TA的每日心情  | 怒 2022-12-29 15:40 |
  签到天数: 1 天 [LV.1]初来乍到
请教下大师里面的这个Action表示的数字1,2,3,4,5是啥参数,不晓得啥意思~~4 v! d1 d( j0 i4 n
Private Function dialogfunc(DlgItem$, Action%, SuppValue&) As Boolean
6 S, o5 e& J  I4 T) v    Select Case Action%) a. g9 z0 a& o  y" S
    Case 1 ' Dialog box initialization
& j! K0 g+ i, k6 E9 o$ I        DlgText "Xstep", ActiveDocument.GridX(plogGridDesign)*36 d6 Q) b. B1 a& X9 A+ T3 a8 J* x2 P
        DlgText "Ystep", ActiveDocument.GridY(plogGridDesign)*3
7 P- X1 O2 Z5 K& E  j        View_Change
, M) P6 n8 l# }" ?8 ~$ q' Q" f        Document_SelectionChange
* w: f( Q# f' ^# r: [$ n' u1 G    Case 2 ' Value changing or button pressed
  ~% u4 k( a, x/ m1 S        changing = True
3 {* Y9 ]+ q- p9 x- R5 x        dialogfunc = True
5 Q  V+ S, Y+ U! r0 v        If DlgItem$ = "Vertical" Then
" V8 C  B- N5 K. Y0 Y  A3 I% ?            DistributeV: N! j" B5 J1 J& y4 R! V
        ElseIf DlgItem$ = "Horizonal" Then " X7 ^2 N5 J9 Q% K4 e# c1 R7 p( m& S
            DistributeH
/ v4 S2 S$ n+ Q& v, f        ElseIf DlgItem$ = "MirrorX" Then: u6 `6 O8 W/ S: ]
            MirrorX' n7 q: k$ Y" t
        ElseIf DlgItem$ = "MirrorY" Then
) q+ N  L9 T7 ?  ~3 |            MirrorY# l# E) ?( O4 X$ `: V
        ElseIf DlgItem$ = "Rotate90" Then) e9 p4 g! o0 |# n$ l
            Rotate90
) f3 `% y% e' V2 q  u8 Z        ElseIf DlgItem$ = "SetPos" Then( V8 m: k) ]! s
            SetPos" d- S/ M8 C4 y
        ElseIf DlgItem$ = "Top" Then" K& Y, W' R( r0 h& v7 m
            AlignTop# _* s- T8 D/ A+ g0 h# u8 f" u
        ElseIf DlgItem$ = "Bottom" Then
5 E9 g5 j1 M, _/ N* k. _8 F% P7 e            AlignBottom1 E, u$ t2 t8 X5 Z, T9 @/ }; t
        ElseIf DlgItem$ = "Left" Then7 H0 S9 J( J3 w( P- R
            AlignLeft
* |  ?+ W: y( \; f# ^1 s        ElseIf DlgItem$ = "Right" Then
* ^9 q" W3 L: M8 N' r7 `            AlignRight
0 }3 N( H+ q* ]        ElseIf DlgItem$ = "CloseBtn" Then& b. ^; J# Q: @+ I4 ^% j# h
            dialogfunc = False
- p3 K0 z9 G7 W, Y/ F+ E4 S  }        End If
& U# E, c. j3 Q: ?( S" ]5 O6 l        changing = False( g, c4 C% i. B( A2 T+ G
5 g0 n3 g3 S* ~: A9 ^) s3 c1 }    Case 3 ' TextBox or ComboBox text changed
# b( P0 b2 o4 y! q  ^8 u    Case 4 ' Focus changed5 u  @% l, b. v3 O  k  `6 A  f
    Case 5 ' Idle
; V, P! k# `4 b7 D) I1 ?% _        ' dialogfunc = True ' Continue getting idle actions
; d; m# Q+ f" o% L* c; I% R( i3 x' d7 P0 N5 N
! }+ ^2 F$ W4 x* C3 M9 F    Case 6 ' Function key' ~4 {. V- K" n4 H: e5 c8 b7 K2 u3 f
    End Select+ @# V8 d: A' t
End Function |
