查看: 704|回复: 2
关于pspice中的模型编辑
发表于 2015-5-29 10:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
小弟从iRF的官网下载 了,以****.spi为后缀的模型文件。这个模型导入到Pspice中,发现与实物不对,最后检查模型编辑,是模型里这样编辑。这个里面对于模型的编辑文件如下:
( }1 D2 a" c6 \4 J.SUBCKT irf7501 1 2 3
" X+ M! @# r* Y. v. L" L* k0 ^**************************************
" P! Z) \6 u8 T5 Q0 o9 X* @; X*      Model Generated by MODPEX     *' A( X7 B: z3 a( M9 t
*Copyright(c) Symmetry Design Systems*
9 |8 e, M4 z+ W' D' [& y*         All Rights Reserved        *  |  ?; q6 n" H1 x$ F
*    UNPUBLISHED LICENSED SOFTWARE   *
% ~6 c2 {( ^' c$ y*   Contains Proprietary Information *$ O0 T) A% q: W! n
*      Which is The Property of      *
# l( {+ Z  L7 A  ~* J, h  g*     SYMMETRY OR ITS LICENSORS      *
" i8 w* E( Z/ ^0 ^4 ?*Commercial Use or Resale Restricted *( m$ m8 b6 |3 Z. g
*   by Symmetry License Agreement    *
6 q8 \2 G; f: m: ^6 A# E**************************************
, O- b: w8 z5 `+ w" W: |7 V* Model generated on Apr  3, 02! \0 s2 `4 j' U
* MODEL FORMAT: SPICE34 S7 D! T% ^. k8 @8 m6 T
* Symmetry POWER MOS Model (Version 1.0)
$ M1 H; Q$ k0 z- H" y( p* External Node Designations2 o+ y" G7 ~; S2 u7 A
* Node 1 -> Drain
% N( D* ^" O8 H/ G& v* Node 2 -> Gate
3 w; U. f4 x/ K5 l2 d& h5 }* Node 3 -> Source- m9 R( V! p5 h" E
M1 9 7 8 8 MM L=100u W=100u
, u% s, D% H2 Q4 Q.MODEL MM NMOS LEVEL=1 IS=1e-320 L0 }+ V0 t  w
+VTO=1.41125 LAMBDA=0 KP=9.09648
& u3 Q9 O% l4 S4 J3 g1 I+CGSO=1.95e-06 CGDO=1.55467e-08  L2 o# ?$ Z3 H) E6 \
RS 8 3 0.00010 a& f- H7 x3 S8 d
D1 3 1 MD
, v4 z' q5 ]/ N7 w2 R.MODEL MD D IS=4.87114e-10 RS=0.0569645 N=1.35135 BV=200 G1 m  e$ D7 H2 P) ?5 p
+IBV=0.00025 EG=1 XTI=2.51194 TT=0; {2 M. U( s+ l+ D& \# ]3 f8 [
+CJO=1.81022e-10 VJ=2.97768 M=0.654619 FC=0.5, s$ p; Z4 h9 q) E; L/ k2 ~0 J0 k
RDS 3 1 1e+06
2 f1 x: x& f5 a( W. ~RD 9 1 0.034725
$ y+ o0 |, f( p6 i- aRG 2 7 9.8673
5 q+ _: v5 z$ i4 ^- x6 C- JD2 4 5 MD1
* Y( g9 L2 g7 V4 f) v( M* Default values used in MD1:- t4 m7 B+ `+ m* _
*   RS=0 EG=1.11 XTI=3.0 TT=0
$ P8 f6 l. U! [: A*   BV=infinite IBV=1mA) _9 ~1 ]4 D+ H% B/ Q
.MODEL MD1 D IS=1e-32 N=504 M/ W7 P+ s; g
+CJO=3.45255e-10 VJ=0.676574 M=0.563658 FC=1e-08/ ]) ~$ l  K# d0 w/ i- z9 i# o; m
D3 0 5 MD2
' B2 K0 x& \9 R( W: |8 T; T+ ^7 p* Default values used in MD2:# J$ o6 M3 d& B' K8 L1 p
*   EG=1.11 XTI=3.0 TT=0 CJO=0, h- ]) y4 z4 w, ~
*   BV=infinite IBV=1mA! J  f; k( V6 J6 U
.MODEL MD2 D IS=1e-10 N=0.402525 RS=3e-063 s" N$ @$ |/ A3 r) ?$ ~! _
RL 5 10 1% F& w) P9 C& e) `: \
FI2 7 9 VFI2 -1+ ~. M! P! g" F8 F$ U
VFI2 4 0 02 S% F) E* Y! }8 f, y: }  j
EV16 10 0 9 7 18 O$ O' N" D* E1 W( e$ Z5 I7 ]$ o
CAP 11 10 6.99896e-10+ ~" u- N; A3 R* T
FI1 7 9 VFI1 -1
9 P8 X1 @* w+ Q8 ?VFI1 11 6 0
9 V7 C: b' T* Q& _: b; ?6 h1 FRCAP 6 10 1
' N( o/ D  t+ T6 _3 |& X5 UD4 0 6 MD32 P6 c% D# A# M* @) X1 a9 T
* Default values used in MD3:
; ~+ q, X9 f/ k/ y1 i*   EG=1.11 XTI=3.0 TT=0 CJO=0
6 ?5 |$ H: Q; L9 v% Q*   RS=0 BV=infinite IBV=1mA7 `2 L+ s* F" o# ^; J' m9 V
.MODEL MD3 D IS=1e-10 N=0.402525# F* V9 B: S& N* m! J* p1 u# }
.ENDS irf7501, M* R, V% M* [# i
  k% e+ _; ?0 o- [
这个里面对于模型只是定义1,2,3个脚,而实际用到的是so-8的封装,坛里对于这个程序编辑比较熟悉的,麻烦请问这个程序编辑有什么规则,或者有什么文档或者书籍。麻烦求一份。
& O6 c; _* \( d- ?# `, ~
发表于 2015-8-5 17:12 | 只看该作者
楼主解决了没?
没有。这段时间没有再关注这个。  详情 回复 发表于 2015-8-6 12:36
 楼主| 发表于 2015-8-6 12:36 | 只看该作者
yap 发表于 2015-8-5 17:125 V+ X* g( G9 }9 I$ O
楼主解决了没?
6 U( e$ ~3 b  G( K没有。这段时间没有再关注这个。9 S$ r4 S3 K8 q3 F+ j9 @6 O$ ?# A) E
GMT+8, 2025-10-28 21:28 , Processed in 0.156250 second(s), 28 queries , Gzip On.
