查看: 603|回复: 0
TimeQuest_User_Guide
发表于 2015-1-6 10:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ction 1: Getting Started
. H- ~- z( j/ F' m: ~) t' w& k
* g/ [/ ]8 i; s: Q# ?3 K) w          This first section is meant to get a user up and running as quickly as possible.  It touches
; ?3 ~- I0 v$ Son multiple topics that are detailed later, and is meant for application and a quick understanding.
7 L% P2 Z2 X; J6 Z  T1 v5 IThat being said, I think all users should look through this section and make sure they understand
$ P; |1 ^4 {6 [: S4 T- Q' Fit.  5 ~/ c( ~6 t" F6 A. k5 I$ C. L
          The last portion of Getting Started covers analyzing results, which is an integral part of
% ~- D* {( ?0 v& |! sentering constraints.  One can't enter core timing or I/O constraints without being able to read the  + b/ b9 I8 Z4 [9 J
analysis reports, so it is recommended to read that section in conjunction with the information at  3 W! U: Q/ ]: p* l& O; n; j# O
the beginning.
6 T, R5 R, j, a6 ]% @
, @7 e4 }: U+ m& i" ?9 hQuartus Setup
! v& P$ i! H6 ~$ e& y  U          Within Quartus, there are a number of quick steps for setting up your design with  , p, P8 E9 x1 L0 W8 w5 _
TimeQuest.  These are accessed through the pull-down menu Assignments -> Settings:
& v' g  r' c) L' B, J& g% C1 e
8 B' o: P5 V2 n: c2 h- X
" B$ v$ T; ]+ A$ U$ }$ x0 i  n3 [: N4 B4 x, n
1)  Along the left panel, select Timing Analysis Settings and select the "Use TimeQuest…" radio  , C+ |2 q0 @/ g/ ]- ]* ?- {$ a4 ~
button.  The Classic Timing Analyzer is the old timing analysis engine, which is not
( r( C$ J$ T+ z) C; @: _& ?& t; mrecommended for any new designs or architectures, and will eventually become obsolete.
5 e/ D% S; c6 Z& b9 C, i8 j7 f
; f6 B6 C6 R$ L2 d$ q2)  Select TimeQuest Timing Analyzer in the left panel.  The screenshot should look like below,  8 q9 C( j; R' E  t  w
whereby the user can add a new SDC file.  SDC stands for Synopsys Design Constraint, which is  ) q0 Z% l4 l+ c; W% N, G& X0 z
the format TimeQuest uses, along with many other tools.  If no .sdc file exists, we will create it
5 S7 y8 ^  M' g  q* zin the next section.  Note that SDC files are analyzed in the order listed, top to bottom.
2 E- G9 P& @. W, ^7 R6 @. i
& |1 m. ]/ c3 F; u
2 `, q* s5 |4 R5 f  Y
TimeQuest_User_Guide.pdf
3.77 MB, 下载次数: 2, 下载积分: 威望 -5
GMT+8, 2025-10-31 10:54 , Processed in 0.140625 second(s), 27 queries , Gzip On.
