WARNING: Since the starting (6.7322835,7.6968501)(mm) and the ending (6.7322831,7.6968504)(mm) coordinates of the arc are to close, it will be interpreted as an arc of 360 degrees per ODB++ standards and can potentially cause problems.# R) F* b6 M2 e# V( i
; W0 N, d# k* d% |; `5 ~+ V4 }
WARNING: Since the starting (1.3133467,3.0012447)(mm) and the ending (1.3133473,3.0012450)(mm) coordinates of the arc are to close, it will be interpreted as an arc of 360 degrees per ODB++ standards and can potentially cause problems. / h; L8 G; x1 P: L
0 H {' w$ P& @" R" ?8 d2 E报警提示的坐标都是在原点附近的,我尝试着把原点设置到-100,-100的位置,报警的坐标也就涨到10,10的样子,不像是PCB上面的线,不知道哪边设置有问题$ s1 f9 w6 P. x$ Z* d
