
        when( lShape
        dShape_temp = car( lShape )
        unless( onep( length( lShape ) )
        for( n 1 length( lShape ) - 1
        dShape = nth( n lShape )
        unless(        axlDistance( car( dShape->bBox ) cadr( dShape->bBox ) ) < \
        axlDistance( car( dShape_temp->bBox ) cadr( dShape_temp->bBox ) )
        dShape_temp = dShape
        ); end for
        ); end unless
        ; get Shape center
        lSym_shape_box = dShape_temp->bBox
        fSym_left_x  = caar( lSym_shape_box )
        fSym_right_x = caadr( lSym_shape_box )
        fSym_left_y  = cadar( lSym_shape_box )
        fSym_right_y = cadadr( lSym_shape_box )
        fSym_center_x = ( fSym_left_x + fSym_right_x )*0.5
        fSym_center_y = ( fSym_left_y + fSym_right_y )*0.5
        ; get symbol RefDes, and move it to this shape center
        when( dText->parent == dSym && dText->text == dSym->refdes && substring( dText->layer 1 7 ) == "REF DES"
        ; here still need to check original text orientation, and adjust text coordinate about 0.32 times
        fDelta_y = cadr( member( dText->textBlock lBlock ) )
        if( dText->isMirrored then
        ; if do not care some special degrees, like 90.287
        ; it will be easy
        caseq( round( dSym->rotation / 45.0 )
        (                ( 0 5 6 7 )
        fText_rot = round( dSym->rotation / 45.0 ) * 45.0
        (                (  1 2 3 4 )
        fText_rot = round( dSym->rotation / 45.0 ) * 45.0 + 180.0
        );end case
        else
        (                ( 0 1 2 3 )
        (                (  4 5 6 7        )
        );end case
        );end if
        fSym_x = fSym_center_x + fDelta_y*sin( fText_rot * PI / 180.0 )
        fSym_y = fSym_center_y - fDelta_y*cos( fText_rot * PI / 180.0 )
        ?textBlock dText->textBlock, ?rotation fText_rot,
        fSym_xy = fSym_x : fSym_y
        bText_status = car( axlDBCreateText( dText->text, fSym_xy, rText_orient, dText->layer, dSym )        )
        when( bText_status
        axlDeleteObject(  dText  )
        ); end when
        ); end foreach
        ); end when
        ); end foreach dSym
                                                            else
        unless( !bStop || axlFormGetField( ps_RefDestoCenter_From "Layer_mode" )
        axlMsgPut( "Wrong select, please select symbol!" )
                                                            ); end if
                                            ); end Symbol mode
                                            while( bStop && bLayer
                                                            ; in Layer mode, should set Run Button active
                                                            axlFormSetFieldVisible( ps_RefDestoCenter_From "aspcRun" 1 )
                                                            unless( !bStop || axlFormGetField( ps_RefDestoCenter_From "Sym_mode" )
        axlMsgPut( "Please select a layer, then click Run Button to move those RefDes on the layer!" )
                                                            when(        axlSelect(?prompt nil)
        axlClearSelSet( )
                                                            bLayer = axlFormGetField( ps_RefDestoCenter_From "Layer_mode" )
                                            ); end layer mode
                            ); end global while loop
                    else
                axlUIConfirm("E- the tool is expired, please contact EDA team")
                    axlMsgPut( "Done!" )
    ); end procedure ps_RefDestoCenter
    procedure( ps_RefDestoCenter_Routine( ps_RefDestoCenter_From )
      let(
        ( sLayer_active
                            PI
                            lBlock
                            lSym
                            lText
                            sPackageLayer
                            bText_status
                            dShape
                            dShape_temp
                            fDelta_y
                            fSym_center_x
                            fSym_center_y
                            fSym_left_x
                            fSym_left_y
                            fSym_right_x
                            fSym_right_y
                            fSym_x
                            fSym_y
                            fSym_xy
                            fText_rot
                            lShape
                            lSym_shape_box
                            rText_orient
                            nCheck_All
        PI = 3.1415926
              case( ps_RefDestoCenter_From->curField
                      ( "select_layer_name"
                                    ;axlCancelEnterFun( )
                                    ;axlClearSelSet( )
                              sLayer_active = ps_RefDestoCenter_From->curValue
                                     case( sLayer_active
                                            ( "Assembly TOP"
                                            ( "SilkScreen TOP"
                                                    axlVisibleLayer( "Board Geometry/SilkScreen_TOP" t )
                                                    axlVisibleLayer( "Package Geometry/SilkScreen_Top" t )
                                                    axlVisibleLayer( "Ref Des/SilkScreen_Top" t )
                                                    axlVisibleLayer( "Route Keepin/All" t )
                                                    axlVisibleLayer( "Route Keepout/Top" t )
                                            ( "Assembly BOTTOM"
                                                    ; display related layers, assembly or silkscreen Top/Bottom layer
                                                    axlVisibleLayer( "Board Geometry/Assembly_Bottom" t )
                                                    axlVisibleLayer( "Package Geometry/Assembly_Bottom" t )
                                                    axlVisibleLayer( "Ref Des/Assembly_Bottom" t )
                                                    axlVisibleLayer( "Pin/Bottom" t )
                                            ( "SilkScreen BOTTOM"
                                                    axlVisibleLayer( "Board Geometry/SilkScreen_BOTTOM" t )
                                                    axlVisibleLayer( "Package Geometry/SilkScreen_Bottom" t )
                                                    axlVisibleLayer( "Ref Des/SilkScreen_Bottom" t )
                                                    axlVisibleLayer( "Route Keepout/BOTTOM" t )
                                            ( "Move All"
                                                    axlClearSelSet( )
                                                    axlFormSetField( ps_RefDestoCenter_From "Layer_mode" t )
                                    ); end case
                                    axlFlushDisplay()
                                    axlShell( "redisplay" )
                      ( "Sym_mode"
                                    axlClearSelSet( )
                      ( "Layer_mode"
                                    axlClearSelSet( )
                      ( "aspcRun"
                                    axlClearSelSet( )
                                    sLayer_active = axlFormGetField( ps_RefDestoCenter_From         "select_layer_name" )
                                    nCheck_All = 3
                                    unless( sLayer_active == "Move All"
                                                    nCheck_All = 0
                                    for( i 0 nCheck_All
                                            case( i
                                                    ( 0
                                                    ( 1
                                                            axlFlushDisplay()
                                                    ( 2
                                                            axlFlushDisplay()
                                                    ( 3
                                                            axlFlushDisplay()
                                            ); end case
                                             axlClearSelSet()
                                            lSym = axlGetSelSet( axlAddSelectAll( ) )
                                            axlClearSelSet()
                                            lBlock = nil
        if( dText->rotation == 0.0 || dText->rotation == 180.0 then
        else
        if( dText->rotation == 90.0 || dText->rotation == 270.0 then
        else
        ); end if
                                            ); end foreach
                                            foreach( dSym lSym
                                                            lShape = nil
                                                            when( lShape
        ); end for
        ); end unless
        ; get Shape center
        ; it will be easy
        (                ( 0 1 2 7 )
        (                ( 3 4 5 6 )
        );end case
        else
        (                ( 0 1 2 7 )
        (                ( 3 4 5 6        )
        );end case
        );end if
        when( bText_status
        ); end when
        ); end foreach
                                                            ); end when
                                            ); end foreach dSym
                                    ); end for
                                    when( nCheck_All > 0
                                                    axlFlushDisplay()
                            ); end aspcRun
                      ( "aspcHelp"
                                    axlClearSelSet( )
                                    nvhtmBrowser( nvmmrbc_HELPPAGE )
              ); end case
            ); end let
    ); end ps_RefDestoCenter_Routine
    procedure( ps_RefDestoCenterstop()
      axlFormClose( ps_RefDestoCenter_From )
            axlClearSelSet( )
            axlFlushDisplay( )
            bStop = nil
    擦汗
    2024-5-15 15:49
  • 签到天数: 314 天
    [LV.8]以坛为家I
     楼主| 发表于 2016-8-5 14:08 | 只看该作者
    求大神帮忙修改代码,实现器件丝印中心对准器件中心,而不是器件左小脚对准器件中心
    GMT+8, 2025-8-21 07:56 , Processed in 0.125000 second(s), 23 queries , Gzip On.
