查看: 3599|回复: 7
导入PCB时候 文挡看不是太懂 请高手解释下
发表于 2008-1-7 14:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*pads-ECO-V2007.0-MILS*/ Y; k! A9 n1 p7 w) ^8 r
*REMARK*  old file: C:\PADS Projects\ppcbnet.asc
9 ?6 R9 Y' a( r* ^6 Q4 m. `*REMARK*  new file: C:\PADS Projects\ecogtmp1.asc6 @- C- D# }3 Q( `
*REMARK*  created by ECOGEN (Version 6.4v) on 2008-1-7 14:01:35
( o5 b$ U* T. @: c6 k*DELPIN*
. @2 O7 }% `' M! V# EIC1.4  BUSPOWER9 _8 N& l  j$ f6 p  P- g: ~& B2 X
*CHGPART*
1 t; `& g0 M# [C10  0402(3D)  CAP-CC059 i5 ~  a* N7 r+ X
C8  0402(3D)  CAP-CC05
$ E& E( ~6 m' m/ g8 N/ j" LC9  0402(3D)  CAP-CC05
( m/ h2 I* r/ I7 @4 `+ qL1  0603  IND-MOLDED2 J7 ?- ?0 P$ t9 {3 ]% ^) x
L2  0603  IND-MOLDED" {( V& ?/ n, W/ u2 Y; j( j& ~
L3  0603  IND-MOLDED( |! `# ?; I8 p, Q9 ]+ \
C11  CAP1  CAP-CC05: a* {: y! l# Q  G2 T/ D
C5  CAP1  CAP-CC057 U% ]3 r* i  x3 k" k3 G- m
C6  CAP1  CAP-CC05
2 r6 M9 @% P$ i& T0 v( w% {C7  RES0402  CAP-CC05
# V7 X9 e- Z: y. y2 W, ?8 H*NET*
% F$ _; [" o# ?9 o*SIGNAL*  +5V0 o; ?! K5 n' {; Y) k9 \- o, J
YI1.4( V' v& `! T0 V& g
*SIGNAL*  BUSPOWER
8 A9 E* @6 T' V- p; W3 tIC1.NC/ECO
; x4 H6 D' g, R2 f8 {*SIGNAL*  POWN# \: l: D; @* k
IC4.214 O& N6 K) T# A/ Q1 f
*SIGNAL*  PWDN
, y, C# e3 Z0 D# }; V( q8 h# i& WIC2.J7
6 E  d* P8 l. Z3 F*SIGNAL*  XCLK1 F  R# `7 N' S0 ^0 S, t- d) `: V
IC4.2
( y1 T6 U4 o0 R" W+ P7 ]2 p*SET_ATTRIBUTE* PART C104 b( C' u) F& |) {# r6 W
"Sim.Analog.Model" 2 k$ W5 H1 O' a7 O
"Sim.Analog.Order" Model$
8 V4 k. D$ [, S( |4 e! e' b"Sim.Analog.Prefix" C8 }, O0 T. H/ |+ S2 D7 v
"Description" RADIAL CERAMIC CAPACITOR, MIL-SPEC SIZE CK05! _* \. j! m$ J) U* ~
"art Number" CC05CGXXXX: Y! y* ~+ \: b  i6 O! {
"Manufacturer #1" KEMET
! b8 l, k1 I  a1 Y, x. F& ~& J"Value" 0.1UF
2 Z. l- v: \* S$ q3 W"Tolerance" 0.1uf$ R3 I# ~) L! p$ Y; @
"Voltage Rating" ???
2 G  `* f) u% w"Cost" ; N7 X( X1 w7 v( D0 ]6 z: d
*SET_ATTRIBUTE* PART C11( q+ l  U. Q0 G' [, z9 R
"Sim.Analog.Model"
& {! S' ?; T8 C"Sim.Analog.Order" Model$0 ^- `' p& P- n/ s  E5 u# Y/ x* V
+ U0 F$ i- X. X) u$ ~' D6 C* R"Description" RADIAL CERAMIC CAPACITOR, MIL-SPEC SIZE CK05/ H' J  @0 [6 y: l% [& X8 V
  B2 v2 o6 H( H+ j"Manufacturer #1" KEMET
0 w  N& w7 p7 ~* M"Value" 0.1UF1 D8 f0 S& k: i$ P6 w* `& ^: D
"Tolerance" 0.1uf
! l$ G- P0 S8 ^* g  S"Voltage Rating" ???' i0 A9 q( w  k
"Cost" % k* y2 b# O9 `& g
*SET_ATTRIBUTE* PART C5
) V/ \4 ?- A* }5 {' M$ A! G"Sim.Analog.Model"
$ {; m' i+ ^5 d( s2 s# D2 m"Sim.Analog.Order" Model$8 o2 q/ t" {# y# [) Q; m
5 N3 d6 c- X+ e"Description" RADIAL CERAMIC CAPACITOR, MIL-SPEC SIZE CK05
  v( n9 [. k/ r# K$ D; x"art Number" CC05CGXXXX
% q1 e* T8 T4 y& V4 C"Manufacturer #1" KEMET
; P8 q8 p5 D0 x6 G$ J"Value" 0.1UF
  n; |% ?4 J3 v"Tolerance" 0.1uf
+ m2 Q( L( P' e3 x+ s# h"Voltage Rating" ???
/ j; H" r- q& Q( D"Cost"
+ h9 b7 g5 U. U) u9 k! t8 j' I*SET_ATTRIBUTE* PART C6. _& _$ J2 w- w5 y
"Sim.Analog.Model" , D( D) o; T  {2 B/ X$ f5 J, H+ [! o3 \
& O0 S0 l! {7 b8 [+ @"Sim.Analog.Prefix" C
2 R9 p* k2 ?5 Q"Description" RADIAL CERAMIC CAPACITOR, MIL-SPEC SIZE CK05
6 Q, s: |0 c& y# G"Part Number" CC05CGXXXX
0 j- Z- B: F" J6 _0 P1 I"Manufacturer #1" KEMET2 R" v8 n  V/ C! X/ \/ n# H) t+ D1 `
"Value" 0.1UF
. v& X- o! C7 Y9 G* w9 |"Tolerance" 0.1uf
1 o' m5 X: Z3 v# q! P"Voltage Rating" ???
* Q  e( p/ q8 z; W2 `"Cost" 7 T' C5 l/ R1 ~% ]" D
*SET_ATTRIBUTE* PART C7
+ I3 Q' s' f1 m" r"Sim.Analog.Model"   X2 R( Z+ S+ Y
"Sim.Analog.Order" Model$6 I8 p/ E. ~! O
"Sim.Analog.Prefix" C& u* S8 H) n! L! M% ]
; E$ ?0 ]3 ?0 \1 ~/ V" Q7 ["Part Number" CC05CGXXXX
* e/ ^1 _5 d4 H"Manufacturer #1" KEMET
' I& m2 `# }6 t9 k( M' m"Value" 0.1UF; U4 c( z# v* @/ `  v6 l; |1 i
"Tolerance" 0.1uf
( v# T3 F/ f3 C4 B"Voltage Rating" ???2 J7 ^8 U' Y) w" T+ W' T% n$ M
"Cost" ! H# j* |# A) D, C
*SET_ATTRIBUTE* PART C8
. z9 X. O$ Y  r  }8 {7 N& `# n"Sim.Analog.Model"
+ I6 b/ c+ u! n, L"Sim.Analog.Order" Model$! \; r! e( p1 ^, o
"Sim.Analog.Prefix" C; o' f1 q( C1 [! M3 o
"Description" RADIAL CERAMIC CAPACITOR, MIL-SPEC SIZE CK05; z  C$ |) n& ?5 Q0 ~0 G  {
$ m7 J4 N2 {+ V% ], b: f4 y"Manufacturer #1" KEMET
% _6 [% K* U. Q"Value" 0.1UF  v8 u, y, M. h9 @
"Tolerance" 0.1uf! y' `% h4 F) y% _. g) q6 `' `
7 {* V: m5 f3 g. s6 ]& z"Cost" . j$ n8 w3 a* y) k. e( t
*SET_ATTRIBUTE* PART C9
0 a% W' y# @) H4 p"Sim.Analog.Model" 9 c, J7 g+ }5 l
"Sim.Analog.Order" Model$$ E5 |6 j0 K& I; i7 {6 E3 j
"Sim.Analog.Prefix" C) l6 c9 |/ C* X, b
"Description" RADIAL CERAMIC CAPACITOR, MIL-SPEC SIZE CK05( H* p3 p5 H% t
+ H" R+ K" C. o4 n- g! n"Manufacturer #1" KEMET
$ z9 \. c' p/ Y/ b$ F"Value" 0.1UF; _9 ]! Z9 {- v! W$ x1 B: ]
"Tolerance" 0.1uf
6 h- D, Z5 F, W' _' @0 E"Voltage Rating" ???
2 i7 {: }+ M% G5 f- O" r"Cost" ; b5 K0 O" M4 A3 `' Y  p7 Q0 Y
*SET_ATTRIBUTE* PART L1/ D$ h0 @, A" X+ N9 z( C5 k3 j
"Sim.Analog.Model" 5 g& ?: b4 \( p* q
! J2 J0 }1 V! k1 m"Sim.Analog.Prefix" L$ m9 u3 [% E; k; j. O8 f5 `+ Z4 q
"Description" MOLDED INDUCTOR, 0.5" PIN SPACING
# U' J3 \. c3 p1 w# v"Cost"
* Z, a! Y) V, h"Value" FB# c4 {1 x6 g# @7 Z3 L: M4 `
"Manufacturer #1" / v5 P* T9 H7 y: ]& G  M) `
"Spil Part #"
. ^* X( \0 {+ i*SET_ATTRIBUTE* PART L2
3 _' q) B  A" [+ l0 U: Z9 l"Sim.Analog.Model"
7 D( @% e* C7 @/ L; b) G"Sim.Analog.Order" Model$/ G) F+ l5 ^+ E" Y
"Sim.Analog.Prefix" L8 W* X, |! L6 [6 T& D8 f
3 P  m, L- e2 N) e  i"Cost" 3 w: c( n% d% B5 {- G3 V$ [" h( B* S1 d
"Value" FB
" ^5 w6 V9 l/ i2 H/ C% n3 r"Manufacturer #1" 1 `$ c) g3 R4 F+ W6 I, v, T
"Spil Part #"
3 w9 X4 p8 [+ f; R1 Q. ]4 e( X*SET_ATTRIBUTE* PART L3
) Q) O. u, b7 R; {/ ]/ {"Sim.Analog.Model" / Z$ j+ @0 a; d( c" c
- b2 l7 W% Y1 |& u"Sim.Analog.Prefix" L
! k! ^  ]; q; t$ e: |"Description" MOLDED INDUCTOR, 0.5" PIN SPACING
! m: G" M+ n! I$ r$ ~"Cost" # g( G" A0 r5 R4 W, Q9 P: ?
"Value" FB( g. q  \' d" v5 f. R! b) V
"Manufacturer #1"   M8 a2 p( v  P/ Z$ k
"Spil Part #"
  Z6 g4 W& P0 _*MODIFY_GENERAL_RULES* CLEARANCE4 f" A, P9 c8 I* F, ~( l
HIERARCHY_OBJECT PCBCB# l' h( i% z% d
TRACK_TO_TRACK 6.000000
1 R6 z! J. y  I" qVIA_TO_TRACK 6.000000; q) Z4 ^6 ^; r' K* U
VIA_TO_VIA 6.000000
8 {  y/ S2 B" u' _$ m8 L/ DPAD_TO_TRACK 6.0000006 A% b3 P) Q4 h% q( o, ?
PAD_TO_VIA 6.000000
0 ?" L: J5 e+ U% q; {- aPAD_TO_PAD 6.000000$ F# e3 z/ {+ }  i6 O2 V
SMD_TO_TRACK 6.000000
$ \. h8 j; @6 L$ {; n1 lSMD_TO_VIA 6.000000
1 V% d! U; s; D6 N9 V, FSMD_TO_PAD 6.000000/ q9 r* J: T7 ^2 I1 o2 J" S
SMD_TO_SMD 6.000000
0 `8 E, P! c% O" _: ~COPPER_TO_TRACK 6.0000002 i# y+ j0 N5 ]( v% U+ e
COPPER_TO_VIA 6.000000
5 @8 u2 k8 W* F5 j+ I: w( RCOPPER_TO_PAD 6.0000008 p; q5 A% u0 M5 O7 F  J( w5 \
COPPER_TO_SMD 6.000000
* o  P+ F" Q; v* r/ g; `COPPER_TO_COPPER 6.0000009 b1 R2 X5 u5 O/ V' e
TEXT_TO_TRACK 6.000000
: Y  F; k+ d3 k2 ?- t! ^TEXT_TO_VIA 6.000000
$ z) G' e* J( ~, c$ c, p# BTEXT_TO_PAD 6.000000
$ q8 m# ~" V) W1 G$ K- q! kTEXT_TO_SMD 6.0000003 T- E0 O7 W- a: [- g- {
OUTLINE_TO_TRACK 6.000000' N9 B4 [. ?0 h/ o. m8 b! Y
OUTLINE_TO_VIA 6.000000
3 B# r& @6 A: _# w; f% R3 yOUTLINE_TO_PAD 6.0000000 }$ S. ^# b* R( `; ~9 Z
OUTLINE_TO_SMD 6.000000% a6 D1 x# Q2 z2 x! H; d
OUTLINE_TO_COPPER 6.000000; C) Z5 s+ U2 F. X- B
DRILL_TO_TRACK 6.000000& ~+ p" [7 X- u& _$ {% |! n
DRILL_TO_VIA 6.000000
% m$ O- f! B" _5 s4 K" i& ]DRILL_TO_PAD 6.000000# n0 H0 V8 H" n/ v9 {
DRILL_TO_SMD 6.000000. d$ w' ^1 Z" v2 V0 F
DRILL_TO_COPPER 6.000000* f1 l0 K; d- w9 S# J9 y/ [
SAME_NET_SMD_TO_VIA 6.000000
+ |. B; W1 z# s0 c* E5 ASAME_NET_SMD_TO_CRN 6.000000; L+ e. F. v; P0 v' f4 ^. Y
SAME_NET_VIA_TO_VIA 6.000000
5 E1 {  ?& u: A2 kSAME_NET_PAD_TO_CRN 6.000000" d2 Q9 O/ z# A5 C; p2 g  Y9 n
MIN_TRACK_WIDTH 12.000000& `% q9 U7 y! E5 T- D
REC_TRACK_WIDTH 12.000000
. P5 j- s: S7 c  tMAX_TRACK_WIDTH 12.000000
7 J* I; I) D3 Q& w' JDRILL_TO_DRILL 6.0000004 ~, x4 H& g: U8 V) t4 R, b
BODY_TO_BODY 6.000000( L4 w. }$ {1 |. l) `/ M& H
SAME_NET_TRACK_TO_CRN 6.000000; {% ^7 A  I/ C5 j+ m
*MODIFY_GENERAL_RULES* ROUTING. Q, h8 f8 \3 j  M5 Y
# F  i( [' m8 B) L' xLENGTH_MINIMIZATION_TYPE TOTAL
' u' h3 G4 z. u& U' A* v( ?+ d4 ]TRACE_SHARE ON$ m& j2 g4 }2 V2 R) A
VIA_SHARE ON  X+ }. F+ }; r
AUTO_ROUTE ON
1 a+ K& }# h# I5 IRIPUP ON
( z$ [& k. M6 a1 mSHOVE ON
3 g- E" P5 o. C/ k% E5 H9 nROUTE_PRIORITY 39 p/ U) y% S. U; `, m5 O
MAX_NUMBER_OF_VIAS -12 @5 C+ F) G  w  ~5 s  ]# `
VALID_LAYER Top
% ~4 X5 ~$ s, b+ V: Q$ NVALID_LAYER Inner Layer 2
. D1 `1 n3 u7 ?VALID_VIA_TYPE STANDARDVIA2 k8 h+ e/ t# D
SHOVE_PROTECTED OFF% e3 D& y, m* R- k6 ~3 J/ u7 L
*REMARK*  Deleted pins: 1,  Added pins: 5
. J( ?' X0 ^. ?/ `" h$ a*END*
 楼主| 发表于 2008-1-7 14:17 | 只看该作者
从这个里面能看出什么/?
发表于 2008-1-7 14:44 | 只看该作者
你那个报错里面也有这个 玩意吗
发表于 2008-1-7 14:46 | 只看该作者
好像看不懂呀,不要插入表情哦.一个个错误贴出来,好像没有填写Voltage Rating这个值+ w  B: X+ ^  F9 l- v
& \8 Q/ Q$ r7 v3 Z, W[ 本帖最后由 dingtianlidi 于 2008-1-7 14:48 编辑 ]
发表于 2008-1-7 14:50 | 只看该作者
我看到了一些基本的设置规则!还有一些封装信息!
 楼主| 发表于 2008-1-7 15:06 | 只看该作者
 表情是哪里进去的汗?
发表于 2010-8-8 22:44 | 只看该作者
我也存在这问题:要研究下,先留个记号,明天再细细瞧下
; ^# w2 s6 b0 r0 N4 q6 L*PADS-ECO-V2007.0-MILS*
6 t& ~  t3 n# C5 O, X9 y& y*REMARK*  old file: C:\PADS Projects\ppcbnet.asc
6 M- n& w1 |+ f& i* `' |*REMARK*  new file: C:\PADS Projects\padsnet.asc
: Y1 m7 I1 u* D3 A7 Y*REMARK*  created by ECOGEN (Version 6.4v) on 2010-8-8 22:37:33
2 R% b% @# A( L# }. s*DELPIN*5 M9 J# @1 i; k& \7 G: d7 z" O
R17.1  $$$6252# v7 w: |( k1 P. j: |; N$ y
R17.2  $$$11755' E, r8 C. [) D8 C
U3:2.1  $$$12815
9 \9 @# I: B. V# B4 ~' Y9 K5 `U3:2.2  $$$127989 s2 |" W/ [. x; Q% A9 |+ K* b# `
PC123-B.3  $$$53871 [' Z( |4 O' R( @# D. a" m
PC123-B.4  $$$4610- L  s/ A3 O! ^
R120.3  $$$6252+ f4 L! F- d( T/ w) Z, Q4 m1 t9 I/ M
*DELPART*3 D8 ?) c; K, C; ~
R17  PC123-A
! m* J- Q+ K6 p8 T7 xU3:2  PC123-A4 @+ a" ~& ], W4 {9 u
PC123-B  PC123-B9 Q+ h# Q0 _, I6 U  N0 C
*CHGPART*6 m" t6 Y! z& f, ~
U3:1  PC123-B  DIP-4* }7 V- P& @2 m- G$ ]
*RENPART*, J1 K" q$ r8 T! Y! D. C
U3:1  U4# `6 N# n, n" c' y1 v
*PART*
5 V" S* q8 ?, p; W' YU5  DIP-4
% e0 f: c5 t% P; R# m*NET*
" @% W4 F) c- e& C' t*SIGNAL*  $$$11755
& a# k, N) T) T9 X4 y1 t. aU5.2( J( f5 a+ ]! l
*SIGNAL*  $$$12798
% d) T7 z' _; u; `# mU4.2
) U9 v/ @5 g% a# e*SIGNAL*  $$$12815# A$ u5 R! n  w8 Z
U4.1
' n: [) \: V* o4 ]+ A8 i& N4 M*SIGNAL*  $$$4610
8 F' C. ]) t" k$ T! \; ^) X7 CU5.4$ @  j( a, s  Q& O$ }& _
*SIGNAL*  $$$5387, e; ~- H" \$ ]+ r
U5.3# b$ h$ j  H; c( f  O! N
*SIGNAL*  $$$6252
9 w8 _* K( H2 p* d" ]& I9 B! U7 ]; B2 OU5.1  R120.3( W- ~4 ~$ w; I- f
: I& ^' W7 g- y' J  `5 @% h  A" g9 R) @*MODIFY_GENERAL_RULES*        ROUTING5 @& j- w& F# U! B
3 U/ {( M0 {" t, ~HIERARCHY_OBJECT        PCBCB% c8 |% ]' s$ [9 r/ T5 d' \
, m0 |0 ~. m. m9 f- E9 D1 R7 i. ]TRACE_SHARE        ON5 n5 i1 U- D& N5 W* P, u
VIA_SHARE        ON& D2 L) {) `& q
AUTO_ROUTE        ON
9 Q- C# A! [2 C5 r/ z7 URIPUP        ON
3 j# `/ C1 ^' t  C& @SHOVE        ON1 g! d* n1 r/ W  @/ A
ROUTE_PRIORITY        39 Q+ y' Q' C1 a" ]1 C  T0 h
MAX_NUMBER_OF_VIAS        0
- T% k% }- p9 F4 r8 d2 \, ]VALID_LAYER        Top
- j" d/ e/ Y6 j: B  W2 b$ l% CVALID_VIA_TYPE        *USE_CURRENT*
. {! r5 Z4 b" ^! W! RSHOVE_PROTECTED        OFF
6 n% u" o$ b. C3 V* V8 o( U/ o. ~
2 v3 z  j! P/ [9 _0 T*REMARK*  Deleted pins: 7,  Added pins: 7
4 G8 ~" w6 e. R6 f6 W/ W*END*
发表于 2010-8-9 17:55 | 只看该作者
*DELPIN*
7 X9 ]! U* C3 [R17.1  $$$6252
. h- r* }3 E, V: Z是指删除R17的1脚的网络,
1 r! g0 q# e2 y. L" ^*DELPART*1 Y7 V* u& i, h8 Q0 a6 ]( W
R17  PC123-A
5 b: L* {9 q3 p8 R7 {+ e是指删除元件,R17.
$ \) M/ {" I# h8 M- s; ~/ j*RENPART*  d) X7 c" b# p0 u2 _# h8 w
U3:1  U4
8 D0 H( [( I4 z. T) X3 ^$ a是指重新命名,把U3改成U4
GMT+8, 2025-10-26 01:10 , Processed in 0.171875 second(s), 27 queries , Gzip On.
