Synthesiable High PeRFormance SDRAM Contoller
5 ~/ z. h+ q# u) f$ e* ^5 B2 Q) ?) G) l5 o" V& p3 n" S
Synthesiable High Performance SDRAM Contoller
; `7 J" N/ K' J) ?: J9 L& `Synchronous DRAMs are available in speed grades above 100 MHz using LVTTL I/Os. The
/ @; q4 M3 g6 z, A% |8 `- v1 ]9 ~Virtex? series of FPGAs and the Spartan?-II family of FPGAs have many features, such as2 W% }" ]# e: ~
SelectI/O? resource and the Clock Delay Lock Loop, that make it easy to interface to high
* R$ P: y4 {$ B9 Jspeed Synchronous DRAMs. This application note describes the design and implementation of
3 Z* ?) q' { ^8 t3 a0 Ca synthesizable, parameterizable, flexible, auto-placed-and-routed synchronous DRAM* i* U( d& {$ H1 W
controller in the Virtex FPGA family. The design can also be implemented with a Spartan-II5 y- B/ b+ I- `0 m$ V
device. A 32-bit wide data interface version can run up to 125 MHz when automatically placed5 g2 F6 o8 t2 x# d& S( S
and routed in a Virtex -6 speed grade device. Hand placed versions of the design can run even8 N7 ^ ]5 L: x: E0 K8 t- P$ M
faster. |
