EDA365»¶ÓÄúµÇ¼£¡
ÄúÐèÒª µÇ¼ ²Å¿ÉÒÔÏÂÔØ»ò²é¿´£¬Ã»ÓÐÕʺţ¿×¢²á
¸üÐÂÄÚÈÝ£º; l" U; `% I7 l5 z3 q
DATE: 03-29-2013 HOTFIX VERSION: 0063 a$ U$ o2 P4 A6 z0 O
5 O% S5 K' o! CCCRID PRODUCT PRODUCTLEVEL2 TITLE% A0 m8 t& ?- n( \7 ^$ [# ]
$ ]( Z" C8 w! i% ?/ ?' ]3 Q110139 FIRST_ENCOUNTE GUI Error in Save OA Design form% x, a% n) q! ^" y! d9 O/ K! Q
625821 concept_HDL CORE publishpdf from command line doen not work if temp directory does not exist.
0 c' U0 {4 _3 P! d, W* l642837 Pspice SIMULATOR Option to disable Bias Points when Primary Analysis in Active Simulation Profile is DC Sweep$ @ n# ? C& a9 k: D. _$ X
650578 allegro_EDITOR SHAPE Allegro should do void only selected Shape without "Update Shape".
9 _+ x( B4 B/ E/ h653835 ALLEGRO_EDITOR MANUFACT Double character drill code overlaps with "cross" in NC drill legend
4 z: R& D& I y/ F/ k- ?687170 SIP_LAYOUT DRC_CONSTRAINTS Shape to Route Keepout spacing DRC display incorrect
$ Y. W. \" B4 V5 S9 Z; p8 A$ W, q' n787041 FSP DE-HDL_SCHEMATIC FSP Refdes inconsistency when gen schematics) Z9 G7 l- Y/ s N8 A
825813 CONCEPT_HDL CORE HDL crashes when copying a property from one H block to other e: w6 ?' I7 y5 Z9 A& ~
834211 ALLEGRO_EDITOR SHAPE Constant tweaking of shape oversize values is time consuming! z7 Q/ e/ s. n& e' N
835944 ALLEGRO_EDITOR OTHER Customer want to change for Jumper symbol by other Alt symbol.
' O% B7 e2 v/ }8 m868981 SCM SETUP SCM responds slow when trying to browse signal integrity
$ W* D. W! I0 d: s871899 CONCEPT_HDL CORE 'Multiple:' column of Grid window in DE-HDL option is too wide( J) F% Q$ P% x1 k1 h9 W( ~
873917 CONCEPT_HDL CORE Markers dialog is not refreshed! Q- W$ Y z0 ~# x- e3 B: V' {
887887 CONCEPT_HDL CORE Option to find unconnected Pins/Nets with DEHDL L License
' ~9 [9 d( M+ P$ O. w8 |888290 APD DIE_GENERATOR Die Generation Improvement
* Z) I1 y' v6 Y- W/ Y892857 CONCEPT_HDL CORE packager treats R? as a unique reference designator
3 M) W& k9 b/ q) C902908 PSPICE SIMULATOR Support of CSHUNT Option in Pspice
* J3 |% Z6 g+ h+ i# ?* ]908254 ALLEGRO_EDITOR INTERACTIV Enhancement request for DRC marker to have a link to CM
& H5 r. o) o% }: Q6 b" a0 v/ i- s922422 CAPTURE NETLIST_ALLEGRO Netlist errors when using mix of convert and normal symbols5 S$ s" o0 N6 f* D( X
923361 ALLEGRO_EDITOR INTERACTIV Stop writting PATH variables in env file if no modifications are done using User Preferences6 _* ?9 p7 Q; {2 L6 q3 A
935155 CAPTURE DRC No any warning messages listed in the On line DRC window even executed "Check & Save" to on line DRC3 G% W R& K4 C- _
945393 FSP OTHER group contigous pin support enhancement
5 q0 \$ V' Z3 p6 ?969342 ALLEGRO_EDITOR DATABASE Enhanced password security for Allegro database/ k" K/ Y; f9 |/ h) V/ q. }
1005078 CAPTURE ANNOTATE Copy paste operation does not fill the missing refdes3 [4 l# o& }( ?0 B3 @% I
1005812 F2B BOM bomhdl fails on bigger SCM Projects
( E$ m- \5 c$ e9 F; w1010988 CAPTURE OPTIONS ENH: ADD ISO 8601 Date Time format to Capture
7 |3 D' u3 e9 z6 h3 o& M5 V1011325 ALLEGRO_EDITOR PLACEMENT Placement replication creates modules with duplicate names5 v# C Y0 J: x( M+ z, h
1016640 ALLEGRO_EDITOR PLACEMENT Error/Warning Message for not finding or unmatched mechanical symbol or fiducials or which are not on a net
+ [+ `2 l; R6 P1018756 CONCEPT_HDL CONSTRAINT_MGR Match Groups with Pin Pairs are not getting imported into the schematic CM during Import Physical
; e9 x* X* n7 q6 W$ u2 X1032387 FSP OTHER Pointer to set Mapping file for project based library.
) _6 J- g# F! ^3 K- B9 ?- I5 k1032609 FSP IMPORT_CONSTRAIN Import qsf into FSP fails with ¿PLL PLL_3 does not exist in device instance�
$ j* ?4 X, S, G. F3 b8 j1040678 ALLEGRO_EDITOR MANUFACT Text spacing is inconsistant for top and bottom SM layer in xsection chart
0 U2 H$ e7 E S" Y3 u1 r1042025 APD WIREBOND Order placement of power rings for power/ground rings generation with using PeRForm Auto Bonding
0 B: b( V0 s! [; n. v' D( N; f1045500 CONCEPT_HDL CORE Why Search results does not display the correct Physical Pages.
* A2 }' [/ d/ I t( `. e9 x5 D; w( k1047259 CIS EXPLORER Sorting in CIS Explorer is not Numeric even for columns which are of Numeric data type
; |) i( s# e6 E5 \' e0 C1047756 CAPTURE NETLISTS Not adding user defined properties in netlist generated by orDump.dll8 H0 e- c9 m; |7 y# q9 F" y: g
1052455 RF_PCB DISCRETE_LIBX_2A RFPCB IFF Export to fix port direction for ADS for footprint having the same pin rotation8 m1 T9 U+ i! Z, ~ c' _
1054314 CONCEPT_HDL CORE Zoom of custom text is different from other schematic objects: |) ^ L; }8 w* |* O: J7 E
1061529 CONCEPT_HDL CORE Space can be included in LOCATION value and cannot be checked by checkplus
- Y1 h4 e4 ~4 I+ t/ O1064035 CONCEPT_HDL COMP_BROWSER Component Browser crashes on part number search using a library containing >23K parts6 j- h' {5 B0 p9 h4 ~2 w8 V
1064604 ALLEGRO_EDITOR MANUFACT Enh - Include ability to add slot notes to designs4 s* e) o' O+ S/ n
1065636 CONCEPT_HDL OTHER Text not visible in published pdf
1 m9 Z9 r/ |- t) z8 C$ G1065843 CIS PART_MANAGER time stamp on library from different time zones triggers part manager lib out of date warnings- w/ _ j5 E7 E7 A
1066701 ALLEGRO_EDITOR OTHER Missing padstack warnings not in Symbol refresh log summary5 {3 i2 t" ?% K; N% i" y
1067283 SCM PACKAGER ALLOW_CONN_SWAP does not work for lower level schematic parts
4 m2 x p. o0 n' o0 _4 j- L# B; T# Q1067400 CONCEPT_HDL CORE ERROR(SPCOCD-171): Port exists in symbol but not in the schematic0 J2 A M5 l. r! ~/ W9 ]0 g7 z
1068878 CONCEPT_HDL CORE Rotating symbol causes the pin name to be upside down+ G+ R( M2 r: X- z2 _- G
1069896 ALLEGRO_EDITOR EDIT_ETCH Cline changes to arc when routing even when Line lock is set to Line 45, }9 q X: x- {! O b
1070465 CONCEPT_HDL CORE Why does ConceptHDL crash on renaming a Port Signal+ K. J: |2 y# A; E4 g
1071037 PSPICE SIMULATOR Provide option to disable Index Files Time Stamp Check# P' _. p. J5 t! ^
1072311 CONCEPT_HDL OTHER Schematics are incorrect after importing design.
8 K/ _6 ?0 d( S* O6 l7 E* {+ q1 A1072691 CONCEPT_HDL CORE Customer has the crash from Run Script of DE-HDL 16.51 again(#3)
$ C% G+ Q8 \5 ^" y) ]1072859 SIP_LAYOUT DIE_EDITOR padstack selection window crash from Die Editing: Component editing of Co-Design Die
# c8 @4 ?, n' R, O w! L l1073354 CONCEPT_HDL CORE Bubble defined on symbol pin is not visible on the schematic
! s& ]% M. R6 n; y1 q1 S3 ?1073837 ALLEGRO_EDITOR GRAPHICS Some objects disappear on ZoomIn ZoomOut
# T; ?1 }6 g! m$ g( p; F* ?# E1074243 ALLEGRO_EDITOR GRAPHICS Allegro WorldView window does not always refresh after dehighlight of objects- o+ g$ c9 u+ b4 o Q
1074606 ALLEGRO_EDITOR INTERACTIV Enh - Cosmetic change in Filter Option UI of Replace padstack to indicate multiple pin entry format
' m! A: g/ F1 w0 P! |1074794 ALLEGRO_EDITOR REPORTS add commonly reguested via reports to Allegro and ICP reports. Via per net, via per layer per net) |& r$ f7 d/ O0 m1 ]8 g- j' i* c
1075587 CONCEPT_HDL PAGE_MGMT Unable to insert page in schematic: G6 ~/ F$ A& o
1076117 PSPICE PROBE Copy & Paste text/label in probe window changes font size and later gets invisible* U5 I6 e- v# e$ b, p- x" ?3 [
1076145 SIP_LAYOUT DIE_ABSTRACT_IF Issue message in Add Codesign and Refresh Die Abstract if Pin Numbers from Die Abstract exceed 31 chars.* D5 s6 D0 O4 B) ]- ?% a
1076566 ALLEGRO_EDITOR EDIT_ETCH Sliding diff pair cline that has a min/max prop rule displays the HUD meter inconsistently.
# D* {2 ^- o8 }" l/ @7 Q/ j4 x1076604 ALLEGRO_EDITOR SHAPE Sliding via in pad corrupts surrounding shape and generates false DRC Errors7 Z0 q$ z9 p, y+ R( d
1076820 SPECCTRA FANOUT Fanout fails to stack vias in bga pads.
g9 p& Q0 s5 f; j% g1076868 ALLEGRO_EDITOR PARTITION Symbols become 'read only' inside a design partition/ n8 k/ S6 r, A' Q$ z
1076879 GRE IFP_INTERACTIVE Plan Column should not be present in Visibility tab for Symbol Editor
8 j% L8 y! U3 H8 O. o: u' g1076898 CONCEPT_HDL CORE User can not increase logic grid size value continuously using Up button on Design Entry HDL Options' E8 Q7 V3 U( p. l) ?( l* y+ F, d# |, s
1077026 CIS LINK_DATABASE_PA fonts changes while linking db part in 16.5
8 z" |& u1 M0 M k. x/ S8 a1077187 ALLEGRO_EDITOR DATABASE DBDoctor appears to fix database but nothing is listed in the log file.
1 v6 U- t) H4 u8 f6 C1077527 CONCEPT_HDL CORE ConceptHDL net with name U cannot be found using Global navigate* f5 ~# Q8 Q8 p/ W1 Q$ _5 G
1077621 CONCEPT_HDL CORE DEHDL crashes when saving page 3
2 |6 n f6 @/ S% d5 D/ |' r; @1078270 SCM UI Physical net is not unique or not valid
% ~8 _, B7 W7 [ |1079616 CONSTRAINT_MGR CONCEPT_HDL Packager error in 16.5 which is resolved when system is re-booted3 r2 i. G0 @# K, R
1079821 CONCEPT_HDL CORE Project Setup does not respect $TEMP variable for temp_dir and creates a directory in project calle% { `5 _. ?% [) R9 L
1080142 CIS CONFIGURATION peated entries in Allowed Part Ref Prefs
. J% O3 L2 ?2 x0 C q8 m1080207 ALLEGRO_EDITOR INTERACTIV Separate the 2 types of SOV violations."Segments over voids & Segments with missing plane coverage". J8 n# n, n/ ]6 `6 c2 L) _
1080261 PSPICE SIMULATOR Encryption support for lines longer than 125 characters
" e6 p/ W" \( I1080336 CONCEPT_HDL CORE Backannotation error message ehnancement
( [, y2 O7 J1 L% {, r* j, O1081001 ALLEGRO_EDITOR PLACEMENT Package boundary is not visible while manually placing a component when using orcad license4 D+ s! c7 O$ ^7 G- L8 ^. }
1081237 ALLEGRO_EDITOR PLACEMENT Place replicate > apply does not apply component pin properties stored in .mdd4 J$ V0 [# d3 S+ ]
1081284 MODEL_INTEGRIT TRANSLATION Space in the file path will create a bogus error( d! u% u; I: n- m3 l8 ~0 P9 U9 m
1081346 ALLEGRO_EDITOR INTERACTIV With Place manual, rotation of the symbol is not updated.1 R: ~/ @5 E6 H' \/ _% d$ M4 g! {
1081760 FSP CONFIG_SETTINGS Content of ¿FPGA Input/Output Onchip termination� columns resets after update csv command# z' Z8 W! [* t, f2 F
1082220 FLOWS OTHER Error SPCOCV-353
- |8 o2 C. _8 i0 U1082492 ALLEGRO_EDITOR PLACEMENT Place replicate create does not highlight symbols.& M7 z8 r- |1 M( @$ p J: K
1082676 ALLEGRO_EDITOR EDIT_ETCH HUD meter doesnot display while sliding / add command3 c4 V) Q$ c% \* K. K( r7 Q5 a
1082737 CAPTURE GENERAL The ¿Area select� icon shows wrong icon in Capture canvas.0 P* U. {/ j8 m
1082739 CAPTURE OTHER The product choices dialogue box shows incorrect name
, Q7 ^ u5 q) ], v7 i: }& O8 h: Q1082785 CONCEPT_HDL CORE DE HDL should clean the design with non sync properties in some automated way( l( m) H6 A( M5 E; l! [* z5 _
1083761 CONCEPT_HDL OTHER AGND text missing from PDF Publisher
' D! f# V5 |% p" ]1083964 CONCEPT_HDL OTHER Do not display Value and other attributes on variant parts which are DNI8 m" g6 S% x, [( J& S1 s9 X: {) X+ S
1084023 PSPICE MODELEDITOR Model Editor is slow/unresponsive while opening a Model by double-clicking on .lib file
# h( k- }+ |9 |" O5 S, h. J' A1084178 ALLEGRO_EDITOR SHAPE Spike create on dynamic void.
0 i; H* I) B8 P# y1084637 ALLEGRO_EDITOR INTERACTIV Enhancement: Pick dialog should automatically be set to enter coordinates
9 R4 Q! S- [7 B( B' H0 o7 E9 T% ?, i1085010 CONCEPT_HDL CREFER Crefer crashes if the property value in the dcf file has more than 255 characters
2 ?" E' J' O- p" Y$ T& X" D1085347 CAPTURE SCHEMATIC_EDITOR Replace cache results is loss of net graphic changes.
7 o2 S0 r' ?; d. z8 F1085522 ALLEGRO_EDITOR INTERACTIV Allegro add angle to Display->Measure results1 J. `* l" n2 Z( A* h" V
1085791 CONCEPT_HDL CORE Publish PDF can not output Constraint Manager properties into PDF file./ |4 N f- @4 O8 {
1085891 ALLEGRO_EDITOR INTERACTIV about DRC update
9 }- ^% K E' k1085990 CAPTURE DRC B1: "ERROR(ORCAP-2207) Check Bus Width Mismatch" should be INFO
- K: C! d; Y8 k1086514 CONCEPT_HDL COMP_BROWSER Component Browser placement restrictions not working% |9 Z, Z" r$ j5 Q! W$ G
1086576 CONCEPT_HDL CHECKPLUS CheckPlus hangs when running Graphic rules./ M6 W" ^. i* C- W
1086671 PSPICE SIMULATOR SPB16.6 pspice crashes with attached design4 [% X8 Z1 _4 ?% v6 B
1086749 ALLEGRO_EDITOR mentor mbs2brd: DEFAULT_NET_TYPE rule is not translated
4 K# z5 S0 J0 i% x( D1086886 CAPTURE PROPERTY_EDITOR "Is No Connect" check box in property editor doesn't work for power pins& p3 W1 m$ ?3 |4 a8 ~, t
1086902 CONCEPT_HDL INFRA Problems occurred while loading design connectivity! r( p/ V6 ~& N- c
1086937 PSPICE ENVIRONMENT PSpice Color map getting doubled leading to crash after colors are modified number of times.
% w. S# `8 E' h2 N% t1087221 CONCEPT_HDL OTHER Part manager could not update any parts.3 U: z/ `, M( h
1087223 CAPTURE CROSSREF Cross Probing issue when login into system with user name containing white space3 N& K6 Y! ]! f7 G! l
1087295 SIP_LAYOUT EXPORT_DATA Enable "Package Overlay File for IC" for concurrent co-design dies too# [1 F9 b& h( \3 W( H
1087658 CAPTURE PRINT/PLOT/OUTPU Lower level design pages are getting print twice( x m' h# _9 ~2 Y( V
1088231 F2B PACKAGERXL Design fails to package in 16.5
# t5 N Y) R3 L8 ^4 I1088252 CONCEPT_HDL CORE Menu commands grayed out after Save (with 16.5-s035) when launched from ASA.! h4 j" V7 M+ I F
1088606 ALLEGRO_EDITOR INTERACTIV Pin Number field do not support Pin Range for Symbol Editor! y- Z; V+ Y1 L+ {4 S% W
1088983 CONSTRAINT_MGR CONCEPT_HDL Units resolution changed in 16.6 Constraint Manager* z, C0 j# ^ ^! l7 q$ W
1089017 ALLEGRO_EDITOR SHAPE What is the cause of the shape not filling?
' f2 d. j+ f1 @+ t6 j& W1089259 SCM IMPORTS Cannot import block into ASA design
7 h& I' t4 m$ |. D( r# x& _1089356 SIP_LAYOUT DIE_EDITOR Distributed co-design : launching die editor taking more than an hour to bring up edit form O- @# R. x, d# k! v
1089362 PSPICE STABILITY Pspice crash on pspice > view simulation result on attached project
8 R3 v% M4 I2 I* v# |* P: p1089368 SCM OTHER Can't do Save - cp: cannot stat ... No such file or directory W3 I$ K" K+ A' t8 z* ?
1089605 CONCEPT_HDL CONSTRAINT_MGR Power net missing from the CM opened from DEHDL Schematic editor.6 @4 e: B! H: X9 L6 A7 o6 l* _+ G
1090068 ALLEGRO_EDITOR SHAPE shape priority issue in SPB165- Y$ u+ ~3 y9 \& `- W5 M' _- y
1090125 ALLEGRO_EDITOR DATABASE Q- The rename resequence log file is not giving correct message.
6 ~* K# u k8 ^1090181 GRE CORE AiDT fails for the nets with errors SPGRE-21 & SPGRE-225 q( x% ^3 H2 b$ E
1090930 CONSTRAINT_MGR CONCEPT_HDL DEHDL-CM does not retain customized worksheet.2 M3 }9 d6 g# q/ g$ \; y$ Q- S3 b; Y
1091335 CONCEPT_HDL OTHER Color change cannot remain in some situation.
! J' {! R; ?, D8 X0 e1091347 CAPTURE TCL_INTERFACE The Project New link on Start Page doesn't work when Journaling is enabled
% c* {* i; z: d: @- B1091359 CAPTURE GENERAL Toolbar Customization missing description
* _6 P7 t& d& K3 R$ E3 c8 w4 Z1091662 CONCEPT_HDL CORE Incorrect behavior with the SHOW_PNN_SIGNAME directive
6 X2 M7 p" y# `1 i1091714 CAPTURE PART_EDITOR More than one icons gets selected in part editor at the same time
: s7 e8 E; F, I' v& w1092411 CONSTRAINT_MGR INTERACTIV In v16.6 CM multiple net name selection under net column is not working as in v16.5
2 s- i( t0 H4 ?4 Q/ F- x1092426 CONCEPT_HDL CORE Getting ERROR(SPCOCN-1993) while saving a Hierarchical Design7 ^& R6 y3 R( T) D: l! Q! |
1092874 CONCEPT_HDL CORE DEHDL wire short during move not detected with check enabled0 F' Y; q1 i: Y" {" Q4 z6 r9 Q& j
1092882 ALLEGRO_EDITOR EDIT_ETCH AICC should be removed from orcad PCB Designers design parameters
`, t4 c8 ?2 p& E1092918 CAPTURE GENERATE_PART Generate part functionality gives no/misleading information in sesison log in case of error$ h/ U. O* ^ }' A0 {/ t Q
1092933 CONCEPT_HDL OTHER PDF Publisher saves the pdf generated in the previous project folder
3 Y2 w! p' [5 Q1 d" \" H7 B1093327 CONCEPT_HDL OTHER Getting error SPCODD � 369 Unable to load physical part in variant editor
7 s) h# @8 ~1 K$ |' k1093391 CONSTRAINT_MGR OTHER Setup > Constraints > (domain), doesn't open correct worksheet with OrCAD PCB Editor Professional license.
8 r( Z2 l K5 G9 l+ L% _6 I1093886 SPECCTRA HIGHSPEED Pin delay does not work in PCB Router when specified in time m- Z0 X$ U D g/ x# n
1094223 CAPTURE PROPERTY_EDITOR CTRL+S does not work in Property Editor but RMB > Save.4 u: X3 W( k; A' k; p+ o
1094513 CONCEPT_HDL CORE How to display $PNN for which SIG_NAME is not visible?! D# {# G/ g6 @9 c& M5 f, f+ B* B
1094611 CAPTURE PROPERTY_EDITOR E1: 'Tools->Update Properties' should list parts which are present in .UPD, but not schematic6 ?9 o/ [' B, c& O
1094618 CONCEPT_HDL INFRA Unable to uprev the design in 16.5. ~! l/ S( y2 @! R6 W8 B. A
1094867 CONCEPT_HDL CORE Page Up / Down Keys are hard-coded assigned to Next /Previous Sheet) I" ^3 d- r0 W( R
1095449 SIP_LAYOUT LOGIC Allow netlist-in wizard to work on a co-design die
# Q7 u; x. ]* H: s+ a+ Y1095701 CONCEPT_HDL CORE Replace part in replicated block only preserves the Refdes in 1st instance of the replicated block6 e7 Q4 M* }" n; v$ d# |
1095705 CONCEPT_HDL CREFER Cref_to_list not updated on repl icated blocks in 16.5 release worked fine in 16.3
/ b, i$ P. g2 S6 \1 v6 _- _* N1095861 F2B BOM Using Upper-case Input produces incorrect BOM results
2 q5 \3 @3 h$ ?/ z% f- Z8 T1096318 ALLEGRO_EDITOR INTERFACES IDF import not removing MCAD tagged objects during import
9 u( W1 S8 Z# x) N8 {1097241 CONCEPT_HDL CORE Concepthdl - zoom in to first object in Find result automatically. T4 O7 w8 O( C# X
1097468 ALLEGRO_EDITOR INTERACTIV Need ability to hilight and assign color to vias3 v) s2 h6 p0 t9 @
1097675 CAPTURE ANNOTATE Enhancement:Option to have Incremental reference Update to be checked at all times when we click on Tool>Annotate
/ S1 x F9 { E G1 ~0 t, d1099151 SIG_INTEGRITY SIMULATION All Neighbor crosstalk numbers reported when there are no aggressors; X/ i' r T; p, S
1099175 CONCEPT_HDL CORE CPM directive that enables the Command Console Window in DE-HDL- r3 G4 x3 A9 j
1099838 CAPTURE TCL_INTERFACE TCL library correction utility is not working correctly." E8 ?) {% N$ O# Q; H
1099903 ALLEGRO_EDITOR PLACEMENT Mirror and rotating component places component mirror side, J; @7 Z- o# K! G3 k9 E; j. ?
1099941 ALLEGRO_EDITOR PLACEMENT Problem in rotating bottom components when using Place Manual or place manual -h command
H8 I _8 D h! o( k1099998 CONCEPT_HDL CHECKPLUS CheckPlus marker file not locating signal when signal name includes the # character./ `, v9 F& s2 u3 w! C6 n" m) |
1100018 CONCEPT_HDL COPY_PROJECT CopyProject gives errors about locked directives9 K) {0 r" S0 h: I0 \* b
1100449 ALLEGRO_EDITOR ARTWORK Pad with Net_short property and shorted to shape supressed wrongly with Pad Supression in Artwork
' Q9 A) i4 j- O) D4 Z5 E1100758 CAPTURE LIBRARY Import properties does not update pin numbers of multi section parts a+ U$ i+ S- F) h$ ]( j9 e
1101009 CONCEPT_HDL CORE Cursor stays as arrow after performing File > Save Hierarchy. E. u3 S8 y+ U( B' n7 B
1101497 ALLEGRO_EDITOR UI_FORMS Allegro PCB Editor crashes using attached script when working with RF PCB Clearances.
4 w# u! ^0 u# n9 ]% t1101813 SIP_LAYOUT DIE_ABSTRACT_IF Support die abstract properties
0 ]- K* R1 z* R1102531 ALLEGRO_EDITOR GRAPHICS Allegro graphics distortion infinite cursor 16.6
2 |' ^/ x8 Y$ g! ^* U1102623 ALLEGRO_EDITOR SHAPE Strange void around the pad# x- q, y: I: ~4 t- I% }- r |
1103246 FSP FPGA_SUPPORT New FPGA request - Arria V - 5AGXMA1D6F31 - IN2P3
n. ?" V2 E0 S8 P' e1103631 MODEL_INTEGRIT OTHER Model Integrity license when using orcad" j( v6 D( u" x' \$ f
1103703 F2B DESIGNSYNC Toolcrash with Design Differences6 y0 x3 I9 I# {7 N; Y, g
1103712 CONCEPT_HDL COPY_PROJECT Copy Project crashes on customer design attempting to update symbol view
, m* Q4 O9 g( d( \7 E+ E+ E- P1104068 CAPTURE DRC "Check single node connection" DRC gets reset in 16.6% D i$ F/ q! k2 R/ v3 z0 m. F9 W
1104121 PSPICE AA_OPT ¿Parameter Selection� window not showing all the components : on WinXP( u' q7 ^2 S' E& i" k8 D: _1 X; K
1104575 CONCEPT_HDL CORE Allign does not allign offgrid symbols correctly }5 W) _: w0 \& z( u+ A6 `$ R& t
1104727 CONSTRAINT_MGR SCM Net Group created in sip does not transfer to SCM% F2 e G7 @0 b( z
1105128 CONSTRAINT_MGR DATABASE Import dcf does not clear out user defined schedule.
+ V+ T, b" ~9 N) q1105195 SIP_LAYOUT WIREBOND Request that Tack points default to a "fixed" position after Generate Bond Wires.: s: X6 X# ~3 A; O
1105249 ALLEGRO_EDITOR OTHER PDF out--- component user defined prop doesn't list the prop selection form. R' O2 `5 F) P& t
1105443 PSPICE AA_OPT Parameter selection window in optimizer does not list param part
# J0 i8 I; k' P5 O1105818 ALLEGRO_EDITOR INTERACTIV Menu-items seperators are clickable and menu goes away when clicked
& F; R. S( I# z9 x8 h( Z2 A* E; b1105822 ALLEGRO_EDITOR SCHEM_FTB Netrev failing with compact pin syntax3 n1 I8 [4 e4 ?" f/ V* g
1105993 SIP_LAYOUT LOGIC Import netlist no longer works with co-design die in SiP 16.6) ~( m4 ^5 f% D7 p
1106332 SIP_LAYOUT OTHER sprintf for axlSpreadsheetDefineCell writes characters in upper case only
8 m1 O" P0 j# ^$ Y# j1 Z' w1106786 CAPTURE SCHEMATICS Bug: Pointer snap to grid# s4 V' Z0 |1 c$ p$ H' a8 F4 p
1107132 FSP OTHER Altera ArriaV (5AGXMA5GF31C4) support.7 p! Z1 @; S5 R1 k8 y
1107151 ALLEGRO_EDITOR ARTWORK Shape filling removed when changing artwork format to RS274X in Global Dynamic Param, g# I( l/ C6 k1 S7 a# j' A; B% x1 P6 M
1107237 SIP_LAYOUT WIZARDS Updating a Die using the Die Text In Wizard will error out and not finish- w- d5 Z+ M, Y/ Q0 D: k" C8 W
1107371 ADW COMPONENT_BROWSE ADW preset Warning filter is spelt incorrectly. (Wraning).
( Q: N- h! @1 q- ^+ U6 G1107599 CAPTURE STABILITY Capture 16.6 crash when trying to invoke- l. G: X3 t' J8 y' A& X1 j/ t
1108118 ALLEGRO_EDITOR OTHER PDF Publisher pad rotation messed up with flashed pad.* `! _" h" q; ~6 E+ }
1108574 ADW COMPONENT_BROWSE LifecycleStatus functionality does not work when in Metadata mode. Work correctly in PPT Mode, `; }' _5 U3 I
1109095 SIP_LAYOUT WIREBOND Bondfinger move in hug mode create drcs
5 t+ v1 S0 i4 ~$ Q$ }3 H H1109113 ALLEGRO_EDITOR DATABASE Allegro Netrev crash with SPB 16.6% E, B1 j6 R2 S% d) F* {. j& l
1109622 SIP_LAYOUT DATABASE In a wirebond design, the ratsnests with 'Closest Endpoint' should not point to the die pins.
6 `* M/ Z& ]( U+ o( }; b$ T0 Y3 @1110077 ALLEGRO_EDITOR DRC_CONSTR Duplicate Drill Hole DRC's are not shown for Pins overlapped in same symbol unless "Min metal to metal" DRC is turned ON
* n* }" S7 W P" @6 g9 _1110256 ALLEGRO_EDITOR SHAPE Auto void on dynamic shape is not correct in 16.6$ o" Y6 v! |5 \6 @
1110264 RF_PCB FE_IFF_IMPORT IFF Import in DEHDL has component offset H& T' g4 b# J2 B' v
1111226 ALLEGRO_EDITOR DATABASE Name too long error with Uprev command when output file name exceeds 31 characters
9 ]3 @0 C0 u( w1111234 ALLEGRO_EDITOR MANUFACT Double digit drill character overlaps with figures triangle, hexagon and octagon in NC drill legend, Z4 g* T. `; d8 g
1112431 SIP_LAYOUT COLOR Frequent crash while working with latest version of CDNSIP
$ O" ^5 d2 P* S. x1112493 ALLEGRO_EDITOR DATABASE Customer does not like 16.6 Ratsnest points Closest Endpoint
0 C6 ^ B& [0 q( W' f, x) j1112774 GRE CORE Allegro GRE not able to commit plan after topological plan
% T5 p( Y# v! X1113908 ALLEGRO_EDITOR COLOR Dehilight command fails to remove highlight pattern on a cline, without removing net custom color.
, H* M7 q" `, c3 g% L8 ]1114815 ALLEGRO_EDITOR OTHER Q1: Switchversion error when reading -fa file7 P" X0 A+ p0 |8 n6 D% S
1114994 ALLEGRO_EDITOR DATABASE Getting an error after upreving components to 16.6
$ }' ~; l, T- B3 i# e
2 o5 Z7 G/ j- P3 Z t, B, q; [DATE: 03-7-2013 HOTFIX VERSION: 005
* q* s9 A! M# ]/ m* V0 V4 m, Z' H===================================================================================================================================
. z" c; M( q s, A: KCCRID PRODUCT PRODUCTLEVEL2 TITLE% E: h& ~& `5 t4 ]0 ~1 `5 o
/ d" |4 e k: ~" U I8 E1067770 IXCOM-COMPILE COVERAGE Assertion failed: file ../covToggleCoverageXform.cpp, line 1102" a P4 S& X( P% d+ c
1100442 ALLEGRO_EDITOR PLACEMENT Placement queue shows components whichs are already placed
2 k+ u' P+ n U& R4 x: p. u3 R7 n" v4 f1101555 ALLEGRO_EDITOR DATABASE Allegro Crash frequently- r, d9 C* {4 D E. e" S% v) J% ?
1104011 ALLEGRO_EDITOR DATABASE Place replicate move group of a modules leaves traces behind
* [+ F/ e0 p& L, x0 U/ Z% H1104065 SCM NETLISTER SCM 16.6 has problem generating Verilog with existing sym_1 view
; ^! m2 T7 T8 J0 I$ F6 P# e# q- `1104605 F2B PACKAGERXL Pins of function swapped part in block not displayed
" s* j' @, Q: `3 B- @1104790 SCM IMPORTS Corrupt data once SiP file is imported into SCM
; P0 X, Q4 i" X7 W: n$ U7 x$ k1105066 APD IMPORT_DATA Import NA2 worked in 16.5 "035" but fails in 037 and 16.6# v3 F/ U9 B! d
1106323 ALLEGRO_EDITOR PLACEMENT Unable to locate specific placed symbol on this board as it becomes invisible after placement.8 g3 N, q3 s' D5 D# Y
1108032 CONCEPT_HDL CORE 'Find' option does not list all Components in the Design. `1 ]2 z/ F+ ]: S9 K0 a8 ]" `# g
1109080 ALLEGRO_EDITOR OTHER Window DRC is not working in OrCAD PCB Editor Professional- D" D0 q) w l9 z' s
2 L# r) R& Z* h; M2 b. h* tDATE: 02-22-2013 HOTFIX VERSION: 004
/ V2 t% ^5 G' f/ B7 g! T===================================================================================================================================9 [# b1 w6 E0 x* s; C& p; ^
7 J0 o, X; u- ^8 ^: i===================================================================================================================================
! |/ Z$ F& a% z, S6 s9 ]1081026 ALLEGRO_EDITOR GRAPHICS 3D Viewer do not show the height for the embedded component correctly& Y' z3 x2 p* A/ h$ V# M
1095225 ALLEGRO_EDITOR EDIT_ETCH The Constraint option does not work from right mouse click>Options>Line Width > constraint during interactive routing% `: Q5 k: h9 ]* k0 N- k
1096356 ALLEGRO_EDITOR DATABASE Cannot Analyze a Matched Group in CM I- g& x6 k) h1 p6 n* [9 m& l
1097481 ALLEGRO_EDITOR INTERACTIV Allow replace padstack command in design partition
) p* w- p# z, h& u5 ]- }1098252 ALLEGRO_EDITOR MANUFACT Double digit drill character overlaps with figure "circle" in NC drill legend4 H, b& ]+ K$ }, E1 n
1099958 ALLEGRO_EDITOR PAD_EDITOR Library Drill Report producing an empty report
4 a/ d" J! s' u8 e; I8 P- @1100401 ALLEGRO_EDITOR OTHER Invalid switch message for "m" for a2dxf command
, E% }, C& v v1101026 ALLEGRO_EDITOR OTHER utl_perftune hanging in fpoly_RemoveVerySmallSegments(), causing shape degassing never to exit.1 X& g( s% A" X
1101064 SIP_LAYOUT SHAPE 'Shape force update creates a rat
& g! z& B5 N' V# \: o1102798 SIP_LAYOUT OTHER Stream out puts offset pad in wrong position if pad is mirrored but not rotated.
, K6 z9 v' h4 s" A+ v! I# \4 H) C" d# A. z/ M' D' C
DATE: 02-8-2013 HOTFIX VERSION: 003
; }7 ?9 z8 @# R8 J N$ @* Z; T===================================================================================================================================, y$ D. W* y0 N- L: ^
CCRID PRODUCT PRODUCTLEVEL2 TITLE2 h. d/ g; |' u4 M! p+ a( q
===================================================================================================================================% U# r8 ~! g3 d# l2 ]
1077728 APD EXTRACT Extracta.exe generate the incorrect result
. C/ X% U) Q U1084711 APD DXF_IF Padstacks with offsets cause violations in Export > DXF! Z* r6 h' i% M6 j
1090369 SIG_INTEGRITY LICENSING Impedance value not updating in OrCAD PCB Designer( ?' {" G% B* q+ Y
1093050 ALLEGRO_EDITOR DRC_CONSTR Taper trace on diff pairs not checking to min line spacing.
5 z% z% b5 S4 H- w* J& V5 o1093563 SPECCTRA ROUTE PCB Router crashes with reduce_padstack set to on; B7 K: ], X2 G3 j5 e
1093717 APD DATABASE Design is crashing in Tools > Update DRC and in Dbcheck but seems inconsistent' w" S. a2 H+ H+ F3 B6 F
1094788 SIP_LAYOUT WIREBOND Wirebond edit move command$ g- q. I: d5 I3 u& _9 @
1095786 ALLEGRO_EDITOR DRC_TIMING_CHK Allegro PCB crashes when running DBDoctor4 ]' o$ @* c- I$ F+ H6 c
1096234 ALLEGRO_EDITOR DFA Via pad connected to shape didn¿t show up after ¿Suppress unconnected pads� option.
8 J4 a) q/ R: {( J# h6 S# Q1096313 RF_PCB LIB_TRANSLATOR Allegro Discrete Library to Agilent ADS Translator offsets in the CDNSsymbo.iff: N c1 r" |6 \- Y( u9 h2 Z
1096613 ALLEGRO_EDITOR INTERACTIV Enh-While moving parts silk ref des should remain visible
3 l, @* K; H4 R% ]/ y) I& [* U1096676 CONCEPT_HDL CORE SPB 16.5 HF36 breaks designs that workded fine in HF35
! G9 r ?- g* a$ _! a' V4 D9 W1096913 APD IMPORT_DATA Import > NA2 fails to bring in the Y1 component.3 Y' z7 c. ]) i, g* t! z
1097751 ALLEGRO_EDITOR DATABASE Import CIS netlist crashes.
8 B0 x- T7 C% G5 S( H1097889 ALLEGRO_EDITOR DRC_TIMING_CHK Allegro crashes when routing from a via to a pin using High Speed option license.0 |% p+ ?* h/ }* B: v9 C
$ O7 L; f- Z- Y+ }
DATE: 1-25-2013 HOTFIX VERSION: 002+ ^: s0 f+ g0 k/ G6 V* ]6 c
===================================================================================================================================3 S- ]0 W; o& F+ d2 l
! [5 q3 E# P( y4 I===================================================================================================================================
0 N( }2 b0 u5 s/ T7 _& z! T$ S491042 CONCEPT_HDL SECTION Prevent PackagerXL from changing visibility on SEC attribute
9 ?2 N+ L+ l5 Y( {863928 ALLEGRO_EDITOR INTERACTIV Segment over void higlights false "nets with arc"
^# l: N" D: U/ U# {7 O$ l1067272 PCB_LIBRARIAN CORE Unable to retain the symbol outline changes
" w& b5 m3 X7 m3 Q1074820 ALLEGRO_EDITOR GRAPHICS losing infinite cursor tracking after selecting the add text command with opengl enable
8 K& h0 _5 H Y5 o% N" I1075622 CONCEPT_HDL CORE PDV Edit Symbol in DE-HDL all editing functions disabled since Hotfix 338 \2 z6 P0 p5 Q( I7 @
1076986 APD WIREBOND Wirebond Adjust Min DRC does not maintain the finger position in the same sequence. }- j/ Y t4 r3 a
1078031 SIG_INTEGRITY REPORTS Requesting improvement to progress indicator for report generator4 Y- E7 j8 U0 y9 h7 @
1080213 SIP_LAYOUT WIREBOND Wrong behavior of Redistribute Fingers Command7 E) t7 o" {0 I" d
1080667 ALLEGRO_EDITOR GRAPHICS Allegro lines with fonts not displayed correctly in 16.66 j+ ~5 s8 q% ~- O
1080982 CONCEPT_HDL CORE Crash of Allegro Design Entry during a copy of a note.( x5 q8 J6 P4 \5 X% W+ J* i
1081200 CONSTRAINT_MGR OTHER In the DIFF_PAIR worksheets various Analysis seem to take a long time to complete.
! Z1 l5 ?; t( q2 z1081553 CONCEPT_HDL OTHER Model Assignment can not translate M (Milli-ohm) property value of DE HDL." ?7 ~1 p- v0 e9 ?7 v0 ]. Y. d
1081696 ALLEGRO_EDITOR INTERACTIV Compose shape not working when radius is set to 1.0
8 ~" w5 u( \' R$ s |$ o0 R1082595 ALLEGRO_EDITOR COLOR Infinite cursor remains white even we change background to white( C0 C! F7 b0 ^$ F9 ~1 I6 D
1082704 ALLEGRO_EDITOR GRAPHICS infinite cursor disappears when using Display>Measure A( f$ u/ r! c; c
1082715 SIG_EXPLORER INTERACTIV Single line impedance for BOTTOM Layer is not calculated in cross section upon changing the thickness of dielectic layer
9 P9 q9 w6 J) I. ^- ?1082774 ALLEGRO_EDITOR TECHFILE Import techfile command terminates abnormally when importing a generic techfile.( U% J- O3 _3 u# }, I* j9 r9 U
1082820 CONSTRAINT_MGR UI_FORMS The configure generic cross-section pull downs do not work.
5 x8 n3 M/ _, |/ |/ c+ x: x1083133 SIP_LAYOUT INTERACTIVE SiP will crash when using the beta Pad Rename command to change a BGA pads name.
- a; n+ `; A# ~# B9 Z1083158 ALLEGRO_EDITOR GRAPHICS The cursor chage to Arrow head for Shape Select is more sensitive to location in SPB 16.6
1 k3 M6 i% t; A, s! Z+ o1083533 CONCEPT_HDL CONSTRAINT_MGR Bug -Net-count under few of the netclasses are not in sync between Schematics & Layout6 p: Y0 T1 s! X( ]
1083637 PCB_LIBRARIAN CORE Save As is not renaming the NAME in the symbol.css file' M% d( f0 N1 L! ^
1083934 ALLEGRO_EDITOR PAD_EDITOR Error(SPMHUT-41): File selected is not of type Drawing.9 P% a* V/ T N2 C* b7 ^+ u( n
1084148 CONCEPT_HDL CHECKPLUS The CheckPlus hasProperty predicate fails in the Physical environment.
" @5 B; E! _5 x7 e& h1084166 SIP_LAYOUT DIE_ABSTRACT_IF Updating sip layout with new die abstract doesn't properly update IC_DESIGN_CELL* properties
1 T5 v. P, r* t! c3 {3 @+ L1084285 CONCEPT_HDL INFRA Corrupted dcf was never fixed and caused PXL error
/ r/ {8 {1 y! `2 H e' I0 }1 R1084441 CONCEPT_HDL CORE Assigned net property value changes to numeric
$ w6 V/ S0 q# t& Q0 |1084542 ALLEGRO_EDITOR DRAFTING Dimensions associated with frect doesn't rotate with the symbol.
3 w% H }( S. _6 v1084736 APD IMPORT_DATA Import SPD2 file from UPD-L shape Pad and text issue
4 x+ ?) X6 ], [# f# P* w1085008 ALLEGRO_EDITOR INTERACTIV Relative (from last pick) option in the Pick dialog not working for pick command
! o8 P- y& [. T6 o8 G8 q. F1085139 ALLEGRO_EDITOR GRAPHICS Infinite Cursor disappear during Add Connect if Infinite_cursor_bug_nt is enabled
1 J# S7 L* Z. i1085187 SIP_LAYOUT INTERFACE_PLANNE netrev with overwrite constraints fatal error+ C2 h# D k; Q' }) M6 I n1 W$ E# R
1086402 ALLEGRO_EDITOR GRAPHICS Infinite cursor dissapear when using command like add connect or Place manually with opengl enabled./ O( R1 b8 _! x; ?+ I
1086905 PSPICE SIMULATOR PSpice crash while simulating circuit file with BREAK function6 F# b2 O* p% \! d8 T4 ]
1087770 ALLEGRO_EDITOR EDIT_ETCH Allegro crashes on a pick with the slide command.
8 Y5 f3 m# O: C1088412 SCM CONCEPT_IMPORT why reimport block adds _1 to the netnames?: v7 \# @. b( F4 ^5 q
1088958 CONSTRAINT_MGR INTERACTIV annot create Differential Pairs out of nets that belongs to a Net Group
6 s; e, j" r! M: v( o1089336 ALLEGRO_EDITOR GRAPHICS infinite cursor and pcb_cursor_angle
$ D: }7 [( ~5 f( l1090689 ADW LRM LRM: Unable to select any Row regardless of Status4 b) B/ w% L7 v( T
1090955 ALLEGRO_EDITOR OTHER Cancel command crashes PCB Editor when add rectangle
6 A v) b) C6 ~/ F: y! e2 H1091047 ALLEGRO_EDITOR REPORTS The "Dangling Lines Via and Antenna� report seems to be missing vias that are antennas.
; z1 N7 ]5 g4 I1091218 ADW LRM LRM is not worked for the block design of included project% Q. R7 h W% p9 w8 h
1091443 ALLEGRO_EDITOR OTHER Crash when toggling suppress pads
0 L% h/ e3 X5 j. @6 N% ~: Q1091706 ALLEGRO_EDITOR EDIT_ETCH Allegro crash while routing after setting variable acon_no_impedance_width. u, r) f3 C3 S
1092916 CAPTURE OTHER Capture crash7 c9 S; E; k8 E8 |3 U4 [& n9 U
1093573 ALLEGRO_EDITOR DATABASE team design opening workflow manager crashes allegro. possibly corrupt database
' y, ]6 b% A- C1 P: t" b3 t
! m' G4 B7 S: g' jDATE: 12-18-2012 HOTFIX VERSION: 001
7 y; @# `" _+ m4 y===================================================================================================================================
$ k( z3 M! k4 ^5 f4 b! QCCRID PRODUCT PRODUCTLEVEL2 TITLE
5 [& Z9 n) h3 V2 A) S9 Y# T===================================================================================================================================
; y* ~# P; \- H# Y6 f5 d" B" t501079 ALLEGRO_EDITOR MODULES Enhancement for Module swap function similar to component swap) L; m; m0 L' X/ K; ^+ b4 T l+ s
745682 CONCEPT_HDL CORE Attributes window requires resizing each time DEHDL is launched& |" j; |$ ~# R1 K
825846 CONCEPT_HDL CORE The module_order.dat file gets corrupted0 u: [! ]- Q# G' W
871886 CONCEPT_HDL CORE Browse button in Signal Integrity window of DE-HDL option causes program crash
; i+ |+ Y% B: m& Z- V+ C891439 ALLEGRO_EDITOR INTERACTIV moving cline segments0 v8 U5 c, |/ A, a( P7 [/ a' N
898029 CAPTURE PRINT/PLOT/OUTPU ENH: TCL:To show net alias clearly in print out if alias has underscore
~2 g: T( R* C; H: y3 x; e923210 CONCEPT_HDL CORE Search with multiple properties does not show all properties7 w2 }9 b$ Z @/ e5 [
938977 CONCEPT_HDL CORE Properties attached to standard/DRAWING symbol does not propagate to parts placed in the schematic
9 S% p5 O: w* R947451 ALLEGRO_EDITOR INTERACTIV Allow the tool to select multiple shapes when assigning a net to more than one shape.
. h" v( F, \! k( h3 A& ~; q968646 ALLEGRO_EDITOR EDIT_ETCH The Cline to Pad spacing not followed for Multidrill pad it is more then minimum spacing7 K: S8 s& U" n
976723 ADW MODEL_MANAGEMENT SI DML Model has to be provided the Auto Generate function for discrete components on DBeditor
/ b+ h8 E! z4 |; {: K981767 SCM UI Add series termination in ASA will crash if both output and input pins are selected.
7 F) V5 J4 q U/ T: A982273 SCM OTHER Package radio button is grayed out# K8 z: @$ ~/ |/ K& c5 G: x2 s( O
988438 CONCEPT_HDL CORE Visible constraint disrupts MOVE command2 n3 E% X6 X! I; q! k
989471 ALLEGRO_EDITOR INTERACTIV Functionality to zoom to the selected object in Pre Select Mode0 `( B- f' p9 p1 j! b
993562 CONCEPT_HDL INFRA After upreving the design save hierarchy is leading to WARNING(SPCOCD-34).
: b U# K0 c6 G0 S' H' {+ P& H996577 SPECCTRA ROUTE Specctra not routing NET_SHORT connections- c2 d3 c/ L; e0 F% B: X U
997992 CONCEPT_HDL CORE Why are Page Numbers not enumerated correctly when multiple TOC Symbols are used?0 ^( K, S8 j' a4 N
1001300 PSPICE MODELEDITOR BUG: Simserver crash with encryptedm model
: y! G% B! I3 f" R/ k& g1010124 PSPICE SIMULATOR Monte Carlo summary doesn't list all the runs in case of Convergence error in one of the runs
2 Z N6 L* g, A1 J1 I1013656 SCM OTHER create diff-pair should honour diff-pair setup or ask user for positive negative leg" R5 I' M( R; T$ K/ u" J
1013721 ALLEGRO_EDITOR EDIT_ETCH Routing near a 2x3 multi drill padstack does not maintain the spacing constraints.1 i7 {8 Y( o8 W
1016859 SCM REPORTS dsreportgen exits with %errorlevel%% \ `7 T$ V0 R
1018506 ALLEGRO_EDITOR INTERACTIV Edit copy with retain net of via will assign net to pin
& C3 T+ i1 [1 ?3 H1020746 CONCEPT_HDL OTHER PDF Publisher tool behavior inconsistent between OSs
g0 l- V$ ]3 l1 B; k1020798 SIP_LAYOUT SHAPE Shape not voiding on layer 2 causing shorts* i1 c0 g* E/ p. r+ o
1023051 SCM UI Wrong and incorrect message is generated while adding connectivity in SCM matrix view � DSTABLE-140
( g7 @7 ^' A" i: V+ Y- U" f1023774 APD WIREBOND After "xml wire profile data" is imported it isn't reflected to actual wire.
0 S: k0 T1 z4 k% E7 t( m5 e/ a! t1023807 SPECCTRA GUI Unable to close SPECCTRA using File > Quit or by clicking on standard window red close cross button
' \4 s( M3 _* j0 C4 Y! z1024239 ALLEGRO_EDITOR INTERFACES DXF pin location is moved when I execute DXF out
9 ?7 T. n7 |# m" I% a8 w( A1028237 CONCEPT_HDL HDLDIRECT Error binding design when generating simulation netlist
' X4 D5 H9 D" ^1030591 CAPTURE LIBRARY Library Correction utiltiy locks the library and deosn't frees it even after being closed% j2 X6 e/ Y7 Z$ d& }
1035624 CONCEPT_HDL CORE Options pre-selected when launching base product3 x, t' z7 S+ W% @2 ?
1035896 SIP_LAYOUT ASSY_RULE_CHECK Rule Wire Length under Wire on line in Assembly Rule Checker doesn't work correctly
- R2 i2 [9 p% p1036580 ALLEGRO_EDITOR MODULES Module created from completely routed board file has lot of missing connections in it.: @' s3 E% S% Y& ?0 L
1037345 ALLEGRO_EDITOR INTERACTIV Enhance Allegro's Snap-To tools to select the origin of a sub-drawing(clip file)) H5 E. @- x6 t }8 f3 Z4 q
1038180 ALLEGRO_EDITOR DRC_CONSTR BGA escapes not being calculated in phase tol
+ ?5 O% B# g h9 @6 Y9 O& l. E1038285 SCM UI Restore the option to launch DE-HDL after schgen.
' ^3 J' [) B1 F2 O6 J! I) K! N1038371 ALLEGRO_EDITOR INTERFACES Import > IDF fails with error "(SPMHDB-187): SHAPE boundary may not cross itself."
2 `+ E* `. M. D1038577 ALLEGRO_EDITOR DATABASE Modifying Void crashes Allegro' U# B, w! Q: n% `, j
1039112 ALLEGRO_EDITOR ARTWORK Antietch and Boundary layers deleted when Match Display selected9 P( u/ N0 ]3 w3 Q$ m; \1 @
1039147 ALLEGRO_EDITOR COLOR Need an option to change color of Text marker and Text select in Display listing; E4 D% J6 Y* V3 d" \: j
1040653 ALLEGRO_EDITOR DATABASE Cannot update netlist data, ERROR(SPMHDB-121): Attribute definition not found.
& n, i" c9 i( D4 P- r1041368 APD DEGASSING The Degas_No_Void properties assigned to Cline does not work.
" A+ B" W+ S( [$ e* w0 F& M1041864 ALLEGRO_EDITOR MANUFACT Allegro crashes when opening the Backdrill setup menu
2 Z/ P+ \" s9 [7 v1042199 SIG_INTEGRITY SIMULATION Waveform list was not refreshed by switching tab.
) ^! ~: a9 j) C( Q1042348 SIP_LAYOUT STREAM_IF GDSII export includes the full refernce path, breaks CATS flow
* d5 T; Y5 ~# A& x7 v; i* @1043861 SIG_INTEGRITY REPORTS Derating values are NA in bus simulation report when derating table is not in working directory
1 e6 y) _4 }' K2 W7 @9 C1043903 GRE GLOBAL This design crashes during planning phases in GRE.
: E* i# D8 v/ o) a' o1044029 PSPICE ENCRYPTION Encrypted lib not working for attached5 l, W5 b' z: a8 i
1044222 ALLEGRO_EDITOR INTERACTIV Capture Canvas Image changes working directory* r" F4 B ^6 m: G
1044264 PSPICE SIMULATOR Why does the 'ORPSIM-15009:This device scales to 0.0 at this Temperature' Error occur.# ^/ \4 ?$ T$ x* ]0 V
1044577 GRE CORE Plan > Topological either crashes or hangs GRE( B. `& }& [3 O7 K! Q
1044687 TDA CORE tda does not get launched if java is not installed: N9 I% x) S: f. M& L& S
1044754 SIG_INTEGRITY SIMULATION Incorrect waveforms when simulating with stacked die
# u4 T" r6 n+ V2 q, P0 T1045607 ALLEGRO_EDITOR OTHER Component get placed even after Cancel IDF in form.
/ k1 x! e8 {1 F. l" C1 [& |1045694 CONCEPT_HDL INFRA Why to package the design twice to pass the net_short property to the board?7 R) D& H, l0 t+ [
1045863 CONCEPT_HDL INFRA Customer had the crash several times when they run script with SPB16.51.8 y; k, `8 A, n( y. s% m) |4 D
1046929 CONSTRAINT_MGR OTHER Unable to create physical of spacing cset after rename the default cset in design entry.
1 i `) p+ P% u3 t1047590 ALLEGRO_EDITOR SCHEM_FTB Buses created in Allegro-CM are deleted by netrev in traditional flow+ C, z c. r/ Z0 x; m3 O' ?
1047823 CONSTRAINT_MGR OTHER acPutValue predicate text not being displayed at bottom of Constraint Manager window.
0 m9 L: S) y/ P% w2 k1048403 ALLEGRO_EDITOR skill Allegro crashes opening more than 16 files with skill, y- T6 j ]. a4 x
1049262 ALLEGRO_EDITOR OTHER APD and extracta crash owing to Wirebond.+ z$ n7 ?% E$ }3 O
1049303 CONCEPT_HDL CORE Block rename deletes schematic data immediately in 16.52 Q# @9 U% Y: ]$ ]
1049317 CONCEPT_HDL OTHER bomhdl with scm mode not working on RHEL in 16.5
' O/ k0 ?- n' t( e1049399 SIG_INTEGRITY OTHER Toggling z-axis delay in CM shows the same value* D$ \. p$ H* t* r
1049956 ALLEGRO_EDITOR DATABASE BUG:dbdoctor deletes fillets as design is migrated from old version7 N+ z5 i0 a9 S! r
1050408 APD DXF_IF Symbol has 45 degrees rotation in mcm but DXF doesn¿t.& v. o! E+ y/ I
1050483 ALLEGRO_EDITOR DRC_CONSTR DRC has been waived but after updated DRC system generated a new DRC.
& ~& i! e5 k5 L0 n# I n7 L5 r& v1050918 ALLEGRO_EDITOR MANUFACT Testprep Automatic generate testpoints with wrong padstack Itype in SPB165S026.
4 v1 w r8 o2 L& W, K9 J1051588 ALLEGRO_EDITOR PAD_EDITOR Pad_Designer library drill report omits some drill holes
8 Z8 m8 G0 @& R5 _( w1052005 SIG_INTEGRITY OTHER Huge difference in Z-Axis delay with the latest hotfix for 16.5 that did not exist in older ISR's of 16.5.0 r g8 s: y, q# r2 |" F* c
1052045 ALLEGRO_EDITOR OTHER Bug - Thermal relief connects not sustaining 15 degrees component spin in version 16.5 unlike v16.3* G/ ~& \7 l$ v/ V
1052449 CONCEPT_HDL COPY_PROJECT Copy Project does not update all relative paths in the cpm file
2 @5 B* o/ A0 f" V1052600 ALLEGRO_EDITOR SHAPE Adding a specific cline causing shape errors. L/ ~; u6 q, G( ?
1052753 ALLEGRO_EDITOR DRC_CONSTR Allegro showing soldermask drc only when the symbol is rotated.1 c8 _4 k, |8 r! u# \6 Y- q6 H$ p
1054235 ALLEGRO_EDITOR PLACEMENT Cannot place alt_symbols for mechanical parts.
% p7 ^7 \+ X+ G3 l3 t- G( G T& u1054269 ALLEGRO_EDITOR MANUFACT Backdrill Setup and Analysis crashes on attached design
" y5 f! I9 e2 F2 p& ?6 Q1 w/ k8 ~1054351 ALLEGRO_EDITOR SHAPE Shape voiding fails for board having diffpairs with arcs
! G3 L6 O1 k) d8 W8 m1054456 ALLEGRO_EDITOR MENTOR mbs2lib incorrectly translates refdes label$ w2 h: ?0 N8 R' f& c# m
1055273 ALLEGRO_EDITOR INTERFACES DXF exported from Allegro has an offset in pad location for Y- direction. ~' `! n5 \8 k4 X9 o4 O5 Z
1055328 CONCEPT_HDL COPY_PROJECT Project Manager - Project Copy
$ N% d( W5 Q4 E. |1 Q% [- Y1055481 APD SHAPE keepout does not clear shape unless it's picked up and dropped down- I# i. |0 t; a% Y6 O) M4 B
1055729 CIS GEN_BOM Standard CIS BOM per page is not working correctly with option Process Selection; `# O% ?0 ~$ {) q6 F" E
1056418 ALLEGRO_EDITOR OTHER PDF exports the blank text markers whether or not the markers are visible.5 `3 Y% V5 E+ t" c! x
1056579 CAPTURE OTHER Ability to define custom variables for titleblocks that update for specific variant views2 K8 C, T' ^ O* {0 n! s+ U) O
1057003 ALLEGRO_EDITOR SHAPE Z-copy to create RKI does not follow board outline' [8 W0 b( j3 e, {+ ?0 f! U
1057976 ALLEGRO_EDITOR DRC_CONSTR No Same net Spacing DRC on attached design.- m& H9 i& y4 M7 c7 ^' F' ]
1058002 SIG_INTEGRITY SIMULATION Incorrect Xtalk sim netlist was created.
4 v" p2 M3 @6 a1058364 ALLEGRO_EDITOR SKILL axlTransformObject() is moving refdes text when only symbol pin is selected for move
. ~8 |4 f' L6 j1 o- B5 |1058940 ALLEGRO_EDITOR INTERFACES IDF(PTC) out command output wrong angle value/ ]! }' E# z' i- U
1059037 CIS PLACE_DATABASE_P What enables the Refresh symbol libs option under hte update menu in CIS explorer8 w6 J+ b5 y6 e4 m: v
1059389 ALLEGRO_EDITOR MANUFACT about back drill analisys report# x4 C+ u: D$ v3 q
1059901 CONCEPT_HDL CORE Global Property Change and <<OCC_DELETED>> property value.
! V+ q4 ?3 F2 A& \+ y1060428 ADW DESIGN_INIT ADW Flow Manager Copy Project fails to complete
3 V0 g W* _, _) l$ {" Y1060589 F2B PACKAGERXL Packager Fails with ERROR(SPCOPK-1053): Cannot find a ppt part that matches the instance properties.
: T; S4 e/ j9 C( S4 G: Z; R1060977 F2B DESIGNSYNC back annotate in 16.5 does not bring in already placed nets as global nets3 ], M% t9 ~& ^
1061223 CONCEPT_HDL CHECKPLUS What determines a passthru pin?
0 S" Z* k- q1 E; }) s1061424 CONCEPT_HDL CORE Customer creates <<OCC_DELETED>> property values., D: G9 ]+ G# b
1061572 ALLEGRO_EDITOR INTERACTIV Shortcut keys wont work after "Edit Text" command is finished.+ [! X5 Q! s0 G% {9 x4 w+ X1 u& V
1061659 ALLEGRO_EDITOR DATABASE Unable to return drawing origin to 00$ U8 B! S" r3 |4 {" e" F& Y
1062558 APD DXF_IF If set both in X and Y offset DXF only get one and not get absolutely value in 45 degree rotation7 r7 w; V8 z0 \- |4 J( p' t
1062982 ALLEGRO_EDITOR MODULES Module containg partitions has been imported to the main design and cant be refreshed.
( H9 [) Y3 M; U7 {; I7 ~/ |& E; W9 l' t1063284 PCB_LIBRARIAN OTHER PDV Save As is broken3 I. j# d3 S5 e3 Q
1063658 ALLEGRO_EDITOR SCHEM_FTB Allegro Import Logic does not remove library defined diffpairs, O0 J8 I# z/ g# W, s" d
1063778 CONCEPT_HDL CHECKPLUS The hasSynonyms CheckPlus predicate is not returning true for all global signals.
d4 O6 N: @1 q+ f* q1063924 CONCEPT_HDL CONSTRAINT_MGR Highlight the net between DE-HDL 16.5 and Constraint Manager.$ e; {/ l$ u5 M. O, M# X6 y" n, P
1064707 CONCEPT_HDL CHECKPLUS Rules Checker core dumps on design7 _- V" W8 j, ^2 f' |5 H6 C5 t1 t
1065124 PCB_LIBRARIAN SETUP PTF properties cannot be deleted from the setup in PDV
$ r- K0 ]. k7 x! ? ^' s1065618 CONSTRAINT_MGR ANALYSIS DRCs on board but Constraint Manager shows the columns as green.+ d+ c9 X, Q y9 m* w& t
1065641 PCB_LIBRARIAN CORE PDV symbol editor is crashing when deleting a group using delete or CTRL+X
9 q3 f; E1 t( d/ Q3 X6 ~7 j1065745 SIP_LAYOUT DATABASE The logic assign net command crashes the application: W) |7 i9 o( ]! J: J
1065860 ALLEGRO_EDITOR REPORTS Design crashes when running a padstack usage report
l9 | l% G2 p$ z4 W* G, j3 N1066051 ALLEGRO_EDITOR TESTPREP Auto Testprep generation creates TP with Testpoint to Component Locatin DRC0 W) \9 q; N' G0 N9 ]" w
1066318 CONCEPT_HDL CREFER Issue with LOCATION visibility in flattened schematic
4 K) V! H( L: Z1 R7 M, y& U1 u1067339 CONSTRAINT_MGR ANALYSIS Relative Propagation Delay analysis in the Partition file seems very inconsitent.
$ q% P8 T% P1 c2 f1067984 SIP_LAYOUT OTHER layer compare batch fails with write protected file* X4 [) X) e/ ~
1068425 F2B DESIGNVARI Out of memory message in Variant Editor while ¿change properties� command8 d- ^! h# Z7 M" m1 Z
1068547 ALLEGRO_EDITOR EDIT_ETCH Outward Fanout is not fanning out this 4 sided part as intended
( }! ^5 Y6 l4 ~5 c! _1068966 SIP_LAYOUT DRC_CONSTRAINTS DRC update aborts on this design with ERROR -3000067
, y5 D9 h# o+ q# R8 c k1069215 CAPTURE DATABASE Capture Crash on usnig a TCL utltiy to correct design9 s5 S, Y: i+ D: E
1069517 SIP_LAYOUT DIE_EDITOR change die abstract pins tab default action from delete to modify
4 J. J9 c1 e X! u6 Q+ m2 G; l& v1069915 ALLEGRO_EDITOR EDIT_ETCH Allegro hangs with when doing spread between voids, a9 p9 `3 u! m/ n; s7 z1 X
1070007 ALLEGRO_EDITOR PLOTTING Export IPF omits drill figure characters for backdrill holes
5 A; `9 D! c Q- F, l2 ~1071722 SIP_RF DIEEXPORT Virtuoso SiP Architect not writing out pins to the .dra needed for LVS flow
; ~9 ?& b# ~: V! J( a( U1072067 APD EXTRACT When expoting using Extracta oblong pads with anyangle are abnormal
* L9 F$ A g& [2 e# r. _1072791 ALLEGRO_EDITOR DATABASE Database check cannot fix error and keep report the same issues cause artwork cannot export.
: H3 R& R! u8 K7 X/ R6 k1072806 CIS EXPLORE_DATABASE Query tab in CIS explorer doesn't show searh fields in 16.67 I. f$ L3 U U$ V9 R/ j4 X7 L
1072843 ALLEGRO_EDITOR PLACEMENT The move command that was present in the right mouse pop up menu during manual placement is missing in 16.52 f' }. a _. h+ G
1072904 SIP_FLOW SIP_LAYOUT Probe pins not being mirrored in Die Editor correctly in Chip Down mode.- }' r/ G& l/ v. k$ i
1073237 SIG_INTEGRITY GEOMETRY_EXTRACT Some nets has no result at Bus Simulation and Comprehensive simulation., d7 ?6 u' [3 f: g( s
1073445 ALLEGRO_EDITOR GRAPHICS 'infinite cursor graphics fail -ghost copies as you move cursor6 N. J& o( O8 _4 Q2 }$ N" ]9 p1 j6 D
1073464 SCM SCHGEN Schgen never completes.% L' X! K- V1 p6 X5 S! o
1073587 SIP_LAYOUT OTHER axlSpreadsheetSetWorksheet command clears the cells in memory2 {) ^4 w! g# ]) N& r! y* }0 Q
1073745 CONCEPT_HDL CORE Import design fails: o% d) }4 n6 R# f
1073852 ALLEGRO_EDITOR INTERACTIV While doing a Copy Via use the last 'Copy Origin'
$ R6 m1 W, K, Q3 n1074279 ADW DSN_MIGRATION Design Migration fails purge if there are cells with BODY_TYPE
5 o1 {( u# y) B# A1074791 CONCEPT_HDL HDLDIRECT User gets port exists in schematic but not on symbol message even though the port does not exist
5 O; i. a. s: L# W, ]/ ~% x1075135 ALLEGRO_EDITOR DRAFTING Ability to edit dimension text block in Instance Parameter0 T' k+ a" N/ p! ]
1075151 ALLEGRO_EDITOR SHAPE Cannot change global shape parameter back to thermal width oversize after having used fixed thermal
7 b% g& L8 ^8 {2 h7 A1 S1075256 ALLEGRO_EDITOR OTHER Import > IPF in 16.5 is dropping data.9 b7 M0 c& \; w; |
1075853 ALLEGRO_EDITOR REPORTS please add "PART_NAME" at Extract UI. Q* U* w' I! Y
1075934 ALLEGRO_EDITOR DRAFTING Able to Changing Dimension Text Block' I9 v9 X1 ^& T' |1 {
1075955 CAPTURE SCHEMATIC_EDITOR ZOOM in 16.6 using key "I" on keyboard in not centered on mouse pointer( E6 s1 q1 f5 V& f2 Z5 S
1075964 ALLEGRO_EDITOR SHAPE Shape voiding is not consistent in conjunction with odd angle and arc traces
; \# I* G% W% b. g) h1076086 SIP_LAYOUT IMPORT_DATA missing wirebond after import SPD2
$ v% V, p! B7 x" r% C% o1076202 ALLEGRO_EDITOR EDIT_ETCH Allegro add connect causing crash after Hotfix$ ?/ E% R7 A2 [3 b
1076205 CAPTURE PRINT/PLOT/OUTPU : Printing of User Assigned RefDes
. J( \% w j6 j" Q- E; w4 ^1076536 ALLEGRO_EDITOR DRC_CONSTR Embedded component which protrude out toward Top do not create DRC with Place Keepout on Top3 ^5 g1 ~# I- V1 A- Z T C$ N
1076538 CONCEPT_HDL CORE Property visibility changes in attribute form not updated in schematic canvas.% s; j( U4 x9 e$ n H
1076655 APD DXF_IF Dxf does not get offset value if die symbol padstack has offset value
- \, \: L* O9 |* q1076846 ALLEGRO_EDITOR EDIT_ETCH Grid snapping broken after slide in 16.6
- f5 i+ |' S Y+ d6 O% f1 v0 V2 a1076891 ALLEGRO_EDITOR INTERACTIV Symbol rotation not displayed correctly when defined as a funckey# R: I6 C+ m0 F- f& k
1076909 ALLEGRO_EDITOR DRC_CONSTR Allegro crashes while placing modules from database) h2 P2 v0 x5 w& G! R8 s- y
1077084 CAPTURE NETGROUPS Crash on selecting bus when Enable Global ITC is unset& T* d4 L+ T0 D# x0 `, \
1077169 APD SHAPE Shape > Check is producing bogus results.7 x2 R! H. |4 u7 w% ?) P5 p
1077572 ALLEGRO_EDITOR DATABASE Mechanical symbol created with 16.6 cannot be placed on board.! ?* F) C8 G; S% K; Q( l3 Z4 J
1077879 ALLEGRO_EDITOR SKILL Allegro Skill axlDBCreateFilmRec fails when 15th argument missing "draw hole only" for the first tim. a- H% X+ W% L1 X$ V$ }, U+ k
1078380 SCM OTHER Custom template works in Windows but not Linux% c* j! ?: L Q) ?
1078497 ALLEGRO_EDITOR INTERFACES Import DXF does not seem to work correctly.3 h+ X& f8 C% V+ j9 w
1078682 ALLEGRO_EDITOR DRC_CONSTR Unaccetable slowness with Slide
+ j' t" _$ B& f$ z- z1079082 ALLEGRO_EDITOR PLACEMENT Swap components, gives error SPMHGE-616, when symbols instead of components are selected for swapping1 }: b$ G# V6 r
1079533 ALLEGRO_EDITOR PLACEMENT Swapping components in 16.6 results in Error "E-(SPMHGE-616): Symbol and layer embedding requirements do not match"
* G. F' W5 x# G( q3 h1079937 CAPTURE SCHEMATIC_EDITOR ZOOM in 16.6 is non uniform on text
4 f. x" V7 i1 b# m, O1082582 ALLEGRO_EDITOR GRAPHICS Allegro hangs on a given testcase using the MMB zoom control
& Z: `* Y1 l7 d# D' H% Q1082981 ALLEGRO_EDITOR SKILL Allegro crash while change the new symbol type as mechanical.
! e( g1 ?' P9 \( C1083230 SIP_LAYOUT SHAPE Shape fill in 16.6 releaase not fillilng shapes as good as it did in the 16.5 release.
2 X3 K& K1 z: H+ u8 @% ^; Z2 }0 L; Q& }. _* J
/ R/ ^4 f. Q* YÏÂÔØÁ´½Ó£º
0 z" { C9 @* Ehttp://pan.baidu.com/share/link?shareid=332083&uk=38260382946 J' j; o* b7 K! v p3 N% e
ÆÀ·Ö
²é¿´È«²¿ÆÀ·Ö
