#include "periph_lcd.h"
# O. l. G( _& C; m( R5 V" M- j7 |
, e8 F% J% z2 X" n/ slcd_code_item_t LCD_CODE_TAB[]=
% N* F b" Y4 r$ ^{ 2 Z4 r) A- j' q+ K. r' Y( ^6 g
[LCD_CHAR_0] ={.COM0_L=1,.COM0_H=0,.COM1_L=1,.COM1_H=1,.COM2_L=0,.COM2_H=1,.COM3_L=1,.COM3_H=1,},
+ n$ h" Z$ g, T0 I9 ? [LCD_CHAR_1] ={.COM0_L=0,.COM0_H=0,.COM1_L=0,.COM1_H=1,.COM2_L=0,.COM2_H=1,.COM3_L=0,.COM3_H=0,}, 5 R4 O# k- q% d; i3 m$ X S
[LCD_CHAR_2] ={.COM0_L=1,.COM0_H=0,.COM1_L=1,.COM1_H=0,.COM2_L=1,.COM2_H=1,.COM3_L=0,.COM3_H=1,},
3 j: e' v6 i/ h. _: C- r [LCD_CHAR_3] ={.COM0_L=1,.COM0_H=0,.COM1_L=0,.COM1_H=1,.COM2_L=1,.COM2_H=1,.COM3_L=0,.COM3_H=1,}, . t) k6 M$ s4 Q. B5 h: I K
[LCD_CHAR_4] ={.COM0_L=0,.COM0_H=0,.COM1_L=0,.COM1_H=1,.COM2_L=1,.COM2_H=1,.COM3_L=1,.COM3_H=0,}, g+ o; x6 n4 j! j! c9 A3 y
[LCD_CHAR_5] ={.COM0_L=1,.COM0_H=0,.COM1_L=0,.COM1_H=1,.COM2_L=1,.COM2_H=0,.COM3_L=1,.COM3_H=1,}, + s) y9 l; }& ]" W9 ^) [: P7 c9 a
[LCD_CHAR_6] ={.COM0_L=1,.COM0_H=0,.COM1_L=1,.COM1_H=1,.COM2_L=1,.COM2_H=0,.COM3_L=1,.COM3_H=1,}, " y+ B* E9 W) [5 s9 H
[LCD_CHAR_7] ={.COM0_L=0,.COM0_H=0,.COM1_L=0,.COM1_H=1,.COM2_L=0,.COM2_H=1,.COM3_L=0,.COM3_H=1,},
' g+ R' s$ }8 h" ~ X3 B [LCD_CHAR_8] ={.COM0_L=1,.COM0_H=0,.COM1_L=1,.COM1_H=1,.COM2_L=1,.COM2_H=1,.COM3_L=1,.COM3_H=1,},
: f3 C" z+ r/ U+ G2 C1 K [LCD_CHAR_9] ={.COM0_L=1,.COM0_H=0,.COM1_L=0,.COM1_H=1,.COM2_L=1,.COM2_H=1,.COM3_L=1,.COM3_H=1,},
- S3 q+ J: ~& [" ?2 v2 U; v. ]5 p
! q: y% Z" B4 E* b5 L3 ^$ v* _, \7 c: I [LCD_CHAR_OFF]={.COM0_L=0,.COM0_H=0,.COM1_L=0,.COM1_H=0,.COM2_L=0,.COM2_H=0,.COM3_L=0,.COM3_H=0,},- f4 ]2 f. n# \/ L+ }" I2 b
8 x& g. h1 x, X) M% k0 I9 V
! I, o/ o3 n9 | f* |6 Z2 J& tvoid LCD_Open(void) + l1 q, U H. [2 d: ]; S
9 T6 H, @' T. Y9 m' Q CLK_PeripheralClockConfig(CLK_Peripheral_LCD,ENABLE); * \. { U6 b5 G9 d/ `
CLK_RTCClockConfig(CLK_RTCCLKSource_HSI,CLK_RTCCLKDiv_64); ; Q: @5 u h% C; K5 J/ c% \
LCD_Init(LCD_Prescaler_8,LCD_Divider_18,LCD_Duty_1_4,LCD_Bias_1_3,LCD_VoltageSource_External);* q! _+ W1 f/ V, b
LCD_PortMaskConfig(LCD_PortMaskRegister_0, 0xff); # I' L4 i+ ~! i# g5 _2 p
LCD_PortMaskConfig(LCD_PortMaskRegister_1, 0x03);
Q9 \. i" @- Y: L. b# t# Z. l {0 |) T0 i
LCD_ContrastConfig(LCD_Contrast_3V0); % z. h4 Z0 u/ d/ y" ~" B8 V
LCD_DeadTimeConfig(LCD_DeadTime_0);
# m+ h' v1 d1 J6 Q: R# t0 i$ A0 T LCD_PulseOnDurationConfig(LCD_PulseOnDuration_7);
) g4 Z8 A. E* N3 [' n! h LCD_Cmd(ENABLE);
" Q7 ^8 Z" @' W1 `+ v3 n( ]& m}
8 o+ _$ i9 I% A- d
/ n! m) m" g) v; k9 uvoid LCD_DispCharOnIndex(uint8ch, uint8 index) ) d; S& ^, W* E% X0 j8 f
{ % ^' y( J# W5 G5 S, M
if(index>=LCD_INDEX_MAX_COUNT)
+ P7 D1 S- w: O4 ~; V) V& ~ { * [8 N U6 ~/ ?- E. B( a" q! b
return ; ; N* a6 C8 y2 F
0 j/ M+ Z7 Q6 H, ~, O% i
! X4 L. O+ b4 P) X( ~ uint8lcd_code=LCD_CODE_TAB[ch].Byte;
& j$ I$ L d* {$ S" D8 D4 f# { * \! v! U4 R+ g# Z7 T/ `
if(lcd_code & BIT_MAST_COM0_L)
* P, Y; y5 u, S, P) ?& ] {
) y0 ]" E `0 D& Z" q bit_arry_set_bit((void *)LCD->RAM,28*0+index*2);
8 W4 U+ Z/ u$ s5 R2 H3 j" g } 9 b2 ^* Z) {: K3 j4 `9 O5 B& G
else 7 z9 i/ M8 Z R; f, E
{ 0 u, m' w$ H' q4 S
bit_arry_clr_bit((void *)LCD->RAM,28*0+index*2);
# q; t, ~- ]) E; a( E0 E* r } ! @! y2 p( b/ g
# P! t2 X* B1 Q if(lcd_code & BIT_MAST_COM0_H) : A: T5 C# X1 p. v. X, {
{ * {0 o5 T- }5 T4 b8 a) s
bit_arry_set_bit((void *)LCD->RAM,28*0+index*2+1);
; H# ]- P6 ^* T* y* f }
- G9 F' _( I( T$ \, j+ Y else
5 R+ P, O0 \0 {- e. n; Y1 k5 e {
4 z) d6 R9 ]8 J( @$ l7 e bit_arry_clr_bit((void *)LCD->RAM,28*0+index*2+1); , k# Q5 ]7 Q5 X. N& h
} ; B) u p) v* L- Y! X# m3 f4 P" b
/ s$ b/ S6 `5 w3 l& v X
if(lcd_code & BIT_MAST_COM1_L)
3 N$ }# n- ~. Y0 c0 `& ?: k { 3 @# w! H0 I" O5 E' R: [" e
bit_arry_set_bit((void *)LCD->RAM,28*1+index*2); 3 `, K* p* h: J! _ h! q
} 9 G/ o! i* A0 ?2 u8 F' {- r
else
& l3 ?( I8 J9 Z5 _ { 2 _1 t. J# z* j$ V
bit_arry_clr_bit((void *)LCD->RAM,28*1+index*2);
4 H% v& t' t7 \/ A0 G }
+ U. I* J$ m: D2 V3 v7 V+ b
4 N% ], Y- F8 Q) h if(lcd_code & BIT_MAST_COM1_H)
! b! \$ f) ~4 V. e: z* e9 N, W, ~ { 4 v: {- o& K/ Q6 a O+ e# E; g
bit_arry_set_bit((void *)LCD->RAM,28*1+index*2+1);
/ j8 j& d) d" B. c3 e( F& s } % v5 \7 V6 w" X a
else
; P0 n2 `- I( Q3 }: X {
1 F3 G) U7 Q( X4 i* T5 t& Y, @ bit_arry_clr_bit((void *)LCD->RAM,28*1+index*2+1);
& r: B5 `- W* F& W3 k% M: X } ) X# N! Y7 I: |5 [
; ]* j! K1 U7 {
if(lcd_code & BIT_MAST_COM2_L) $ O' O% P% l, n
{ & a0 J% ]; U# l5 n4 A$ V" _( b
bit_arry_set_bit((void *)LCD->RAM,28*2+index*2); 4 v x; k4 d8 Y, W2 w/ [0 i' @
) M+ K X) w& G* I, x else
- l- a; M! y: R" q& }6 B1 L/ z { 2 ~6 s; W3 D( S: X# p1 J) T$ L
bit_arry_clr_bit((void *)LCD->RAM,28*2+index*2); 3 ^, O: j& q/ r% g5 W0 E+ g
} U: J* X& l. F
! {4 K* E, K# b8 m if(lcd_code & BIT_MAST_COM2_H)
, P+ |6 g6 g+ _5 K$ @3 [: W {
. w: E9 T9 l7 D6 X' A. ^2 Z bit_arry_set_bit((void *)LCD->RAM,28*2+index*2+1);
8 X3 A9 w( D, J9 z+ C }
1 Q2 f2 v. H: y( c) a else
3 n! H$ L+ t$ B/ Y {
I# T: ]& P6 E ]9 l0 D7 { bit_arry_clr_bit((void *)LCD->RAM,28*2+index*2+1); ( o* Q4 ?2 \) G( M
1 \, m. k4 [! _- b$ d) G6 U
- q1 o( b& y( c* T) v. q if(lcd_code & BIT_MAST_COM3_L) 2 [+ P6 F% b4 \) W" W. i5 P0 n1 F
{ ( I2 c* R' Y( ~) f& n- Y# [; m% T4 D
bit_arry_set_bit((void *)LCD->RAM,28*3+index*2); 6 ? v: \# m! ` b% S* V5 q; {
} # _, k, r# f2 P8 C2 j0 z" J
else
* M/ p% I% r3 e* _' i {
3 h! b' Y8 x# v! O& Z* E* { bit_arry_clr_bit((void *)LCD->RAM,28*3+index*2);
$ ?) ?2 [* I/ B' a. Z* W u } / Z$ i9 m" T: n6 p* N
" V/ c% S; @+ E- f) c if(lcd_code & BIT_MAST_COM3_H)
! z# j0 d T% c+ ? { : s' h' g& p* S$ j
bit_arry_set_bit((void *)LCD->RAM,28*3+index*2+1); ! v5 w) Y N- t& @/ j! N2 M! e
9 d/ O1 F- `7 m }: ?) ~; y else / n: _" U- N4 [1 D# s2 c
. n, x8 I! Z) O( h& S bit_arry_clr_bit((void *)LCD->RAM,28*3+index*2+1); , D" x# p* K+ K5 K( l8 ^! d4 f" o
} 9 u; z4 ~6 U3 V: u5 {2 A
! I, f' {( F7 v& d/ A1 @( S1 V: [2 V! c' [1 |& O
void LCD_DispOffOnIndex(uint8index)
& |4 H. @. f6 S! J$ L! _ _{
3 t0 `( G7 z3 b8 S/ d% C1 i LCD_DispCharOnIndex(LCD_CHAR_OFF,index);
, p1 d% d" @9 y: w2 P' I7 e} , d, q9 c, N7 ?: B& }, @
8 U6 C8 H! s* q1 v" B! w7 ^5 x9 h6 j& e6 l- P+ K
void LCD_DispOffOnAllIndex(void) & n& H6 g& R- x# `# e* \ i# P
{ " a) Z: ]( B' S5 O* X6 y* z
for(uint8 i=0;i<lcd_index_max_count;i++)[size][="" font][="" backcolor][=""color][color="#333333][backcolor=rgb(242," 250,=""254)][size="11.818181991577148px]" [="" color]
: h( S2 I# w! n" [$ A {
6 f' ^3 D' q' D9 ^* h w LCD_DispCharOnIndex(LCD_CHAR_OFF,i);
& {4 _# h) m! q' B+ | } * a* B( q, c" [
} & v; [+ s% T7 R# w/ p4 ]/ e) p
, N- B9 J1 e0 ~7 I
void LCD_DispUint16(uint16num, uint8 blank)
" y6 c- E' z8 W$ V) u' N+ U{
* z( |2 |4 {5 ^( m uint8 bcd[__MAX(5,LCD_INDEX_MAX_COUNT)]={0}; ! R9 z! {7 w5 K4 p1 Z/ {" a. f
uint8 bcd_index;
0 i7 }. x8 T% s3 |- J4 Z uint8 lcd_index; 1 R# f3 h& A7 n" H
: L; F1 ~$ y( d1 g7 Y% ^& K uint8 index_max_count=__MAX(5,LCD_INDEX_MAX_COUNT); " {" @8 O) n# A1 B9 u
6 T+ {* y7 z* T: k5 L" o2 a" } u16_to_bcd_5(num,bcd);
1 q3 U! ~" Z6 h' Y. v( p. l 4 O* R/ P8 o [
bcd_index=index_max_count-1;
! Y' Z& P9 W* Z* Q9 u8 M( ~2 a1 O ' p5 P% M {. {6 k- U* m
for(;(bcd[bcd_index]==0)&&(bcd_index!=0);bcd_index--) , d9 u- H3 A2 j# x: {' `8 ?& C
{ * M! t6 ?, Z9 Y( j; L1 P$ c
lcd_index=index_max_count-1-bcd_index;
; F* Y! l( G. q9 S/ k LCD_DispCharOnIndex(LCD_CHAR_OFF,lcd_index); ! |1 R" G8 o% o M; t
} 6 U2 v, a% S: y6 [# J' s3 y& ~! }2 ]
: Z# w5 H1 x3 H1 W z% i' I) z
for(;bcd_index!=0xff;bcd_index--) . Q, v! z0 ]( S* g
{ # g5 y- i2 [ l: h+ }; J( }+ n
* I; D; r; w% F% E: o LCD_DispCharOnIndex(bcd[bcd_index],lcd_index); - g6 l$ y; y3 Q H3 T
} / N1 j7 S& ~; ?# u. m
! e* y3 x$ W* v) Y/ Y( T: a' O8 M. d- P4 a" j! ]9 O! ?
#include "stm8l15x.h" ; Q R+ c; z4 ^$ I5 Q* w
#include "uni_int.h"
5 @, `: b5 n3 ^3 x- }2 K+ Q#include "delay.h" 6 l3 z$ h6 p6 d0 `1 A* M
#include "periph_lcd.h" 3 E7 e. n' _" z- |2 x$ F/ L
6 U: ]0 t" o/ q9 E3 z9 m
int main()
8 T" w" e6 D( A; \' m{ : {$ ^! q8 \7 E! T ]5 I
LCD_Open(); ( m; c$ a7 B) }. z) D/ }
! H& q" z! t$ Z+ j0 _4 l8 \, ?* E R
uint16 num=100;
6 _* V* o, Q; {: C: u+ [2 O0 W : C6 V/ E2 X1 O" y5 _
while(1) + ?& @) X! h- }0 R; m$ V$ m
0 B7 l& G. S, Y0 l4 z5 { num--; . w: G( I4 ]9 f+ }+ p
LCD_DispUint16(num,LCD_CHAR_OFF);
- {$ c7 l& C( V4 G0 d, V8 G* O/ q delay(); : w4 ^9 o) |" v, z6 }
} 5 X! ?4 ~; t% t
, N$ n, m8 ]& d G, o[size=11.818181991577148px][size=11.818181991577148px]1 ? f4 R* G' t( i3 M* m t* N- `8 _9 k
