Files,
# I! L; K6 r+ D$ N A; A# p9 A" q% K0 [
1)3 z! e0 _! h& p* L1 i/ h
high_level.mdl7 n6 Q3 R: z& `6 E
This file contains the model in Figure 1.
b; ~( |# F) A q2)
: s1 a* v0 k3 {: f/ Hfilter_desgin.m& n& w ^" r9 w- ]' W
Here we design the filter, design a multi-stage filter and convert the filter to fixed-point. The filter results are all saved in one_stage.mat, multi_stage.mat and multi_stage_fixed.mat." }; ]3 L9 ]! E* w. O. R) P
3) o/ f! w8 H* U% I* N
multi_stage.mdl% u7 o. c1 f& I
This file contains the model in Figure 4.& K5 I, Q9 R" Y1 C
4)
- i6 k% L2 h/ ?( Kelaborated_design.mdl8 s3 k' J! P$ r0 f
This file contains the model in Figure 7. 6 L, @- U# d) ^5 _5 ?2 W# P
5)
6 X. h5 s1 l/ L1 C2 Vgenerate_fir_lut.m and bin2sbin.m( y* L8 ~9 e5 r: X0 A: ^. ~! ^0 C
These files generate the lookup tables for the elaborated design. 2 A" a# y+ N4 [, ~: u1 r
6): B" w" _; _+ V6 a3 v y4 d
fixed_design.mdl
5 s9 C! P" n: G Z+ TThis file contains the model in Figure 8.5 ?1 j$ @+ j' z
