使用双运放的时候 编号错误 如下 + i; A7 C9 _9 b* E, D ~+ I; Q
实在不知道怎么处理,有谁遇到过啊,期待大侠!!!
. t& L# w* g9 @, }3 x! m# h0 s; ] q- M4 c% {2 ]) j
********************************************************************************. A- ^% Q+ C) u) Z/ {6 r" u
*8 ^0 D) i" P2 W5 l T
* PeRForming annotation.
& O( O, Q( G, z; f+ u% P8 {# o*$ S$ d& ?9 Y' k: a; O# n5 D/ A
********************************************************************************8 O" O- o, ? E2 ^, P3 x& w
ERROR(ORCAP-1377): Component U2A has different common pin connection for two instances and hence packaged separately.
0 n; v3 T, w$ |; PERROR(ORCAP-1377): Component U4A has different common pin connection for two instances and hence packaged separately.
2 O4 f8 j6 I2 p) J6 \( [% {* @ERROR(ORCAP-1377): Component U6A has different common pin connection for two instances and hence packaged separately.$ m3 `* {% x9 w" {
ERROR(ORCAP-1377): Component U8A has different common pin connection for two instances and hence packaged separately.
# P5 Q- ^7 Y' |* I ]9 \) _* UERROR(ORCAP-1377): Component U10A has different common pin connection for two instances and hence packaged separately.
) w5 ?1 E& X2 {9 M$ i# HERROR(ORCAP-1377): Component U12A has different common pin connection for two instances and hence packaged separately.& c6 s4 r4 N$ s6 G N/ p' r
ERROR(ORCAP-1377): Component U14A has different common pin connection for two instances and hence packaged separately.
3 o ~# d1 J& i( o2 n) x* CERROR(ORCAP-1377): Component U16A has different common pin connection for two instances and hence packaged separately.; G7 J- P- M9 e# o% d3 S
