原理图封装后报了两个ERROR,然后修改,再次编译、封装,两个ERROR没有了。在对PCB进行前向标志时显示未成功,查看“Forward Annotation.txt”文件,里面显示如下红字所述,和原理图封装报的错一样,明明改过了,怎么还是有呢?" j2 g" D: A, c7 a, ^9 X
, i& B# v0 U9 i9 E+ H n" O, PERROR Block TOP!POWER9 Page 3, Symbol XCMP2352: The required symbol is not in the Parts DataBase.
# Z0 h- A9 Q+ ?7 E# ^0 p" P This is a MVT040 symbol; Z! i- W( {6 B& q
with a reference designator U73
, E( A6 V4 y" p* s5 ~9 y plus a QFN19-13.46x33.02mm Part label and a MDT040A0 Part name
3 k A0 n& e p" d using Part number MDT040A0.
) H( {. E+ d, n# b' F* G u: U
8 X: H. \( {; ~4 o1 h5 T1 f; b/ G1 A! v5 H( Y
ERROR Block TOP!POWER9 Page 3, Symbol XCMP2351: The required symbol is not in the Parts DataBase.
2 B9 C0 Y" Y# y5 y This is a MVT040 symbol9 B2 W3 H6 h$ r! d0 d
with a reference designator U79! p# m5 L8 k/ D9 x4 h
Z5 m m. {1 e5 ` using Part number MDT040A0.' u+ f" j# M- x- D
' |5 E/ J' L' p) V
) C" a, |3 R/ N- N1 i3 [ 2 packaging errors have been found.
* X1 V" E% K% A. Y* [- B1 U For those errors that only involve the application of wrong
) m" k' ~& W( e- u pin numbers, either repackage the schematic by hand or! Z C8 r" G; f& u) e0 w5 k5 R
simply remove at least one pin number per reference designator# i H6 L9 H: r/ e3 U2 K" K: e: c
to enable automatic packaging when you run this/ V3 G4 P- t$ |2 f7 Y4 a5 d" f
procedure again.# w# o. Y% C* C& | |
. E, E0 B: T$ Z; B' m
: D3 b: m( U2 e7 F
1 N' ]3 [$ A0 x8 N( j# ]3 p' e
! u2 d o' O2 ?) l2 A& r DataBase Load is being terminated with 2 errors and 4197 warnings.( [' m+ t# m/ ?9 M) k/ F4 s. P
Logic Data has NOT been Compiled.
9 Y# c6 a" }8 l5 n) u; |
0 i) D, x) X j3 R- `2 X |
