AD15.1.13 6 l* M& s9 s3 X7 P# ?8 M( u' J
Altium Designer no longer crashes on start, in environments utilizing a roaming profile $ U7 e1 F: \) @! V5 \% A$ Y4 O
Several fabrication and assembly output issues concerning TrueType special String conversion, location, and justification, have been resolved (BC:5521).
9 v0 P% w4 X2 h: AInvalid files nor longer generated during export to Parasolid
4 `; X0 R4 w3 [8 n1 SThe PCB can now be exported in PDF3D format, directly in the Project folder. This fixes the issue where a blank PCB was being created, that overwrote the existing PCB document.
/ u4 a5 t0 O# QFixed issue with non-editable via sizes during routing.
7 k2 f4 |+ J5 C5 B" dAvailability of Component State validation has been restored in OutputJobs.
p8 _- R# p/ d+ w" VAn issue with Altium Designer licenses not being recognized when using Private License Server v14.0.0.33 (or earlier), has been resolved.
" h; O+ H3 C2 j# C) p, q( D& t7 \- l LThe MCAD collaboration standalone license no longer needs to be re-activated every time Altium Designer starts. : h" F7 V: k# B, S8 {: \$ L, F! Q% T4 g
All cell data is now loaded properly when opening older CmpLib files in Altium Designer 15.1
# j3 S5 Y$ l8 @3 Y8 ]( dMultiline strings with CR LF now display correctly in PDF3D export.
: ?1 j$ N& V: h3 O* u! }2 pAn issue with the Symbol Wizard window not being movable, has been resolved.
4 k F3 x+ u; W/ m2 k) PThe Component Template (CMPT) Editor is now compatible with Altium Designer 15.1. : x+ [9 [/ J& a
