PartType        RefDes        PartDecal        Pins        Layer        Orient.        X        Y        SMD        Glued
  L# W# Y2 m+ H! c1 K8 Y. ]) pTP/2        BAT+        TP/2        1        Bottom        270        20.108        18.337        No        No
. Y$ Z" }4 g# N# x; k' Z7 TTP/2        BAT-        TP/21        1        Bottom        90        21.361        15.483        No        No
, s6 A" {$ I% q9 [8 j; h+ xCAP0603        C1        CAP-0402        2        Bottom        0        -7.660        13.657        Yes        No
6 h" M6 q. U" ^* @% ], n; B/ wCAP0603        C2        CAP-0402        2        Bottom        180        6.746        12.942        Yes        No
% e3 m7 d  z! M2 GCAP0603        C3        CCS-0603        2        Bottom        270        7.276        4.200        Yes        No        1 Z9 W& H: {# I
CAP0603        C4        CAP-0402        2        Bottom        270        6.157        4.022        Yes        No        " O% K- s. v, O3 a4 |; p
CAP0603        C6        CCS-0603        2        Bottom        90        -4.989        21.173        Yes        No
/ l& u0 |: I; I2 C1 Z, g- iCAP0603        C7        CCS-0603        2        Bottom        90        0.717        21.173        Yes        No
! t; s- o3 p7 r( u/ tCAP0603        C8        CAP-0402        2        Bottom        270        9.171        12.403        Yes        No        ) A% ^/ @8 G! Z# Q
CAP0603        C17        CCS-0603        2        Bottom        270        10.092        16.849        Yes        No
6 R  c' I0 o. [% T8 KCAP0603        C19        CAP-0402        2        Bottom        270        -4.001        18.589        Yes        No
- p4 w5 @" j7 A& N& ^/ p  sCAP0603        C33        CAP-0402        2        Bottom        180        6.813        16.262        Yes        No
8 D8 S- u5 Q4 ~7 s3 s; @FPAD_2        CHG_L+        FPAD_2AAAAAAA        1        Top        270        -3.607        12.994        No        Yes
6 |4 z+ f# q* y& L2 [FPAD_2        CHG_L-        FPAD_2AAAAAAA        1        Top        270        -3.643        10.395        No        Yes
, l+ D& @8 ?, t1 K# N2 rFPAD_2        CHG_R+        FPAD_2AAAAAAA        1        Top        270        3.571        12.995        No        Yes        , L) s& w. X8 v0 `7 [8 M
FPAD_2        CHG_R-        FPAD_2AAAAAAA        1        Top        270        3.609        10.394        No        Yes
7 H; ]" K4 R: J! c( P/ WHEADER_4        CON1        4PIN/0.5MM        6        Bottom        0        11.783        1.883        Yes        No
, e6 t3 y, N0 o( t# PLED        D1        0603LEDAA        2        Top        180        -3.633        1.470        Yes        Yes
/ C$ P' l9 G- z+ C! G0 |LED        D2        0603LEDAA        2        Top        180        -0.014        1.470        Yes        Yes
+ j2 R* C4 E1 \* p' PLED        D3        0603LEDAA        2        Top        180        3.571        1.470        Yes        Yes
# Y# o. Y4 ]7 ^. [' A  y5 s( aR        D4        DFN1006-2L        2        Top        270        -5.812        12.994        Yes        No
" S7 u6 N$ v" X; {: jR        D5        DFN1006-2L        2        Top        90        -8.029        21.704        Yes        No        * S! `6 S2 [' h- b/ F! w3 K& ^$ {
R        D6        DFN1006-2L        2        Top        90        5.983        12.987        Yes        No        + f. g# L% J: H* Z
TP_1.0        DET_HALL        TP_1.2        1        Top        270        12.035        6.341        Yes        No        2 h1 R% a0 A+ e, m3 u
TP_1.0        DET_KEY        TP_1.2        1        Top        270        -1.430        10.234        Yes        No
6 i  r3 s: d& G" B# yTP_1.0        GND        TP_1.2        1        Top        270        17.361        8.190        Yes        No        0 J3 Z2 V  X, s/ \; ]8 N
TP_1.0        I2C_SCL        TP_1.2        1        Top        270        6.017        9.010        Yes        No
! ]6 V' B  Y( v0 h, [/ y, M1 D( ZTP_1.0        I2C_SDA        TP_1.2        1        Top        270        0.867        10.194        Yes        No        8 ^: s) X* y5 I3 ~
INDUCTOR        L1        IND-5X5        2        Top        180        14.081        20.400        Yes        No
% O1 a6 k, {' hTP_1.0        LED1        TP_1.2        1        Top        270        -5.432        3.031        Yes        No
' f2 s2 T! @# RTP_1.0        LED2        TP_1.2        1        Top        270        -7.001        5.006        Yes        No
* h* ]' n  s3 Q. O* }, b( C+ |TP_1.0        LED_COM        TP_1.2        1        Top        270        7.651        2.729        Yes        No          |1 W1 T2 m, a) K; G( D8 h
TP_1.0        MCU_VDD        TP_1.2        1        Top        90        4.187        3.616        Yes        No
" Y; X" F: ^: V% ]; RTP_1.0        NRESET        TP_1.2        1        Top        270        -1.763        4.024        Yes        No
+ Y2 t# D- t+ o8 B. g9 h7 Y+ u0 f, `FPAD_2        PWR_KEY_L        FPAD_2AAAAAAA        1        Top        270        -3.681        7.794        No        Yes
) R3 R1 n0 M& Z9 C1 T( TFPAD_2        PWR_KEY_R        FPAD_2AAAAAAA        1        Top        270        3.647        7.794        No        Yes
4 l0 A5 `5 a2 I8 y( Q9 o% C9 ]' GREC-        R1        R0402/3A        2        Bottom        0        -3.485        1.492        Yes        No
% r* @" z7 p* V0 L6 t* xREC-        R5        R0402/3A        2        Bottom        180        6.666        17.100        Yes        No
: [8 F% ?' a  o$ ?/ y7 V% t* s$ U/ bREC-        R6        R0402/3A        2        Bottom        180        -7.630        12.774        Yes        No
0 G0 M- `( ~2 g: Z4 y' K8 |, ?REC-        R7        R0402/3A        2        Bottom        0        6.733        12.076        Yes        No        ) Y- k+ Y; _5 P" F
REC-        R8        R0402/3A        2        Bottom        180        6.668        13.853        Yes        No        $ G2 R  R9 T0 ^4 p% g
REC-        R9        R0402/3A        2        Bottom        180        6.613        10.091        Yes        No
/ Z4 Q  D* e9 u% W% n) tREC-        R10        R0402/3A        2        Bottom        270        8.520        4.086        Yes        No
4 o( K; p4 J1 y# X% J, v" NREC-        R11        R0402/3A        2        Bottom        0        -7.519        11.890        Yes        No        1 c' E8 N. M6 W3 t
REC-        R12        R0402/3A        2        Bottom        90        8.191        12.412        Yes        No        , M2 P7 P; c; S& Y" n
REC-        R13        R0402/3A        2        Bottom        0        6.788        15.372        Yes        No
9 R2 y3 |2 f! E2 F. N& A5 ]' ^7 bREC-        R15        R0402/3A        2        Bottom        90        -9.047        15.997        Yes        No        ( ^. Q+ t8 t) L/ S( B
REC-        R16        R0402/3A        2        Bottom        0        -7.547        14.640        Yes        No
9 Z2 [4 \: ~6 ?8 LREC-        R17        R0402/3A        2        Bottom        180        0.079        1.499        Yes        No        % s% F. d" E1 O" _0 r$ c. p" R
REC-        R19        R0402/3A        2        Bottom        270        -7.100        10.471        Yes        No        " p  v, O4 w# ^" G2 \' A/ [
REC-        R22        R0402/3A        2        Bottom        90        10.109        12.383        Yes        No        * b- w) n/ p1 S6 d3 k+ ~: w
REC-        R23        R0402/3A        2        Bottom        180        9.568        13.958        Yes        No
% ?, c  p; t2 d% c' `REC-        R24        R0402/3        2        Bottom        270        -4.960        18.704        Yes        No        * K+ G- b$ U" A( ?' N
REC-        R25        R0402/3A        2        Bottom        180        6.615        9.202        Yes        No
$ O5 U6 h) X: l3 f# Z" D4 pREC-        R36        R0402/3A        2        Bottom        270        9.179        10.533        Yes        No
% B5 l+ j* D5 K& vREC-        R39        R0402/3A        2        Bottom        270        8.188        10.529        Yes        No
1 S7 ^0 K; c. g! LREC-        R40        R0402/3A        2        Bottom        270        -8.048        10.444        Yes        No
4 O/ r/ l$ k  i) jPTC        R41        PTC-1206        2        Top        0        -7.087        19.984        Yes        No
! B8 b2 l3 t# Y/ R5 \REC-        R46        R0402/3A        2        Bottom        0        -7.584        15.583        Yes        No        2 R) M  d: u% m: C: M9 C+ x7 _
REC-        R47        R0402/3A        2        Bottom        0        -7.572        16.554        Yes        No
9 M2 `' |2 w! K- n2 MREC-        R49        R0402/3A        2        Bottom        180        6.612        11.016        Yes        No        ( H9 M0 O5 f0 t2 }
TP_1.0        RX_L        TP_1.2        1        Top        270        -7.077        10.639        Yes        No        2 s9 w3 t% q& X4 q* T
TP_1.0        RX_R        TP_1.2        1        Top        270        9.943        10.984        Yes        No
( ?! }/ x# C9 c" e: M( }6 tTP_1.0        TX_L        TP_1.2        1        Top        270        -9.015        9.153        Yes        No
4 x" j9 W; u8 V5 x: U+ Q$ P6 e) }TP_1.0        TX_L1        TP_1.2        1        Top        270        -5.584        15.875        Yes        No        + v; w: D& I4 R0 }" V
TP_1.0        TX_R        TP_1.2        1        Top        270        2.768        6.310        Yes        No        7 I& Y5 |2 }% d) ~
TP_1.0        TX_R1        TP_1.2        1        Top        270        3.588        16.052        Yes        No
; l; w% r, E+ r  k8 UTP2803        U1        QFN_24        25        Bottom        270        -0.027        15.495        Yes        No
  W6 c/ X$ [- Z5 N3 [IC-N76E003AQ20        U2        IC-QFN20-3X3_0.4        21        Bottom        180        -0.140        6.180        Yes        No
) `: n. I& P; f: D, j: I) d$ TUSB        USB1        MICRO-USB-AF5246198R-ZH        13        Top        0        -2.831        21.901        No        Yes        0 `# ~! }/ ^- R6 ?+ i/ B6 y
TP_1.0        VBAT        TP_1.2        1        Top        270        11.453        8.997        Yes        No        * z- x% ]) r5 r
TP_1.0        VBUS_IN        TP_1.2        1        Top        270        -9.409        18.143        Yes        No        ! o7 s0 N, K  _7 p6 ?3 D/ a
