我刚用EE2007.3,下了个破解的,中心库的设计能用,但DxDesigner中原理图等的save保存按钮怎么是灰的,无法保存,那位高手给我指点一下啊,是我破解过程中那块有问题?我用的破解文件见附件,谢谢了7 }& P" A4 i7 J$ b/ ?
5 e- O, b% k! t* Y z破解的说明为:
6 w+ t7 N) P x9 Tmentor EE/pads20007.4 license keygen and path
6 a" ?9 \& w- j' a" k1, use my MGLS.DLL to replace the origin one which is 1,564,672 (1.49M) bytes sizes4 t6 W. z3 B2 \3 F. H' L W: c( o
other MGLS.DLL which version is not 2008.056 is not need to replace.0 ~: ^! n8 t& a0 M- j3 w
2, use my keygen to make licensefile.:3 |, ?8 \" M: z" t. Z% c5 M
# t4 |- o6 }2 Q) Q( w o
note:
+ l. r' |& C2 B) z! W; @" Tmust make license file which has SIGN2 key. so you can run my MakeLic.bat to gen a valid license file.% l1 M+ o4 s: @& t" a X% c
! u: n1 Q. f9 h5 P. ?* x( o3 y% c3, not use for sale and commerce.
: ^& _( p" _ [# w0 H4, this file only test in win32 OS.
9 b1 n6 M: ^% D' E" X. i% C( X" A* \! u
LONG: Q: [) A4 p# W) R: E. z* A
2007.08.06
/ t0 Q1 S0 Q/ `( s3 X! v* U
" Q, U3 ?. _2 H . _0 x; D. q8 B+ z( {
A,先完整的安装程序在C目录下,安装过程中要指向license file,可以先指向文件夹中的license.txt。. ?( C/ c, w L! \4 t ^5 c1 X
B,安装EE运行EE2007.4安装在C盘完成后直接运行.bat
' S* p# F2 Q( ~4 G5 r# _ 或者安装的是PADS,运行pads2007.4安装在C盘完成后直接运行.bat- ^: ~. t4 \2 W5 R2 H2 X9 C$ Y X+ ^2 Z, F
若没有成功请手动设置环境变量和license Server.
8 u8 I* G$ C) L) p 注:安装在D:\或者其它目录,请自行修改BAT。
8 @8 I% K l6 O' p8 s1 H# {1 B* O - v1 s1 n3 e' E/ b) S
- w5 ?" x" v% @3 e+ R) ~ WANG
. e H7 T# p8 o i* ]( j 2008 .10 .12 |
