查看: 1184|回复: 0
Vivado ISIM语法问题——请高手指导
发表于 2016-5-20 10:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
ISIM仿真内容如下,提示错误:[USF-XSim 62] 'compile' step failed with error(s)while executing 'F:/Camera_HDMI/Vivado/SCCB/SCCB.sim/sim_1/behav/compile.bat'script. Please check that the file has the correct 'read/write/execute'permissions and the Tcl console output for any other possible errors orwarnings.
; {) W4 Z$ R8 m6 S. H+ w/ Z  q把实例化sccb_ip去掉就好了,但不知道为什么
& k! b+ W2 J. f
module sccb_sim(
reg [15:0] sub_addr;
reg [7:0] data_from_cpu;    //
reg rd_wr,sio_en,sio_c,sio_d;
wire [7:0] data_from_slave;
initial
   begin
       sub_addr[15:0] <= 2'b01_1000;
       data_from_cpu[7:0] <= 8'd101;
       rd_wr <= 0;
       #10000 $finish;
   end
reg clk = 0;
always #10 clk <= ~clk;
sccb_ip sccb_ip(
   .clk(clk),
   .sub_addr(sub_addr),
   .data_from_cpu(data_from_cpu),         //
   .rd_wr(rd_wr),                          //
   .sio_en(sio_en),                       //
   .sio_d(sio_d),
   .sio_c(sio_c),
   .data_from_slave(data_from_slave)      //
endmodule
源码如下,综合已经通过
module sccb_sim(
initial
   begin
       rd_wr <= 0;
       #10000 $finish;
   end
reg clk = 0;
sccb_ip sccb_ip(
   .clk(clk),
   .rd_wr(rd_wr),                          //
   .sio_en(sio_en),                       //
   .sio_d(sio_d),
   .sio_c(sio_c),
7 Q# H) d5 D" L0 G" s8 [% n; u
endmodule
+ f8 q! ~, a4 c- O; `0 ~2 M
工程界面
工程界面
GMT+8, 2025-10-31 18:57 , Processed in 0.156250 second(s), 27 queries , Gzip On.
