哪位大神过来看看啊,这altium真让人受不鸟了。4 Y8 W+ Z6 y v3 Q, t
最近自己画个图,用层次原理图进行的设计,其中还使用了 harness,结果一编译就出警告“has multiple names”,也不知道哪里出了问题,改了好多地方,包括工程设置,也都不行,上网上查找的方法也不管用。' v5 N, _' \# \& [9 g9 h7 R. `
7 x6 x& s4 p( O( M
$ a$ |9 p# _" H/ eClass Document Source Message Time Date No.5 I; X' e1 u3 w5 ~3 F
% l& D G: d! ]# V. k1 ~& d
[Warning] TOP.SchDoc Compiler Nets Bus Slice CONF_FLASH_A[24..0] has multiple names (Net Label CONF_FLASH_A[24..0],Net Label CONF_FLASH_A[24..0],Port FPGA_CONFIG.CONF_ADDR[24..0],Port FPGA_CONFIG.CONF_ADDR[24..0]) 17:49:14 2016/3/9 29
) J; Z: j5 F ~% v" M d8 [6 g[Warning] FPGA_CONFIG.SchDoc Compiler Nets Bus Slice CONF_FLASH_A[24..0] has multiple names (Net Label CONF_FLASH_A[24..0],Port FPGA_CONFIG.CONF_ADDR[24..0]) 17:49:14 2016/3/9 30+ y. Z; k' r2 T8 k0 g
[Warning] TOP.SchDoc Compiler Nets Bus Slice CONF_FLASH_D[15..0] has multiple names (Net Label CONF_FLASH_D[15..0],Net Label CONF_FLASH_D[15..0],Net Label CONF_FLASH_D[15..0],Port FPGA_CONFIG.CONF_DATA[15..0],Port FPGA_CONFIG.CONF_DATA[15..0]) 17:49:14 2016/3/9 31
, {" ^( k6 ]3 [5 [' D; k[Warning] FPGA_CONFIG.SchDoc Compiler Nets Bus Slice CONF_FLASH_D[15..0] has multiple names (Net Label CONF_FLASH_D[15..0],Port FPGA_CONFIG.CONF_DATA[15..0]) 17:49:14 2016/3/9 32( ~6 l& d2 d G" e% ` w
[Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[0]: CONF_FLASH_A has multiple names (Net Label CONF_FLASH_A0 (Inferred),Net Label CONF_FLASH_A0,Port FPGA_CONFIG.CONF_ADDR0 (Inferred)) 17:49:14 2016/3/9 334 Z' e3 {8 z6 T
[Warning] TOP.SchDoc Compiler Nets Element[0]: CONF_FLASH_A has multiple names (Net Label CONF_FLASH_A0,Net Label CONF_FLASH_A0 (Inferred),Net Label CONF_FLASH_A0,Net Label CONF_FLASH_A0 (Inferred),Port FPGA_CONFIG.CONF_ADDR0 (Inferred),Port FPGA_CONFIG.CONF_ADDR0 (Inferred)) 17:49:14 2016/3/9 34
" L2 T9 o) _/ u! ]# \3 ^[Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[0]: CONF_FLASH_A has multiple names (Net Label CONF_FLASH_A0,Net Label CONF_FLASH_A0 (Inferred),Port FPGA_CONFIG.CONF_ADDR0 (Inferred)) 17:49:14 2016/3/9 35
4 D% S! r- _* k" ][Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[0]: CONF_FLASH_D has multiple names (Net Label CONF_FLASH_D0 (Inferred),Net Label CONF_FLASH_D0,Port FPGA_CONFIG.CONF_DATA0 (Inferred)) 17:49:14 2016/3/9 36
8 A% ~% J+ a% n" H. y8 z a[Warning] TOP.SchDoc Compiler Nets Element[0]: CONF_FLASH_D has multiple names (Net Label CONF_FLASH_D0,Net Label CONF_FLASH_D0 (Inferred),Net Label CONF_FLASH_D0,Net Label CONF_FLASH_D0 (Inferred),Net Label CONF_FLASH_D0 (Inferred),Port FPGA_CONFIG.CONF_DATA0 (Inferred),Port FPGA_CONFIG.CONF_DATA0 (Inferred)) 17:49:14 2016/3/9 37! Y4 a3 \- R* [1 b4 f
[Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[0]: CONF_FLASH_D has multiple names (Net Label CONF_FLASH_D0,Net Label CONF_FLASH_D0 (Inferred),Port FPGA_CONFIG.CONF_DATA0 (Inferred)) 17:49:14 2016/3/9 384 T- J- e8 V- g! Q. ]
[Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[1]: CONF_FLASH_A has multiple names (Net Label CONF_FLASH_A1 (Inferred),Net Label CONF_FLASH_A1,Port FPGA_CONFIG.CONF_ADDR1 (Inferred)) 17:49:14 2016/3/9 39
+ ~! g6 t$ Y# V9 [[Warning] TOP.SchDoc Compiler Nets Element[1]: CONF_FLASH_A has multiple names (Net Label CONF_FLASH_A1,Net Label CONF_FLASH_A1 (Inferred),Net Label CONF_FLASH_A1,Net Label CONF_FLASH_A1 (Inferred),Port FPGA_CONFIG.CONF_ADDR1 (Inferred),Port FPGA_CONFIG.CONF_ADDR1 (Inferred)) 17:49:14 2016/3/9 40
8 M. p/ v; x j- g" A4 X5 P! @/ D" f[Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[1]: CONF_FLASH_A has multiple names (Net Label CONF_FLASH_A1,Net Label CONF_FLASH_A1 (Inferred),Port FPGA_CONFIG.CONF_ADDR1 (Inferred)) 17:49:14 2016/3/9 41: q7 @$ E7 N9 a. _. l
[Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[1]: CONF_FLASH_D has multiple names (Net Label CONF_FLASH_D1 (Inferred),Net Label CONF_FLASH_D1,Port FPGA_CONFIG.CONF_DATA1 (Inferred)) 17:49:14 2016/3/9 42) D8 _+ m7 i0 T2 T f, G0 ]
[Warning] TOP.SchDoc Compiler Nets Element[1]: CONF_FLASH_D has multiple names (Net Label CONF_FLASH_D1,Net Label CONF_FLASH_D1 (Inferred),Net Label CONF_FLASH_D1,Net Label CONF_FLASH_D1 (Inferred),Net Label CONF_FLASH_D1 (Inferred),Port FPGA_CONFIG.CONF_DATA1 (Inferred),Port FPGA_CONFIG.CONF_DATA1 (Inferred)) 17:49:14 2016/3/9 43
1 ]+ P8 ]. Z7 Y( B7 \[Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[1]: CONF_FLASH_D has multiple names (Net Label CONF_FLASH_D1,Net Label CONF_FLASH_D1 (Inferred),Port FPGA_CONFIG.CONF_DATA1 (Inferred)) 17:49:14 2016/3/9 44
9 a2 f4 M9 g% \/ `# |[Warning] TOP.SchDoc Compiler Nets Element[1]: EN has multiple names (Net Label EN1,Net Label EN1,Net Label EN1 (Inferred),Net Label EN1 (Inferred),Port EN_A1) 17:49:14 2016/3/9 452 }7 V. N5 |0 w8 W' B( U8 q$ w
[Warning] TOP.SchDoc Compiler Nets Element[1]: L_IN has multiple names (Net Label L_IN1,Net Label L_IN1,Net Label L_IN1 (Inferred),Port L_IN_A1) 17:49:14 2016/3/9 460 r$ w" j- X3 v; ^) Q7 s9 I
[Warning] TOP.SchDoc Compiler Nets Element[1]: POWER_OUT has multiple names (Net Label POWER_OUT1,Net Label POWER_OUT1,Net Label POWER_OUT1,Net Label POWER_OUT1 (Inferred),Port POWER_OUT_A1) 17:49:14 2016/3/9 47* P2 m0 g( W* z o9 {' J- @
[Warning] TOP.SchDoc Compiler Nets Element[1]: R1C has multiple names (Net Label R1C1,Net Label R1C1,Net Label R1C1 (Inferred),Port R1C_A1) 17:49:14 2016/3/9 48" v' K+ b% d/ p- w& H
[Warning] TOP.SchDoc Compiler Nets Element[1]: R2C has multiple names (Net Label R2C1,Net Label R2C1,Net Label R2C1 (Inferred),Port R2C_A1) 17:49:14 2016/3/9 49( K" {$ \* z3 C
[Warning] TOP.SchDoc Compiler Nets Element[1]: RFB has multiple names (Net Label RFB1,Net Label RFB1,Net Label RFB1 (Inferred),Port RFB_A1) 17:49:14 2016/3/9 50
6 @4 U& ]' p3 \$ @& A. _[Warning] TOP.SchDoc Compiler Nets Element[1]: SS has multiple names (Net Label SS1,Net Label SS1,Net Label SS1 (Inferred),Net Label SS1 (Inferred),Port SS_A1) 17:49:14 2016/3/9 51
) \8 K! Y! n9 @0 ]4 l# Z[Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[2]: CONF_FLASH_A has multiple names (Net Label CONF_FLASH_A2 (Inferred),Net Label CONF_FLASH_A2,Port FPGA_CONFIG.CONF_ADDR2 (Inferred)) 17:49:14 2016/3/9 52
( d! K- m/ w8 `' d4 g/ n, i[Warning] TOP.SchDoc Compiler Nets Element[2]: CONF_FLASH_A has multiple names (Net Label CONF_FLASH_A2,Net Label CONF_FLASH_A2 (Inferred),Net Label CONF_FLASH_A2,Net Label CONF_FLASH_A2 (Inferred),Port FPGA_CONFIG.CONF_ADDR2 (Inferred),Port FPGA_CONFIG.CONF_ADDR2 (Inferred)) 17:49:14 2016/3/9 53. I$ a1 M4 v& V/ f) I# ]/ U. n
[Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[2]: CONF_FLASH_A has multiple names (Net Label CONF_FLASH_A2,Net Label CONF_FLASH_A2 (Inferred),Port FPGA_CONFIG.CONF_ADDR2 (Inferred)) 17:49:14 2016/3/9 54
/ S8 A+ ^# E( H+ I+ o[Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[2]: CONF_FLASH_D has multiple names (Net Label CONF_FLASH_D2 (Inferred),Net Label CONF_FLASH_D2,Port FPGA_CONFIG.CONF_DATA2 (Inferred)) 17:49:14 2016/3/9 55
/ o* ]! S- H; B[Warning] TOP.SchDoc Compiler Nets Element[2]: CONF_FLASH_D has multiple names (Net Label CONF_FLASH_D2,Net Label CONF_FLASH_D2 (Inferred),Net Label CONF_FLASH_D2,Net Label CONF_FLASH_D2 (Inferred),Net Label CONF_FLASH_D2 (Inferred),Port FPGA_CONFIG.CONF_DATA2 (Inferred),Port FPGA_CONFIG.CONF_DATA2 (Inferred)) 17:49:14 2016/3/9 560 d- ^) C" N+ e. F: q
[Warning] FPGA_CONFIG.SchDoc Compiler Nets Element[2]: CONF_FLASH_D has multiple names (Net Label CONF_FLASH_D2,Net Label CONF_FLASH_D2 (Inferred),Port FPGA_CONFIG.CONF_DATA2 (Inferred)) 17:49:14 2016/3/9 57
" ]0 M" E A/ P u0 m1 G
1 S% `7 q+ Q; i2 F8 Y; ~
8 D& A. S) L! T, f. z5 I1 Q |
