查看: 14335|回复: 33
[Cadence Sigrity] 关于Allegro转PADS问题?
发表于 2015-3-6 21:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
8 N. G9 A6 I0 w/ x# R; g4 t$ S, A4 p2 p3 T0 i8 a
在网上看一遍关于allegropads的方法,看着不错。我认真按文章做,但是不成功,上来问问看有没有高手碰到过。谢谢!!!
  z+ C7 W: U3 H! [8 s9 c
我在Command命令栏里键入:skill load "dfl_main.il"   执行完后再输入:main out      执行完后,错误内容如下:
" A8 }9 p/ R% @. T; f
function createAll2ExpFileHeader redefined
% X' W& k, F% r9 g6 Y! A5 t. W
function fillinAll2ExpBaseview redefined
8 V1 t, _. s/ }: W
function createAll2ExpBaseview redefined
. a9 v% M* t7 x3 H% I
W- *WARNING* defstruct: Redefining StructureDC_sControlVars.
+ w  ?1 y  t2 ~9 I/ Y
W- *WARNING* defstruct: Redefining StructureDC_sPackage.
. T* t- \* T' b4 y! B1 w# f
W- *WARNING* defstruct: Redefining Structure DC_sText.
" M+ W. b* P( [
W- *WARNING* defstruct: Redefining StructureDC_sClearance.
! G! N5 [: u0 V# q: f; f: j
W- *WARNING* defstruct: Redefining StructureDC_sDefClearance.
* I, Z, `! H  E" p5 v! @
W- *WARNING* defstruct: Redefining Structure DC_sWidth.
0 u! ]0 q) n9 a( t# x/ w9 j3 j
W- *WARNING* defstruct: Redefining StructureDC_sNetData.
: z+ J- N4 z/ E& f* o! `$ E
W- *WARNING* defstruct: Redefining Structure DC_sElectricalRule.
% l; e7 F; s1 d, A5 Y
W- *WARNING* defstruct: Redefining StructureDC_sMatchedDelayRule.
6 o1 n' i4 n. E# j: J5 V1 E
W- *WARNING* defstruct: Redefining StructureDC_sRuleArea.
1 {+ u5 L, Z0 r+ s+ e7 ~9 O6 t( |
W- *WARNING* defstruct: Redefining StructureDC_sFormula.
0 w4 j' B+ j% z+ F9 [  x
W- *WARNING* defstruct: Redefining StructureDC_netPinData.
8 _0 Z* x% v. b4 m7 \3 c# F
W- *WARNING* defstruct: Redefining StructureDC_netKeyData.
) f8 _- ~4 I2 z7 a9 y3 X
W- *WARNING* defstruct: Redefining StructureDC_sSymbolProps.
3 z/ t* E7 W" ~9 ?8 E! x; M
t
1 W% h/ W2 e: ]8 d7 A1 l1 n
Command > main out
" \- a( ~8 @9 L6 l2 e/ L% g* D# D) R3 E
Please wait...extracting and processing technology file
4 f7 r) c; ~. R) R3 }( _
Converting techfile...
  s# Z  h7 q& d( E9 W$ m
Executing command C:/Documents and Settings/admin/桌面/aaa/kp201_Rev1.2_130806_MGC/Work\techconv.bat
' q& c0 [! ^6 f: }
E- Cannot open script file; 'C:/Documents.scr' does notexist.
7 u: u3 y/ ~. d' b. u/ {- I2 Q
Error: Techfile conversion failed!
4 T+ U2 K9 w/ m) s) R/ B
Deleting Existing Classes File
' V6 j. j' \4 c6 U& Y, {# U
Deleting Existing Props File
( x8 Q9 p" K# a9 y
Deleting Existing Board Items File
2 [( k7 y0 o7 t0 [3 d+ I  E5 E
Exporting Electrical Constraints...
3 e8 p9 v" C+ c/ ]* \
extracting device files
3 I( b, j% i+ z2 [9 J; Z" U
Error: create_devices command failed!
! B( A; q% A3 U! T! p, N  }
extracting Net Properties
$ y; p& K& `8 v
Loading axlcore.cxt
; Z* `* t: y8 g! X
6 O: Q3 M- O+ C0 i
E- *Error* get/getq: first arg must be either symbol,list, defstruct or user type - 0
( `& c( z$ M$ b6 L, E, m# V( I
1 c+ I5 f" M3 J6 E. g& l6 J0 r
& y* R5 {9 p- u; S
9 Q9 y! R6 N. p' j
教程方法如下:大家也可以试试,看能成功不。
allegropads终极篇
现有一种比较简便的方法是:用AD导入Allegro的pcb,再将AD的PCB转成PADS,这种方法简单易操作。   但个人感觉最终转换的数据不能让人满意。PADS软件有个Transtor,但通常是不可以直接转的,会报错。  经过几天的摸索,终于搞清楚了操作的过程,现在分享给大家,以方便大家  转换的前提条件是:你的机器要安装16.3或以上版本的Allegro   6 Z/ z5 x! y0 J$ f" |6 j5 \2 r
1.首先要建立两个系统变量(有的机器可能已经有了,就不需要建立了):
- Y# \5 G! F; A
AEX_BIN_ROOT               值:        (你的PCBENV文件夹的位置),如E:\Allegro_Project\pcbenv * p/ h# r% T  p* ^
AEX_ENABLE_JOBPREFS_LAYER_FIX        值:1  * W' e2 _" n" x: @! v5 h
2.将PADS安装目录下的skill_scripts里面的文件全部copy到pebenv里面
  s& H4 m9 ]' o, G
如:将C:\mentorGraphics\9.5PADS\SDD_HOME\translators\skill_scripts下的文件COPY到E:\Allegro_Project\pcbenv
# j: X6 D5 q- K% F4 B) h7 E5 Z8 e
3.将Allegro的PCB转换成低版本的(16.3或以下)的PCB文件,新建一个文件夹,将要转换的低版本的PCB文件放在新建的文件夹中
% z6 @% a4 p$ T; D* W6 v* r
在Allegro软件的Setup下的user preferences Editor 中的Skill选项里,在telskill选项中打√
# z/ I8 E( a1 W
这时软件会弹出一个对话框,不用理会,关闭它就可以了。
; b3 H( f, ^. P% x
5.在Command命令栏里键入:skill load "dfl_main.il"                                                     * I8 V* |5 M  w' a! W$ e
注意输入时,引号不能少,load和引号间是有空格的,要是输入不正确,命令是无法执行的。
; O0 F4 h; s5 k) U7 o/ C, A* K" h, y
回车后,会看到程序执行一大串命令,中途的每个命令不能有出现ERROR错误信息,否则转换不成功。
! d2 a4 G2 ^) [: ]2 K/ K
执行完后,在Command中输入:main out
& L) ~# z) h5 k
% \* U- p) c. ?$ I6 P6 \1 |2 u这时会弹出一个对话框:
& V+ \& E& N8 A+ a7 ~
点击“Star One Way Translation”
/ J+ U5 \2 A1 H" J& y等待…        结束。
5 x; B% `1 c2 m
5.打开PADS的Translator工具:        Allegro DesignsTranslators
# R# a! m  l! n* O添加刚才处理过的低版本的Allegro  PCB文件,执行转换,
+ _3 G4 \9 a" K- |/ b- {转换完成后,在PCB的文件夹下会产生一个这样格式的PCB文件:        design_ ******** .pcb'
" {- j% z. ]5 P* B3 m8 l# o( ~
用PADS Layout打开它,设置一下颜色显示,惊喜!就是你要的文件!
ok,恭喜转换成功!
; u  K# t0 j! z1 f" M4 ]
" l3 w: B( |# t0 i
2 X, v2 K# O$ d+ n& }, H5 w
* Z) `3 }8 O. ], U' H
    奋斗
    2024-12-19 15:16
  • 签到天数: 94 天
    [LV.6]常住居民II
    推荐
    发表于 2020-3-9 15:51 | 只看该作者
    本帖最后由 yahoboy 于 2020-3-9 15:52 编辑 9 K: w: i& C$ p0 G; q
      i  W% r9 a! V+ p5 r* C  s. w% v$ [
    ERROR: Techfile conversion failed!1 a. R4 ~8 e  j# J
    WARNING: layer TOP not found in layer table.  Check the Allegro cross-section!2 ?6 K6 e! H1 B* {
    WARNING: layer BOTTOM not found in layer table.  Check the Allegro cross-section!
    * l8 ?5 U1 `0 F7 b/ qERROR: no data issued for clearance DEFAULT8 X! q/ r9 F$ g9 d# r
    WARNING: layer SOLDERMASK_TOP not found in layer table.  Check the Allegro cross-section!
    4 F6 S/ W6 w2 P5 d5 H2 d( mWARNING: layer SOLDERMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!/ G1 V+ N) o2 n5 R; A
    WARNING: layer PASTEMASK_TOP not found in layer table.  Check the Allegro cross-section!2 Y- a" [' T/ u
    WARNING: layer PASTEMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
    0 l* Y( x) a. [6 C  aWARNING: layer FILMMASKTOP not found in layer table.  Check the Allegro cross-section!
    - ]+ N+ y) D4 O( C& f9 y% @WARNING: layer FILMMASKBOTTOM not found in layer table.  Check the Allegro cross-section!
      W$ {  P2 @& _- B# u' vERROR: Unable to issue shapes for padstack PAD3 - layer problems, }# S9 q8 |' {: p
    ERROR: Unable to issue shapes for padstack PAD1 - layer problems4 ?0 y  T4 n' a; L+ B
    ERROR: Unable to issue shapes for padstack PAD2 - layer problems, E5 B7 G' l6 q: b
    ERROR: Unable to issue shapes for padstack PAD4 - layer problems: v! N( n; v. W! \1 ~! H
    ERROR: Unable to issue shapes for padstack PAD5 - layer problems
    % ~8 h2 R/ @& ?# p3 AERROR: Unable to issue shapes for padstack PAD7 - layer problems9 X& y/ c: d$ I) M+ ?
    ERROR: Unable to issue shapes for padstack PAD6 - layer problems; h$ ^) n* ~9 O2 P' S
    ERROR: Unable to issue shapes for padstack PAD8 - layer problems
    1 g- q% W" |$ x  b1 D( l0 PERROR: Unable to issue shapes for padstack V16X8_via - layer problems3 _9 K8 k8 ~- I5 B' V
    ERROR: Unable to issue shapes for padstack V15X8_via - layer problems
    8 Z6 `  I. i- XERROR: Unable to issue shapes for padstack S_R3R50X3R00 - layer problems( u. k; b% e  I5 [
    ERROR: Unable to issue shapes for padstack S_S1R00 - layer problems* C0 a* Q/ k3 O: e
    ERROR: Unable to issue shapes for padstack S_R0R95X1R30 - layer problems0 ^8 S6 h$ q1 h8 Y
    ERROR: Unable to issue shapes for padstack S_R1R40X1R60 - layer problems
    / T. p- C* X( G% m* w8 {  ?ERROR: Unable to issue shapes for padstack S_R1R80X2R00 - layer problems
    0 a2 y6 T! R% q) S5 t# _' qERROR: Unable to issue shapes for padstack SHAPEESD0402_R - layer problems
    9 o4 n) X2 M# P6 N" yERROR: Unable to issue shapes for padstack SHAPEESD0402_L - layer problems
    9 v  Z# K  P  {9 d7 f& eERROR: Unable to issue shapes for padstack S_R0R965X0R80 - layer problems3 M- K& W& [6 X6 Z% K  [& {
    ERROR: Unable to issue shapes for padstack P_O2R00X0R60_O3R50X1R50 - layer problems
    1 W1 I1 b. z6 L* M  S5 P( JERROR: Unable to issue shapes for padstack P_C2R20_C2R20_NP - layer problems
    + k% R9 H. |- ?: G0 E& vERROR: Unable to issue shapes for padstack P_O2R00X0R80_3R50X1R80 - layer problems
    - N6 t' C9 b+ ~7 n" B2 WERROR: Unable to issue shapes for padstack P_O1R10X0R45_O2R10X1R45 - layer problems6 c5 \9 R/ ^1 V
    ERROR: Unable to issue shapes for padstack P_C0R65_O1R40X1R25 - layer problems4 Z( |2 g/ V& I
    ERROR: Unable to issue shapes for padstack S_R1R40X0R40 - layer problems* z0 H4 e; q3 E6 C
    ERROR: Unable to issue shapes for padstack P_C0R80_C0R80_NP - layer problems
    $ n0 I+ S. |& C6 C0 vERROR: Unable to issue shapes for padstack S_R1R50X4R00 - layer problems( |8 r; x/ U7 {: J
    ERROR: Unable to issue shapes for padstack S_R3R40X1R30 - layer problems) s; I# U% I9 B, e7 e
    ERROR: Unable to issue shapes for padstack S_R0R70X2R00 - layer problems
    $ q2 T( i( o8 s% r* t$ _  h8 WERROR: Unable to issue shapes for padstack S_R1R00X1R20 - layer problems
    % f# S, G  I/ y  P& b6 h+ OERROR: Unable to issue shapes for padstack MARK_C1R00_C2R30NP - layer problems
    . K, @* f9 `2 q1 g6 ~( Y9 ?8 WERROR: Unable to issue shapes for padstack S_R0R80X1R10 - layer problems
    $ e# r! k+ a. v# Y7 Z6 M) Y3 pERROR: Unable to issue shapes for padstack S_R0R65X0R80 - layer problems
    , g1 _, l5 M/ [ERROR: Unable to issue shapes for padstack S_C0R70 - layer problems
    * e4 K- S5 S, W0 ^/ P; U( k# IERROR: Unable to issue shapes for padstack S_C1R00 - layer problems
    ( _: k9 f. \% L/ o6 uERROR: Unable to issue shapes for padstack S_R0R70X1R00 - layer problems6 G8 R  H: l* Z: F
    ERROR: Unable to issue shapes for padstack S_O0R70X1R00 - layer problems: T2 \) t; y- t5 H2 P2 F4 d* t
    ERROR: Unable to issue shapes for padstack S_R1R10X0R60 - layer problems
    1 u9 {( Y2 K: }& J+ uERROR: Unable to issue shapes for padstack S_O1R10X0R60 - layer problems) O+ `: |/ i- V  D8 C1 l. g
    ERROR: Unable to issue shapes for padstack S_C0R38 - layer problems
    & X  R: {! m2 eERROR: Unable to issue shapes for padstack S_R0R30X1R80 - layer problems
    ; W- J( q% t( E. IERROR: Unable to issue shapes for padstack S_R1R40X1R20 - layer problems
    + F: O: E5 T; r) k0 eERROR: Unable to issue shapes for padstack S_C0R35 - layer problems
    " p# P7 |, z! ?! M! VERROR: Unable to issue shapes for padstack S_R0R80X0R90 - layer problems3 S( M( S  T7 L. M7 \' V
    ERROR: Unable to issue shapes for padstack S_S0R55 - layer problems
    2 i3 y4 E( x7 R9 g& d  zERROR: Unable to issue shapes for padstack S_S0R50 - layer problems
    ' h! C+ X" d: W- t" i, Q% D9 {ERROR: Unable to issue shapes for padstack 0402_via - layer problems7 B% i% T& |- m$ p* ^
    ERROR: Unable to issue shapes for padstack 0503_via - layer problems
    . X' o8 A$ }$ A& a" s; KERROR: Unable to issue shapes for padstack 03502 - layer problems
    ! ]! ?  g% D' F4 w) Q0 HERROR: Unable to issue shapes for padstack S_R0R80X2R90 - layer problems
    ' W7 V# s& U# q7 ?3 B& r$ o+ F- iERROR: Unable to issue shapes for padstack P_C0R85_R1R45_P - layer problems; a* P7 J; ^0 x3 v: c# Q
    ERROR: Unable to issue shapes for padstack P_C0R85_C1R45_P - layer problems
    " o: e$ X1 l/ AERROR: Unable to issue shapes for padstack S_R2R20X6R00 - layer problems" [1 v$ U; v6 \3 C+ R
    ERROR: Unable to issue shapes for padstack S_R1R80X0R75 - layer problems) [( Y2 C1 }6 a1 u' h
    ERROR: Unable to issue shapes for padstack S_R1R70X1R00 - layer problems
    7 z$ S( s! b7 _: [4 C* u( vERROR: Unable to issue shapes for padstack S_R0R72X0R52 - layer problems
    ; t% m" n1 I) A: JERROR: Unable to issue shapes for padstack SHAPE_C1R025_C1R625 - layer problems
    0 K- u/ {2 t' n$ G: a! ~3 R; BERROR: Unable to issue shapes for padstack S_S4R15 - layer problems, Y! [/ Z" q3 [
    ERROR: Unable to issue shapes for padstack S_R0R20X0R50 - layer problems  ~9 W+ C1 B0 Y" F8 M4 D0 K
    ERROR: Unable to issue shapes for padstack S_0R50X0R20 - layer problems2 }0 e/ a5 L* u7 Z/ ]
    ERROR: Unable to issue shapes for padstack S_R1R00X0R25 - layer problems2 E- @2 L% B. `0 H8 b
    ERROR: Unable to issue shapes for padstack S_R3R60X6R40 - layer problems
    1 L0 ?/ d6 F  w- TERROR: Unable to issue shapes for padstack 0402PAD - layer problems
    4 |( E4 o/ j1 gERROR: Unable to issue shapes for padstack S_R0R50X1R00 - layer problems
    2 X, U# @: c1 I# P4 P: `- Q4 PERROR: Unable to issue shapes for padstack S_S1R90 - layer problems1 X7 E) f, ~6 o* d* d
    ERROR: Unable to issue shapes for padstack S_R1R80X0R95 - layer problems! n' J: g  j% f) _
    ERROR: Unable to issue shapes for padstack S_R0R90X0R80 - layer problems
    0 U0 f& Z/ c4 e, A) x1 JERROR: Unable to issue shapes for padstack P_O1R10X0R65_O2R10X1R45 - layer problems! [5 a; T1 \/ I; X
    ERROR: Unable to issue shapes for padstack P_C0R65_O1R50X1R25 - layer problems
    5 e8 i" n. e  E9 K9 RERROR: Unable to issue shapes for padstack S_R1R00X1R27 - layer problems
    9 o' H- U% E9 fERROR: Unable to issue shapes for padstack P_C1R05_C1R65 - layer problems
    6 w- x# q2 [" h4 B: C$ \ERROR: Unable to issue shapes for padstack S_R0R60X0R80 - layer problems
    3 y5 i6 Q" y0 E% K, A5 y: g9 oERROR: Unable to issue shapes for padstack S_R1R20X1R70 - layer problems5 O: g3 w% y7 ~
    ERROR: Unable to issue shapes for padstack S_R3R10X2R31 - layer problems' u$ D# i4 H: u- }3 H, y$ r
    ERROR: Unable to issue shapes for padstack S_R0R76X1R93 - layer problems" U7 D% K) K- P1 i6 H
    ERROR: Unable to issue shapes for padstack S_O0R76X1R93 - layer problems
    ; ~# K+ t; C- G0 C; D& ?. JERROR: Unable to issue shapes for padstack S_S4R40 - layer problems7 w# z7 T+ E  j
    ERROR: Unable to issue shapes for padstack S_R0R80X0R20 - layer problems- u, o5 p) E4 J1 ]4 b
    ERROR: Unable to issue shapes for padstack S_R0R20X0R80 - layer problems
    5 b/ t4 ]$ L/ I, K/ MERROR: Unable to issue shapes for padstack S_O0R20X0R80 - layer problems
    ( G2 R" s& s3 M+ {2 e  m8 r5 zERROR: Unable to issue shapes for padstack S_R1R00X0R70 - layer problems
    3 G1 T8 k  W' M+ s, [ERROR: Unable to issue shapes for padstack P_C1R00_C1R00_NP - layer problems! k2 _! ~; o' n1 V# p; q
    ERROR: Unable to issue shapes for padstack P_C1R40_C1R40_NP - layer problems) |9 w: o4 i+ O4 \
    ERROR: Unable to issue shapes for padstack S_R0R76X2R05 - layer problems
    7 t5 Q% f" w# r, l, _ERROR: Unable to issue shapes for padstack S_R0R70X3R00 - layer problems9 N& Q' c0 ~0 m/ i8 h1 k
    ERROR: Unable to issue shapes for padstack S_R1R50X2R30 - layer problems
    # Z7 U6 f7 Z  N# YERROR: Unable to issue shapes for padstack S_R0R80X1R20 - layer problems; i/ ~$ ~; Y3 w/ f. N
    ERROR: Unable to issue shapes for padstack S_R1R90X2R50 - layer problems
    1 p' F: b0 _" GERROR: Unable to issue shapes for padstack S_R1R016X1R625 - layer problems  k* q; M8 ]2 |
    ERROR: Unable to issue shapes for padstack P_C1R00_O1R80X2R00 - layer problems
    $ f, R8 Z# D# Z$ r! V! A% BERROR: Unable to issue shapes for padstack S_C0R80 - layer problems
    : v1 C, Z& l- z$ cERROR: Unable to issue shapes for padstack S_O0R48X1R30 - layer problems& u. o1 |  G: r% ^# U* M
    ERROR: Unable to issue shapes for padstack S_R0R48X1R30 - layer problems
    ; H6 T' I% Q$ z9 W5 EERROR: Unable to issue shapes for padstack P_C0R75_C0R75_NP - layer problems
    5 g, U2 W9 @0 j5 E# n' r6 b0 v" y. {8 aERROR: Unable to issue shapes for padstack S_R1R20X0R50 - layer problems
    9 G# x  V3 b" \+ h# ^ERROR: Unable to issue shapes for padstack S_R3R50X4R30 - layer problems
    4 G/ M" V' z1 M3 [ERROR: Unable to issue shapes for padstack S_O1R90X0R70 - layer problems
    ; }5 n8 y. O. d3 P* w; lERROR: Unable to issue shapes for padstack S_R1R90X0R70 - layer problems! G0 {2 i9 \4 t& y. d$ V3 V3 f1 f
    ERROR: Unable to issue shapes for padstack P_C0R50_C0R50_NP - layer problems2 w! Y( ]3 }! r; j' K
    ERROR: Unable to issue shapes for padstack S_R2R00X4R00 - layer problems
    . v+ N' ^5 X2 UERROR: Unable to issue shapes for padstack S_S2R20 - layer problems
    % g' j, I; h: |! E! iERROR: Unable to issue shapes for padstack S_R2R286X0R508 - layer problems
    ; d; D' O# G# ^" T, Z5 m6 N" I8 @ERROR: Unable to issue shapes for padstack P_C0R90_C0R90_NP - layer problems
    4 m  C# w3 K: m1 LERROR: Unable to issue shapes for padstack 0402_via - layer problems
    5 b. B1 V4 d5 z: r" EERROR: Unable to issue shapes for padstack 0503_via - layer problems
    % N+ j  C7 j) e$ R( ^; UERROR: Unable to issue shapes for padstack 03502 - layer problems4 g  ?' I4 q. o! t1 x$ K
    WARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!
    % d( k% Z/ W5 F( X- L. \, ]4 rWARNING: layer ~TSM not found in layer table.  Check the Allegro cross-section!% `7 k# l7 P* R" ?
    WARNING: layer ~BSM not found in layer table.  Check the Allegro cross-section!
    9 `5 X# }" [8 r+ `4 _9 jWARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!, M! `# M9 W  `/ }. r( x
    WARNING: layer ~BPM not found in layer table.  Check the Allegro cross-section!
    $ F5 v5 T3 I) _5 ?% IWARNING: layer ~TFM not found in layer table.  Check the Allegro cross-section!& _9 i9 D5 q* H' [- H
    WARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!6 }& F  U- g3 l9 ~* |) K5 m2 `7 O
    : z4 s' H# P5 b  c+ D; K! r( f$ I
    也遇到上面的问题,哪位大侠帮忙看看怎么解决,谢谢!!!用Allegro 16.3版本的PCB文件,转成PADS VX2.3, 报错。
    & v  G! x+ F0 k
    2021-8-19 15:42
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    推荐
    发表于 2022-6-11 01:05 | 只看该作者
    ERROR: Unable to issue shapes for padstack THS-0R9_1R5 - layer problems
    $ ]6 P; `" T+ H. nERROR: Unable to issue shapes for padstack SMDS0P5 - layer problems
    1 G. K: b$ ^: q/ n3 {8 WERROR: Unable to issue shapes for padstack PAD_0R3X2R6_REC - layer problems
    $ i% ~$ n# Z. W- t5 `ERROR: Unable to issue shapes for padstack OB150_71X83_36D - layer problems
    " w- M$ q3 v8 j( Q2 k" C; ?$ hERROR: Unable to issue shapes for padstack OB103_63X59_36D - layer problems
    ' G' B/ k/ t/ _2 ?! h5 e4 l4 k, CERROR: Unable to issue shapes for padstack PAD_0R3X0R9_REC - layer problems
    ( o. t; D; I; V# _5 G- j8 aERROR: Unable to issue shapes for padstack PAD_C0R65_D0R4 - layer problems2 j' x+ B7 b. o+ Q
    ERROR: Unable to issue shapes for padstack HOLE-0R65_mtg - layer problems
    1 C  X2 H, G6 `4 w! {" g0 YERROR: Unable to issue shapes for padstack HOLE_0R65X0R95_OB_mtg - layer problems. c$ P' R, |  C) v
    ERROR: Unable to issue shapes for padstack OB63_39X43_20D - layer problems
    . B" R2 z# W% C* C, w- O) JERROR: Unable to issue shapes for padstack PAD_1R1X1R8_REC - layer problems
    4 A" d/ ~( u& V- w- AERROR: Unable to issue shapes for padstack SMDR1P15X1P45 - layer problems
    " W) D  C2 _, e! }) P8 k* d& @ERROR: Unable to issue shapes for padstack SMDR0P8X0P85 - layer problems6 E& c6 B' b3 U- h8 `
    ERROR: Unable to issue shapes for padstack SMD36_36 - layer problems
    + w$ D7 Q; g) |+ c# l. I. yERROR: Unable to issue shapes for padstack SMD36_50 - layer problems* r2 G% h% ]! z6 C
    ERROR: Unable to issue shapes for padstack PAD_S0R8 - layer problems) W' |$ e  G( K6 K6 A1 o5 }9 g
    ERROR: Unable to issue shapes for padstack PAD_65X118_R - layer problems3 @- @2 N, S2 P9 B
    ERROR: Unable to issue shapes for padstack PAD_20X24 - layer problems
    3 p" L9 z8 D, r. b, t8 {ERROR: Unable to issue shapes for padstack PAD_14X44 - layer problems
    1 u) M) T2 |+ _- r& q4 V' a4 gERROR: Unable to issue shapes for padstack OB75_91X28_61D - layer problems$ \: z$ t! R" V& \5 {% M- o
    ERROR: Unable to issue shapes for padstack OB63_47X33_24D - layer problems
    4 N/ e4 l: T7 V- qERROR: Unable to issue shapes for padstack RE63_47X33_24D - layer problems/ f2 @& e/ q* e' i' s
    ERROR: Unable to issue shapes for padstack HOLE-1R3 - layer problems) H0 I. F! z" o6 _) n
    ERROR: Unable to issue shapes for padstack THC-OR9_1R5 - layer problems
    4 t2 i- r4 ^9 P: lERROR: Unable to issue shapes for padstack PAD_53X102 - layer problems( t" V* V5 z' q
    ERROR: Unable to issue shapes for padstack PAD_S34 - layer problems
    ; j$ N1 f, V+ }* jERROR: Unable to issue shapes for padstack PAD_16X20_R - layer problems
    * m8 h3 R1 Y, l/ e. v' c" eERROR: Unable to issue shapes for padstack SMD12_35OB - layer problems  I9 Z/ r7 v" _( @# d3 [
    ERROR: Unable to issue shapes for padstack PAD_S24 - layer problems
    ) W1 `8 C/ M4 Y0 D! K5 S; ]5 o, {ERROR: Unable to issue shapes for padstack PAD_O24X47 - layer problems& `, o( e8 F: e& G
    ERROR: Unable to issue shapes for padstack SMDO0P6X1P8 - layer problems
    7 z  N+ J; d& [4 ?ERROR: Unable to issue shapes for padstack PAD_1X0D22_R - layer problems
    * d, f' _+ I4 z* P: }' D( y1 xERROR: Unable to issue shapes for padstack THS-2R0_6R3 - layer problems
    - j0 |% O! K9 V2 Q7 Z" yERROR: Unable to issue shapes for padstack PAD_8X39 - layer problems2 Y1 p8 d! Z2 Q1 n
    ERROR: Unable to issue shapes for padstack PAD_14X62_R - layer problems
    - R! N4 m* G, aERROR: Unable to issue shapes for padstack THS-1R5_3R78 - layer problems
    1 ?4 [; c) b& }$ r2 G3 j: ]ERROR: Unable to issue shapes for padstack PAD_10X60OB - layer problems
    1 K. b1 E6 K& iERROR: Unable to issue shapes for padstack THS-2R5_7R75 - layer problems
    . e1 W; q* h6 H# NERROR: Unable to issue shapes for padstack PAD_8X25 - layer problems
    * V( q! i( _9 l3 k+ o" z- z  YERROR: Unable to issue shapes for padstack PAD_S2R7_D1R2 - layer problems
    " i& |9 _& t) h' g1 o( f8 FERROR: Unable to issue shapes for padstack SMD55X10 - layer problems2 X$ ]' Y7 b8 D& C5 w2 I3 ^; O
    ERROR: Unable to issue shapes for padstack PAD_10X30_OB - layer problems" g" V' G" F5 n4 B& \5 n
    ERROR: Unable to issue shapes for padstack PAD_S130-CIR59D - layer problems
      h. A4 w( t7 A! {+ yERROR: Unable to issue shapes for padstack PAD_12X63_R - layer problems
    $ D; _1 J! B8 }9 O$ Z, AERROR: Unable to issue shapes for padstack PAD_10X55 - layer problems1 K# _0 Y- T5 L5 L$ C
    ERROR: Unable to issue shapes for padstack PAD_12X55 - layer problems
    : T+ e/ P3 R; W  s; a8 F8 I. M+ DERROR: Unable to issue shapes for padstack PAD_52X40 - layer problems- G* y! ]* q9 I# q+ O9 e
    ERROR: Unable to issue shapes for padstack HOLE_3 - layer problems9 ?" S! I* Y" v3 K
    ERROR: Unable to issue shapes for padstack 4-65MM - layer problems! r% e6 V9 D0 u! D
    ERROR: Unable to issue shapes for padstack 2-7MM - layer problems4 ~/ A' \3 J8 D% s
    ERROR: Unable to issue shapes for padstack 3MM - layer problems  R+ I/ Y$ x. v7 b  \6 f
    ERROR: Unable to issue shapes for padstack ID-BOARD - layer problems9 [  g* Q' R$ m+ L: T8 ^+ \, {
    ERROR: Unable to issue shapes for padstack PAD315CIR158D - layer problems
    8 ^9 @4 a7 K+ d6 f4 `! `ERROR: Unable to issue shapes for padstack PAD79CIR40D - layer problems: g2 K! K. j5 {
    ERROR: Unable to issue shapes for padstack THC60D40 - layer problems5 F9 o2 B+ v$ u( g8 n" x5 T/ X2 s
    ERROR: Unable to issue shapes for padstack THC80D55 - layer problems
    5 ]0 f: k; s7 EERROR: Unable to issue shapes for padstack OB118_61X79_32D - layer problems$ y5 {: z0 W# r% o, |' U& f: |
    ERROR: Unable to issue shapes for padstack OB118_55X79_24D - layer problems7 z( p+ Z1 M7 x# f
    ERROR: Unable to issue shapes for padstack SMDS2P4 - layer problems6 C* ]8 _% s# z+ Q9 c  q! _
    ERROR: Unable to issue shapes for padstack PAD_S3R0_D1R4 - layer problems' _. h9 g( A) T: W* w& c- A
    ERROR: Unable to issue shapes for padstack OB208_81X118_31D - layer problems
      l5 D4 C3 Z5 AERROR: Unable to issue shapes for padstack OB150_71X80_31D - layer problems
    ( q/ _/ I' D; ~8 tERROR: Unable to issue shapes for padstack VIA-GEN_12_24_via - layer problems
    . i9 X% U8 B) J# A* AERROR: Unable to issue shapes for padstack VIA-GEN_16_28_DBFIX1_via - layer problems+ O! v8 p( e9 S& W7 v( G9 H" }3 x; S1 z
    ERROR: Unable to issue shapes for padstack VIA-GEN_14_28_via - layer problems! y3 s! ~" }. ]4 t, Y
    ERROR: Unable to issue shapes for padstack VIA10-20_GEN_via - layer problems: j- q4 o( ?7 ~( V' [3 f" k
    ERROR: Unable to issue shapes for padstack PAD_40X71 - layer problems9 y: R, x6 ^. D5 f& A! w9 i
    ERROR: Unable to issue shapes for padstack PAD_28X36_R - layer problems* h5 o- ]3 C; C1 t/ c
    ERROR: Unable to issue shapes for padstack SMD10X55 - layer problems4 f9 b( ^" V8 X
    ERROR: Unable to issue shapes for padstack VIA-GEN_16_28_via - layer problems
    * |" I, I" Z" }* c5 i0 PERROR: Unable to issue shapes for padstack OB70_50X50_25D - layer problems
    , H* ^, y% p6 @: X9 L) L( K% {ERROR: Unable to issue shapes for padstack RE70_50X50_25D - layer problems' U5 q! c* `+ H. U' l# N
    ERROR: Unable to issue shapes for padstack PAD_S2R7 - layer problems
    ' I1 s% r' S# N1 q  p/ q$ J" SERROR: Unable to issue shapes for padstack PAD_2R7X3R2_REC - layer problems
    - T' b' {/ M) x9 i6 ZERROR: Unable to issue shapes for padstack PAD_0R3X1R7_REC - layer problems+ W8 R* [8 o; y5 p3 Q- p; L
    ERROR: Unable to issue shapes for padstack THS-1R2_6R3 - layer problems; `5 q1 r; O4 i! A$ p
    ERROR: Unable to issue shapes for padstack THS-1R2_3R78 - layer problems/ F+ o: `  p* L1 o1 I9 x: E  m
    ERROR: Unable to issue shapes for padstack PAD_50X60 - layer problems
    1 u  X  z0 ~, n: m7 X; jERROR: Unable to issue shapes for padstack PAD_10X42 - layer problems
    2 o5 @) j  }! [$ _0 WERROR: Unable to issue shapes for padstack PAD_S8_VIA2R5 - layer problems
    ( J! z& y0 H. _ERROR: Unable to issue shapes for padstack SMDR0P6X1P8 - layer problems
      h3 q. l* @5 U. }& f7 C& jERROR: Unable to issue shapes for padstack HOLE_C4R2-D2R5 - layer problems, U, G8 |+ U. L1 U$ F/ Q, R
    ERROR: Unable to issue shapes for padstack VIA-GEN_14_28_via - layer problems2 a( n. r" e9 e
    3 N. X8 @; \! }' _ERROR: Unable to issue shapes for padstack VIA-GEN_16_28_via - layer problems
    : S( |) @3 c5 V0 I! FWARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!2 N! Z+ L# J, Q, k8 @) g5 r3 @
    & B; l) X3 h! x$ d7 l3 |3 ]7 @WARNING: layer ~BSM not found in layer table.  Check the Allegro cross-section!
    7 Q8 C$ @: f% R+ t9 z' m( WWARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!8 q, ]+ ?8 r0 \/ S* r( x
    ' X8 Q& I+ t6 D8 s! uWARNING: layer ~TFM not found in layer table.  Check the Allegro cross-section!
    0 M) H4 E1 |* I5 @' U- dWARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!( m) Z5 F( m  w% B" c* x
    2 Q6 t/ S3 F0 `5 q# r都是有问题。软件为PADS VX2.3 和ALLEGRO PCB 16.6
    2023-12-8 15:41
  • 签到天数: 159 天
    [LV.7]常住居民III
    推荐
    发表于 2021-4-30 10:16 | 只看该作者
    & J" A" _% Q+ p; ?/ F- e2 ~4 A* qextracting Layer Stackup, q: o6 ^$ d7 V1 q/ c
    extracting Design Rules7 Y# g1 J: v5 ?5 b/ C3 G! p( `
    Deleting Existing Classes File* w  u% j; P1 T. i
    , N5 @) O4 A( i* R) GDeleting Existing Board Items File7 g% |) t( s0 C* l0 g
    & [0 D4 w. V# N$ B( {- ?Reading report definition file 'D:/Cadence/SPB_16.6/share/pcb/signal/reports.dat'.
    ' a; k6 _. b* o3 i) C6 a, Y5 w- gFinished reading report definition file successfully." n6 M& {0 `( w' K; S- K0 W
    Reading report definition file 'D:/Cadence/SPB_16.6/share/pcb/signal/custom_rep.dat'.
    ( S% G& f& W. }, ^" f# ?, {1 OFinished reading report definition file successfully.
    ; E8 T3 J1 u+ pdeleting old device files
    ' r6 q6 o7 P. {$ E0 q3 }/ O: k2 Yextracting device files
    5 P, H" A7 p+ d6 P3 Fextracting Net Properties6 P% s# f( ?7 F: T2 I% w5 B& z1 |
    extracting Board Extent: u* T1 d) C0 ]1 H
    extracting padstacks
    . m. q* [& I" a2 }6 `extracting padstack completed
    ) U: d. N7 }: ]6 O9 d) l% {2 Jextracting Placement1 c  t. B- p: b4 K) _6 X: `. h
    leaving placement& v+ o1 A  g: ~2 ?+ `: t: @  m
    extracting Device Pads
    ; R2 G; f: z- M) T, zdevices pads extraction completed
    ! |) S# J4 e! X6 aextracting Board Areas
    : T& f4 c& O/ \/ m( `Loading skillExt.cxt
    * [3 c0 L; J, w) ^Starting report...
    - k2 t* ^1 w& s+ xreport completed successfully, use Viewlog to review the log file.
    6 @$ ]* D* Q' z/ R% @( S" {report completed successfully, use Viewlog to review the log file.
    7 s* K7 ?6 t+ z/ i8 Z/ z$ ~Exporting net information.
    + W% t* x% G7 ~& M. j, YThere are no component properties in this database.: g: Q$ T& T/ P0 x5 c
    There are 203 different net properties in this database.
    & ?: s/ n, C: k' r1 pHierarchical net constraints have been flattened onto individual nets for export.
    ; G* k2 F9 d+ J' d0 u6 GThere are 5 different pin properties in this database.5 e* \3 J* U3 m& v1 C6 R+ @
    C:/Users/Administrator/Desktop/1/DXF_MGC/Work/propdelay_raw.tmp has been created.
    ( X0 P9 @8 p) a, F0 oLoading cmds.cxt
    . D9 q, ?% Z# H% e) ?* 143 error(s) generated, view interfacelog.txt" O6 ?  B8 P) w# |6 f3 Q7 m
    C:/Users/Administrator/Desktop/1/DXF_MGC/Work/LayoutDB.dfl Output Complete.
    * d0 A1 Z: a% y1 MGenerating Padstack HKP FIle.  |  s7 x! j: G& k6 g5 P
    & N/ p0 \1 J9 q7 d: e. ~; }Create .PAD Definitions.
    " k- I9 a4 G1 p, r) j4 v# Z6 OCreate .HOLE Definitions.% Y& p$ u; o( U# R# m* c
    Create .PADSTACK Definitions.
    4 o, l7 }4 s5 C" I2 X0 U4 ZGenerating Cell HKP File.
    ! }4 b' G" W! q6 \9 v# q8 } --------------------------- 4 R5 c% k$ k* p
    Info: Database transaction started.
    7 D8 f* W6 T+ I$ i/ CCell HKP Added temp instance of symbol: "SOP127P600X155-9L"% u! M7 m/ o7 T5 d3 {0 w" K
    Cell HKP Added temp instance of symbol: "CAPC3216"/ a. }  K6 E+ |  D/ x
    Cell HKP Added temp instance of symbol: "SOP127P790X200-8L"9 y2 x1 H/ f2 i
    Cell HKP Added temp instance of symbol: "INDC1608") h5 w% y9 Z& V4 s' g9 Z0 M# n
    Cell HKP Added temp instance of symbol: "CON3-2D54_V1"0 a* H4 x0 r# C# h/ l; x! L$ ~
    Cell HKP Added temp instance of symbol: "CRYSTAL-GND"1 T& }: I- F( @3 K! x$ O
    Cell HKP Added temp instance of symbol: "RESC1608"0 P; Z" Q) v5 d
    Cell HKP Added temp instance of symbol: "R0201"
    1 _5 G6 @- i6 Y# U  W3 X" n0 NCell HKP Added temp instance of symbol: "SOP127P600X175-16L"3 @; Y2 E7 c4 C0 x- y
    Cell HKP Added temp instance of symbol: "CAPE-2D5-6D3_V0"1 h: f. A, x1 O- E! y6 [
    Cell HKP Added temp instance of symbol: "USBA-H_V1_TP"
    2 C. D: ^% t9 o- j; Z( uCell HKP Added temp instance of symbol: "TP-1D5"
    ) }/ \, F- T" @: c7 j$ j* zCell HKP Added temp instance of symbol: "CA-MCU-736-H4_V0"
    ' V& E0 D/ ^8 T1 a) v; `/ i0 zCell HKP Added temp instance of symbol: "QFN68-8X8-E6D4"! c, T6 n% k! c5 ^
    Cell HKP Added temp instance of symbol: "CAPE-2D5-5_V0"9 y& P% S6 h4 H' W7 u
    Cell HKP Added temp instance of symbol: "SOP50P310X110-10L"
    ( C# n; k- ]& B; t& pCell HKP Added temp instance of symbol: "INDWS5X5"  |1 a1 Z$ N; k* {
    Cell HKP Added temp instance of symbol: "INDWCM2012"
    7 y4 e* `- q" V4 H$ v' ~Cell HKP Added temp instance of symbol: "CAPC2012"* A6 b7 T& H3 o- M
    Cell HKP Added temp instance of symbol: "RESC2012"
    ) z: y( v5 K  kCell HKP Added temp instance of symbol: "SOT23-5"% q, H8 _: h( _( \6 m9 U- U, Y/ y
    Cell HKP Added temp instance of symbol: "QFN16-3X3"* K' d% K" F) c- s. D0 [* |
    Cell HKP Added temp instance of symbol: "CAPC1005"7 a) y. \; [. u
    Cell HKP Added temp instance of symbol: "SW4-V_V0"
    - w* M; O. p; @6 o+ o8 J! l5 \! A/ @Current Symbol: SW4-V_V0
    3 A! j. v7 _1 |  o! [Current Symbol: IF-02D-MINI_V0_TP" c3 H" f' d  K( h. X; Z: F  f( p
    Current Symbol: SENSOR-V5 `* d2 U! O: T  R* [, W) ~
    Current Symbol: CAPC10051 ^) m; C1 ^6 q
    Current Symbol: QFN16-3X35 K1 f9 E% H; [1 b; H- P
    Current Symbol: CON6-2_V1
    . \3 D# N+ h$ M$ k1 sCurrent Symbol: SOT23-5# L7 P1 ~3 [2 U. v6 m. E) u+ J
    Current Symbol: MARK& [1 c! T' o( d% n8 z! X6 i
    Current Symbol: RESC2012
    + C2 M8 M  q8 n' q' a( t- fCurrent Symbol: C0201
    . g$ j- H: O0 w/ |) SCurrent Symbol: LL-34
    6 o2 m( O) ?) @/ ~3 i, W+ [/ ?Current Symbol: CAPC20124 i$ a9 l2 x8 e* t9 n8 l' M
    Current Symbol: PCB_PROCESS_REQUIREMENTS4 m% z. Q  h* p, H: E" I% N3 _8 h# `
    Current Symbol: INDWCM20121 q: T- j# l# P0 p: b
    Current Symbol: DCPOWER005-2_V0_TP+ U+ {) p6 N2 z* x6 Y
    Current Symbol: INDWS5X5
    6 f: y7 _  I/ ]) m0 QCurrent Symbol: SOT223$ F: m3 ]9 y# m" M& G
    Current Symbol: SOP50P310X110-10L, B( h1 o+ M& U2 A' k$ l
    Current Symbol: CAPE-2D5-5_V0
    4 t6 N3 b3 M9 ^: V; S& u# @0 |Current Symbol: QFN68-8X8-E6D46 G4 h" F# H2 v, D' H& ?
    Current Symbol: SOT23' _  |/ q8 z/ z0 p  J. I
    Current Symbol: CA-MCU-736-H4_V0
      r/ E6 l6 j9 i) d2 X* ECurrent Symbol: TP-1D5! a  j! e' N& Z3 T2 F8 s
    Current Symbol: USBA-H_V1_TP* `. _( v0 C' `! \& e
    Current Symbol: AV-8D4-3-B_V2_TP
    * }/ K: K( d5 u5 p7 t9 ^1 CCurrent Symbol: SN_6X6
    7 X& f: Y1 F* z- p* s8 g  F' {Current Symbol: CAPE-2D5-6D3_V0
    . c1 j8 S6 f: dCurrent Symbol: CON4-2D54_V1  u" `" k# m) @$ Z1 e
    Current Symbol: SOP127P600X175-16L
    3 Y. K: \$ h. l1 n9 NCurrent Symbol: R0201
    . Z+ @1 O. `) X. L& o5 m: vCurrent Symbol: DFN-10
    8 Z. T, B* H9 }# K$ Z$ DCurrent Symbol: SMA7 q/ A2 |$ q6 h- L5 D4 ]; R; a( X$ T
    Current Symbol: RESC1608  H7 Q. L2 p( i
    Current Symbol: INDWS4X4
    8 `3 _3 ]" y7 \$ E. }" \8 xCurrent Symbol: SOT23-6
    # F5 y; b8 S( xCurrent Symbol: LINEAR_DIMENSION
    * \) ^9 h0 N. H7 a# o' yCurrent Symbol: CRYSTAL-GND
    ' p3 q+ x3 S, [9 _# ]) R3 qCurrent Symbol: SCART-A_V2& s" h; A5 a& a) W
    Current Symbol: CON3-2D54_V1
    ; ~" v- B7 v# D3 O! h$ vCurrent Symbol: AV3-45_V0_TP) A8 M8 A  A1 d+ ^& S% d
    Current Symbol: INDC1608
    ) o. j) c; G+ L# hCurrent Symbol: DISPLAY-SINGLEROW_LED-38X10-V
    6 B: J( A" k7 e. S2 @Current Symbol: HDMI-10D55_V2
    % w; g1 S/ E6 x! FCurrent Symbol: SOP127P790X200-8L
    ! N5 P0 E, H* ?" Q- nCurrent Symbol: CAPC1608- Z$ J- Z1 S0 S% b: M9 `
    Current Symbol: RESC1005
    % p, y, j7 H) {/ J" D. s3 ACurrent Symbol: CAPC3216# V3 M. c& V, c+ D- p8 {
    Current Symbol: SOP127P600X155-9L2 p( \$ u" M+ }: B
    Removing temporarily added symbols.
    ; r  ?' g4 i5 a6 |! y24 symbols removed.2 f8 }! i; y2 M" C4 E5 ]/ \9 \
    Creating Net Properties' ?, i: A  k  L7 h! p
    Creating Net Class
    , W4 q% ^" p$ X---------------------- Al2Exp summary ----------------------3 i/ S4 U6 a* L& @
    Al2Exp - 143 error(s), 9 warning(s)
    . U. H) h- D+ h$ A1 [" ~9 jExport log file saved at "C:/Users/Administrator/Desktop/1/DXF_MGC\LogFiles\interfacelog.txt" file" e4 p7 h. A9 P9 \
    Run "show log" command to view log file' D8 b- P6 _$ [: h9 u& A+ @& h
    ------------------------------ Done -------------------------------
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2015-3-7 08:48 | 只看该作者
    关键的问题在这:
    # _( n3 o/ Q$ KE- Cannot open script file; 'C:/Documents.scr' does notexist.
    9 ^8 |7 v2 W9 r# B3 m- Q$ c( N
    8 |, h  S! j" K6 p/ v* X" e因为你的PCB文件目录放在了C:/Documents and Settings/admin/桌面/aaa/,路径中含有空格和中文,这是转换程序所不能支持的格式,不建议Allegro的工作目录、文件名含有任何非法字符,以免引起各种莫名其妙的问题。1 n) @# ?( r0 o5 o0 F3 K
    ) [( F( g3 I0 r$ B4 r  l
    可惜我还是没转成功. 我执行完skill load "dfl_main.il" 还是会有警告!内容如下,我没管,又执行 main out . function SetupDir redefined function createAll2ExpFileHeader redefined function fillinAll2ExpBas  详情 回复 发表于 2015-3-9 11:26
    非常感谢你的热心回答!正如你想的一样,是文件夹有中文名导至不成功的.  详情 回复 发表于 2015-3-9 10:48
    参与人数 1威望 +2 收起 理由
    NIWO99 + 2 很给力!
     楼主| 发表于 2015-3-9 10:48 | 只看该作者
    dzkcool 发表于 2015-3-7 08:48$ `1 E+ ~/ a2 I
    关键的问题在这:" V1 t8 F7 H" f. G. G1 G0 \
    - X8 U6 y; q6 ]# \
    非常感谢你的热心回答!正如你想的一样,是文件夹有中文名导至不成功的.' `8 y& B. p  _" Y
     楼主| 发表于 2015-3-9 11:26 | 只看该作者
      W- j- W0 A1 B! `. _( i
    dzkcool 发表于 2015-3-7 08:48. w6 E& E$ G) ^" F$ [! C
    关键的问题在这:
    2 ~6 O  z/ C. Y" b. W7 m& s1 a; `E- Cannot open script file; 'C:/Documents.scr' does notexist.
    . x- ]/ ~) @' J1 w; v- w
    , X% q7 U7 {4 J1 z- f2 f4 |" B可惜我还是没转成功.+ m: i% U5 A- y" }. [( x: P( k
    我执行完skill load "dfl_main.il" 还是会有警告!内容如下,我没管,又执行 main out .3 {- w4 A: {" {$ Z2 W. a4 n1 C
    3 k+ h; K5 K1 z' t6 c4 tfunction createAll2ExpFileHeader redefined3 m& V8 e. B7 V/ _5 g0 U
    function fillinAll2ExpBaseview redefined6 W! L! w+ P6 D. ?9 t
    function createAll2ExpBaseview redefined7 x$ Z4 J( @, o8 T5 E, M( r
    W- *WARNING* defstruct: Redefining Structure DC_sControlVars.
    : L( e% O& L$ d* V8 P8 ?W- *WARNING* defstruct: Redefining Structure DC_sPackage.
    / y& \  E0 M& i0 V- o1 eW- *WARNING* defstruct: Redefining Structure DC_sText.
    1 X! v5 z* u. X4 K8 ?& Y9 n3 i( J& FW- *WARNING* defstruct: Redefining Structure DC_sClearance.. r% a' F1 E6 Y0 ]( H- M* W
    W- *WARNING* defstruct: Redefining Structure DC_sDefClearance.% e6 c2 S# H. s6 Q' l% v1 I
    ; |5 \! a% t) l' s6 ?: \W- *WARNING* defstruct: Redefining Structure DC_sNetData.
    " w, M' B( t9 E) o9 Z: z/ ]W- *WARNING* defstruct: Redefining Structure DC_sElectricalRule.
    & T( H( m' a8 v. _9 _W- *WARNING* defstruct: Redefining Structure DC_sMatchedDelayRule.
    : `' @- o9 \# f0 p$ K4 s+ ^W- *WARNING* defstruct: Redefining Structure DC_sRuleArea.
    . |0 i8 a/ \- ~( qW- *WARNING* defstruct: Redefining Structure DC_sFormula.  W9 X7 H& V, i1 ]! o
    W- *WARNING* defstruct: Redefining Structure DC_netPinData.
    % R/ d% q: ]; Q, B* E) kW- *WARNING* defstruct: Redefining Structure DC_netKeyData.0 L  F1 t$ T5 O  X+ G0 p% P
    W- *WARNING* defstruct: Redefining Structure DC_sSymbolProps.
    9 M" ^( c. o, B3 x6 It* H, E; y7 U9 @6 Y
    我执行完 main out 后内容如下,我不知道这样是不是算成功了?+ r! y7 R* c- s! C. e5 d& ]
    Current Symbol: C_DIP_1000X0750_3PIN
    1 p3 u: h% B# @5 q( C; Q7 kCurrent Symbol: RJ45_PLC) Z. Y5 o! B! `- a+ e- c+ L
    Current Symbol: HOLE_320
    * N+ u9 g  u% r8 [4 M4 UCurrent Symbol: JACK_450X100_2PIN& {( {) k/ d+ o4 f
    Removing temporarily added symbols.$ t! b! B+ q# ]4 n
    37 symbols removed.. c" L* i3 q; e3 c' b
    ---------------------- Al2Exp summary ----------------------! B( J7 x* ^' E) I: A- ?9 _
    Al2Exp - 95 error(s), 20 warning(s)6 X$ W, q8 }+ ^# }1 x/ e+ o
    Export log file saved at "C:/aaa/kp201_Rev1.2_130806_MGC\LogFiles\interfacelog.txt" file( _/ W5 ^$ x  y# L
    " ~; _  E% T& `. S( c5 p' S------------------------------ Done -------------------------------
    ; V) \8 f  s! X8 Y3 m& TCommand >
    8 f- @( F- J) w8 L! i4 ~2 _$ I1 C: d3 {# O0 d! G7 G
    完成后会生成如下6个文件. LayoutDB.pcb 这个文件用PADS9.5直接打不开. 我的ALLEGRO软件有16.6 和16.3的软件.我是在16.3里面执行命令的.- }: @5 G* Q$ c1 t* J  u0 {
    7 w7 e% R  v3 m8 t+ C! F, \) O0 v- X3 Z, y
    我用PADS的Translator工具Allegro DesignsTranslators   直接打开用来转换的allegro16.3 文件.
    * Z8 o! M# P8 ]2 T* U
    8 n2 y! E5 g, ?+ ~$ M弹出如下错误.# j' [1 p1 [) K0 v& n1 I
    ; o* `2 E7 g+ W) s$ j# N2 O8 g
    6 s% u/ t7 C$ i* I我现在是不能确定那里出错了.在次救教.谢谢!!!
    1 o' j* u' ]. d$ l; b: S: m% p1 l! p9 E: ^, g6 l( Z
    2 w4 z! S. Q7 @: h4 l: x0 e  [! m! f( W2 p
    1 Y% M" U0 G  H( i. i, g+ ~1 z; a5 i3 v
    2 D* Y! m$ l: P" n, c
    1 R4 l- y5 F5 p, W. [3 p6 z/ I4 S3 s4 K6 r
    " T# Y- `& o+ D3 Q- t
    9 }) u* o& u7 C1 K) B6 \! v% F5 t; A8 K6 Y* a0 L
    ) H9 T3 [; R( ~7 Z
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2015-3-9 11:34 | 只看该作者
    问题在这:: U3 t. T, }' |" Z* N& G
    Al2Exp - 95 error(s), 20 warning(s)$ {, o5 g7 S4 j. x0 \3 H
    Export log file saved at "C:/aaa/kp201_Rev1.2_130806_MGC\LogFiles\interfacelog.txt" file/ B- P% u6 ~4 T% I
    7 R' m! p5 U* `; U$ Q0 [& O$ Z你去打开interfacelog.txt这个文件看看里面的信息,所有error必须解决,warning尽量解决。
    唉,不整了,没那么多时间去弄. 这种方法可行性不高,把那些个错误解决,这个板子还能转成什么样?还是谢谢你,谢谢你的热心!希望这个问题对坛子里的兄弟姐妹有帮助.  详情 回复 发表于 2015-3-9 13:34
     楼主| 发表于 2015-3-9 13:27 | 只看该作者
    错误内容如下.
    - ]& O! ?  a# N8 vERROR: Techfile conversion failed!
    7 G- z$ D+ [! r8 ^1 W% ?" `% E+ qWARNING:  No route border found, bounding box used!! u; j! ?% [1 v" s( I0 {
    4 X6 `4 \! @. H" sWARNING: layer TOP not found in layer table.  Check the Allegro cross-section!
    $ X# b9 ~. A2 f! r9 ]6 U' M$ sWARNING: layer BOTTOM not found in layer table.  Check the Allegro cross-section!  t! L! i2 ?# I% X8 W5 B7 ~! y
    WARNING: layer SOLDERMASK_TOP not found in layer table.  Check the Allegro cross-section!' X/ i( R1 `7 C4 y( E$ `. T* [
    WARNING: layer SOLDERMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!7 m, O' z4 r; N# X4 y2 i6 [
    WARNING: layer PASTEMASK_TOP not found in layer table.  Check the Allegro cross-section!9 j" A# G4 D3 ?/ D
    WARNING: layer PASTEMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!' o' n. @; J: e
    $ I0 T! [+ V( D# G- A0 cWARNING: layer FILMMASKBOTTOM not found in layer table.  Check the Allegro cross-section!
    ) l* ^3 O  q( S" x2 nERROR: Unable to issue shapes for padstack PAD60SQ36D - layer problems
    ! e# z2 s4 p2 D+ [+ YERROR: Unable to issue shapes for padstack PAD60CIR36D - layer problems
    ! C2 L# J5 z# y5 w& V0 y! yERROR: Unable to issue shapes for padstack PAD93CIR58D - layer problems
    1 p% ^. c- q! U1 t. q8 F3 K8 NERROR: Unable to issue shapes for padstack SMDR61X56 - layer problems
    $ @1 [) e4 k* J! [' ZERROR: Unable to issue shapes for padstack 60X50 - layer problems
    3 O: N+ g! h+ `+ `) dERROR: Unable to issue shapes for padstack VIA26 - layer problems
    / H4 N, Q8 Z8 u- s' R* e. D5 uERROR: Unable to issue shapes for padstack VIA - layer problems' u4 m* v3 L* a4 a( S. [, R! w
    2 r3 P' C! C1 J& O# S  W: G4 JWARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!
    2 f: j9 b; j8 k8 S: ]" lWARNING: layer ~TSM not found in layer table.  Check the Allegro cross-section!
    8 |* p( S6 j6 NWARNING: layer ~BSM not found in layer table.  Check the Allegro cross-section!/ T" Z- s% t- t  L0 P( N; H* K; ]
    WARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!7 J% P5 R, z& V% Z$ B4 R
    WARNING: layer ~BPM not found in layer table.  Check the Allegro cross-section!/ K- b% G4 R  L. A
    9 _4 N: n' ]. p3 ZWARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!
     楼主| 发表于 2015-3-9 13:34 | 只看该作者
    dzkcool 发表于 2015-3-9 11:34
    & |) w. W; }4 J" I0 O* ^7 E问题在这:8 x9 R$ Z5 g" J4 d7 `* M
    Al2Exp - 95 error(s), 20 warning(s)7 x  _: `  m' |$ b
    Export log file saved at "C:/aaa/kp201_Rev1.2_13080 ...
    - m) R. ?3 N) f$ m唉,不整了,没那么多时间去弄.
    $ Z! `1 Q$ j8 Z6 c6 p这种方法可行性不高,把那些个错误解决,这个板子还能转成什么样?还是谢谢你,谢谢你的热心!希望这个问题对坛子里的兄弟姐妹有帮助.
    - T, e8 Z( o: ~& H
    我也没整成功 转换出来的板子线都没有了  详情 回复 发表于 2015-4-25 13:16
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2015-3-9 17:36 | 只看该作者
    如果把板子上的东西按照转换程序的要求做好的话,转起来还是很快的。
    版主,请问转换程序的要求是要做成什么样的,能否提醒一下,我也遇到同样的问题了,感谢  详情 回复 发表于 2019-3-27 17:39
    13#
    发表于 2015-3-9 18:09 | 只看该作者
    我allegro转PADS就是用这种方法转的!
    14#
    发表于 2015-3-9 18:12 | 只看该作者
    你把你的系统变量的AEX_BIN_ROOT改成AEX_BIN_ROOT=%SDD_HOME%\translators\win32\bin,试试
    谢谢回答,这个我也试过了,也是不行。改天有时间我再试。  详情 回复 发表于 2015-3-12 21:04
    15#
     楼主| 发表于 2015-3-12 21:04 | 只看该作者
    yangyang1989 发表于 2015-3-9 18:12/ Q* `. ?4 ?4 Q$ m! D
    + {* f9 d  f- h/ z0 K0 @3 y谢谢回答,这个我也试过了,也是不行。改天有时间我再试。0 d2 J) o- Q( T0 X- M$ A  `! Q& |
    16#
    发表于 2015-4-25 13:16 | 只看该作者
    NIWO99 发表于 2015-3-9 13:34
    , Y  Y$ X, O' ^7 H) C& R* i唉,不整了,没那么多时间去弄.: b; v% i$ S5 j
    这种方法可行性不高,把那些个错误解决,这个板子还能转成什么样?还是谢 ...
    % k7 a" U& z$ B! Z4 ]8 G. I" v
    我也没整成功 转换出来的板子线都没有了
    17#
    发表于 2015-5-28 14:02 | 只看该作者
    : Z) M! d: g' T6 h: h' c5 S
    5 I5 G3 `: z' ^. B2 l4 }楼主,我的提示如图而且我的PCBENV文件路径不对。如图2所示
    6 D& a' w  b: p" m  f( O
    18#
    发表于 2015-9-8 15:57 | 只看该作者
    我的也是不能导啊,不知什么回事
    2 u1 k3 H8 d$ V. |/ U. g! e! x
    GMT+8, 2025-11-2 12:51 , Processed in 0.218750 second(s), 36 queries , Gzip On.
