TA的每日心情 | 开心 2025-6-10 15:51 |
签到天数: 1 天 [LV.1]初来乍到
下载链接:https://www.sync.cloudbox.hinet. ... zRkMTI4ZTQzN2UxODY=
( p! d7 ^5 z ~% R- y" c6 O更新说明:, L( ?2 F( {$ {% U% R' ?9 r
DATE: 07-25-2014 HOTFIX VERSION: 032* N$ F. |2 _% V1 p" C; v0 a
===================================================================================================================================- N: Q! ]% a( v) w. P" W0 [2 ~
CCRID PRODUCT PRODUCTLEVEL2 TITLE+ n6 J0 `1 o6 |' ~. X
! f j% B# H7 f. g; ]: s9 {; z381127 SPECCTRA CROSSTALK Specctra xtalk reports aren't correct# T7 s' p2 L, C# Y: ~9 A% h
616770 allegro_EDITOR COLOR Remove the APPLY button in the Color Dialog window.
0 v: y+ P3 O/ e2 a3 w* a: v: i982944 ALLEGRO_EDITOR COLOR seperate the Etch to the Shape and the the Cline in the visibility window) I7 b# }0 W9 S" Q# a
982995 ALLEGRO_EDITOR INTERACTIV Shown infomation for the selected physical symbols4 p7 p6 w7 v3 l# l: R0 \7 r1 p
1024832 Pspice PROBE Shows wrong data & header when exporting trace to .txt
9 [( f7 t" N+ F* O1063258 PSPICE AA_OPT curve fit fails with error same data works in 16.5 Simulation error: out of range of data6 {$ q: I3 b( b; [9 Z8 o/ e3 V
1112360 PSPICE AA_OPT Advacne analysis gives runtime error while using Optimizer in attached design
5 |+ L& }- V! Z& y: f. S4 y1154323 PCB_LIBRARIAN VERIFICATION Con2con is choosing incorrect Primitive from Chips file and failing FTB Checks3 y, ?( I3 {5 M5 d1 U) t/ U
1184690 concept_HDL CORE Weird behavior of genview for split hierarchical blocks4 r' C& G" j- j# K ?
1212577 PSPICE MODELEDITOR IBIS translation fails without any information in log file
- m- k" e1 I& ?4 l- r2 Z1213204 ALLEGRO_EDITOR PLACEMENT Place Manually with existing fixed net behaving incorrectly
' N9 y( L# c$ T' C* _) m6 m- V1213837 ALLEGRO_EDITOR INTERACTIV When copying a stacked via the temp highlight does not display on the last layer of the stack.
) ?! v; r( |% V. u) J9 w! @1216519 SPECCTRA ROUTE Autorouter will not add BB via between uvia within the BGA area9 W3 s+ Q1 i5 v x% w7 Z! \
1220655 PSPICE DEHDL_NETLISTER Support for automatic addition for Power source and Ground Node for Globals in DEHDL PSpice netlisting, f1 n `1 v3 g: t
1223018 CAPTURE OTHER Diff pair Auto Setup not working for the buses.
4 m. q: h& \1 F, | O0 P1 l1225689 PSPICE AA_SMOKE Smoke analysis crashes with attached testcase
1 w8 v$ Y, N4 s# M5 N; r T1232124 CONCEPT_HDL COMP_BROWSER unable to generate ppt_options.dat file in first go
% Y/ r) X( o, ?5 E) G1235059 PCB_LIBRARIAN IMPORT_CSV pin_delays not being imported into PDV
z# o4 B% @, S1238815 CAPTURE OTHER Capture doesn?t retain more than 191 library in add part/capture.ini under part selector configured libraries3 u+ Z" I5 ^6 q" u
1239241 ALLEGRO_EDITOR INTERACTIV Via replacement doesn't replace with correct via but right padstack name.
" F+ h) g6 w# ~/ Q3 O$ p1240201 ALLEGRO_EDITOR EDIT_ETCH RPD DRC unresolved evenif HUD turns Green
@, E1 d' v7 ?; w% o- y1240314 PSPICE SIMULATOR Getting internal error,oveRFlow for the second run0 M, w" @- e3 f+ X" h
1242805 ALLEGRO_EDITOR DRC_CONSTR no_drc_progress_meter variable hangs allegro after running update drc* c# d+ |4 D+ l }5 _" q8 \+ e, [
1243267 ADW TDA URL to TDO-SharePoint should be defined in CPM File
6 ~4 P; O4 c" C0 N2 x1244857 ADW TDA Policy File Variables not working correctly in policy file
v5 g6 t, n+ j2 K( M3 G1245779 CONCEPT_HDL CONSTRAINT_MGR Obsolete objects in DEHDL CM% G, z+ o: a2 i$ X( |: e8 E: J5 M; P
1246811 CIS EXPLORER Option to keep the part type tree in CIS explorer expanded on every invoke# K4 A6 [" D+ q% V( l
1246964 PSPICE PROBE Simulation Crashes in 16.6 but running successfully in 16.55 P, }- x4 _! A! U+ ~- M0 _
1248782 CONCEPT_HDL CORE Display winning physical bus names (occurrence mode) in the the lower block of an Hierarchical design. P7 G+ T" l& z4 l; q& V5 M }+ I
1249238 CONCEPT_HDL CORE Uprev from 16.3 splatters text around sch page
* |* a2 B7 D s% O; f8 ~1249692 ALLEGRO_EDITOR GRAPHICS 3D Viewer is wrong when resizing its window.
6 e( t4 L, y1 x1249850 ALLEGRO_EDITOR SHAPE With shape_rki_autoclip Route Keepin to Shape DRC is created" r! S7 S- `% T; b3 L. T
1250683 ALLEGRO_EDITOR INTERACTIV devpath corrupts if edited from user preferences.3 v/ A6 ~) n6 R0 a
1252059 ALLEGRO_EDITOR INTERACTIV Preference Editor is unable to delete a previous path entry for library paths
5 z% l/ i) Q. t1253563 SIP_LAYOUT DEGASSING Not getting degassing voids when close to shape in center of design5 H+ L2 A% r* [- l- w+ s S
1254319 ALLEGRO_EDITOR GRAPHICS ENH: Functionality to change the 3D Model color for more realistic view5 Y5 Y. \, l" S" `9 g. t" Y2 Z) t
1254562 ALLEGRO_EDITOR DATABASE Unable to delete a subclass that exist only on classes Package Keepout, Package Keepin and Route Keepin.
) W! \) K$ ]. ` y( c0 ?1 |/ R4 B1255169 CONCEPT_HDL OTHER ADW (BPc) Packager should report the specific corrupt directive in the .cpm file6 f# t1 `, n$ M& R% {: M
1255573 ALLEGRO_EDITOR DRC_CONSTR Need soldermask DRC checks when same net via and smd pad overlaps4 T5 \$ ~8 z4 Q. A) D/ W; E- W
1257950 CONSTRAINT_MGR SCHEM_FTB Changing xnet name on Allegro CM.
" L) Y9 G1 Y# g7 ~, z1258165 F2B DESIGNVARI changing visibility of Probe_number in variant schematic changes it to $Porbe_number
4 N& U, _* O1 D& I1258274 PCB_LIBRARIAN VERIFICATION con2con crash with no notification or error message
# {2 F2 u5 J+ J& [1258860 CAPTURE PROJECT_MANAGER Bug: Text Editor (File> New> VHDL File) filters characters from Text
! i& u: N& ?& x! F( C1258872 CONCEPT_HDL CORE Objects are copied (instead of moved) when moved from sheet to sheet* I+ x; ^ |; B6 G
1259284 CONCEPT_HDL PDF HDL_POWER ( global) net does not get transferred to the published pdf
7 |' j. `5 R6 v% q* Q2 N+ k1259375 CONCEPT_HDL CORE Help link to cdnUsers.org needs to be changed. o. ?0 E. ?$ k
1259860 ALLEGRO_EDITOR INTERACTIV Edit > Mirror does not display asymmetrical pad correctly when the footprint is attached to cursor.
) Z9 m/ ^& D3 P" d: h5 C! M. F1260002 ALLEGRO_EDITOR INTERACTIV Alt sym hard is not obeyed when using Edit > Move > Mirror
* L! u( W7 s1 w- t1260006 ALLEGRO_EDITOR PLACEMENT funckey r iange 90 rotation issue. k u" h' w: e4 a' z9 B. p+ i1 \ Q
1260667 ALLEGRO_EDITOR EDIT_ETCH Allegro crashes when running AICC command on few Diff Pair traces.2 ] i" X) ^7 P% a" m3 h/ n( n
1260763 CONCEPT_HDL CORE Export Physical fails with $TEMP entry in Setup-Tools' c; L/ q" R4 @* w7 Z) X& h( N+ D6 I6 t
1260847 SIP_LAYOUT SYMB_EDIT_APPMOD Border texts seen as triangles.
( n! h$ }6 e% e& E. ~1260948 ALLEGRO_EDITOR SHAPE Dynamic ground shape is shorting to via of a different net at layer 4 & 5 in this design
: p$ l3 ^0 k; F1262011 ALLEGRO_EDITOR PLACEMENT Key Properties on Component Instance/ Definition on available to use with Quickplace by Property+ u4 D' q9 n. v& D) e
1262322 ALLEGRO_EDITOR PADS_IN Pads_in can not translate route keepout which specified for the all layers.# \/ [, n; O+ L" q- h
1262626 CONCEPT_HDL CORE PROBE NUMBER attributes lost from the nets after upreving the design
9 e% g+ Q, w! z2 |: f7 A" r( O1263592 PCB_LIBRARIAN VERIFICATION Unable to check in Schematic Model due to pc.db file
' c6 w0 I$ y6 ]8 L6 t% Y7 P1263685 ALLEGRO_EDITOR INTERACTIV Editing Photo Width value from non zero to zero allegro gives warning- Value must be greater or greater to zero$ u; ~# |( h$ G
1263704 ALLEGRO_EDITOR EDIT_ETCH Bug - AiTR wrongly deletes blind vias and do reroutes.) j% P$ M) Y2 |6 Q+ _0 K3 i
1265120 ALLEGRO_EDITOR SHAPE Require voids in dynamic shapes to use pad value
" |! K) V: O: K7 |1265275 ALLEGRO_EDITOR DRC_TIMING_CHK When XNETS are dissolved by removing the Models all Physical and Spacing NetClass associations are lost
4 u0 U( O2 H/ {; T& X1265633 PSPICE SIMULATOR Bias point result is different in consecutive simulation run of the attached project
# X, _# E* Q- z, ?2 j2 w1266349 ALLEGRO_EDITOR PLACEMENT Rotating symbol while placement show wrong angle of rotation than the placed angle when Angle is set in Design Parameter
% c1 x# B4 _+ s y9 E0 X1267541 PSPICE PROBE pspice.exe does not exit when run from command line
. u" C; r$ I# B1267707 ALLEGRO_EDITOR PLACEMENT Mirror Command - preselect/postselect bug with general edit mode
. j9 E: C8 B. o1268299 PSPICE STABILITY Pspice crash on attached design
7 @: ]) `! b5 v% F9 c+ u1270879 ALLEGRO_EDITOR COLOR Color view save creates .color file using older extension" U/ }2 @9 V: d/ S
1271295 SIP_LAYOUT DIE_STACK_EDITOR Die stack editor support needed for large variant combination designs.
( q; ?2 h$ l8 r# V' y, k" d1271385 CONCEPT_HDL CORE Locked property can still be added
# h) a0 [2 j% m6 a1271853 APD OTHER When using the beta "shape to cline" command, add improved messages and partial completion of individual segs in error.
) m6 g, w u- F8 C1272197 CONCEPT_HDL CORE concepthdl_menu.txt contains invalid Variants menu
. p" ?2 e0 l3 J* i a1272318 CAPTURE GEN_BOM BOM_IGNORE not working for Capture BOM on hierarchical designs.+ X7 }- g6 {2 }) e' Y N
1272743 ALLEGRO_EDITOR PADS_IN PADS Library Translator does not open the Options dialog window.* ^* A3 f7 W/ Z) f( p
1273517 F2B PACKAGERXL Netrev error - ERROR(40) Object not found in database
8 Y; t' z. Y' {, c6 V6 h' Y1274000 ALLEGRO_EDITOR DATABASE PCB layer can't be removed' T( }8 L6 G3 e! b
1274530 ALLEGRO_EDITOR INTERACTIV Add Circle radius value changes next time using this command
5 r0 f, M& V- W8 @' E9 D1274697 PSPICE AA_MC pspiceaa crashes when running Advanced analysis monte carlo for the attached design
0 v) y5 _1 C7 C( o8 t1275154 CONCEPT_HDL CORE Hierarchical Blocks lose ref designators when moved to another page6 W* h0 M# d. x8 a* ^% x$ }
1275724 GRE CORE AiDT delete another clines/ B+ N. j& [, g3 c& m5 B* m+ }$ ?
1275831 ALLEGRO_EDITOR DRC_CONSTR Waived DRCs return when using multi-thread DRC check. O5 b0 A1 F+ r5 [( Y
1275834 CONCEPT_HDL CORE ERROR (SPCOCD-569) on global bus- E3 H! q: ^( B1 h) J9 w6 P5 s
1276334 ALLEGRO_EDITOR PADS_IN PADS Library Import problem with outlines9 C" D7 g0 ]" q" \, H; h' P. A
1277062 ALLEGRO_EDITOR PLACEMENT Swapping parts from top to bottom Orientation changes
! f! j! V" ], A8 ?0 W" E1278746 ALLEGRO_EDITOR DRC_CONSTR Package to package DRC allows place_bound_top in 0 spacing has drc in 16.6 version.
' Q/ h8 u& G: Z8 W) P1278804 CONCEPT_HDL COPY_PROJECT Copy project crashes
% G/ f+ r7 ?3 N3 ]% C1279362 ALLEGRO_EDITOR INTERACTIV User skill file makes Allegro Icons gone away, u6 ?( y2 _4 `/ B
1279619 ALLEGRO_EDITOR DRC_CONSTR Netgroup in a Netclass doesn't inherit Spacing Cset0 O% q7 F. O( a( w* |
1279815 CONCEPT_HDL CORE Text > Change and RMB Editor does not allow multiple text edits/ f, t7 G+ r( b9 k7 N0 X
1279876 ALLEGRO_EDITOR DATABASE Using the Curved option in Fillets results in a pad to shape DRC& k8 [. n# n. H! W, R
1280435 F2B BOM BOMHDL with variant repeats the PART_NUMBER value
- n6 M* y- ~ g2 T& n2 Q! E1281669 CONCEPT_HDL COMP_BROWSER Match Any radio button in Component Browser didn't work.
! P) {8 e4 l3 ]3 _1282001 ALLEGRO_EDITOR DRC_CONSTR Updating the DRCs on this design cause the DRC count to change on every update7 `4 F) i# x8 \- i
1282480 SIP_LAYOUT WIREBOND Info on the Wire Count property needs to be updated indicating that it is a User Defined Property x( ^1 c8 D$ _$ C; X# k8 L4 Q
1283952 ALLEGRO_EDITOR PLOTTING Published pdf does not show dotted or phantom lines [4 @& E9 h) n9 C2 J4 M
1283957 ALLEGRO_EDITOR INTERACTIV Replace padstack in "Single Via Replace Mode" is changing netname of the vias with the latest hotfix of Allegro 16.6 x/ P4 j0 N9 i9 k, D& J* i' d3 w
1285588 ALLEGRO_EDITOR DRC_CONSTR Dynamic phase control has wrong analysis result when add rectangle test bead in Clines.
4 ^) a0 S1 s2 `" q( ]8 f1286743 ALLEGRO_EDITOR SHAPE Getting copper islands in the design after running the Delete Plating Bar command2 I+ C3 r6 s3 ~3 E
1287215 ALLEGRO_VIEWER OTHER Allegro viewer plus does not support constraint regions
$ ]: H6 G R9 S+ l* ?( G+ [1288808 APD LOGIC Derive Assignment stalls out or won?t finish and appears to run out of database room.
5 k; ]: F6 ^( m1 i, g! ^/ j5 h7 |1289251 ALLEGRO_EDITOR SCHEM_FTB Pin escapes (clines and vias) not inheriting new net name from a pin with a new net name.
+ L8 E8 Z6 O" h4 |" M1289293 F2B DESIGNVARI Warning 04: Cannot merge the variant properties on variant instance C119 component with same canonical path not present- M2 m/ t. w( w& e- o
1289809 SCM VERILOG_IMPORT User not able to import a verilog netlist into SCM
* o/ W7 j7 c& `! i1290696 CONCEPT_HDL CORE Copying a net name repeatedly causes it to go off grid$ {# D' A$ j7 A( X
1291162 CONCEPT_HDL CREFER crefer crashes when selecting generate cross refernece for all nets selected- s0 k! v; ?5 k( O1 ]
1291285 SIP_LAYOUT IMPORT_DATA Replacing a Die with the Die Text in Wizard causes some Clines to Shift, creating new DRCs./ F& ]4 }" g0 e1 L% d* z
1291658 ALLEGRO_EDITOR INTERACTIV Cannot add Frectangle to Group
9 T9 q2 Z1 j% \' `+ E* F+ ^$ `/ m4 V1292180 ALLEGRO_EDITOR SKILL Allegro Crash while performing query contents of "Maximum_Cavity_Size" with the skill command 'axlDBGetPropDictEntry'
- e5 H/ H% s( d1292210 CONCEPT_HDL CORE DEHDL crash if design was opened with -nonetlistuprev option.
2 K) u9 b8 n u8 x% y7 `7 K1292278 SIP_LAYOUT WIREBOND When creating Wirebonds by Importing a Wirebond File, (wbt) the wirebonds are not on the correct Die layer
7 e8 c. ?* F$ H2 N. d1292282 SIP_LAYOUT INTERACTIVE Getting Multiple GUIs when the Wirebond Import is open and we select outside the command GUI.
4 y" ], u8 g) I" Q$ k0 ]3 G. h1 g1293381 SIP_LAYOUT IMPORT_DATA Import SPD2 error
8 o7 s$ }6 X( g, d1293889 CONCEPT_HDL PAGE_MGMT page name regression result deleted by netassembler5 h5 F- Z9 h! b5 H
1294124 ALLEGRO_EDITOR INTERACTIV Samsung Mobile division wants to disappear the grids in the display window when zoom-out function executes in the allegr
! n& n. B* c0 Z: @1294749 ALLEGRO_EDITOR ARTWORK Null pad is flagged as an error that break Thales automatic tape out* ]2 @. n$ l' F0 y$ E
1294777 ALLEGRO_EDITOR SYMBOL Mechanical symbols missed on STEP result
3 k1 K* M9 z+ s" o- l7 I, P8 M- t) s1 t/ O8 _" I
DATE: 06-20-2014 HOTFIX VERSION: 0319 g3 l6 y1 b! t6 M& ?+ b
, D/ ]5 w$ f5 U0 ACCRID PRODUCT PRODUCTLEVEL2 TITLE$ w8 d( f6 s' ^% @5 c# X; l$ H
. M5 k# Q2 l; B( b) _726553 FSP CAPTURE_SCHEMATI Method to select bus bit?s order while generating Capture design from FSP.
: |8 n$ G. y. }7 g1257631 FSP DE-HDL_SCHEMATIC Schematic Generation selects incorrect symbol version
. J, O: \1 ?+ X" P3 N, |% x1273456 ALLEGRO_EDITOR PLACEMENT Place module instance causes Allegro to crash0 |( }2 ^. D0 h6 L
1277099 ALLEGRO_EDITOR INTERACTIV Clines and pins are disconnected even though they are at the same x, y coordinate.
' N2 R# m) |* u6 m1 z1280913 ALLEGRO_EDITOR EDIT_ETCH Add Connect should be able to be made by go straight even though the cursor is not exist on straight line
5 |& }7 K* q& V4 W; L1282491 ADW PURGE ADW PURGE is removing Page Name data in DEHDL
3 L! a' `3 a1 }3 _$ t+ e1 R1283045 ALLEGRO_EDITOR DATABASE Ecset not getting downreved.+ w. ` K- y6 l3 M4 X. h8 E0 M+ z
1283138 SIP_LAYOUT IC_IO_EDITING symed app mode chooses wrong text block sizes for I/O driver inst names' E m" H8 ?3 X2 T
1283227 PDN_ANALYSIS PCB_STATICIRDROP Enhancement request to add 32 bit files for IRdrop: F& l+ k+ T+ e; l# p1 @, n* X
1284656 CONCEPT_HDL CREFER Crefer fails on large design& _1 \( y9 G K0 J8 h0 {; f
1285814 CONCEPT_HDL CORE DEHDL crash on opening the Design( Z: V1 W% b0 Z: w5 S
1285967 ALLEGRO_EDITOR EDIT_ETCH Slide via in circle pad* U& C& A% b5 @" g* X: c
- T/ z" Z: Q" h- d. }! p0 m
DATE: 06-12-2014 HOTFIX VERSION: 0308 c6 `1 \7 W% [/ S: v
===================================================================================================================================9 E6 G% H; ~) F
6 `- v x4 @, M, y6 E===================================================================================================================================# e0 K+ j$ P5 b3 T
982961 ALLEGRO_EDITOR PLACEMENT Show the Rats when one selects physical symbols to place them
3 [ U7 O8 |8 o* [; ^: l1138680 FSP POWER_MAPPING Ability to assign decoupling capacitors in spreadsheet like application" {* P: f# j2 Q# E7 O
1243410 SIG_EXPLORER EXTRACTTOP Circuit topology extract failed in case of CLASS
$ p" c" W; m, R) n. q1262977 ALLEGRO_EDITOR TECHFILE When importing a certain tech file into an empty .brd Allegro crashes.
2 y3 ]1 k9 b/ Q4 _( E, u$ z! J1267558 ALLEGRO_EDITOR INTERFACES Arc part of symbol pin missing in 3D view of step model5 k* u, G: W: ]4 q7 I+ q
1268252 ALLEGRO_EDITOR GRAPHICS step place bound issue(3D View) j$ e% e/ P8 t; p* ?- j& e
1270450 ALLEGRO_EDITOR INTERACTIV footprint add line on line crash5 y5 K) y1 f' n. f* x
1270962 CONCEPT_HDL PDF PDF Publisher command line does not print pdf file if double back slash is present8 X8 |/ _3 Y2 J. u( J/ G6 E
1270964 ALLEGRO_EDITOR mentor Mentor translation crashes with no errors in log file9 a& c* O1 Z( @3 v" y: b# K
1270999 MODEL_INTEGRIT TRANSLATION ibis2signoise Issue: V: y/ W, a6 q4 W
1271543 ALLEGRO_EDITOR PAD_EDITOR Library import reporting missing padstacks
3 R$ b' {4 {& ]1272099 ALLEGRO_EDITOR GRAPHICS Plotting does not fill shapes6 X1 x& b: [4 L8 ^' I
1272406 ALLEGRO_EDITOR DRC_TIMING_CHK SKILL command 'axlDBTextBlockFindName' returns 1 when nil is expected
" Q E% i0 {1 F z" J+ M3 r# \1272748 ALLEGRO_EDITOR GRAPHICS 3D viewer crashes on this specific testcase
8 A% |8 Q8 O, k3 m9 j7 P- S2 R. G1272793 ALLEGRO_EDITOR GRAPHICS 3D view doesnot displays hole with offset correctly
3 o( J( c o& \, C. T& g1272863 ALLEGRO_EDITOR INTERFACES Ability to find the origin of STEP File in order to place it exactly where it needs to be on footprint during mapping.& Q; b$ I- B% o5 i' l3 d
1273264 ADW COMPONENT_BROWSE hyperlinks not recognized in the component browser2 q+ N8 V8 v1 T- x; G3 T, b
1273304 CONCEPT_HDL PDF Publish PDF from commandline does not work if there are spaces in the Path
8 d" _7 q F! @/ ~' l* G- j1274661 CONCEPT_HDL CORE I can't copy a property from one component to another
. ?& L: B* r/ I: e3 m1275237 ALLEGRO_EDITOR DATABASE Allegro Crash on running DBDOCTOR for a board
! k4 q% F) j; s$ `; q4 [! ~9 \1275345 CONCEPT_HDL CREFER The Xref information page number values are incorrect, G5 i( u$ o/ f7 r; W& k
1275748 APD IMPORT_DATA WireBond starts away from the Die Pin after importing Die using Die Text In Wizard+ s$ v" S; J5 ]! C! ~8 M; {/ Z
1276270 CONCEPT_HDL CORE DEHDL crash by Zoom In > Ctrl+A > Move
) a% w% E8 p3 L" _6 K! `1277735 SIP_LAYOUT IMPORT_DATA sip layout spd2 translator issues with offset die and mirroring* E7 _$ N$ s) f+ J
1279258 CONSTRAINT_MGR OTHER Import logic stops with error6 N! V3 g! G3 p' b
1279694 ALLEGRO_EDITOR SKILL axlCNSSpacingMin('via nil) crashes Allegro PCB Editor
) p0 |$ U. j0 d) k S; ]% W: I# ^4 `( v* {8 u9 D! V$ ?! n4 y
DATE: 05-23-2014 HOTFIX VERSION: 029
3 J: e/ O/ m2 Q' E1 R6 n7 I===================================================================================================================================
" |4 _4 c3 P1 w/ j1 ?; G! ^CCRID PRODUCT PRODUCTLEVEL2 TITLE
, x+ b4 g1 d( e9 B7 c4 l===================================================================================================================================4 [" [3 |5 C* M- {
1209461 FSP DE-HDL_SCHEMATIC Hierarchical Block Size not automatically adjusting to text needs
: F( u$ d" V# w" t) p- w3 F2 W1217832 SIG_EXPLORER SIMULATION S-param generated by SigXP doesn't match with HSPICE/ADS.
v) b6 ?1 x2 Z8 z& t1263575 CONCEPT_HDL CORE Copy-Pate makes Components Off-Grid
9 L' {5 ~/ J( z4 ~8 z0 I2 Z1267602 SPIF OTHER Route Automatic hangs( q: t8 X, Q3 O4 N
1268022 FSP PROCESS FSP is not respecting the use banks for attached design./ f" d* z9 U0 ?$ K/ f5 F
1268587 ALLEGRO_EDITOR INTERFACES Enh. Preserve relation between hole and padstack in IPC-2581
' z8 n1 b% |# N5 e! @5 _1268918 SIP_LAYOUT DIE_ABSTRACT_IF SiP - DIE export from co-design object to XDA results in missing data
& A% s$ G) m0 S4 I! f1 I# f) g" m1269232 CONCEPT_HDL INFRA While pspice uprev the design crashes
0 ^ ^+ p5 R2 L- l1269825 SIG_INTEGRITY SIGNOISE PCB SI hangs when running crosstalk simulations
$ n) m7 w7 r/ N' @1270963 ALLEGRO_EDITOR GRAPHICS Add Circle lint font hidden/Phantom has resolution problem
, V Y9 F" X) q: J0 u1270990 ALLEGRO_EDITOR GRAPHICS Allegro response is slow when added circle
% \, P1 K( X, i% Q9 r1271655 ALLEGRO_EDITOR MANUFACT Dimension option causes a generic crash, reproducible in any design
3 I! S- z, k/ n: f$ O" ^2 M1272495 ALLEGRO_EDITOR MANUFACT Filtered Part numbers in IPC-2581 still pass actual part number for references onutide of BOMItem# {6 Z4 S. }5 o8 @0 J% z
1272839 ALLEGRO_EDITOR MANUFACT Kindly explain the drill legend behavior when padstack rotation is 45 degrees and mirrored ?4 l6 z2 I2 o* T, E8 w1 b
1274518 ALLEGRO_EDITOR ARTWORK Artwork does not create void correctly.
: g. m1 g' T |( S$ Y( G% M2 R' H* n6 M$ J( a
DATE: 05-10-2014 HOTFIX VERSION: 028
Q; { E, y, G/ d6 |1 w===================================================================================================================================
! @. M# B* \1 N* o5 B: y4 {7 qCCRID PRODUCT PRODUCTLEVEL2 TITLE
8 Z* J7 x! x, d0 p2 I===================================================================================================================================
3 ] N2 B6 q1 ]5 V! G- B1199256 ALLEGRO_EDITOR INTERACTIV DFA bubble does not appear when moving a symbol to within another symbols dfa bounds on specific symbols, R( e0 g% h: Y: w! c f4 y! @& S
1220196 ALLEGRO_EDITOR OTHER create xsection chart results in ERROR(SPMHA1-73): Text line is outside of the extents. \) b4 u) Z3 @8 B$ M. p5 r5 B
1259520 ALLEGRO_EDITOR EDIT_ETCH Allegro will crash when adding connections to a differential pair.
0 v4 G( J$ |4 Z0 S9 n% d7 x: a1260446 ALLEGRO_EDITOR VALOR Creating odb output the xhatch shapes where arcs are will become inverted. Difference in the geoms.out extraction?( q. D# \. W) c# L/ M) I5 N7 b4 Q* ~
1261313 ALLEGRO_EDITOR INTERFACES Step mapping does not show all Available Packages
/ w" m# i5 Z& d0 C1261356 CONCEPT_HDL CREFER crefer is crashing with generate for all nets option
* V* ^- B6 q. `. \5 u# j3 j4 {' K1261514 ALLEGRO_EDITOR ARTWORK Exporting raster artwork with overlaping voids fails.5 b) J, O: a8 W' d9 x% U! z
1261735 ALLEGRO_EDITOR ARTWORK Presence of Smaller shapes inside bigger shapes is crashing artwork generation.9 t7 V# P! F- |8 ^) Z/ c
1262019 ALLEGRO_EDITOR INTERFACES Artwork control form hangs if we close PDF publisher gui* X% K! z' }) ~' [7 C
1262246 CONSTRAINT_MGR ANALYSIS Constraint manager shows ALL PASS when Adding members to a NetClass and adding parallelism rule
9 j1 d5 _9 {; r3 y/ q4 ?# y+ l0 h8 f1262560 APD WIREBOND bondwire can't connect to GND ring directly$ T7 ]) e- v; m" o2 U" B3 V
1263275 CONSTRAINT_MGR OTHER Import of constraint file hangs in this design
' x& m8 v% G0 C" D0 _6 B1263358 SIP_LAYOUT OTHER SiP Layout - Void adjacent Layer enhancement to merge voiding for PADS without changing shape params
1 C; Y( T% @3 q' P1264109 ADW LRM LRM error - WARNING(SPDWREV-7): Unable to read the design
x! h ]8 V( Q- T6 K' P$ E1265580 APD MANUFACTURING Icp_soldermask_allow_pins cannot create correct solder mask when the pin rotate.
" E8 Q) l% I5 A9 `" P1266391 APD LOGIC SPB16.6 Derive assignment : want to select 1 DRC marker only.
7 D* c4 n, a+ t& v Z, ^& M6 E& W1266687 ALLEGRO_EDITOR SKILL The SKILL p" T! j3 @0 e* V4 B e
1267267 SIP_LAYOUT WIZARDS Attempting to create a die using the die text in wizard but the tool is not creating the correct die outline3 o4 p. ~' S% n1 ]+ u9 P
1267308 SIP_LAYOUT OTHER When updating a BGA with the Symbol Spreadsheet tool it will start, update a few pins then stop./ H, ^: k. j x2 y7 ^
1267639 ALLEGRO_EDITOR PARTITION Allegro crashes when partition is created and opened from a location that contains "!" in its path./ P: g5 |1 X* M$ k" g" p1 J, v% g
1267704 SIP_LAYOUT STREAM_IF Cannot import stream file, the tool starts scanning the file and never stops.0 z/ t/ {2 Z" G. y5 Q( y; v7 `% H0 T
1267907 CONCEPT_HDL CORE Ctrl+RMB Context Menu Option doesn't work.
3 K8 b4 B- p0 ]* r) p2 l$ w+ i
5 Q6 U( v( e9 {! w8 [, V+ ~" w1 m. LDATE: 04-25-2014 HOTFIX VERSION: 0278 D7 k1 x \+ @
. y+ G2 U* M# uCCRID PRODUCT PRODUCTLEVEL2 TITLE
2 y8 g- j6 q+ f) m===================================================================================================================================3 u+ I% `) M+ ^# `
308701 CONSTRAINT_MGR OTHER Needs to delete user defined schedule in CM
3 U3 R+ d0 k# ~& E481674 ALLEGRO_EDITOR PADS_IN No board file saved from PADS_in
7 T" g2 X1 s5 H982929 ALLEGRO_EDITOR EDIT_ETCH can't route on NC pin and other that are not pin.
1 k; e+ |) b2 I- u, D, ?! P4 y8 S1012783 FSP OTHER Need Undo Command in FSP& B `; }% r# K6 ?. k* Q
1017381 ALLEGRO_EDITOR DRC_CONSTR Need Dynamic Phase to be able to measure back to the Drive Pins.3 |$ R9 W( _/ _" X+ _- N" j
1072673 PCB_LIBRARIAN GRAPHICAL_EDITOR Copy paste goes offgrid if mouse is moved# O7 f5 u' \# e0 ^7 D
1073231 CONCEPT_HDL CORE Copy-paste of signal names goes off-grid in Windows mode.
! I( g7 t1 x$ Q$ ~( |1 p) V% v1105371 CONCEPT_HDL INTERFACE_DESIGN Strange behavior when shorting two Net groups" x6 K& e1 O* D' p( r- w# Y: M
1116498 CIS LINK_DATABASE_PA link database with modified part results in Capture crash" _ q W' O' E& u: K$ L
1118632 ALLEGRO_EDITOR GRAPHICS Text display refresh issue while in Edit > text command9 X: K9 j0 D o V' {
1155821 SIG_INTEGRITY LIBRARY Xnet are not recalculated correctly when model is changed on the Series switch part defined as discrete with Espice mode( @# a) `# Q# Y a( r" F) \
1157372 ALLEGRO_EDITOR DRC_CONSTR Dynamic phase for Diff Pairs not reporting back to Driver pin if pin escapes present, F! D; `, I! n9 X9 N- R
1171951 ALLEGRO_EDITOR CREATE_SYM Jumper has a limited of count when it add to list.
# d1 [7 c- Y/ B6 a1180871 CAPTURE LIBRARY_EDITOR Copied parts don't retain pin name and pin number settings
. d( @8 S# B Z" U1185575 SIP_LAYOUT DIE_STACK_EDITOR Updating symbols causes the graphics for the Assy layer to change from Bottom to Top.
, l" R: ]+ [5 a) s, f1 G9 N6 C1185772 PCB_LIBRARIAN CORE VALID_PACK_TYPE warning when cell was opened in PDV
9 B# f8 {0 C4 K* M7 b1192377 CAPTURE SCHEMATIC_EDITOR Pin name/number position is incorrect on schematic if it is changed for a rotated part.4 O1 t8 K6 v' V5 i
1202654 ALLEGRO_EDITOR GRAPHICS Zoom using mouse wheel shall maintain the center co-ordinates
* W4 }0 t2 O; O& z6 Z9 J1208031 ALLEGRO_EDITOR INTERACTIV Snap to Pin for via during Copy command do not snap to connect point everytime+ d. e$ O) e0 x/ N# A
1208478 PSPICE PROBE Attached project gives overflow error with marching ON.
" Y. E' K" ?! A; |6 \1210015 CONCEPT_HDL CORE The value of $PN should be not turned on spin or rotate symbol
) \% y1 W9 b" f, s3 W5 v, x( `" Q4 K1210425 CONCEPT_HDL CORE When moving a circuit tool reports that connectivity has changed- D1 a) H$ X7 l9 [% [! `
1215858 ALLEGRO_EDITOR SHAPE Force update does not void cline with the shape4 |9 q1 R: J9 h4 [5 i- y- e
1215906 ALLEGRO_EDITOR SHAPE Dynamic shape fill smooth failed when copying to other layers; k. w- X/ e, r- M
1216358 CONCEPT_HDL CORE Can we improve our export BOM function to check if user did export physical function before exporting BOM?
" X( E$ U4 }' ~1 _& @! I1217364 CONCEPT_HDL OTHER Netlist reports fail because error: GScald failed.9 C3 \; k+ ?4 o) f$ U1 q' E& K2 H, q
1217529 CONCEPT_HDL CORE ADW checks do not catch single quotes in PTF values
9 r2 t0 r' ^7 i1217556 F2B PACKAGERXL signal name change not sent to Allegro after packaging
: `6 ~. r( Q( H2 P" x, j1219283 ALLEGRO_EDITOR DRC_CONSTR Show constraint is inconsistent when displaying region information8 Q- W/ {+ ]$ B) M! m
1220078 F2B PACKAGERXL Export Physical crashes when ALL the part pins are added2 _2 i* w+ F# y$ R7 T' z/ q% F
1220393 CONSTRAINT_MGR CONCEPT_HDL HDL import physical from board file will annotate CM data back to HDL which includes cross-section thickness.
; y7 G0 |7 ]9 W0 P1220540 ALLEGRO_EDITOR GRAPHICS Need an option to see the pads inside the internal plane shapes* v9 p$ r& _0 `$ B7 ?, q) S3 j6 t
1220936 CONCEPT_HDL CORE About crash by vpadd/vpdelete command on Linux1 E; c3 O8 ?* f9 {- I
1221059 ALLEGRO_EDITOR DRC_CONSTR Get a "Shape to Thru Via Spacing" DRC error only the first time when the shape is manually voided.
' V8 V1 P& }6 m- g8 d/ i1221182 ADW TDA Team Design with SAMBA5 j: o: q6 K. n
1222442 CONSTRAINT_MGR UI_FORMS Duplicate pin pairs appear in DiffPair
{# S4 O4 O2 u3 w/ U1223175 CONCEPT_HDL CONSTRAINT_MGR Schematic crashes when opened, g4 q. q, _6 U
1223533 ALLEGRO_EDITOR GRAPHICS Why the through pins for STEP models are shown at an offset when viewed in 3D inside Package Symbol?
; \- _+ y1 ^. E% g+ V1223680 CONSTRAINT_MGR ECS_APPLY Improve ECSet mapping by allowing user to address ambiguity of Parts
6 m! }9 L7 x2 M1 W0 a$ N1224156 SIG_INTEGRITY SIGWAVE Exporting spreadsheet with filter Subitems in SigWave exports all waveforms. g# g' d& J3 w$ Q8 Q4 N S
1224417 ALLEGRO_EDITOR PLOTTING Hidden font pattern is not showing correct in 16.5 version also 16.6 version.9 r, {# w* x9 z) E2 {
1224704 F2B DESIGNVARI There is no lock for the variant.dat file - multiple users can open the editor* Y! _' q6 e7 O; A( @
1224968 ALLEGRO_EDITOR INTERACTIV Delete >(RMB click) Cut> Snap Pick to>off grid loction does not work for lines.. e4 w# F) G9 `0 M7 w, M
1224982 CONCEPT_HDL PDF commandline publishpdf does not work when there are spaces in the path* n" m; h$ {. E3 o. q& c
1225114 CAPTURE GENERAL H-pins added after netgroup pin get color as of netgroup pin
- q) X! X$ l9 h( y1225494 CAPTURE DRC Different DRC results for Entire design and selection2 w9 n7 o8 b' i+ g- B8 C
1226153 ALLEGRO_EDITOR INTERFACES Export STEP should include PART_NUMBER property
( o( ~6 n# j, C t5 G1226235 ALLEGRO_EDITOR EDIT_ETCH Enhancement to include Pin_delay of descrete forming Xnet
7 J+ Q0 E8 c2 ?1226372 CAPTURE GENERATE_PART ENH: Functionality to add pin spacing in New Part From Spreadsheet
2 a+ G* k! k5 D: F9 j1226477 CONCEPT_HDL CORE DE HDL縮 `Allowed Global Shorts� function is inconvenient for Global Signal8 o* ]2 s/ e% ^! ^9 a9 S: @
1226813 SIP_LAYOUT LEFDEF_IF ERROR SPMHLD-120 when importing a DEF file. Request to increase the number of characters/line in a .cml file
3 R9 y2 I0 s' H6 `3 @6 `1227453 ALLEGRO_EDITOR SHAPE Addition of Fillet generate Pin to Shape Spacing DRC errors and DBDOCTOR errors0 H4 X7 r- y+ ]: o
1227461 ALLEGRO_EDITOR SHAPE Sliding a cline for certain net changes the thermal relief connects for pins connected to another net from 4 to 5,6,7,8
$ R& x# l3 O' b, s! N+ ^( G% h1227469 CIS DBC_CFG_WIZARD Oracle Views not visible on Step2 of CIS Configuration
/ V" ?2 N: V0 u6 N E5 [) U1227780 CAPTURE ANNOTATE Inconsistent behaviour when annotating heterogeneous part0 \0 n! a1 R8 t+ B! ] } C; {
1227831 CONCEPT_HDL CORE Pin text and H-block name in upper case
3 e4 H, T0 V- f+ }0 R1227954 CONCEPT_HDL OTHER supress check for global signals when wires are unconnected to pins
' V% M% o. W3 k1228190 ALLEGRO_EDITOR OTHER Unable to close the 'usage' window during license selection& s0 j- \' H( X% L* ], i! J
1228899 CONSTRAINT_MGR INTERACTIV Export/Import constraints in "overwrite" mode from same design shows different results when imported second time.- v5 W) ^3 \. Z
1228934 ALLEGRO_EDITOR EDIT_ETCH The "View Active Layer" option like the Board Station should be provided for dynamic layer visibility.
: o$ [' E/ Q& b. g2 U1229316 ALLEGRO_EDITOR EDIT_ETCH When routing with Hug only enabled we were able to route through other routes(sometimes Hug).+ y1 v) {1 v+ i- @. W
1229545 CONSTRAINT_MGR OTHER Allegro indicate bundle scheduled nets in CM
0 z8 }& { o( {$ T. k% E1230056 ALLEGRO_EDITOR GRAPHICS Bug: 3D View of Mechanical Symbol with the drill hole defined% Z; Q' k8 p i) M+ [% Y: S- j
1230432 CONCEPT_HDL CORE No Description information in BOM
6 @. e1 K6 D; ^& k5 F9 W$ j1231148 F2B DESIGNVARI The variant.dat file is not updated with library PTF changes; u8 e4 p+ c- W% T4 A4 O! p
1231625 F2B DESIGNSYNC VDD at command line needs to support sch2sch and test variable to write out report files$ x* v) f0 Q9 o$ D! p' }8 V5 Y
1231697 CONCEPT_HDL CORE If any locked files exist force a pop-up dialog restricting certain commands3 ]6 e* p5 ^! N# \ a7 M' R% u
1231767 CONCEPT_HDL OTHER Unable to find under the search options single bit vector nets
5 j# y% O/ C4 E" a8 K1231961 ALLEGRO_EDITOR SHAPE Shapes not updating to smooth unless we use force update and as a result false DRC's appear in board.3 t0 {2 q i X( e0 v
1232100 CONCEPT_HDL SKILL Unable to execute the SKILL commands in viewer mode
8 I$ Z( L! b9 U- p( ^# g1232336 CONSTRAINT_MGR CONCEPT_HDL cmFeedback takes 5hrs to complete during Import Physical
/ C. z( W- N6 y+ h! N$ h9 n; w z1232710 F2B DESIGNVARI Dehdl crash while moving component in variant viewer mode+ D: b ~( k/ J; W
1233894 F2B PACKAGERXL The page data is missing in the pst* and PCB files& J! {% t$ q* S0 z0 ~
1235785 CONCEPT_HDL CREFER cref_from_list custom text is not subsitituted in complex hierarchy) C1 l0 O: R8 S( [( P
1235928 CAPTURE SCHEMATIC_EDITOR OleObject modifications not saved, _9 V5 G+ L3 {$ `
1236065 CAPTURE PART_EDITOR Mirrored part after being edited get pin name locations incorrect
o* R3 D; f5 C+ F& l) E1236071 ALLEGRO_EDITOR SHAPE Airgap for Octagonal Pads ignores DRC Value when Thermal set& h% l1 ]; d! C2 l& h2 C
1236072 CONCEPT_HDL CORE Page 122 cannot be saved as logical page 119 has different page mapping in connectivity data and schematic# `! q! p: m3 n, q: U8 m! c& h1 |7 G
1236161 CONCEPT_HDL CORE Import Design shows the current project pages! G9 _; b5 {. W: \, b n
1236432 ALLEGRO_EDITOR PADS_IN pads_in doesnot translate via and shape in some instances.& M3 P9 J; P$ W' Q9 A; x0 f( m
1236557 CONCEPT_HDL PDF Running Publish PDF on command line in linux doesn't output progress until completion/ y3 n( H" j: o: b6 I
1236589 CONCEPT_HDL PDF Enhancement license failure error should appear in pdfpuplisher log file0 i7 w: p5 I# C
1236644 ALLEGRO_EDITOR EDIT_ETCH create fanout deletes shape% y& a4 N& z+ [" E+ i" x. f
1236689 ALLEGRO_EDITOR GRAPHICS Graphics displays extraneous lines when panning or zooming
- b/ }5 f+ d: d' W) m9 W* @, s8 D1236781 F2B PACKAGERXL Export Physical produces empty files0 `: I5 x1 g7 t- r6 ?% X& z
1237331 PSPICE ENVIRONMENT pspice.exe <cir file name> - hangs when run
% H" u$ X& B* A7 ^% U3 N' R% f2 x1237400 CIS EXPLORER Capture hangs on 2 consecutive runs of `refresh symbol from lib� command
; B/ D; T& Y1 e1237437 CONCEPT_HDL CONSTRAINT_MGR CM Crash when saving after restore from definition3 G$ \- A) I, W3 Q4 {3 X
1237862 CONSTRAINT_MGR OTHER A way to remove the RAVEL markers from the Constraint Manager.
+ q+ l1 `4 J7 O) g1238852 CAPTURE GENERAL signal list not updated for buses( [8 K/ o4 }5 ^
1238856 FSP DE-HDL_SCHEMATIC FSP schematic generation crashes6 J4 X; H6 m6 G, U/ v. e& [
1239079 ALLEGRO_EDITOR INTERACTIV The 16.6 Padstack > Replace function leaves old padstack.& {6 G. Y# B; u- U2 ^4 l# n' w
1239706 CONSTRAINT_MGR ANALYSIS The reflection result on a differential signal in the CM when Measurement location is DIE( {' x' E' @0 _* k$ {
1239763 PSPICE PROBE Cannot modify text label if right y axis is active
6 B, v5 t1 c0 Q* ~3 d1240276 ALLEGRO_EDITOR GRAPHICS Printing to PDF from SigXp is giving unreadable images
% w2 V0 e1 r: J$ G/ f! i4 g% W1240356 CAPTURE IMPORT/EXPORT Can縯 import SDT schematic to Capture.
. n" K' Y) N& N& j0 Z1240502 F2B PACKAGERXL Corrupt cfg_package does not stop PackagerXL from completing
: v5 h6 p: U, r: D! ]1240607 ALLEGRO_EDITOR OTHER Footprint of screw hole got shift in DXF file
3 s) \! J6 H0 O1 r1240670 ALLEGRO_EDITOR PLACEMENT Select multiple parts and Rotate makes them immovable7 I3 @$ _( l8 a5 j! i/ F
1240773 CAPTURE DRC DRC check reports error for duplicate NetGroup Reference in complex hierarchy0 P5 O& @; l6 Z( x* N3 A+ G; j. O
1240845 SIG_EXPLORER EXTRACTTOP Narrowband via models for Mirrored BB Vias not extracted in in the interconn.iml and this gives bad ringing in waveforms
# q! A5 Z, ? N3 d( H% B1241634 ALLEGRO_EDITOR OTHER Netshort for pad-pad connect not working4 p$ {7 k+ A: T
1241776 CONCEPT_HDL CORE In hierarchal design not all pages are getting printed./ } y, i; F& O7 H% l5 ]! z, g) A
1241788 CONSTRAINT_MGR CONCEPT_HDL Issues with changing focus in Constraint manager using keys on keyboard
) V" I2 L$ S, I, W, Q7 b1242683 ALLEGRO_EDITOR INTERACTIV Color View Save replaces file without warning0 w+ R+ P0 _- L$ [3 L2 I
1242818 ALLEGRO_EDITOR PLACEMENT Placement edit mirror option places component on wrong side/ n, q0 ~: ^! g; C3 I# A; R
1242847 ALLEGRO_EDITOR GRAPHICS Need an option to suppress Via Holes in 3D Viewer
+ v& p1 S5 U0 T1242923 ADW COMPONENT_BROWSE UCB reports Missing From DB only after selecting the Row in the search results ?* F5 k+ }0 J# v% x. Y
1243609 CONCEPT_HDL CORE autoprop for occurrence properties8 L4 r4 ^$ K4 k8 M9 `
1243682 F2B DESIGNVARI after undocking variant icon cannot be redocked back to GUI* A+ k3 q; e: P) d L
1243686 ALLEGRO_EDITOR GRAPHICS Invoking Edit->Text, the infinite cursor disappears until edit mode is changed.
" A; e8 v* n7 d/ F1243715 CAPTURE PART_EDITOR Pin name positioning get changed after rotating or mirroring) \* ]+ n! J5 a8 b2 Q3 t
1244945 CONCEPT_HDL PDF PDF Publisher does not include image when file is not located in the root folder
* X7 X/ x7 E9 B. h) y1245568 CONCEPT_HDL CORE Dual unselect needed for wires attached to other net/source and property is not deselected when component is0 I; J1 f3 M! l
1245819 F2B PACKAGERXL wrong injected properties information passed during packaging of the design' s q: v* \; }; E- \ P
1245916 SCM CONCEPT_IMPORT Where does the folder location reside for DEHDL imported blocks?7 j9 J. E$ N8 Y0 Z$ o
1246347 CONSTRAINT_MGR CONCEPT_HDL DEHDL crash if environment variable path has trailing backslash character
- s+ W% g, l( }- z5 I1246896 ALLEGRO_EDITOR DFA DFA_UPDATE on Linux reports err message if the path has Upper case characters
; S: o, M+ G) S' [1247019 SIP_LAYOUT DIE_STACK_EDITOR SiP Layout - refresh/update symbols is mirroring the assembly drawing data on DIE that is placed ChipDown5 M( Z: t* V( ?. a5 x
1247037 CAPTURE LIBRARY_EDITOR Copy & Paste of library parts resets pin name and number7 ?" r! l* W |0 w! d
1247089 CONCEPT_HDL CORE Group Align or Distribute > Left/Center/Right crashes DEHDL
6 }$ G! K! r C; X: |5 w7 Z+ b1247163 CONCEPT_HDL PDF Physical Net Names in PDF not maintained
7 m& V- N' k/ ?3 i3 w1247462 CONCEPT_HDL CORE Text issue while moving with bounding box
4 E2 _* d; @4 ?% @- t9 J& f0 m1247464 ALLEGRO_EDITOR UI_FORMS When using the define B/B via UI the end layer dropdown arrow is partially covered
% r" z) d. d4 F1 j' p1249063 CONCEPT_HDL CONSTRAINT_MGR CM and SigXP doesn縯 respect PACK_IGNORE at components& g! }. d4 {1 K# I2 h
1250270 CONCEPT_HDL CORE Part Manager Update places wrong parts
+ N: W5 t3 X+ e6 m- v; A. p7 K1251206 ALLEGRO_EDITOR ARTWORK Aperture command cannot create appropriate aperture automatically from design.# P4 m. Z9 r1 p1 O
1251356 ALLEGRO_EDITOR INTERFACES Some STEP models are missing in 3D view of footprint, although all components have STEP model mapped in footprint
, o* r3 h9 i/ i4 b6 q1251845 ALLEGRO_EDITOR EXTRACT Crosshatch arcs do not extract correctly) {5 Y) R6 o8 q, U) U
1252143 APD OTHER When using the beta "shape to cline" command the tool is removing the shape instead of converting it.- F: a Z% j8 I N$ Z; {6 s3 i6 }
1252737 SIP_LAYOUT OTHER SiP Layout - Option to create shapes from Pins for WLP wafer level packaging technologies4 K" b: f3 F- P) V6 G/ ]3 Y' {1 K
1253424 SCM SCHGEN Export Schematics Crashes System Architect
8 x: w# {, F/ V3 e/ y9 A1253508 ALLEGRO_EDITOR INTERFACES Bug - Export IPC2581 exports Crosshatch shapes as filled
" A9 |. j$ x, R* K4 M. E1253554 SIP_LAYOUT OTHER SiP Layout - Add Netlist Spreadsheet export to SiP layout to help with connectivity auditing% \; F, c( |; D
1254578 SPIF OTHER Specctra crash with Error -1073741819 for Auto router3 P: }6 l* k% ~
1254637 ALLEGRO_EDITOR DRC_TIMING_CHK adding nets to a net group causes constraint assignment error! |7 S, w3 l& ]1 D5 m4 I, q1 ]
1254676 GRE IFP_INTERACTIVE Rake Lines disappear when Auto-Interactive Breakout is enabled.
: g; i" r, x$ \4 N4 i1255067 SIG_INTEGRITY REPORTS Allegro hangs on Net Parasitc Report generation
( L2 d! x S) b1 _ D4 q2 ~1255267 ALLEGRO_EDITOR SKILL axlDBGetPropDictEntry does not return a list of all objects% W0 ?: l) S4 _+ T. s ?
1255383 SIP_LAYOUT IC_IO_EDITING cant move bumps or driver in app mode1 K- ?+ R5 a. p: F
1255703 ALLEGRO_EDITOR SKILL axlCNSSetPhysical and axlCNSGetPhysical return nil if a constraint set name is provided
9 N! g1 m) b: p& Z1255759 ALLEGRO_EDITOR INTERFACES Change the silkscreen OUTLINE from layerFunction DOCUMENT to layerFunction BOARD_OUTLINE
! {+ t% H; H" O% y8 q X. W7 S! ^1256457 CONCEPT_HDL CONSTRAINT_MGR Extracting a XNet from CM crashes the tool" Y9 G2 X7 a) w/ i+ a% q& E- Z k# I
1256597 GRE CORE Allegro GRE crashes while running Plan Spatial, on a particular design
8 A2 ?' X- Q% c# t$ W0 q: Q1256650 ASI_PI GUI PFE - Cannot generate model file error when using company decap library
% K' z* h' D/ n4 Z1256837 SIP_LAYOUT DIE_EDITOR Open and close of die editor takes too long
0 e- w1 H' m4 r1257732 CONSTRAINT_MGR OTHER Bug - Export Analysis Results in CM makes Allegro crash
# C: [: X) t. o$ f1257755 ALLEGRO_EDITOR OTHER Editing time in Display > Status seems to be logging wrong time
; N# Q1 T" ]9 y7 i1258029 APD WIREBOND The bondwire lost after import the wire information6 F) T; x6 A8 J) I5 A
1258979 APD NC NC Drill: There is difference of number of drills.
! e* S6 o! n& G; j. @! [2 F/ V1259484 SIP_LAYOUT OTHER SiP - calc min airgap calculate minimum airgap beta feature improvement- Y( P! n5 `5 f/ E$ N: c. L, T
1259677 CONCEPT_HDL CORE hier_write -forcereset cause component prop change.
( l2 X! u9 r" a! @& t% y1259913 ALLEGRO_EDITOR UI_FORMS Unable to save setting of "use secondary step models in 3D viewer"1 b- R/ e& N& X( a2 N
1261758 ALLEGRO_EDITOR EDIT_ETCH Auto Interactive Delay tune (AiDT) is deleting clines
( c! R" A2 K, d. Y1 J( W1262543 ALLEGRO_EDITOR MANUFACT merge shape results in moved void% ^6 D! [* c( |4 P5 }7 J6 x d
1264767 ALLEGRO_EDITOR DRC_TIMING_CHK XNET is choosing to resolve to a different name from 16.5 to 16.6 and is causing constraint loss
! _2 F8 |/ ]: c1 S0 X
2 `& J6 U9 Z* E6 l/ v1 bDATE: 03-28-2014 HOTFIX VERSION: 026
i2 l1 U+ h1 \1 |) t) S===================================================================================================================================4 }; [* ?7 l2 A
* e$ s0 y# J: V5 T===================================================================================================================================9 Q4 P# R8 S7 M7 @) v( h
1190942 CONCEPT_HDL CORE Cannot copy locked .xcon files; J! J1 ?* o2 d: }
1226085 F2B PACKAGERXL Winning net NC shorted with loosing net due to PACK_SHORT
0 r. n# w" _. p B2 n+ V1244894 SCM SYSTEM_OBJECT Get packaging error when adding a pullup/pulldown resistor7 n- |1 w2 r- M9 t! [% D
1247432 CONSTRAINT_MGR OTHER PCB Editor crash
5 J( G" z7 f. M1248560 F2B DESIGNVARI Variant Editor > Help about for S024 says unreleased ?
/ Y: b; v6 v, Q- L1248712 SIP_LAYOUT WIREBOND Changing the charecteristics of a Bond Finger causes it to shift position" E- b2 R: @/ M7 i u5 Z
1248839 ALLEGRO_EDITOR OTHER 16.6 S023/024 crashes on Logic Change Parts command.
9 K+ X" E6 J2 }) E9 c. f1249000 SIP_LAYOUT DIE_EDITOR unexpected shift of instances/pins by co-design die editor2 G T3 Q: W+ _( c- i
1249186 ALLEGRO_EDITOR INTERFACES Bug - Export IPC2581 ignores property UNUSED_PADS_IGNORE
# L7 I2 q% v! j/ }1249272 SIP_LAYOUT IMPORT_DATA film resistor pins/pads are created on the wrong layer. Always synthesized on top cond layer regardless of config file* `9 n; S* C9 ?7 l, O* |$ |0 f
1249792 ALLEGRO_EDITOR INTERACTIV Cannot place rectangular shape as per included width and height.
6 h# v7 R8 b1 _* t& y* ^1249801 ALLEGRO_EDITOR INTERFACES Bug - Arcs in IPC2581 export are corrupted' w- z7 o! O( _- x+ f
1251006 ALLEGRO_EDITOR INTERFACES IDX does not recognize PKG_PIN_ONE property6 i' g9 p& H6 E. z6 z+ Z
1252142 ALLEGRO_EDITOR INTERFACES Remove inappropriate Conductivity specs from the dielectric layers from the IPC-2581 output
$ ]; ^9 e5 |# P6 L& M1253047 ALLEGRO_EDITOR SCRIPTS Bug: SAV file when creating symbol
" c0 L' P D4 z& `! Y3 _9 A3 L% P2 q6 g% |* K+ j# _1 h
DATE: 03-13-2014 HOTFIX VERSION: 025
& K: ] f+ T8 k( m/ L. p===================================================================================================================================
$ l! u. v$ `4 g' ECCRID PRODUCT PRODUCTLEVEL2 TITLE
, X; w* S1 b) P! J8 @===================================================================================================================================* g9 Q) u B% u4 ~$ E; v( X' F
1194646 CONCEPT_HDL GLOBALCHANGE Global Update > Global Component Change does not work1 @! f: V2 X% K% c5 V, D4 d5 {5 @
1227843 SIG_EXPLORER EXTRACTTOP Cannot extract the topology correctly.
8 Y) ^5 t' u$ k% p: C1231510 ALLEGRO_EDITOR INTERFACES IDX exchanges with CREO 5.0 issues* C' H0 R' N0 i0 m1 |7 |1 z: ~
1233030 SIG_INTEGRITY GEOMETRY_EXTRACT Net Parasitic of ground Connection
8 f; a% x8 w- J0 Q+ Y$ d' G" b) @1236961 SIP_LAYOUT OTHER Moving component using Place Manual -H causes mirror_geometry.
* l, P2 I& _' k$ j! y( c R1241456 ALLEGRO_EDITOR EDIT_ETCH When creating Die pins or changing their attributes an oval is placed on the pin
4 p9 K1 W* V9 f9 I1242461 SIP_LAYOUT OTHER SiP Layout - DIE is being mirrored when placing: e6 t+ ~1 s' c( C8 A
1242682 CONCEPT_HDL PDF PDF Pubisher crash DEHDL on design9 Y! b {& q8 s
1242685 SIG_INTEGRITY SIGNOISE Incorrect net name was displayed/output if the net include consecutive underscore.2 o& g% p1 e" I# K/ S
1243357 ALLEGRO_EDITOR INTERFACES Ability to add any new name
; [( X! v5 i/ k3 y' P: Y6 j1243758 ADW COMPONENT_BROWSE I don't see an option to switch between database and cache mode, R9 T; w$ d/ s& @$ f
1244325 ALLEGRO_EDITOR INTERFACES Merge all the BOMItems with same part number into one single entry in IPC2581B.
$ V4 v4 n% @4 e2 \( \% z1245363 CONCEPT_HDL CORE Design Entry HDL program crashes upon save
! }$ C- y8 L: {! Y# B. p1245790 ALLEGRO_EDITOR PADS_IN Bug: PADS Translation with 16.6s023 gives parse error: F- l+ t8 b, t5 I# q
1246343 ALLEGRO_EDITOR SKILL axlAirGap command is broken in s022
) f; d: m" g$ i& G7 S1246419 CONSTRAINT_MGR OTHER Netrev fails with SPMHGE-268 on existing design
- M2 G2 a, q: k! Y& m) F* E# Y1246878 CONCEPT_HDL CORE Changing Symbol in Variant Editor makes schematic page crash) n) L" p) O/ o& S5 C
1246884 ALLEGRO_EDITOR GRAPHICS Infinite cursor disappears from the canvas after step package mapping GUI is closed." t& S6 J7 u3 c4 G5 |* y
1247016 ALLEGRO_EDITOR INTERFACES STEP Model of connector cannot be zoomed sufficiently after mapping it to symbol dra file.
* R' t6 C) E' ]1 c( G1 b! H1247107 ALLEGRO_EDITOR INTERFACES Incorrect Spelling in IPC-2581 EntryFillDesc field
% ^5 o4 ~* m& d# d0 }2 F" `1247177 SIP_LAYOUT WIREBOND Bondfingers not aligning to wire when tack point on the other wire end is moved from center
4 ~! L. }% r& c* p, M1 k1247400 ALLEGRO_EDITOR INTERFACES option to Export optimized PDF in color
' G) S c( S) D+ Z4 w a" g
1 {- G0 \( L* |2 h: K9 v' ~DATE: 02-28-2014 HOTFIX VERSION: 0243 ]9 w X y! j: S4 @- [1 c) K u
===================================================================================================================================' P+ h0 a, q; A4 R* H$ ~
CCRID PRODUCT PRODUCTLEVEL2 TITLE, x5 ]! l/ Y. D3 ?
===================================================================================================================================# t" q) ~: {$ n7 B
1207753 CONCEPT_HDL OTHER The Variant Name with a dash is represented by #2d1 s) r' }, J3 a0 x
1234991 ADW TDA Team Design does not remove deleted page files from zip files
" f+ R9 r1 V/ w1235919 CONCEPT_HDL PDF DNI crosses are not printed on the correct components: m; n& n; O! Q2 b* n) x( \ a2 M
1238007 ALLEGRO_EDITOR PARTITION Import partition removes properties from RKO that were on the exported partition
: ?1 E& F$ f) F1 ^7 M1238140 CONCEPT_HDL CORE Design Entry HDL Crashing- x6 S. @& k. u( b
1238195 ALLEGRO_EDITOR DATABASE Via's losing net idenity after being mofifed or replaced.$ N* h! `. ~) Z1 S7 n7 q5 K
1238478 ALLEGRO_EDITOR ARTWORK IPC-2581 negative artwork layers does not recognize shape bounding box value. s1 l6 _& D. W3 Q0 K3 Y
1238483 ALLEGRO_EDITOR ARTWORK IPC-2581 not drawing negative artwork correctly with traces in voids.: b* |! e# k2 \) Z6 C2 F
1239070 SIP_LAYOUT WIREBOND When importing wirebond data onto a Die rotated 90 degrees the WB data is placed in the wrong locations
5 \& I! S# A0 V" O1239433 SIP_LAYOUT WIREBOND Need the Wirebonds to lock to the die aftter importing wirebond data
! s6 K# W# q0 n `1239952 ALLEGRO_EDITOR SYMBOL Allegro crashes with a component rotation of 45 or 135.
/ l, m3 A. ?) [' a1240205 SIP_LAYOUT DIE_EDITOR Crash occurs when trying to "oops" for a moved driver in co-design die editor in SiP- T. |" b" P- P N3 S: @
1240288 ALLEGRO_EDITOR INTERFACES Why are some of the mechanical holes not showing up in Step output of thi design, while others are ?
R3 U' Q& W6 v5 D; u0 b1240305 ALLEGRO_EDITOR INTERFACES STEP Export gives some errors which are not documented
6 F A: v1 x# P1240425 ALLEGRO_EDITOR DATABASE Export ODB is not working on 16.6 HF 22! m1 I, ~6 N% Z9 ]1 r2 `
1240879 ALLEGRO_EDITOR NC NC ROUTE file is not correct using hot fix 22 of v166
! L. [3 }1 `3 q2 E1 z c# R1241904 ALLEGRO_EDITOR INTERFACES IDX baseline import displays false DRC with Package_height Offset until DRC update is run.
2 ^: H$ n6 o" _1 e1 ?( K1242266 ALLEGRO_EDITOR INTERFACES IPC2581 crash on HF22 and HF23- I1 G0 e: @: f! ~6 l) {
1242433 ALLEGRO_EDITOR INTERFACES ipc-2581B incorrect LayerRef values in BOTTOM side RefDes elements
/ Q. V) @- f: x7 q& P1242988 ALLEGRO_EDITOR SKILL Allegro crashes on skill command axlDesignFlip3 t1 j8 X1 k/ n9 ~$ _ n8 O
1243845 FSP FPGA_SUPPORT FSP design created in 16.6 s018 will not open in 16.6 s021
9 H$ E# {, d) H
; t3 d& V8 n- x; q! x# cDATE: 02-14-2014 HOTFIX VERSION: 023
: X% _& r4 P6 F! j6 o===================================================================================================================================/ S. V5 U! \4 ]- Z- A2 ?
: Y9 _- ~, c: J/ H9 Q! G N===================================================================================================================================
& e* s7 [5 y: ?4 n7 W! p& g8 r/ ~1120183 F2B DESIGNVARI Variant Editor Filter returns incorrect results.4 b- L9 g1 C, q) K/ _
1202715 SPIF OTHER Objects loose module group attribute after Specctra
6 a% z& O$ |- L9 ]9 q1203443 ADW LRM LRM takes a long time to launch for the first time7 [ c- s+ v. K$ q' n2 F; e
1207204 CONCEPT_HDL CORE schematic tool crashed during save all h2 q$ K' k+ s8 u& s. X+ {
1222101 CONCEPT_HDL CORE Pins are shorted on a block by the Block's title delimiter
$ D$ Z' C0 t& a- i Y4 t1223709 FSP FPGA_SUPPORT Need FSP model of Altera 5AGZME3E3H29C4 FPGA
1 X6 R3 h2 I: S B9 a1 ?4 e: _1224025 ALLEGRO_EDITOR INTERFACES The 3D viewer when working on a brd file shows package placed on BOTTOM side of my board while it is present on TOP side
6 i) P5 I% m7 Q, ?1225591 F2B PACKAGERXL Aliased net signals starting with equals sign are not resolved correctly in cmgr
2 ?* c8 p9 i$ w5 u+ d4 y1226480 ALLEGRO_EDITOR EDIT_ETCH Routing time is took to double increase when using the Add Connect because DRC is Allowed.7 x9 o8 Y. o$ Q( g, }
1229234 FLOWS PROJMGR Can't open the part table file from Project Setup" W3 ]- l4 j, N$ }- v+ Y; x9 U
1229555 ALLEGRO_EDITOR ARTWORK IPC-2581 not recognizing pin offsets correctly.
0 Q( V9 Y7 b. I' A0 D& b1229610 FSP FPGA_SUPPORT New FPGA device request - Altera Cyclone V ST: 5CSTFD6D5F31I7; I# [4 k& ]$ U. c& @$ F- r
1229664 ALLEGRO_EDITOR SHAPE Shape not voiding different net pins causing shorts with no DRC's
. W5 L$ e/ P9 {/ g) _) d1232601 ALLEGRO_EDITOR MANUFACT Cannot add test point to via on trace.
4 b8 a/ [3 j; P) @9 J: O% k: U1232772 ALLEGRO_EDITOR DATABASE When applying a place replicate module Allegro crashes/ N7 U3 f3 w+ S& ~# s4 s
1233216 SIP_LAYOUT DIE_ABSTRACT_IF Allow more than 2 decimal places for the shrink facor in the add codesign form
) X' ]# T$ ]8 X# z, A1233690 PDN_ANALYSIS PCB_STATICIRDROP PDN IRDrop: Mesh mode in Report is incorrect.
S, C" h! k% }$ d" i1233977 ALLEGRO_EDITOR INTERFACES single shape copied and rotated fails to create when importing IDX2 X8 w2 I7 w7 c. z7 h/ u5 F' ]8 m
1234357 SIP_LAYOUT SCHEMATIC_FTB DSMAIN-335: Dia file(s) error has occurred.
: u, d5 j7 Y+ h% ?1 h8 l1234450 ALLEGRO_EDITOR INTERFACES clines, pads, etch shapes to be at the same level with the board when viewed in STEP viewer.
8 S7 W! Q3 l* E9 g5 \1235587 PSPICE MODELEDITOR PSpice Model Import Wizard does not display symbol graphics for DE-HDL Symbol
9 H- ]# e" r6 e# E, r5 Z1236571 ALLEGRO_EDITOR GRAPHICS Allegro display lock up and panning issues
2 R0 w6 R5 l- u) q1 r% w7 @+ w1237415 ALLEGRO_EDITOR INTERFACES Multidrill pad is exported with single Drill in the STEP File8 e' n, i N& Y& j
1237807 ALLEGRO_EDITOR SCHEM_FTB The line feed code of netview.dat0 E# Z) n: c* p; O1 w( Q d: |
# d/ ^0 u! m; ^# b( ]+ A' p& [
DATE: 02-7-2014 HOTFIX VERSION: 022( z K6 Z8 ^: A) X2 }% Q7 C: R
* ]1 ~5 C2 m1 g0 Y' gCCRID PRODUCT PRODUCTLEVEL2 TITLE
) B' @4 g# q7 q===================================================================================================================================( C% d8 Y- R' L" n
192358 ALLEGRO_EDITOR PADS_IN Pad_in does not translate some copper shapes
) p( y# L, w. ?) I% w222141 ALLEGRO_EDITOR PADS_IN PADS_IN: Extra shapes are created when importing PADS design
u( L& X7 a! x+ s$ d" c274314 ALLEGRO_EDITOR PADS_IN PAD_in boundary defined for flooded area be translated DYN
) N6 D0 I: U R413919 ALLEGRO_EDITOR PADS_IN pads_in cannot import width of refdes.
; H! Y, s- F/ i+ C% X: a609053 ALLEGRO_EDITOR PADS_IN "Mils to oversize" of "pads in" did not work correctly for MM data.+ t7 L# e& E: S, [ v+ S8 ~6 Y( r
666214 CONCEPT_HDL OTHER Option to increase Line thickness in publishpdf utility- ~* J: n( ~% D
738482 ALLEGRO_EDITOR GRAPHICS Export image creates black image with Nvidia GeForce 8400M GS Graphics card; ~, K# V3 y ]! t
982950 CONCEPT_HDL OTHER change the mouse button for the stroke to have same function with in pcb editor) q1 y% P2 P- J- z' b" w4 G% D7 a
1020886 SIP_LAYOUT LEFDEF_IF a quicker way to promote die pins (by importing macro_pin list)
" B) i" i2 [$ P! p1032678 CIS VIEW_DATABASE_PA View Database Part gives incorrect result in complex design with variants.
) ^6 i& V) s+ Q. `1033864 ALLEGRO_EDITOR PADS_IN pads_in doesnot translates teardrops present in design' v, H* i5 \9 c6 X( [
1054862 CONCEPT_HDL OTHER Option to increase Line thickness in publishpdf utility$ {+ }+ [. R$ q
1055252 FSP PROCESS Add a synthesis option to target a group to contiguous or consecutive banks
+ r! Q! A5 U! c: D' |/ t1100772 CONSTRAINT_MGR OTHER In Constraint Manager > DRC > Spacing the Show Element DRC totals are wrong.
. a7 }7 {6 P, Z6 {) }1 D9 `1135020 CIS DESIGN_VARIANT Variant list is showing wrong results for hierarchical designs
* G7 P& r$ Z& f& H) \: @1138951 SIP_LAYOUT DIE_ABSTRACT_IF Fix die abstract r/w to properly support pinnumbers on ports
5 C6 C" @8 w: Y# Q1140042 CONSTRAINT_MGR OTHER Diff_Pair lengths and analysis are lost after closing and opening Constraint Manager.# Z5 I! J1 d0 A7 s/ Y. ]0 Z
1143662 ALLEGRO_EDITOR INTERACTIV Enhancement Request for RMB - Snap Pick to options increased to include Pin edge
4 O3 m3 g# ^( {- n0 U, C( W1147961 PSPICE SIMULATOR Simulation produces no output data/ z% t' M7 s6 A1 Z8 H7 a* \) R3 k% }
1150874 ALLEGRO_EDITOR PADS_IN Dimensions in PADS are not translated correctly during pads_in translation
( r. e2 ]9 X! j- D0 \# S0 L1154184 CONSTRAINT_MGR CONCEPT_HDL Difference in the way topology is extracted in 16.3 versus 16.6' D: |8 N7 w+ ~+ H1 s6 x: O, s9 f
1154770 CAPTURE PROPERTY_EDITOR Variant Name property doesn't show value in Variant View mode8 A4 P- j' J+ ^+ I& x
1158350 CONCEPT_HDL CORE Need a warning Message while importing a 16.3 sub-design in a 16.6 Design
% K/ z1 ^) x f3 Y, L1162347 ALLEGRO_EDITOR EDIT_ETCH Enh- Allow new option in Move command such that it allows stretching etch using only 45/90 degree segments directly( v* ~6 v0 W" x5 G7 Y
1165553 ALLEGRO_EDITOR INTERACTIV Subclass list invoked from the status window does not represent correct colors.; @4 L% b1 W8 ?6 \* H
1168079 FSP MODEL_EDITOR Clicking OK or Save As in rules editor allows user to overwrite the master with no warning1 }. ]3 ?! G3 ` Y A
1172043 SCM OTHER : in pin name causes SCM to crash
0 Y% o, T$ T' L' {- G1172207 CAPTURE STABILITY Capture crash while adding new part from Spreadsheet
/ e3 e$ c! U* K( g* v# d( T* g1172743 ADW TDA Allowed character set for the check-in comments is too limited2 X& z5 B% s$ \1 V, R0 U$ Y& Q5 e" z
1174099 SIP_LAYOUT WIREBOND Option to reconnect wire based on 縫in name� in the Wire Bond Replace) i: M8 b! I. _: u. O& n. @3 Z: S7 `0 P
1177672 APD IMPORT_DATA Netlist-in wizard didn縯 provide detail information about what columns have been ignored by import process" A0 T& I ]7 Q* E/ r+ s
1177714 CONCEPT_HDL RF_LAYOUT_DRIVEN RF component's LOCATION property can not be set to invisible+ U2 ^; i8 C {$ W1 u5 D" T
1177820 CONSTRAINT_MGR INTERACTIV Done the Allegro command when attempting to launch CM
6 i R" y' h# G% a6 X1178586 ALLEGRO_EDITOR EDIT_SHAPE Number of digits displayed after the decimal point of Shape Creation function does not match the Accuracy of BRD- ?' }1 j, D5 B" n+ S( j! r! v" j
1179688 PSPICE STABILITY pspice crash for particular HOME variable vlaue# U- X, N4 Q) Q) }8 K5 W/ h- |
1179827 SIP_LAYOUT OTHER SiP Layout - Spreadsheet to Symbol export - enable field to add Keywords for data fields to excell cells
- [5 G) t% K: O: c- N5 X1179879 SIP_LAYOUT STREAM_IF Data file corrupt when exporting Stream data from SiP database.
( ]) i4 v: ^+ d8 Z, ~, D! M3 |1180164 F2B BOM BOM csv data format converts to excel formats
! ]; g' c6 b, r/ z1180477 ALLEGRO_EDITOR INTERFACES IPC-356 output is listing a duplicate location in the comment section( o; @4 c" Q; I" [
1180932 SIP_LAYOUT OTHER SiP Layout - Symbol to Spreadsheet add option for writing to existing spreadsheet3 ~* H& l0 b# R: i' {
1181377 ALLEGRO_EDITOR INTERACTIV Pick Releative does not work correctly with RMB-Move Vertex7 ` }$ n! j" F. s8 p' `+ C
1181516 ALLEGRO_EDITOR DRC_CONSTR Getting a "Thru Pin to Route Keepout Spacing" when there should not be one.$ d/ b4 S" D! r1 b4 [9 T
1181739 GRE CORE Running Plan > Spatial crashes GRE5 N4 k: ]$ w9 L0 B0 |6 M+ b5 t
1181935 ALLEGRO_EDITOR DATABASE Enh. Property that allows internal C-C DRC errors" @6 x; {! x8 }+ @# q' g* v
1182185 SIP_LAYOUT OTHER SiP Layout - Import symbol spreadsheet - suppress Family for the font in the XML spreadsheet
5 S/ ~, F4 d0 B @3 ~3 }( a6 u1182566 SIP_LAYOUT OTHER SiP Layout - Spreadsheet to symbol - Enhance ability of spreadsheet exchange to allow for a portion of a full pin map* t6 V- l+ S7 c$ ?+ \) u4 {$ E: T
1182599 CONSTRAINT_MGR DATABASE CM Prop Delay Actuals do not update after Z Axis option is turned ON or OFF and Analyze is run.
; m1 L5 Q { T4 t. k5 _1182892 CAPTURE SCHEMATIC_EDITOR Pspice marker rotation before placement
! c( d) c- I5 r1183682 ALLEGRO_EDITOR DRC_CONSTR Implement Nodrc_Sym_Pin_Soldermask & Nodrc_Sym_Pin_Pastemask to symbol level
% u! b% [, s' C- s5 A1185445 SIP_LAYOUT DIE_ABSTRACT_IF Die abstract export needs to be able to select xda file type when browsing
. O; ~/ g3 p. I4 i. t1185932 ALLEGRO_EDITOR SHAPE Soldermask in solder mask void DRC6 J5 `$ T' s. T& K
1185946 CONCEPT_HDL CORE Ericsson perfomance testing report 5 sept 2013
4 i- P+ s8 O6 H1187213 FLOWS PROJMGR Unable to lock the directive: backannotate_forward! ]: h+ k# i4 W+ W
1187444 ALLEGRO_EDITOR DRC_CONSTR With this design Database check prompts error "SPMHGE-47: Error in call to batch DRC" ~, j2 F+ d+ N( E$ Z
1187597 ALLEGRO_EDITOR DRC_CONSTR No Package to Package Spacing DRC error, when symbol overlap sideways at 45 degree.# z* H# l1 L$ s5 o
1187723 FSP PROCESS Synthesis can fail depending on component placement/ J; ?5 Z" q" t: B: R
1188164 SIP_LAYOUT OTHER SiP Layout - Spreadsheet interfaces Import Export and Add Component - include Keyword for NET_GROUP
9 y! J2 S% c2 P7 P8 V6 b1 d6 }1188245 CONCEPT_HDL CORE INFO(SPCOCN-2055): You cannot run the CHANGE command in a read only schematic
0 ^# M- _* W$ x1 \: J+ n& {' o1190927 CONCEPT_HDL CORE Check sheet does not report shorted signal/power nets if power symbol is connected to a pin/ a0 l8 [1 F: @
1191497 ALLEGRO_EDITOR INTERACTIV ENH: Adding names to the text block parameters numbers
( s" \- ~2 q; T+ i7 a4 e! Y1 C1192005 SIP_LAYOUT IMPORT_DATA Import SPD2 is missing 1 smart metal shape from file
1 t( r6 _" C& D0 D* t1 I3 A1192204 ALLEGRO_EDITOR EXTRACT Need ability to extract vias that are labeled as microvia
6 k% ^$ K! C* _( W1193063 ALLEGRO_EDITOR MANUFACT TestPrep log displays "Pin is not accessible from bottom". The component is through hole.
! E) W8 w, F0 U" F1193418 ALLEGRO_EDITOR GRAPHICS 3D Viewer can`t export image in both SPB166S015 and SPB165S047( u3 E3 S. z; e9 h, j3 N& g
1194305 SIP_LAYOUT EXPORT_DATA export package overlay creates file with no package info
! M, o2 i" k3 q' y: p0 H; U1194418 APD IMPORT_DATA issue when do File->import->netlist-in wizard
1 q3 G2 U! V. G+ p I. P1195279 F2B PACKAGERXL Ptf files are not being read when packaging with Cache; p2 V. Z- S' c2 I, O
1195374 ALLEGRO_EDITOR INTERACTIV Modules are not showing up in Tools > Module reports
: |! E5 Z; ^; f2 z6 S/ d; E1196603 SIP_LAYOUT EXPORT_DATA Change form for "Write Package Overlay..." to better support longer lists of routing layers
( P* x3 k5 a" {$ [: o i: x1197302 CONSTRAINT_MGR UI_FORMS Inconsistancy in selection of object for Spacing Constraint Worksheet
( W' l$ f% r$ J, y' F! N1197399 CAPTURE OTHER Draw toolbar disappears when using Print Preview
Y5 |5 {4 ~ r, p1197543 ADW TDA TDO does not correctly show deleted pages
- I5 f: n/ v% g7 k0 `1198033 CONCEPT_HDL CORE Signals do not get highlighted when Show Physical Net Name is option enabled
+ o* b3 X( ?2 \2 M) I1198468 ALLEGRO_EDITOR GRAPHICS 3D_step model does not show the correct view in 3D_Viewer when symbols have multiple place_bounds.( N, K' e. f( M! Q; p9 t+ y8 v
1198617 CIS GEN_BOM Mech parts are showing with Part reference in CIS BOM
/ V" X, m. C: p; v0 u1199764 ALLEGRO_EDITOR SHAPE Allegro crashes when trying to delete small island on POWER layer.
( f2 o/ M1 Y; }1200232 ALLEGRO_EDITOR INTERACTIV Moving all items including board outline which is made of lines does not move the board outline in General Edit Mode.
$ c* q" m5 `; j0 _. d1200748 ALLEGRO_EDITOR INTERACTIV Additional pin edge vertex object to snap pick
. `- R" q+ n0 M0 i$ \1201056 ALLEGRO_EDITOR DATABASE Unsupported functionality strip design creates a .SAV file
! i! K, f) I2 O/ z E- P$ ]1201638 CIS PART_MANAGER Part retains previous linking inside the subgroup
3 X# X+ G: f0 X$ R6 [1201834 ALLEGRO_EDITOR PLOTTING Bug: Import Logo command changes resulting imported object# m$ D9 Z0 W+ V
1202406 SIP_LAYOUT OTHER enable the dynamic display of component pin names for co-design dies in Sip Layout3 E! G' W* q( v# }
1202431 CONCEPT_HDL PDF The publishpdf -variant option should have a "no graphics" option- R" p( E) D ?% y& g' R3 c
1202717 ALLEGRO_EDITOR DATABASE About Warning(SPMHA1-108):Illegal line segment ... end points. y( \7 ~/ Y' b7 \5 c
1203459 CONSTRAINT_MGR INTERACTIV Object Report has no mechanism to output information for a specific design.
& }; m- p0 D0 p" |( B7 w1204544 F2B DESIGNVARI Variant Editor does not warn on save if no write permissions are on the file
' F) j& \5 \( i. ?7 C, ~) P1205500 FSP CONSTRAINTS MAPP FSP FPGA port mapping VHDL syntax
, y" ~: y4 D# G; o' G4 x( ^1205952 ALLEGRO_EDITOR GRAPHICS Step Model for Mechanical Part is visible in 3D viewer only when Etch Top Subclass is enabled) Q5 u3 f% h' T
1206103 SIP_LAYOUT IC_IO_EDITING add port name property to pins, and add Skill access I/O driver cell data
* d9 s8 L4 m. j4 A1206546 CAPTURE ANNOTATE User assigned refdes are resetting when 緼nnotation type� is set to 縇eft-Right� or 縏op-Bottom�
" e) e6 ]# X1 K; T' T1206561 ALLEGRO_EDITOR GRAPHICS Not all mechanical symbols made with Step files are displayed in the 3D View# }4 S9 i, v/ K$ V9 h& Q& L7 V3 t
1207125 SIG_INTEGRITY ASSIGN_TOPOLOGY ECSet mapping wrong for 2 bit in a 4bit bus0 L. S* s5 [8 E3 z
1207386 CAPTURE GENERATE_PART Altera pin file not generating the part properly
+ K+ E" \% g: f4 \3 G! s0 Q1207629 CAPTURE TCL_INTERFACE Bug: GetMACAddresses tcl command not working
+ `5 m% U6 ]1 K; k# d" r1207994 CAPTURE TCL_INTERFACE TCL pdf export in 16.6 fills DOT type pins with black color) [+ e- E$ A* x5 W+ r% C
1208017 F2B DESIGNVARI sch name is not same when updating Schematic View while backannotating Variant
: C& U" n- o& q! ?& M* x1209363 ALLEGRO_EDITOR INTERFACES When placing pins using the polar command the tool returns 4500.00 for 45 degrees." o0 ?# l, F5 c+ |! K5 J
1209769 CONCEPT_HDL CORE Top DCF gate information missing3 i: Z* p/ [( b! _! k
1210194 CONCEPT_HDL CONSTRAINT_MGR HDL crashes with Edit Via List dialog box
2 y" q! w6 A) @$ l1210442 CONCEPT_HDL INFRA Save design gives ERROR(SPCOCN-1995): Non synchronized constraint property found in schematic page
: k B! G1 m0 x6 ~1210685 ASI_PI GUI User can't edit padstack in PowerDC-lite
6 ~/ t8 J9 o' L( r% R8 E, u1210744 SIG_INTEGRITY SIGWAVE SigWave: FFT Mode Display unit seems not to be correct
( |+ T- c4 p. y& F+ C. X1210829 CAPTURE NETLIST_VERILOG Shorted port is missing from verilog file9 C% |+ u$ \0 G+ K: F
1210850 CONCEPT_HDL CORE DE-HDL backannotation crashing after instantiating specific cell from Ericsson BPc Library, S0 h0 j* P8 a# u
1211620 ADW COMPONENT_BROWSE Component Browser Performance
) U2 N. M, T7 h7 _1212102 ALLEGRO_EDITOR INTERACTIV Shape edit boundary adds arc mirrored to the highlighted preview." H* W, g1 A) o7 d
1213294 CONCEPT_HDL SECTION DE-HDL windows mode multiple section fails to section first contactor pin from column of individual pins0 j; w, p5 Y' A" B3 y: e" i4 O9 M
1213402 APD DATABASE The old "ix 0 0" fix is now causing the features to lose nets entirely.
# X, P' R3 w* u) R% ?1213694 ALLEGRO_EDITOR PARTITION Via connected to Dummy Net pin in Partition gets connected to shape on the board after importing partition( a+ ]3 e+ ~3 H( P7 |6 I
1214247 CONSTRAINT_MGR UI_FORMS Selecting the "All" folder in Spacing Constraints in CM does not automatically select the first column for editing, s6 g3 ^& K$ A4 _
1214320 SIG_INTEGRITY SIGNOISE signoise command with -L and -k option
/ S8 g+ K3 q; N& z ], N1214433 CONCEPT_HDL CORE Genview does not update sym_1 with ports added to the schematic
0 y/ F, @' H" p1214909 ALLEGRO_EDITOR NC NC Drill Legend show extra rows for drills4 y8 y# e* ^3 b/ M
1214916 SIP_LAYOUT OTHER package design integrity check for via-pin alignment with fix enabled hangs
7 k) a! \# q# b8 f1215954 SIG_INTEGRITY SIMULATION Cycle.msm does not exist error when simulating extracted net
- f5 K4 c' M* t6 T1216328 CAPTURE STABILITY Capture crash
7 a; i9 m; }2 }0 L3 u; `% r# z5 ]1216993 ALLEGRO_EDITOR DRC_TIMING_CHK Allegro crash on SPB16.50.049
3 c- m5 t, F9 i/ D! s& g: L% k5 P1217450 F2B BOM ERROR 233: Output file path does not exist2 P1 R; r: Y3 F
1217612 ALLEGRO_EDITOR INTERACTIV Replace padstack will not replace padstacks that have multiple alphabetic characters in the pin name - AB21-AB377 k' g6 G- \" f
1217823 ALLEGRO_EDITOR INTERACTIV Compose shape fails with SPMHIS-473
" e- M# n5 m* ]4 e# S9 P1217887 ALLEGRO_EDITOR INTERFACES An undo option to be made available in the STEP Package Mapping window7 L2 D# d1 v3 j+ c4 y4 H" J. f
1218665 ALLEGRO_EDITOR INTERFACES In step viewer, the bottom side parts are placed above the pcb board surface
$ @4 ?' [% @: K. g1 g+ i( s1219053 PSPICE PROBE PSpice crash with the attached Design) |3 `! n4 N$ V( f5 e& `6 c
1219067 ALLEGRO_EDITOR EDIT_ETCH dynamic fillets behavior is unstable, U" j1 v* ?5 j
1219095 ALLEGRO_EDITOR MANUFACT Design Cross section chart is tapered for two layer board0 d* V4 g z6 T) I* e3 z
1219126 ALLEGRO_EDITOR SKILL Skill issue with axlRefreshSymbol()
( h8 s4 e, e8 R: c/ s7 P1220701 ALLEGRO_EDITOR INTERACTIV View > Windows > Worldview (showhide view command) fails with command not found
" W7 j o0 y6 X+ Z" y( R8 o1221057 ALLEGRO_EDITOR REPORTS Units in Cross section report for spacing is not synced with the design8 S0 `5 M' U9 M* k" |+ C _7 v
1221139 ALLEGRO_EDITOR EDIT_ETCH Delay tune is not tuning differential pair7 @% G) \( X0 Z3 u
1221157 SIP_LAYOUT IMPORT_DATA import spd2/na2 file is not importing data correctly into sip
3 o- @. s1 ~& ^* F1 v$ y; N1221163 SIG_INTEGRITY GEOMETRY_EXTRACT Simulation aborts with severe convergence issue when coupled vias is enabled.% w& R9 J# l" W& f
1221416 ALLEGRO_EDITOR DATABASE strip design for function type
& m5 n0 x y1 J3 z' t1221931 ALLEGRO_EDITOR DATABASE Fatal software error when embedding component
. R3 E- G4 v! u' m' E7 m8 ?1222105 CONCEPT_HDL CORE Moving Pins around the edge of a Block causes the text of the pin to change its text size.8 b; x. ?: J& k, X
1222124 APD DATABASE Same Net DRC's exhibiting inconsistent behavior.# i* F. }' ~9 i$ O: t/ H4 ?( r& n- }
1222272 SIG_EXPLORER EXTRACTTOP Cannot extract net or open SigXplorer after selecting a netgroup( p: k5 M' P* h. b
1222329 ALLEGRO_EDITOR SHAPE STEP-Model Symbol which has place bound bottom is on Top
0 h" t% y) g7 n1223183 SIP_LAYOUT BGA_GENERATOR Getting an incorrect error message when using the BGA generator with a long BGA name.
3 y/ X7 \7 U4 E+ H$ @1223662 ALLEGRO_EDITOR REFRESH Allegro crashes when trying to refresh symbol( I, [* b4 \ x% C! K
1223932 CONCEPT_HDL CORE DEHDL block desend does not find 1st page if its not page1' |- R; G+ q" F9 |7 O
1223940 CONSTRAINT_MGR UI_FORMS Unable to change CLOCK name in Setup/Hold Worksheet under Timing in CM.* K- m. Y0 k3 D. B, A
1224127 SIG_INTEGRITY IRDROP Is the old static IRDrop in 16.6 officially supported?" @/ Y. t* j8 g$ D
1225492 PCB_LIBRARIAN CORE PDV expand vector pins resizes symbol outline to maximum height again: w- `+ d: D; s2 P, [0 |9 Z2 C
1225546 CONSTRAINT_MGR ECS_APPLY nets where the referenced ECS maps correctly in constraints manager for front end but not in back end6 `5 v2 P- `* v0 n- D
1226405 ALLEGRO_EDITOR INTERFACES File > Export > IDF ask for filter config file eventhough it is created in same session and stored in parent folder- e% R$ A$ x: V" I3 ^" u2 ~% g( n
1226448 PDN_ANALYSIS PCB_STATICIRDROP License failure about PDN Analysis with XL and GXL
( F/ T: U( h# ?1228721 SIP_LAYOUT OTHER File Export Netlist Spreadsheet enhance sort to be a natural method per Jedec according to customer
/ E3 s/ S1 H# B/ _& i: g/ P+ C* \* ^# x' n# H& e
DATE: 12-20-2013 HOTFIX VERSION: 021, Q2 o/ m" C8 B7 f# A+ w7 `) |" ]
6 _0 v& T4 l! ^2 a: \CCRID PRODUCT PRODUCTLEVEL2 TITLE4 \ X0 i# l- u7 G; g
4 ^ m/ z3 C$ M5 s$ }1214932 ALLEGRO_EDITOR OTHER Allegro will crash when performing show dimension on linear dimensions.
' S' ^; _8 b2 v& B1215045 ALLEGRO_EDITOR SKILL Successive file open / ipc calls crashes Allegro 16.6) u. }* t2 z! e
1215115 ALLEGRO_EDITOR NC drawing name doesn't display in the ncdrill.log file
7 G1 Q. p7 P* o' Z# u$ k1216028 SIP_LAYOUT PLACEMENT Design will not update embedded component symbols.
) N9 s# P* B6 n* w. A J4 b1218451 ALLEGRO_EDITOR DRC_CONSTR Route Keepout to Pin DRC created even after adding Void in RKO shape7 F2 Z$ j$ N, l# ~! B- u8 r: M
1218636 ALLEGRO_EDITOR SCHEM_FTB netin process will rotate embedded symbols
" U5 H6 b: \) d0 i1218706 CONSTRAINT_MGR CONCEPT_HDL NCC associations get deleted from FE CM+ f; Y6 v5 l( S3 F6 I S6 n
/ T0 O' |+ Q4 A. M6 M( sDATE: 12-4-2013 HOTFIX VERSION: 020
Q% B! C" J' y. u7 b9 l9 B: I( e5 v, Y===================================================================================================================================
- F' |" D' ?: G' X4 NCCRID PRODUCT PRODUCTLEVEL2 TITLE8 C& M4 h* w/ ?% j7 X+ W1 O2 i
===================================================================================================================================- x' v# }5 a0 p* {
1116426 F2B PACKAGERXL Packaging in 16.6 increased by 3 folds compared to 16.3
$ d$ Z; z4 P! u2 m. D/ ~$ e* d+ Q1190095 CONCEPT_HDL CORE In Windows mode select the part and click on version placed selected version +1.' O; r7 v0 ]" {$ \7 \
1199410 CONSTRAINT_MGR CONCEPT_HDL Constraint Differences Report window hangs in 16.6-s0168 B/ s, l: e3 s7 {: Y0 W. c4 R8 A
1199425 CONSTRAINT_MGR CONCEPT_HDL Import Physical fails (the cmfeeback.exe has stopped working) in 16.6-s016
' T ~ ^% q+ d. S, |$ _1199700 PSPICE NETLISTER Netlist fails on addition of netgroup
( f r/ _, z, r9 ^1 m1200936 CONCEPT_HDL PDF publishpdf fails if UNC paths are provided from the command line
* C, |. Y0 V1 U! R7 _- e7 k b; n1202391 CONSTRAINT_MGR OTHER Getting 'An Invalid argument was encountered' when generating Net Class-Class report in CM8 A1 K0 L) V3 I* A. G
1202587 CONCEPT_HDL CREFER Crefer schematic reports cannot be deleted on Linux.
! C5 F+ o. c3 ~. n1203143 GRE CORE GRE crashes on running Plan > Spatial
; P% b: |* _2 i# V! l9 X1206019 ALLEGRO_EDITOR INTERACTIV Allegro needs to be restrated to read steppath with 16.6 S017
# q2 y- C: v. H# G% ^5 m8 h2 s1207050 ALLEGRO_EDITOR INTERACTIV Refresh Padstack fails on Warning
& t W; L: R' ^: d& \* B1207178 CONCEPT_HDL CORE Aqua color on wire does not matches icon color7 I& H& \7 a* W5 m }3 C0 ]! f7 Q6 Z5 `
1208152 F2B DESIGNASSC ERROR: Dictionary File: cmdict.l could not be found
. o2 }5 M9 I' ?2 b9 Z6 {1208276 APD STREAM_IF Stream in fails to import what Allegro exported
* h6 O1 J6 p4 t. x# L7 I ?. g* `1 s' O1208345 ALLEGRO_EDITOR SKILL Why axlChangeLayer not working for shapes on this attached skill file?3 n2 |$ l: ~/ r$ v6 M
1208351 ALLEGRO_EDITOR SKILL axlFilmCreate do not define the IPC2581 domain correctly.
( z$ ^/ H/ c" m& B% v1208467 PCB_LIBRARIAN VERIFICATION con2con mangles cell data after checking cell having syntax errors on part_table6 L. @5 I4 r5 p% e7 U
1208579 SIG_INTEGRITY GEOMETRY_EXTRACT Incorrect traces are extracted when void area is less than anl_min_void_area setting/ q! W$ [3 r9 M; G7 l2 U! ~# f
1209347 ALLEGRO_EDITOR PARTITION Import partition that has diametral dimensions will crash Allegro
7 q+ D3 ]- `, |. [6 i6 |1209897 ALLEGRO_EDITOR PADS_IN Pads_in will not translate design.* B3 O/ A* f$ d* f4 }/ A4 Q( v4 X; i
1209902 PCB_LIBRARIAN CORE PDV crashes reading part
% o; z; j9 f7 G- d/ Q& Y8 r i* [1210183 PSPICE SIMULATOR SimSrvr crash with ORPROBE-3211 RPC Server unavailable Message
/ y8 w$ d- X4 q4 }$ t! P1210408 ALLEGRO_EDITOR EDIT_ETCH AiBT hangs when doing interactive breakout on bundles using latest hotfix.4 X# B5 `+ d7 p5 Q8 o* B$ U6 a: ~
1210443 ALLEGRO_EDITOR INTERFACES Allegro Design Publisher does not create fully searchable PDF for some of the text that are present or certain layers
8 M+ {- w0 J8 l4 r& o9 e5 o/ j1210876 CONCEPT_HDL ARCHIVER Archiver wrongfully deletes directories.' n. u0 r1 }7 e" N2 ]
1211839 CONSTRAINT_MGR DATABASE Topology can't be extracted correctly. v% r7 N( l2 h
1212709 ALLEGRO_EDITOR DATABASE No connect can`t be detected in SPB165S048
# S0 B0 n# {' x2 r1213752 CONSTRAINT_MGR OTHER "Show Constraint Difference Report" option at File > Import > Logic does not retain the last setting" B' \! B. q8 H3 x
, e# S# D8 l, J7 X: n2 X8 nDATE: 11-15-2013 HOTFIX VERSION: 019
/ P& Z) \* l8 F) `% T0 N===================================================================================================================================- T# d0 {$ e$ b% u6 p
CCRID PRODUCT PRODUCTLEVEL2 TITLE! Z1 U, X) s4 _9 m
! @1 |$ a5 P. |- I! {1176155 CONCEPT_HDL CORE Graphics remnants with 16.6 QIR 3
% o/ t! \" U' }% d5 G$ z. { d/ u1178272 CONCEPT_HDL OTHER Verilog netlist does not include split blocks correctly) A5 D. x+ A! U6 D
1190782 FSP FPGA_SUPPORT Support for Altera > 5SGXEA9N2F45 device.
" k% \ w* m2 O" ]1194140 ADW LRM SYNC_PROPERTIES is not resolving issues a based sync_properties settings
6 E0 {- L/ I) }% p r. |1195744 APD EDIT_ETCH Diff_Pair routing fails on certain Uvias in the pair. y6 B3 y Y K! ?5 o6 v5 f
1196704 ALLEGRO_EDITOR INTERFACES ENH: During ipc2581 export checkboxes corresponding to 縈iscellaneous Image Layers� should automatically get selected" b$ h: G( Q8 ~2 q2 q8 ?- Y" r
1198340 ALLEGRO_EDITOR OTHER Multiple -product option on the Allegro command line does not access the second -product
& l U3 a' i" c0 r/ H/ r1198596 ALLEGRO_EDITOR INTERFACES When copper thickness is increased for the outer layers, step Viewer does not show correct component position.
3 H$ D: c" g$ K. n" a1 P1199673 PCB_LIBRARIAN OTHER Component Browser fails to load footrpints if they are set with UNC path
3 S5 e( B, s7 |. z) X6 d1199889 ALLEGRO_EDITOR DATABASE Allegro crashing with latest hotfix.
& r. n8 I7 h. P7 X1200303 ALLEGRO_EDITOR GRAPHICS 3D Viewer does not update after changing STEP model mapping/ V6 @8 S& \/ v' j! q; w* V
1200449 ALLEGRO_EDITOR REPORTS Allegro crashes when generating Net Loop Report.4 C0 X5 R; h M# J; \
1200915 ALLEGRO_EDITOR DATABASE Reducing accuracy of this specific design crashes Allegro
+ N8 e! S- x E9 F' ^# J: U1201011 ADW COMPONENT_BROWSE Component Browser crashes in DB mode% J% w- j1 G6 M2 R' f0 N( `: q& A
1201376 ALLEGRO_EDITOR INTERFACES Allegro hangs when trying to map a specific STEP model to a package drawing.
# T8 m& k" K S1201897 SIP_LAYOUT IMPORT_DATA BGA Pin Colors not matching the Colors defined in the Symbol Spreadsheet after updating.
1 z) r8 P* L( R1202709 ALLEGRO_EDITOR INTERFACES STEP File generated from Allegro is not overwritten when the variable "set ads_textrevs* W% f/ m$ h) ~$ a r
1202820 ALLEGRO_EDITOR INTERFACES Different xml generation for same step model on S106 and S017$ \8 D1 f/ {; u& I7 R
1202842 ALLEGRO_EDITOR INTERFACES Step model invisible for one pin dra in allegro 16.6 symbol editor7 g1 u; l7 o! G2 O# {' m B# Q. P
1202983 ALLEGRO_EDITOR SHAPE Shape voiding creates DRC with Route Keepout
, d! G6 L- W$ g0 x1203125 ALLEGRO_EDITOR OTHER Exporting STEP file with External copper enabled does not show all copper when viewed with Solid Edge or Inventor4 ^7 |1 `( n' B `; ^- c
1203236 ALLEGRO_EDITOR INTERFACES IPC2581 output with crosshatched shape is not correct7 [( @3 u* T5 ^
1203995 CONCEPT_HDL CHECKPLUS CheckPlus rule, local_signal_no_offpage_body, getting an incorrect failure.
" n% ^; X' j" \4 f1204629 ALLEGRO_EDITOR SKILL axlUIDataBrowse crashes the editor or returns error# H2 C* }% O! a F* C. W
1204640 SIP_LAYOUT DIE_EDITOR Concurrent co-design update fails1 s) T* G6 H8 {) s$ A: y
1204881 SIP_LAYOUT BGA_GENERATOR Pin numbers are messed up after deleting a pin at a staggered bga
# Z% u% v+ b+ Y3 k, m6 e8 h9 U1204885 CONCEPT_HDL CONSTRAINT_MGR Cant assign discrete models after the wrong model was removed.
3 a: f9 T. N# P- \+ R' ]1 U9 Q2 q1205374 ALLEGRO_EDITOR OTHER pdf out command creates incorrect drill Symbol Characters placement in pdf file when setting film mirrored.- j* K' r; O8 _1 _
1205729 SIP_LAYOUT DIE_EDITOR update of codesign db fails on exit from die editor
# g& g. e+ H& y4 w5 L$ @, u1205801 ALLEGRO_EDITOR OTHER Tool crash when do export IPF.1 n1 \3 t5 t7 C2 z+ J) _
1205881 CONSTRAINT_MGR OTHER In CMGR , Objects > Create crashes Allegro: _5 W6 [) r% A
4 U* x1 a8 |& a% V: ^3 }$ u4 V% E
DATE: 10-25-2013 HOTFIX VERSION: 018
% [) I5 T0 X" _7 }( x===================================================================================================================================5 w6 x* Q8 \+ |
CCRID PRODUCT PRODUCTLEVEL2 TITLE& D* T% P8 R+ \- _, S6 F3 b' Q! [! H5 |
9 p$ W o( r+ R: ^+ r) W, b: }9 M1118303 CONCEPT_HDL CONSTRAINT_MGR can not prdefine default units in HDL9 {3 j2 I; ^8 y2 j8 @' I
1174901 ALLEGRO_EDITOR GRAPHICS Spurious odd lines are shown in shapes and text that are not part of the design with opengl
- a m* _2 g2 s0 b' H1176990 CONCEPT_HDL OTHER DEHDL BOM tool doesn縯 see similar names.* ?* M+ V3 C1 ~& `
1179665 GRE CORE Plan Topological Crashes after around 8 hours of routing.
4 D) O) `) L+ i; B& H& ]. ~1188193 CONCEPT_HDL CHECKPLUS CheckPlus not recognizing PIN as a base object.+ n" `/ S2 f |; V$ [2 @
1189100 SCM OTHER Replace part in SCM using ADW as library fails: w E6 ]$ J! B6 j3 P; V, ~
1189507 SCM SCHGEN ERROR(SPCOCN-2009): Package error after second schgen run with Preserve mode.
$ g% ~, G6 B$ c* Z2 |, |* H7 d1192391 CONSTRAINT_MGR CONCEPT_HDL Restore from definition deletes local objects in other blocks
3 T' e$ Y8 J; M4 Q& a1194597 FSP OTHER Pin definition problem3 N1 c( r; d6 }' f. ]- O
1195202 SIP_LAYOUT LEFDEF_IF Cannot add .lef files in IC Library Manager. Getting warning message WARNING(SPMHLD-52)! K: C, V9 M% q& q6 a/ `6 h
1195309 GRE CORE GRE crashing during Plan Spatial." W7 F+ U$ ]+ {" ?7 S( [
1197262 ALLEGRO_EDITOR MANUFACT Angular Dimension created in symbol is placed w.r.t. board origin and angle is blank
$ [6 D# s- M2 F3 o+ n1198521 CONCEPT_HDL OTHER cadence DEHDL issue - Note for Hotfix_SPB16.60.016_wint_1of1
8 N! A* Y7 {8 W3 e8 r9 g. ~1199219 ALLEGRO_EDITOR INTERFACES Question on STEP Model export which uses PLACE_BOUND layer for any symbols that do not have STEP model mapped
0 s; Q4 A6 a3 E. Y. z1199235 ALLEGRO_EDITOR SCHEM_FTB capture's behavior is redundant while creating pcb editor netlist8 n5 r* V' C, P7 O: |
1199323 GRE IFP_INTERACTIVE Crash when importing logic9 }3 n/ u' D& s6 `
1199368 SIP_LAYOUT DIE_EDITOR Refresh of die abstract in die editor with this design takes over two hours
2 q1 f+ a' V" {1199760 ALLEGRO_EDITOR DATABASE Allegr won't display Soldermask Top layer
/ M: T4 z A7 V q2 _& y. l
3 o, {% p7 B) X+ h# V) cDATE: 10-10-2013 HOTFIX VERSION: 017
! E" R" u% ]* C7 H, A) U' Y===================================================================================================================================
# D' a+ M+ O4 C" ZCCRID PRODUCT PRODUCTLEVEL2 TITLE
/ e! k) p6 f$ H===================================================================================================================================
9 ^; D0 m8 b& v2 t1 z735992 ADW LIB_FLOW Create Test Schematic does not use the correct package type
9 q2 l0 X4 d# W' b7 V) u6 _1121403 FSP PROCESS "Assign to Pin" not getting obeyed by Synthesis.
% P; O, n- ~8 ]; _* K1141844 RF_PCB DISCRETE_LIBX_2A ADS Lib Translation Pin Soldermask/Pastemask missing
9 A9 A i B; Y7 v% m7 K1169269 ALLEGRO_EDITOR DRAFTING Dimension placed on package symbol moves to different place when it is placed on brd file.
# L. c" [4 Y0 K0 Z2 G# x1 _5 @/ G( a1170488 ALLEGRO_EDITOR MANUFACT Dimension text(on .psm) move to different position, when it is placed on .brd./ L/ E d' w, g# n4 e6 m
1173345 CIS CRYSTAL_REPORTS Crystal Report - Display Parameter dialog for export option
; I) e# E! L( S; @1181759 SCM LVS SCM Crash when doing update all that executing import physical command.
; J- W* Y/ P) j4 O5 I) w1182499 ALLEGRO_EDITOR OTHER Step export to include through hole padstacks (all pins and via) drill.! E/ B& K0 [3 S( L* g; D* K! w5 P" K' c* n
1184682 CONCEPT_HDL CONSTRAINT_MGR Net Constraint not transferring to layout from schematic
0 {& i+ ?3 P; K* Z u4 I1185524 F2B PACKAGERXL Enhancement User would like notification of pack_short in pxl.log
9 ?+ f u! @! J+ i1185902 ALLEGRO_EDITOR SHAPE Update shapes dont clear some diffpairs in HF15
. @' i, W( x: g: j- P: J1186152 ADW LRM Part Status for Deleted Part in LRM is distinguished with other part status
2 r g1 j+ f( e7 h6 W. \1186387 ALLEGRO_EDITOR OTHER DXF cannot catch offset value in s047 hotfix.
5 j0 O( ?% ?# a9 s1186805 ALLEGRO_EDITOR OTHER Exported STEP file missing multiple components placed on board! k& f# [( L7 T+ f" F( Y( r
1186818 ALLEGRO_EDITOR COLOR Custom color not retained during dehilight3 T$ ]3 ^ z* y# Y% w
1187196 CONCEPT_HDL CORE TOC not populating (page 1)% Z; X# Q- g* M; _' {5 u
1187667 F2B PACKAGERXL Existing hard LOCATION property in drawing was left unchanged/ E0 q6 y; @/ g
1188264 ALLEGRO_EDITOR MODULES Some fillets not regenerated in module created from a board file., V' R, `( ]5 F h: _% |
1190144 ALLEGRO_EDITOR OTHER Fillet shape is not genrated around cline, R1 {' ?9 c" B+ J' y6 @( m
1190210 F2B BOM The bomhdl.exe fails - MFC Application has Stopped Working
0 t1 |# p) }. a- t1190618 ALLEGRO_EDITOR GRAPHICS Enhancement for Visible grid' H' |0 M s, M5 r# `
1190813 ALLEGRO_EDITOR INTERFACES 3rd party netlist file in TEL format fails syntax check but imports successfully" ~4 q3 Q" ?. p8 g* W% {, F
1190895 ALLEGRO_EDITOR EDIT_ETCH Route delay meter displays violation when sliding diff pair
$ f, j# n5 A$ m" X, Q1190908 F2B OTHER DE-HDL aborts if dummy net is being cross-probed from PCB Editor, ?7 N- F5 A9 k$ Z/ A& ~
1190990 CONCEPT_HDL CORE Mismatch in .csa and .csb files
* h+ A$ H! T! R1191008 CONCEPT_HDL CORE Remove Binary File feature doesn't work, z3 [; I9 Y1 p7 ?: {: d% }) Y
1191514 SCM PACKAGER Packaging error PKG-100
+ p. y9 f: N- o9 N' [1191517 ALLEGRO_EDITOR DRAFTING Metric +tolerance when using dual dimensions is not displayed correctly; M* P L+ K t" Y- g$ I7 e
1192561 ALLEGRO_EDITOR GRAPHICS Padstack with offset is not showing correctly in the 3D Viewer.& c8 l8 _$ N2 n0 k& J* `
1192916 ALLEGRO_EDITOR EDIT_ETCH Wrong static phase values are shown in the dynamic timing meter for certain Diff pairs compared to CM.4 Q7 ]6 h; G/ ?8 R: g3 n0 G8 t
1194197 ALLEGRO_EDITOR OTHER Step export to include through hole padstacks.3 n4 E) O* _8 X2 E
1194239 PSPICE DEHDL Associate Model does not launch from DE-HDL" }1 ?+ w7 G B0 V9 w! d0 Q
1194736 PSPICE SIMULATOR Design causes RPC failure when run consectively
9 G' p( d0 Y1 X* z( @( _1195139 ALLEGRO_EDITOR PLACEMENT Components disappears from board file once they moved' }( B$ }& I9 a" W+ I* P' l
0 K7 m0 j) a# C( p4 O% P& UDATE: 09-27-2013 HOTFIX VERSION: 0167 O. a+ d7 J" \. [
, s9 ?6 Y8 W" ~: @% p0 wCCRID PRODUCT PRODUCTLEVEL2 TITLE
4 p+ c9 n9 ?6 X6 t. j/ N$ @5 _( |===================================================================================================================================
5 n& x: ? L6 _1 W6 a+ a/ q548538 CAPTURE NETLIST_ALLEGRO Enhancement:Include mechanical parts in Allegro netlist
. r/ Z4 a9 O, m7 h( r& w( i1076579 CAPTURE GENERAL Display value only if value exists G% u# t) T- R& P3 s, c- ?) y7 y
1083904 FSP GUI Need Filter in Change FPGA dialog to select desire FPGA from the long list., v4 }& R! j* y( n; ~
1089313 ALLEGRO_EDITOR INTERFACES Allegro Export PDF requires similar setup options as DE-HDL Export PDF for layer visibility
* A& D# x; n; W% a9 Y1095728 ALLEGRO_EDITOR EDIT_ETCH Slide to grab adjacent elements when extend selection is enabled
& z$ A- d( d9 U" o' k" D# G3 K+ q! y1102698 SIG_INTEGRITY ASSIGN_TOPOLOGY ECset will map on single ended nets but fails when the two nets are define as a diff pair.
+ L$ H* p1 R0 u/ B1 X/ ^& t1104071 SIG_INTEGRITY REPORTS Shape Parasitic value changes for bottom shape for changes in top shape! T. W/ a: `% n. e* t4 u+ Z
1117731 FSP POWER_MAPPING Ability to sort in Power Regulator forms
y! y0 U: r9 O5 g2 q7 \ I6 A3 Z1 r7 C1121539 FSP CONFIG_SETTINGS Cannot configure special FPGA pins (temperature diodes)
1 _; c8 F, s8 m6 G1 p; \4 R1122721 FSP MODEL_EDITOR Partial copy-paste overwrites the complete cell in XML Editor
( u' X0 n, N" I' n1123238 FSP TERMINATIONS Report functionality for terminations defined in the complete design.' J* |" r `6 d9 b2 G; x
1123364 FSP GUI Clicking on column header should sort the column.
+ C$ U- t0 [: T) J J1123403 FSP EXTERNAL_PORTS Improper checkbox selection for 緿o Not Connect� or 縀xternal Port� column4 L& [0 s# T6 H7 U: B V1 t
1125611 CONCEPT_HDL OTHER display unconnected pin in schematic pdf.
$ C5 a; K0 D1 o; ~1129871 ALLEGRO_EDITOR INTERACTIV Wire Profile Editor can't read mcmmat.dat in working directory.
# d; }+ y! m* p& v' K- o) w l, j1133688 ALLEGRO_EDITOR GRAPHICS Enhancement request to enable 3D Viewer to show STEP model from .dra file.- t7 ~4 e' T g3 @0 Y
1141747 ALLEGRO_EDITOR GRAPHICS 3D view dooesnot displays height if step_unsupported_prototype variable set J4 v5 ?) D5 g- ^. E' K
1142215 SIG_INTEGRITY SIMULATION PULSE_PARAM set on DiffPair wasn't used for designlink simulation.: t! V6 {( l# w! m
1142798 ALLEGRO_EDITOR INTERFACES Step file output is incorrect in step viewer when composed of arcs and line.' }# Y- O B8 l4 C
1142894 FSP GUI Ability to RMB on a header and select `Hide Column�
/ h# M6 z0 q! h# [8 I# r. {" j1142940 FSP EXTERNAL_PORTS Issue with checking/unchecking "Do not connect" and "External port" cells. ^0 i5 b7 M. l' M
1142949 CONCEPT_HDL SKILL Usage of "Preferences > License Settings� in FSP
' }& W+ _+ ~. [, I1143091 SIP_LAYOUT SYMB_EDIT_APPMOD symed: When AddPins is used to add pins to a co-design die, those pins are not output as bumps in the die abstract# G* t# x; Q i5 g, N! R
1144371 CONCEPT_HDL COMP_BROWSER Component Browser search results are inaccurate
9 T/ B7 k: e8 m- ^' I1145033 ALLEGRO_EDITOR PLACEMENT When aligning components with options in Placement mode displays no busy indicator
( j1 `) K. {4 H9 I5 X8 I' }1145286 CONCEPT_HDL CORE Directive required for switching off the console
2 N, n2 I; v4 ^/ N; _8 P" \1145800 ALLEGRO_EDITOR GRAPHICS Spurious odd lines are shown in shapes and text that are not part of the design with opengl.
) d8 d3 `9 {/ |9 N! U2 ? c, W1147899 ALLEGRO_EDITOR SHAPE Autovoid two overlapping shapes that share the same net" J7 N$ I! D/ m1 i
1149996 ALLEGRO_EDITOR EDIT_ETCH Routing does not follow the ratsnest 'pin to pin'.
' U( O* O; j d0 i; i) s1 [6 F" T$ C1150847 ALLEGRO_EDITOR INTERFACE_DESIGN Rename of DiffPair was not retained./ C+ Y0 ?% r' C! a; b* j( o0 M
1152577 ALLEGRO_EDITOR DATABASE slide removes cline seg9 A) O6 r, g5 \, y
1152751 CONCEPT_HDL CORE Option to double-click and copy the Netname
# Z( }2 P7 N9 O5 C) x K1153220 ALLEGRO_EDITOR INTERFACES ENH: option to supress header/footer during PDF Export
. ~% V6 V: h% g3 T+ j1153625 ALLEGRO_EDITOR INTERFACES If Symbol has place bound bottom, the step model shows incorrect placement.9 G# ~7 A8 E! x2 T
1153813 CONCEPT_HDL CORE Spaces should not be allowed in the signal name entry form
$ M0 h, g8 D8 ~ z3 B3 Y4 l, Y1153857 CONCEPT_HDL CORE Changing different power symbol should maintain the schematic level properties.
& q0 B1 @7 |6 `6 n& ^/ E! ^! S7 [1155161 CONCEPT_HDL CORE Add Signal name: Suggestion box overlaps with the typed signal name that is typed
m. t6 Y9 ?2 t7 w# D1155922 CONCEPT_HDL OTHER How can I use the batch mode for PDF Publisher and print a variant overlay?
! @) R; _& V' O- a3 e6 h. F/ D) t1156858 ALLEGRO_EDITOR PADS_IN PADS Translator: Missing drill on square PTH padstack" C5 ^6 Z6 F3 @" C
1157362 APD 3D_VIEWER Need a way to color multiple nets in 3D viewer from APD/SiP.
O8 m. t5 h% a* ^! [1158130 CONSTRAINT_MGR ANALYSIS Constraint Manager do not display the Cumulative Result in Reflection Simulation
( k, A& }% O$ z! ~1158210 ALLEGRO_EDITOR SHAPE SIP Layout happens crash while users move the shape with route keep-out
4 E2 P! g4 t, ^2 Q9 b1158452 SIG_INTEGRITY GEOMETRY_EXTRACT CPW differential traces are not extracted as coupled when they are routed at an angle$ ^ X+ _+ n; S; T' r, h8 [/ _
1158827 ALLEGRO_EDITOR EDIT_ETCH Slide a via in pad automatically add cline back to via to pin. ?& s, M. X4 T$ b6 p0 z) B6 g" o
1158871 PCB_LIBRARIAN IMPORT_CSV PIN TEXT is not automatically added when importing the .csv file
4 Y# v# @6 B/ G8 [, j1159738 ALLEGRO_EDITOR INTERACTIV Selecting the Cancel button in the Text Edit command does not cancel the text.
+ u0 X) t. T5 ?7 e1159878 SIG_EXPLORER OTHER Ecset mapping dont follow topology template
. B4 ~! P3 l: U& N& f8 h C1159971 ALLEGRO_EDITOR MANUFACT Allegro PDF Publisher requires ability to control film record sequence when generating the combined PDF file
& _3 C( t- _. ^1160017 SIP_LAYOUT DIE_ABSTRACT_IF Add text to clarify shrink operation
' S& l; M# R4 E5 R5 e1160507 APD EDIT_ETCH Script not playing back what was recorded when sliding lines
3 v: W) j2 W, m: F4 _1161261 ADW TDO-SHAREPOINT Schema for TDO-SP fails on Japanese OS6 \; J- |) K! O0 ~. ]
1161538 CONCEPT_HDL CORE Espice model value edited in DE HDL & then netlisting done, but it doesnt changes the earlier assigned model in Allegro
! e4 ]' t$ W' I1 I* @1161636 ALLEGRO_EDITOR DRAFTING need new function for PDFout : hatching shape' H& f5 J- J7 m3 M
1161777 ALLEGRO_EDITOR OTHER default line width for PDF output
2 o/ G: A4 M+ m& m1162383 CONCEPT_HDL CHECKPLUS Checkplus not using $CDS_SITE/custom_help and $CDS_SITE/custom_rules_include directories.
/ V, n" k M/ u' w0 `1162562 CAPTURE STABILITY Capture crash on second attempt of pspice netlist creation in 16.6; ]% j/ j- K3 @6 |( O( Q. T, a
1162629 FSP PROCESS "Load Process Option" under Run does not work properly8 c3 b; A, h$ [- J! L' s# s) n
1162686 CONCEPT_HDL CORE Changing NET_SPACING_TYPE to display both shows up with $NET_SPACING_TYPE' w: z. W; S! X. n
1163149 ALLEGRO_EDITOR DATABASE Autosilk creates Illegal arc to corrupt database
$ c& K! e* U& n$ ]/ D1163439 ALLEGRO_EDITOR COLOR Duplicate Views Listed in Visibility Tab.' G* D6 J- D* ^) B
1163521 CONCEPT_HDL COMP_BROWSER System Architect crahes on replace0 k" ?+ }; y* B. S( Y M2 s. t
1163709 CONCEPT_HDL CONSTRAINT_MGR Loosing Diffpairs when reimport block or restore from definitioin6 N5 P. P* q9 |* `& D
1163902 APD EXPORT_DATA Q- In APD > File - Export - Board Level Component, check otion of delay reports is not working, is it ?( `6 I' x! X# M" {" k
1164337 CONCEPT_HDL CORE Cannot delete attribute filter value in PDF > General > Attribute Filter list4 O$ Y) e. @& H, u
1164365 ALLEGRO_EDITOR INTERACTIV Symbol not selected for Move because Symbol Pin number selected in options tab not available on symbol! }9 T4 M! g# N- v7 v. }
1164769 APD VIA_STRUCTURE The replace via structure command does not accept a single canvas pick.
. n4 M8 y/ L0 c, N3 x- u3 R1165026 ASI_SI GUI EMS3D exist in Via Model Setup of SI base.1 w3 X2 ^8 w" `9 w; d0 d
1165561 CAPTURE DRC File > Check and Save clears waived DRCs1 C, S+ v7 o5 l! @3 g1 R4 D
1165631 CAPTURE STABILITY Capture crash in the hierarchy tab of Project Manager window; z% l$ @" O8 A9 s% r/ {3 \3 j, W
1165836 SIG_INTEGRITY GEOMETRY_EXTRACT Some nets has no result at Bus Simulation and Comprehensive simulation.(update)5 j8 D" c" v4 Y g
1165911 FSP PROCESS Editing group name in protocol causes incorrect Process option checked
: ^2 i" M- r3 N$ I B \1166026 ALLEGRO_EDITOR DATABASE Running DB Doctor removes net name from vias
4 v3 J# J5 j9 x$ ^/ |1166034 SIP_LAYOUT OTHER SiP - Cline Change Width command enhanced to have selection by polygon not just rectangle
6 x; L. R {; N0 l6 X1166074 GRE CORE GRE crashes during planning phases, k) e% S' k2 r5 ] Y
1166319 ALLEGRO_EDITOR PLACEMENT Swap not succeed U" `, S9 H+ d* a" [, j1 |
1166484 SIP_LAYOUT WIREBOND Bondfinger "Align With Wire" problem during move
# w. f9 E- n; t4 U W1166530 ALLEGRO_EDITOR INTERACTIV Bug: Mirror in Placement Edit resets the options tab for Edit > Move( ^5 Q1 l r/ C: A5 r( s
1166819 CONCEPT_HDL CORE Cadence DEHDL Text Size Issue
' |: X7 l! I: V8 R- |1167847 CAPTURE PROPERTY_EDITOR Implementation name length greater than 31 character causes capture crash1 I+ s: b: X) O: A/ s( L" k
1167887 F2B OTHER Improve message on symbol to schematic generation, S3 C) W% z# M* ]0 [
1168369 F2B DESIGNVARI Variant don縯 appear in increasing order while Annotate.6 Q# ]: s" \3 j: Y' E# s
1168629 APD OTHER Do we have Skill command which is equivilant to Change Characteristics operation of a Wire Bond in APD
1 u4 H2 F `3 @0 u# `# { b4 D d1168678 ALLEGRO_EDITOR NC Drill Figure will be changed wrong layer when some subclass was deleted in SPB165S045.
7 l& x% K2 d4 \1 H" x& d( m1168798 ALLEGRO_EDITOR INTERACTIV Enh - Allow user the ability to set the visibiity layer of refdes while moving the symbol rather than fixing it to silk
9 P9 m9 c# @( v) b3 p1168830 ALLEGRO_EDITOR DRC_CONSTR missing DRC-marker for package to package check
6 y& w& X& f8 e- |( M) G1168864 ALLEGRO_EDITOR CREATE_SYM Saving the dra after Shape Expand/Contract throws warning 'Sector Table is not empty. s' H: W2 T2 f
1169213 PSPICE SIMULATOR Parametric sweep is giving incorrect reuslts z$ ?. u5 Q8 K- c2 V: y4 D
1169436 FSP FPGA_SUPPORT Add support for Cyclone V CSX and CST parts4 d6 z6 H( P9 X; p7 {
1170108 ALLEGRO_EDITOR INTERACTIV Enhancement to preserve Rat T location for Topology assigned schedule' P. N$ g* D: m! Q2 Z7 X. `# v
1170313 SIP_LAYOUT LOGIC scm adding additional pin names and unassigned property to codesign die chips file7 E7 G7 H; t5 i- C, L( L
1171136 CONCEPT_HDL CORE Page Number should also be displayed in Import Design Window.& E' u9 C$ o3 B5 Q$ F
1171747 ALLEGRO_EDITOR PLACEMENT Allegro crashes when doing a gate swap between components
' P/ B1 O* q) r% ^# F+ S) l1172183 ALLEGRO_EDITOR INTERACTIV Alignment modules fails on equal spacing
1 C( y% D8 y* r8 t7 z& K5 v4 `3 p' [. a5 j1173183 ALLEGRO_EDITOR DRC_CONSTR Undesired Same net DRC for overlapping Pin and Via( G5 ?& p* g1 z5 n
1174067 ALLEGRO_EDITOR DRC_CONSTR Soldermask to shape drc does not show if the layer is a PLANE.
3 z: e$ z' X& y+ n1174338 ALLEGRO_EDITOR PLACEMENT preview has rotated pads# p% q, ~4 g1 U- W) y# Y
1175307 CONSTRAINT_MGR ANALYSIS CMGR fails to report RPD DRC for accuracy 4 - mm+ x, A, E: c- `, g
1175537 ALLEGRO_EDITOR REPORTS net loop report crashes Allegro. Design specific
' ~9 z I! I" Z+ ?8 F- t1176126 ALLEGRO_EDITOR INTERFACES 3D viewer doesnot change models units dynamically! d! C: n5 \5 v, ?+ T% G
1176281 CONCEPT_HDL CORE Option to Auto-hide excluded modules
. W8 Q4 H: _2 F" J$ U5 x1176413 ALLEGRO_EDITOR MANUFACT Q - testprep parameter settings is not retained, what could be the cause..
7 a- G: f* Q I7 p/ F1176791 ALLEGRO_EDITOR GRAPHICS Spurious odd lines are shown in shapes and text that are not part of the design with opengl
1 l: R/ A0 B2 L7 `5 s1178052 ALLEGRO_EDITOR SHAPE SIP crashes during shape degassing.% \/ j+ f/ D' b
1178158 ALLEGRO_EDITOR INTERFACES Export step file creates step file of same height
* H1 ~: q4 j5 s* D! U1178201 ALLEGRO_EDITOR GRAPHICS Large oval pads rendered as oblong hexagons in the 3D viewer
- Y w$ B G5 t5 ~: x1178671 ALLEGRO_EDITOR GRAPHICS 3D Viewer in package symbol editor not displaying correct place bound shapes.& Y% c1 [ G+ S6 F j. v7 w4 A
1178725 ALLEGRO_EDITOR OTHER With fillets present, rat lines do not point to the closest endpoint.
# l! z: R7 K) \# ~( t3 F F1178972 CONSTRAINT_MGR ANALYSIS The Cross-Section's parameters was not applied immediately after importing a DCF on the Constraint Manager.
( O# p0 ?7 T0 [& E6 J- l. \1179093 ALLEGRO_EDITOR SHAPE Dynamic Shape for GROUND net on TOP Layer is corrupted and is not voiding correctly in certain areas.
. s, f! _9 R1 G1 c( H9 U# F1179109 ALLEGRO_EDITOR OTHER DXF importing makes figure shift in 16.5&16.6 version it is ok in 16.3 version& C9 W9 C" m) s! T3 ^8 e a
1179571 ALLEGRO_EDITOR ARTWORK Artwork crash and artwork log report Aparture missing/ I& Y# G; R5 V$ E
1179636 SPECCTRA ROUTE Route Automatic will not start if NET_SHORT are attached to a mec-pin
9 G6 E/ Q! S% Z1179659 SIP_LAYOUT DIE_EDITOR die edit on co-design die losing c4 bumps
) F" Z. [7 V" k. w- M6 O. G. b, Z1180306 ALLEGRO_EDITOR ARTWORK When trying to create Artwork the tool crashes with no error messages just a little X box r5 b! g! z. R" | e$ P
1180573 ALLEGRO_EDITOR ARTWORK If one layer has warning, all artwork films are "created with warning".7 L) N) y0 S7 }8 g4 h$ {. m* ~, _
1180960 SIP_LAYOUT PLACEMENT swap function is not swapping logical paths in sip layout!
( X( I, t, Z( z: z5 f. h1182534 ALLEGRO_EDITOR SKILL axlLayerPrioritySet() not working with v166 s013 and up
' X4 _0 u- Q% ~$ o1182560 ALLEGRO_EDITOR PLOTTING Creating plot 2nd time casues Allegro to crash
- w) F7 E* [% V. f' C9 s3 [1182616 ALLEGRO_EDITOR PLACEMENT Application crashes when attempting to place a high pin count BGA
1 F- ~$ p5 h, d$ }* ?6 T9 }" ]1183752 CONCEPT_HDL CORE Unable to modify location properties within a read-only hierarchical block
/ G0 d3 T' V: T9 x1183774 SIP_LAYOUT DIE_EDITOR Die Refresh hangs( z! c( z, C* F" b
1184178 CONCEPT_HDL CONSTRAINT_MGR Ecset xnet members lost from electrical class when restore from definition of subblocks
# R. K; G9 z; a% r! O! A1184787 ALLEGRO_EDITOR EDIT_ETCH Allegro SPB166 s 015 crashes during normal add connect function.
$ e: X& M2 h' B6 X: {% Q9 P* f4 R$ I1 D3 M! {0 Z3 H
DATE: 08-22-2013 HOTFIX VERSION: 015
( k7 I! v) N3 V/ c9 Q7 F===================================================================================================================================
9 T; Y/ t p! P) y5 O# @CCRID PRODUCT PRODUCTLEVEL2 TITLE( }- Y1 y: ^; @' g$ j# _3 R9 N
/ o- C; w' @# s5 {5 A6 d0 s1156102 PCB_LIBRARIAN CORE PDV severe performance degradation on Linux platform makes PDV counter productive after some time$ b/ B# g2 A3 a) F% S
1165756 CONCEPT_HDL CORE DE HDL 16.6 adding ASCII character to properties! F, \; ?1 J, ^$ w' q
1169896 ADW LRM Library Revision Manager makes updates but the interface never returns to the user
/ T W! K& z7 l) w2 P+ n& T1170635 SIP_LAYOUT WIZARDS BGA PIN NAME doesn't sync with PIN Number1 c0 A8 T U r0 P
1171061 ALLEGRO_EDITOR PLACEMENT Place Replicate Apply cannot place module5 z3 F3 Y8 v+ V. d+ |. M% ?
1171415 CONCEPT_HDL CORE Mismatch in the interface ports in design bw_hybrid for block a38410_scsp
6 W/ f- ?' K+ o* \; T/ U, W- C2 E1171598 APD WIREBOND Cannot load xml over 65 profiles defined in file.
/ |- C$ D2 e3 h) o0 g# R- C1171713 ADW LRM Blank lines appear in the LRM - RM-Clicking causes LRM to crash h7 c. [4 V$ m o
1172576 SIP_LAYOUT IMPORT_DATA AIF import fails with Error: symbol is missing refdes
! e2 g/ ], K- i9 A1172938 ALLEGRO_EDITOR PLOTTING Export IPF probrem$ p0 _/ b! _+ P2 j
1173190 ALLEGRO_EDITOR ARTWORK Not able to Add/ Replace film_setup.txt file in Artwork control file.! D& U5 X9 t. q. P0 o* f
1173750 ALLEGRO_EDITOR REPORTS SIP tool crash when clicking report "Net Loop Report"
. n6 c8 f- t9 }0 h3 k+ [: o1175582 ALLEGRO_EDITOR SKILL axlDBCreateFilmRec error undifined function
$ a4 {5 ^+ p% W% r+ `3 S4 ]$ a" d% s8 y8 z0 W ]
DATE: 08-9-2013 HOTFIX VERSION: 0143 {8 { \* W9 k. `
6 C6 N/ O' \1 g s5 U; ECCRID PRODUCT PRODUCTLEVEL2 TITLE5 N/ _; V% \0 _; W! n# J
===================================================================================================================================9 a9 l/ W0 z4 g# E) C
1155569 APD MODULES P1_U1 and P1_U3 Die pins are missing after Place Module.
6 v! H4 F+ r' }2 N9 |" J; a, z1158528 CONCEPT_HDL OTHER Dual Monitor issue: Retain Hard Packaging option is missing and attribute test distorted
( n& {( T0 y! \0 l1160968 ALLEGRO_EDITOR SKILL Text Subclass change difference in Edit > Change and axlChangeLayer Skill command
; a$ N. J& G- \+ U1161986 SIG_INTEGRITY SIMULATION Flatline waveform seen when via model is set to detailed closed form or analytical solution1 S" y8 s) }5 N% q6 y' F
1162323 SIP_LAYOUT DIE_EDITOR Die Editor is incorrectly leaving an unassigned function pin in the die during refresh from die abstract9 r! w' \" _, M5 `. b `( F. D
1162752 ALLEGRO_EDITOR SKILL axlDBChangeText doesnt recognize ?layer as a valid argument as documented _/ M4 {9 L% U+ t. {* N
1165002 GRE CORE GRE Crashes during Plan Spatial giving "Memory Allocation Failure" Error.
1 ]/ P' T8 I, r1165469 CONCEPT_HDL CORE Import Design loses design library name
' i+ L8 ^2 `0 g1165708 ALLEGRO_EDITOR TESTPREP Test point router failing when attempting to insert new TP via's
1 r1 R3 a9 Q5 G8 w- n E, j, S0 {9 S1165801 CONCEPT_HDL PDF Pin texts of spun symbol overlap in publish PDF.
1 @/ \/ Y r# e8 ?4 `. g* I1166020 SIP_LAYOUT WIREBOND Bondpads created with shapes do not follow the orthogonal pattern when adding wirebonds.
: x) O& N( h5 Z( }2 o) x1 @1166371 ALLEGRO_EDITOR DATABASE File locked for writing in 16.5 cannot be unlocked in 16.6
7 d* c4 F# k9 p) n* Y1166482 ALLEGRO_EDITOR INTERFACES Step orientation for y-rotated component is not exported correctly.( M7 j3 t6 [; M) Q% B5 x8 n
1167519 ALLEGRO_EDITOR DATABASE Uprev dbdoctor does not log warnings about renaming properties.
8 @ b; Y- `6 l$ Y1 C1167588 SIP_LAYOUT DIE_ABSTRACT_IF do not create a new pad stack for each I/O pad
- W! h2 L& Y; b6 N1168496 ALLEGRO_EDITOR SCHEM_FTB Export Physical Crashes when netreving the board
6 o9 `, X8 p- q1169510 SIP_LAYOUT WIZARDS Netlist in Wizard is crashing with this text file where the Net Name for one of the assignments is blank, meaning dummy
( x* h4 A% K; `# z* G2 T* i! y0 R3 ]1169593 CONCEPT_HDL PDF Published PDF file's hyperlinks do not work fine when user click 1D10 or 2A10.
( Q ~' F; V% I5 `! C* C0 I) r s j1169984 F2B PACKAGERXL Error Mapping cset when packaging but not in CM Audit7 A2 k6 ]. g: p
1171008 SIP_LAYOUT OTHER SiP Layout - Beta feature Void Adjacent Layer Shapes - changes or modifies "priority" of other/all shapes- m5 d3 u0 b2 ]" c H
1171411 ALLEGRO_EDITOR OTHER Enh - Break in Step 3D view in latest hotfix v16.6s013
* x# Q0 y* g8 x3 X* K+ M+ p! t- V0 I7 ^( s: V
DATE: 07-26-2013 HOTFIX VERSION: 013
$ r9 r( Y" K8 R===================================================================================================================================& G2 o0 J. {* ]. I/ M6 R- e
8 F6 {6 q b: ^7 H# l: m===================================================================================================================================
7 J( L# ~) m9 Q. p111368 CAPTURE CORRUPT_DESIGN Capture - will not produce allegro netlist with 10.0
% R, B+ Q9 l$ G9 k6 L9 K134439 PD-COMPILE USERDATA caCell terminals should be top-level terminals
( _ J( t/ U, e# R5 m' ^4 x+ t( o186074 CIS EXPLORER refresh symbols from lib requires you to close CIS
6 H( l1 z: ]) I I5 {% }1 M! i583221 CAPTURE SCHEMATIC_EDITOR Option to have the Schematic Page Name as a Property in the Titleblock3 Q6 V4 z0 ~- T, s/ ^: ]
591140 CONCEPT_HDL OTHER Scale overall output size in PublishPDF from command line
7 p& j, ^2 T* l801901 CONCEPT_HDL CORE Concept Menus use the same key "R" for the Wire and RF-PCB menus
% f# P$ h4 p8 \4 }5 E$ z813614 APD DRC_CONSTRAINTS With Fillets present the "cline to shape" spacing is wrong.
. X, A' i; y; V881796 ALLEGRO_EDITOR GRAPHICS Enhancement request for Panning with Middle Mouse Button
( P$ Y. t/ s0 ^1 m/ p2 U887191 CONCEPT_HDL CORE Cannot add/edit the locked property( u2 C3 z. m& R4 l- C/ Q6 B
911292 CONCEPT_HDL CORE Property command on editing symbol attaches property to ORIGIN immediately
/ a* B. o" D' E4 l' ]987766 APD SHAPE Void all command gets result as no voids being generated on specific env.
; W% v5 c0 f; l1001395 SIP_LAYOUT ASSY_RULE_CHECK Shape Minimum void check reports lots of DRCs which are not necessary to check out.) ~9 f7 A/ W0 W# R
1030696 ALLEGRO_EDITOR INTERACTIV Enh - Allow another behavior of PAN movement using middle mouse in Allegro) o8 O D0 {( ^% |6 R$ M) [ T
1043856 ADW TDA Diff between TDO and DE-HDL Hierarchy Viewer is confusing to the user
0 e2 O% \; b A' l6 V# J3 t1046440 ADW PCBCACHE ADW: ImportSheet is not caching libraries under flatlib/model_sym when the source design is not an ADW project; v4 b6 u f3 l* L# f/ Q
1077552 F2B PACKAGERXL Diff Pairs get removed when packing with backannotation turned on! c1 b3 A' ?9 d$ o9 c
1079538 F2B PACKAGERXL Ability to block all 縮ingle noded nets� to the board while packaging.
- N, I f: ?/ B* a0 z; P1086362 ALLEGRO_EDITOR SHAPE Enhancement request to autovoid a via if shape cannot cover the center of the via.& f' K* G c5 P$ G( g$ R1 S
1087958 PSPICE MODELEDITOR Is there any limitation for pin name definition?3 G* i; z. a/ H
1087967 CIS UPDATE_PART_STAT Update part status window shows incorrect differences
+ a3 [0 @2 H8 W+ C1 [3 n0 A1090693 ADW LRM LRM auto_load_instances does not gray out Load instances Button
' x2 o8 D) F6 ?, p: S1097246 CONCEPT_HDL CORE ConceptHDL - assign hotkeys to alpha-numerical keys. G9 o) ^# M/ X
1099773 CONCEPT_HDL CORE DE HDL goes into recursive loop if a custom text locked at site level is deleted from Tools > Option% J n! ?+ S: v* C/ k6 v
1100945 SCM SCHGEN SCM generated DE-HDL has $PN placement issue) b( Y6 m9 D! z* L- J* o8 z
1100951 PSPICE SIMULATOR Increasing the resolution of fourier transform results in out file) p4 f R" f- u8 G- v
1103117 RF_PCB FE_IFF_IMPORT Enh- Allow the Allegro_Discrete_Library_to_ADS_Library_Translator to output in its original unit4 i2 O1 d J9 G/ f/ z; E
1105473 PSPICE PROBE Getting error messages while running bias point analysis.
8 Y5 e; _* k |1106116 FLOWS PROJMGR view_pcb setting change was cleared by switching Flows in projmgr.& E( Z2 t2 u) j* Z+ F
1106298 ALLEGRO_EDITOR INTERACTIV Copy Shape uses last menu pick location as origin and not the Symbol Origin as specified in Options.
/ U4 n( `/ s/ }5 b+ c$ H3 ^1106626 CONCEPT_HDL CORE Concept HDL crashes when saving pages- A. p4 _% t2 P8 o! s# E5 }" {
1107086 ALLEGRO_EDITOR INTERACTIV manual void with arc's goes in wrong direction during arc creation3 m4 s# U4 u; G& C; ~# n* j
1107172 CONCEPT_HDL OTHER Project Manager Packager does not report errors on missing symbol; n1 |( |2 \1 J( G- _- ?) L
1108193 CONCEPT_HDL CORE Using the left/right keys do not move the cursor within the text you're editing
7 p5 N; K/ Q& l" h7 \' D1108603 PCB_LIBRARIAN VERIFICATION PDV Tools Verification > View Verification (CheckPlus) leaves <project>.cpm_tmp.cpm9 G" ], Z9 V }" ^& o; T
1109024 CIS OTHER orcad performance issue from Asus.
" H& r0 c/ ?8 v/ f# b1 }; |1109109 CAPTURE NETLIST_ALLEGRO B1: Netlist missing pins when Pack_short property pins connected) F0 R3 t2 `, H1 E' E
1109466 ALLEGRO_EDITOR ARTWORK Artwork create some strange gerber lines for fillet.
* A6 h" Z! Z$ O2 o4 p1109647 SIP_LAYOUT DEGASSING Shape degassing command enhancement - control over what layers are counted in even/odd layer sets.
& z" K, t& ^; L" C* t1 l1109926 CONCEPT_HDL CORE viewing a design disables console window
, D# l- a. I K6 l R1110194 SIP_LAYOUT WIREBOND If OpenGL settings for display of dynamic net names is enabled, should be visible while push/shove wirebonds.# s/ S2 ?2 G4 f3 ?5 X( D
1112357 SIP_LAYOUT WIREBOND wirebond command crashes the application
4 X8 }% r' A ]7 M/ ~: L1112395 CONCEPT_HDL CORE 縗BASE\G� for global signal is not obeyed after upreving the design to 1650.; d5 s9 ^4 j3 s2 b! ], K/ J+ j
1112658 CAPTURE PROPERTY_EDITOR Changing Part 縂raphic� value from property Editor Changes Occ refdes values to instance
1 H) s( u. y5 v8 \( X1112662 CAPTURE PROJECT_MANAGER Capture crashes after moving the library file and then doing Edit> Cut
; u+ e: n( w, X0 V* ]9 j1113177 PCB_LIBRARIAN CORE Pin Shapes are not getting imported properly9 }& |" t3 l* l" X( T* B' K2 E
1113380 ALLEGRO_EDITOR INTERACTIV Change layer to - option for package type .dra is not available in 16.6 release
0 g t( j4 j( T1113656 SIP_LAYOUT WIREBOND Enable Change characteristic to work without unfixing its Tack point.
2 l! j! ?4 O4 q1113838 SIP_LAYOUT DIE_ABSTRACT_IF probe pins defined in XDA die abstract file are added with wrong location' s8 [' e6 ?" x: _9 Q; k5 i% F
1113991 CAPTURE GENERAL Save Project As is not working if destination is a linux machine1 \) B7 V! E# G3 \1 P7 {
1114073 APD DRC_CONSTRAINTS Shape voiding differently if there are Fillets present in the design.- ]0 q n' n: l6 U. `$ g# ?
1114241 CAPTURE SCHEMATIC_EDITOR Port not retaining assigned color, when moved on the schematic0 |* q6 M1 L* x: b# ~" V* z
1114442 PSPICE PROBE Getting Internal error - Overflow Convert with marching waveform on6 e5 `% \1 N2 G% \; `: M+ y
1114630 CONCEPT_HDL ARCHIVER Archcore fails because the project directory on Linux has a space in the name
' O p" X6 v8 a3 j% g2 p' S, Z1114689 CONCEPT_HDL CORE Unknown project directive : text_editor
6 z3 I+ S- S* G$ f% j1114928 F2B PACKAGERXL 縀rror (SPCODD - 5) while Export Physical even after change pin from A<0> to A: K2 D* E; n- ^
1116886 CONCEPT_HDL CORE Crefer hyperlinks do not work fine when user use double digits partitions for page Border.
* c0 e* j- q+ J. v* F1118088 ALLEGRO_EDITOR EDIT_ETCH Should Plan accurate and Optimize be removed in 16.6?- n! w9 d4 V2 l' j X0 W1 a
1118734 APD EDIT_ETCH Multiline routing with Clines on Null Net cannot route in downward direction
9 u2 J) N3 ]4 l% ]1118756 ALLEGRO_EDITOR SHAPE Shape clearance parameter oversize values getting applied to Keepouts( J. O5 y( q6 u9 \: Z$ l
1119606 CONCEPT_HDL MARKERS Filtering two or more words in Filter dialog box' s/ @7 O, w* R; u8 ?* F: W) o
1119707 CONCEPT_HDL CORE Genview does not use site colors when gen sch from block symbol! |$ g: M- T/ x/ j2 c8 M& E
1119711 F2B DESIGNSYNC Design Differences show Net Differences wrongly9 O' K/ _8 l, y; V- y
1120659 CAPTURE PROJECT_MANAGER "Save project as" does not support some of Nordic characters.
% J2 c2 ~# I# o% E8 I$ R; M( L1120660 CONCEPT_HDL CORE Save hierarchy saves pages for deleted blocks./ [" A& {6 Q: \8 T
1120817 SIP_LAYOUT SYMB_EDIT_APPMOD Rotate Pads commands not working while in the Symbol Edit App. mode/ ]9 E* _6 `* J
1120985 PSPICE MODELEDITOR Unable to import attached IBIS model; h8 C* h, n1 J! u
1121171 CONCEPT_HDL CREFER PNN and correct property values not annotated on the Cref flat schematic
5 R% g/ } c6 U$ K$ ~* c! a2 p1121353 ALLEGRO_EDITOR INTERACTIV Local env setting will change after saving and reopening.% ?- w7 `7 @9 [; Z2 }) Q3 r
1121382 ALLEGRO_EDITOR INTERACTIV Undo command is limited to two for this design
$ n3 K8 Y7 E* J1121540 F2B PACKAGERXL pxl.chg keeps deleting and adding changes on subsequent packager runs- u T3 T# D7 o; C
1121558 ALLEGRO_EDITOR MODULES Unrouted net and unrouted connection when module is placed of completely routed board file.
1 J# g# Y5 y/ S6 f: p: f7 z1121585 ALLEGRO_EDITOR OTHER Drill Hole to Shape Same Net Spacing with Dynamic Shapes shows wrong result.
/ ^& s# p, n, \8 G. r1121651 CAPTURE SCHEMATIC_EDITOR "PCB editor select" menu option is missing
+ B0 f: Q4 D8 V( z" y1122136 SIP_LAYOUT PLACEMENT Moving a component results in the components outline going to bottom side of the design.9 ~" I) e# k0 Z, j& ^
1122340 CAPTURE NETLIST_ALLEGRO Cross probe of net within a bus makes Capture to hang.2 r9 Z1 O$ j1 j+ p) F
1122489 CONCEPT_HDL OTHER Save _Hierarchy causing baseline to brd files
+ A. N" N# Q; c( Q$ O& h+ e# w, |1122781 CONCEPT_HDL CORE cfg_package is generated for component cell automatically
$ G: y; G' x: s6 E. \1122909 CONCEPT_HDL CORE changing version replicates data of first TOC on 2nd one
/ }( l0 ~ S: H' r/ W! M1123150 CONCEPT_HDL CORE property on y axis in symbol view was moved by visibility change to None.' m# u( W5 i' j( F: _4 S
1123176 ALLEGRO_EDITOR UI_FORMS Negative values for pop-up location is not retained with multiple monitors (more than 2)
0 }7 o4 w$ a" _; z2 b& t; f9 g1123815 ALLEGRO_EDITOR GRAPHICS Embedded netname changes to a different netname
9 W2 G& j3 K% r$ } ~: l2 X1124369 ALLEGRO_EDITOR INTERACTIV Sliding a shape using iy coordinate does not work indepedent of grid.
& E% {2 Z: a2 i/ y+ H1124544 CONCEPT_HDL CORE About Search History of find with SPB16.5 o& w+ ?8 K( [
1124570 APD IMPORT_DATA When importing Stream adding the option to change the point
- H. Z l# i$ N, z/ L2 t; P1125201 CONCEPT_HDL CORE Connectivity edits in NEW block not saved( lost) if block is created using block add
' A' `( Z7 I' _$ m# i' K1125314 ALLEGRO_EDITOR INTERACTIV Enved crash during setting of library paths in user preference% T- A; X: t- D$ m: Y0 x k
1125366 CONCEPT_HDL CORE DE-HDL craches during Import Physical if CM is open on Linux3 o1 V& R, l: ?
1125628 CONCEPT_HDL CORE Crash on doing save hierarchy+ p c h1 k/ P" K6 ^1 y1 v# M
1130555 APD WIREBOND Wirebond Import should connect to pins of the die specified on the UI." G5 k9 g' c3 D) e8 |" N$ J
1131030 PSPICE ENVIRONMENT Unregistered icon of Simulation setting in taskbar1 N& I# C" G- m) n1 M v
1131083 ALLEGRO_EDITOR INTERACTIV Bug: 16.6 crash in changing the mode in Find filter window
; H% l9 l' X, ~ I T6 g1131226 ALLEGRO_EDITOR PLACEMENT When Angle is set in design parameters while placement component is rotated but outline is not.2 W0 \4 z0 g. a. l U
1131567 CONCEPT_HDL OTHER Lower case values for VHDL_MODE make genview use pin location to determen direction.; R" h- l& `5 e0 p3 J) O* Z! [
1131699 PSPICE PROBE Probe window crash on trying to view simulation message2 {5 R7 M; o! `/ s+ O! [
1132457 CONCEPT_HDL CORE The schematic never fully invokes and has connectivity errors.
# p% `3 X6 m# W( h1 h- k6 n1132575 CONCEPT_HDL CORE 2 pin_name were displayed and overlapped by spin command.
- Q$ w6 i" D5 @( \$ @3 Z$ `1132698 ALLEGRO_EDITOR EDIT_ETCH Slide Via with Segment option with new Slide command
K& F1 L; v. H' t' M! Y1132964 ALLEGRO_EDITOR SHAPE Same net "B&B via to shape" errors created when adding shape
, B) q+ Y; l3 j6 |) j1133677 CONCEPT_HDL CORE Cant delete nor reset LOCATION prop in context of top
3 V9 Q* M9 e" V- a% @$ T( e1133791 CONCEPT_HDL CORE Cant do text justification on a single selected NOTE in Windows mode.' S3 s: ?1 t' ^( D6 |, Z5 E
1134761 CONCEPT_HDL CORE Why does Mouse Pointer/Tooltip display LOCATION instead of $LOCATION property
' C. p) g# H T: d7 x1135118 ALLEGRO_EDITOR INTERACTIV Mirror and other editing commands are missing for testpoint label text in general edit mode.
0 W, d9 q7 ~/ p+ Q a1136420 CAPTURE GENERAL Registration issue when CDSROOT has a space in its path
4 u4 l) G1 E4 U1136808 PSPICE STABILITY Pspice crash marker server has quite unexpectedly
7 y2 n# C' l1 R" M; t1136840 CAPTURE SCHEMATICS Enh: Alignment of text placed on schematic page
2 q6 B; Y; h1 V8 R/ l$ }1138586 ADW MIGRATION design migration does not create complete ptf file for hierarchical designs
( r8 {5 C( x. _1 P2 ]2 Z1139376 CONCEPT_HDL CORE setting wire color to default creates new wire with higher thickness K% R! |& b1 p. q3 E
1140819 APD GRAPHICS Bbvia does not retain temp highlight color on all layers when selected.
, `2 W# S9 N5 e" j* A! A1141300 CONCEPT_HDL CORE DE HDL hier_write save hierarchy log reports summarizes Successfully saved block x while block was skipped
5 a' u E& @. O6 ^* N6 X/ j) v" P1141723 ADW PURGE purge command crashes with an MFC application failure message
7 m" X& K( D% T% |1143448 CAPTURE GENERAL About copy & paste to Powerpoint from CIS" t4 i9 i; q: ^: I- q+ x5 @
1143670 SIP_LAYOUT OTHER Cross Probing between SiP and DEHDL not working in 16.6 release
7 Q* f! u# n/ T/ p1143902 ALLEGRO_EDITOR DATABASE when the shape is rotated 45 degrees the void is moved." Z7 C& }, H8 d* B0 a8 L
1144990 PCB_LIBRARIAN CORE PDV expand & collapse vector pins resizes symbol outline to maximum height
6 @( O8 c% j$ H% N" R1145112 CONCEPT_HDL CORE Warning message: Connectivity MIGHT have changed
4 s p" K; n; o8 ] {' p1145253 CONCEPT_HDL CORE Component Browser adds properties in upper case
# Y5 d% b" T; h# K! q' v1146386 ALLEGRO_EDITOR INTERACTIV Place Replicate Create add Static shape with Fillet shape! p: M" V( C/ n$ n% s' o- C9 Z
1146728 F2B PACKAGERXL DCF with upper and lower case values on parts causes pxl to fail
# a v2 k/ i* ? i" j: j1146783 ALLEGRO_EDITOR INTERFACES Highlighted component is missing from exported IPF file.. I: n4 F4 [5 `2 J
1147326 CONCEPT_HDL CORE HDL crashes when trying to reimport a block d. k- l1 v# ^1 V- A) v" K# \; U2 B
1148337 CAPTURE ANNOTATE Checking "refdes control" is not giving the proper annotation result9 _% E" ^+ E: d9 H' R) {( X
1148633 SIP_LAYOUT INTERACTIVE Add "%" to the optical shrink option in the co-design die and compose symbol placement forms
) r9 @0 _1 R1 G1149778 CAPTURE SCHEMATICS Rotation of pspice marker before placement is not appropriate
( e) D$ `1 Z% T) W6 S# E( H1149987 PCB_LIBRARIAN PTF_EDITOR Save As pushing the part name suffix into vendor_part_number value0 G8 O( F% c+ X
1151748 ALLEGRO_EDITOR OTHER If the pad and cline are the same width don't report a missing Dynamic Fillet.- ~* V' }, _$ ?; X/ v* n0 `
1152206 CONCEPT_HDL CORE ROOM Property value changes when saving another Page, f4 r: k+ N: r0 [6 _; z. b G
1152755 CONCEPT_HDL COPY_PROJECT Copy project hangs if library or design name has an underscore5 ~. z1 w) N2 B4 A3 w; |+ P
1152769 PSPICE ENCRYPTION Unable to simulate Encrypted Models in 16.6
+ S* J1 n; S* ~0 n8 K5 U2 m1153308 ALLEGRO_EDITOR DRC_CONSTR Creating Artwork Getting Warning "DRC is out of Date" even when DRC is up to date
) o9 V$ D- j$ c: U" {; H" K5 N4 b1153893 F2B DESIGNVARI 16.6 Variant Editor not supporting - in name
c& ]7 I# v2 m1154185 SIG_INTEGRITY SIGNOISE Signoise didn't do the Rise edge time adjustment., {0 s% C: r F
1154860 ALLEGRO_EDITOR MANUFACT Double digit drill character overlaps with figures triangle, hexagon and octagon in NC drill legend( k6 `3 K$ p! J, l7 i
1155167 ALLEGRO_EDITOR EDIT_ETCH Via structure placed in Create Fanout has incorrect rotation.
0 f9 {5 T7 R8 Z1155728 CONCEPT_HDL CORE Unable to uprev packaged 16.3 design in 16.5 due to memory
7 [, l) K* x: g7 U1155855 SCM SCHGEN A newly user-defined net property is not transferred from SCM to DEHDL in Preserved Mode
5 [7 X# {& t$ N1156274 ALLEGRO_EDITOR INTERFACES Exported Step file from Allegro is wrong
* E; q& [ R: p: P, R+ s6 k1156316 CONSTRAINT_MGR OTHER Break in functionality while creation of pin-pairs under Xnet in Constraint Manager" O, A/ D' b+ H. F
1156351 CONCEPT_HDL CONSTRAINT_MGR Loose members in Physical Net Class between DEHDL and Allegro
8 m! H4 v" F+ P1156547 ALLEGRO_EDITOR DRC_CONSTR Etch Turn under SMD pin rule check through pin Etch makes confused.
( {' M, y) H7 K0 e" Y* ^+ U1156779 CONSTRAINT_MGR OTHER Electrical Cset References in CM not working correctly
' ^% b3 j4 P# b) G, L6 g1157167 ALLEGRO_EDITOR SKILL axlPolyFromDB with ?line2poly is broken p0 i% V+ c8 o7 e! Z
1158042 ALLEGRO_EDITOR DFA DFA_DLG writes the dra file name in uppercase.: r# \; D( I" c
1158718 CONCEPT_HDL CHECKPLUS Customer could not get $PN property values on logical rule of CheckPlus16.6.6 d7 m3 K1 N. ~% y! D K
1158970 ALLEGRO_EDITOR SCHEM_FTB Changing LOCATION to $LOCATION in DEHDL does not update the .brd file
2 ~$ O. m6 @( h; O* r K1158989 ALLEGRO_EDITOR INTERFACES pdf_out -l creates a PDF. J8 Y0 U5 _% }5 R# E
1159285 APD DXF_IF DXF_OUT fails; some figures are not exported! v2 {6 @- g8 @: H, |
1159432 ALLEGRO_EDITOR SHOW_ELEM http:// in the Show Element in 166 do not have HTML link to open the Website
: W* U0 ?. @0 _4 W4 v1159483 PCB_LIBRARIAN SETUP part developer crashing with
% J8 G2 M5 J, a- u; K1 G# V9 t1159516 ALLEGRO_EDITOR EDIT_ETCH Unable to slide cline segment with new slide.( [; o6 t- |3 {8 q0 [) }7 f
1159959 ALLEGRO_EDITOR GRAPHICS 3D viewer displays clines arcs incorrectly
) s9 |6 Z& X9 P$ H9 q1160004 SCM UI The RMB->Paste does not insert signal names.5 D9 W; v6 N n+ j0 O
1160410 ALLEGRO_EDITOR DATABASE Lock databse with View Lock option is misleading
/ ]+ g) g- ]& v- |1160529 SCM SCHGEN Schematic generation stopped because the tool was unable to create an appropriate internal symbol structure1 ~' q" `& h4 y4 H
1160537 SPIF OTHER Cannot start PCB Router& H) c/ F; T; l7 l
1161363 ALLEGRO_EDITOR SYMBOL Getting error SPMHGE-73 when trying to mirror symbol e8 A" `0 T3 {1 ?# b1 s P
1161781 CONSTRAINT_MGR CONCEPT_HDL SigXp crash when selecting ECset in design- j. i1 r; l! p
1161896 ALLEGRO_EDITOR DRAFTING Tolerance value added for Dimensions is not working correctly (HF11-12)4 g H4 S$ z1 ?! x8 L; ?
1162193 SIP_LAYOUT DIE_ABSTRACT_IF shapes in dia file not linked to the die after edit co-design die/ T# Y A' i5 }5 ^$ j/ W
1162754 APD VIA_STRUCTURE Replace Via Structure command selecting dummy nets.$ N" l0 W6 t, q" o3 @* a% J
& W" q6 y7 h( l: f# ]/ sDATE: 06-28-2013 HOTFIX VERSION: 012
0 M3 \" n0 U: p4 M- [===================================================================================================================================
8 k, X7 O# c" _CCRID PRODUCT PRODUCTLEVEL2 TITLE
( ~4 D' I' @% x) o===================================================================================================================================
- L% j8 h4 T( @( p914562 ALLEGRO_EDITOR GRAPHICS 3D viewer, PCB Symbol view in DRA needs to be same as in BRD- k& u6 w1 ^- n
1120397 CONCEPT_HDL CREFER CreferHDL attempts to create missing vlog004u.sir files
2 N4 z; L* ^4 v+ _& Q9 V8 L1136449 ALLEGRO_EDITOR GRAPHICS about previous shape fill display
! o) d% a! [& X. k1 \1145635 ALLEGRO_EDITOR SHAPE Auto Voding on the same net shapes with other parameter.
$ r! X$ S9 b- T$ m6 ^ K1150334 ALLEGRO_EDITOR EDIT_ETCH AiDT deletes the clines and turns it back to PLAN line/ p; C. {( ?1 d g6 R
1151100 APD VIA_STRUCTURE Net filter not working in replace via structure command.4 N4 d$ ~0 C5 ?! {! f" y$ x
1151126 APD VIA_STRUCTURE Getting "group is not appropriate at this time" message when using Temp Group.
1 |( E' Y- C0 w: N6 A1151458 GRE CORE GRE crashes on Plan Spatial8 I+ F0 |& V$ C5 \ F4 S3 N2 l7 f
1151932 F2B PACKAGERXL PXL error when case is wrong at differen levels in hierarchy
. B: f3 V0 q8 W2 F. k1152151 ALLEGRO_EDITOR INTERFACES dxf2a gives error [SPMHGE-268]
% y: j/ |# _1 ?8 A0 g9 Q1152475 PSPICE SIMULATOR RPC server unavailable error while simulating the attached design1 a0 r8 x. h3 V
1152737 ALLEGRO_EDITOR SKILL dbids are removed because highlighted objects in setting the xprobe trigger y L! y1 n4 T
1153006 ALLEGRO_EDITOR SKILL axlUIWPrint dose no work correctly in allegro PCB Editor 16.6. T& Q1 ]$ X$ Y" R/ C& h+ g K
1153279 CONSTRAINT_MGR OTHER Netrev changing design accuracy from 3 to 2 dec places0 M; i/ n% V- E4 L6 b: v
1153461 SIP_LAYOUT DIE_EDITOR Regression problem in 16.6 ISR: Dia Abstract ECO is causing Die Editor Finish to fail
/ q X3 @7 [ j5 k; a* Z1154973 APD EDIT_ETCH Same Net "Line to Line" violation occurs even with "Allow DRC's" turned off.# y5 r' `; D" T3 S' x! o# {: U
1155227 ALLEGRO_EDITOR DRC_CONSTR via to shape check on the negative layer9 r6 t% R( Q! C' x8 u6 Q7 S
4 Y) L6 o5 J0 D1 d# }; p& C
DATE: 06-14-2013 HOTFIX VERSION: 011( | H6 s% \) G, ^
" d U6 h3 _& U5 [# S0 xCCRID PRODUCT PRODUCTLEVEL2 TITLE
' {" ?; [( ]) C6 r4 q===================================================================================================================================8 ~: B/ J- L! x% K
982306 CONCEPT_HDL OTHER When plotting a PDF publisher output the page coming out half inch bigger in pdf, K6 r4 M/ K( W
1055338 SIP_LAYOUT DRC_CONSTRAINTS Soldermask to Via drcs on bondfingers
* D, C f1 D# U2 j F) W1093375 ALLEGRO_EDITOR PLACEMENT Align Module with Zero spacing value space the modules further away the modules should be nearer. ]6 U2 _6 @% C2 k* q* V, v" X$ ^1 g4 ]
1103201 RF_PCB FE_IFF_IMPORT Wrong permissions to map file during IFF import
0 f# _& Q: S6 N; Q7 K1106900 CONCEPT_HDL COMP_BROWSER Component Browser performance utility should honor CPM directives for include and exclude PPT
( V2 F7 [# `' Y/ t2 E; S- D b1110178 ALLEGRO_EDITOR EDIT_ETCH Line Width Retention should be controlled via setting
' U3 j2 c7 X0 ]1110323 APD DXF_IF DXF out is offsetting square discrete pads.! k/ X5 O0 p* o; o0 R5 F4 a
1123581 ALLEGRO_EDITOR MANUFACT Dimension Line gets changed on board: N8 \# j# v8 ^) p8 Q' L0 F
1134083 CONCEPT_HDL OTHER Published PDF file's hyperlinks do not work fine when user use double digits partitions for page Border.
6 e+ k% j/ K6 J( J4 R1 Q1139338 ALLEGRO_EDITOR DRC_CONSTR The total etch length does not seem to work for Xnets after setting the variable "retain_electrical_constraints_on_nets"
: ?! a) w5 F7 `$ l0 `7 [# P1139361 ALLEGRO_EDITOR DRAFTING Angular dimension tolerance is incorrect when plus minus tolerances are equal.
r5 F. k: F- W9 n- W' {- V1141882 ALLEGRO_EDITOR EDIT_ETCH Allegro Crashes during diffpair slide& X4 s* @9 v, S( h6 p# V
1142876 ALLEGRO_EDITOR SHAPE No DRC error when airgap between place bounds exactly zero
( ?' c% i; R' O, e; v7 h1145235 CONCEPT_HDL CONSTRAINT_MGR DEHDL CM gives error when trying to launch SigXP
: J) @" B4 N' {) Z1145243 ALLEGRO_EDITOR NC Duplicate drills found in the NC Drill output. G' _" R, m! y: X4 _1 S
1145260 SIP_LAYOUT DIE_EDITOR Enable "Copy" in die editor
6 t. a* e1 z" q% s( r1 s$ D1145284 CONCEPT_HDL CORE Publish PDF crashes DE HDL
3 S5 @' T7 P/ U. q; X+ P. Y+ l) P# k1145333 ALLEGRO_EDITOR SHAPE SHAPE boundary may not cross itself. Error cannot be fixed.; g+ o) k- s2 U7 f3 j( B1 O
1145856 ALLEGRO_EDITOR DRC_CONSTR DRC Line to Thru Pin appear while Fillet be added
7 J- h' j: E* A3 n1146287 PCB_LIBRARIAN CORE PDV expand pins and change origin sets coordinates for few pins wrong and places pins on top of each other after collaps
5 o, \7 p4 Z& l, B e1 \1146865 ALLEGRO_EDITOR DATABASE Allegro crashes when trying to place mechanical symbol
9 V& Q" k6 I3 `1148513 ALLEGRO_EDITOR OTHER Importing a subdrawing file causes incorrect net name assignment.7 B1 _: p* l) m7 V! k
1148734 CONCEPT_HDL OTHER Logical Symbol Text is turned upside down after extracting PDF by Publish PDF! x+ I- z) t! }: m% A% X7 q4 `
1149025 ALLEGRO_EDITOR INTERFACES IPC-2581 imports cross-hatched shapes as solid/ U4 b0 I" c; H
1149948 APD OTHER Stream_out hangs on this design -- hang processing merge of overlapping shapes using poly_deletecolinear_only()
! J" n2 ^; q: o* ], A8 q+ n1150274 CONCEPT_HDL CORE Uprev from 16.3 to 16.6 is not preserving RefDes' E0 a; J" w: t1 S
1151450 SIP_LAYOUT DXF_IF DXF export from CDNSIP missing symbols& j5 O: B- X" W& L$ G1 x3 {4 e
4 ]$ V) N0 }/ w& C) J# \7 VDATE: 05-25-2013 HOTFIX VERSION: 010
" {2 {8 q* ^0 X5 S u: L===================================================================================================================================& o& B5 I8 d4 {% P- v7 T6 x: ]% v4 O
- u- c$ E5 g1 A( h+ Z: n/ ~===================================================================================================================================
5 A5 _( n; _1 @+ y5 }+ N0 W1084716 ALLEGRO_EDITOR OTHER Getting an MPS error when updating CM from SigXplorer# k L! u! o2 l, N
1111430 FSP CAPTURE_SCHEMATI Auto-resize the schematic sheet so that hierarchical block fits within border" g6 X I2 a0 j) G7 ^
1119007 CONCEPT_HDL CORE PDF Publish of schematic creates extremely large PDF files! w2 c, C& m1 p2 O2 V- w# @
1121020 FSP MODEL_EDITOR Cut-Paste from Excel causes empty cell in Rule Editor
6 F j3 V1 W4 o8 T( p4 n1124610 PSPICE SIMULATOR Attached design gives "INTERNAL ERROR -- Overflow" in SPB116.6
" P8 n, H% D1 i: A6 [1125330 FSP CAPTURE_SCHEMATI FSP generates OrCAD schematics with components (Resistors) outside page border
4 T/ v8 i; ?$ S1131775 ADW LRM LRM error with local libs & TDA
$ p9 _7 r0 F: k2 ]* _2 q1131868 CONCEPT_HDL CONSTRAINT_MGR Many net-class constraints "fell off" the design after uprev and Import Design of GEP4
6 m% k/ Z9 u8 f9 Q& v1132080 ALLEGRO_EDITOR PLOTTING Size of the logo changes after File > Import > Logo. c3 B& a# a/ U- i2 c$ Q3 {7 h# ^
1134956 SPECCTRA HIGHSPEED Route Automatic fails with error when Impedance rules are turned ON in Allegro CM.
& z# _% g$ W2 j$ G5 M( q1135548 SIP_LAYOUT SHAPE This design shows two areas with shape shorting errors that should not occur
+ K+ Q1 i3 K2 b7 X5 P1138312 ALLEGRO_EDITOR MANUFACT NCROUTE is not generated for filled rectangle slot ?
4 r6 j: X3 T/ _) o; \/ @1139433 ALLEGRO_EDITOR GRAPHICS embedded netnames not displayed or getting very small upon panning after exiting 3D Viewer.( [- y4 P+ w3 a: P
1139509 CONCEPT_HDL CORE The LRM update changes npn device to resistor
1 W0 W# i* A' R. K/ y5 Y7 N3 T1140752 ALLEGRO_EDITOR PLACEMENT Moving a place replicate module crashes allegro
: t# Q* {) H; |- H, A0 d6 ~2 f1141314 SIP_LAYOUT SYMB_EDIT_APPMOD Design will lock up after changing the border using Edit Boundary in Symbol edior mode.1 N" f1 o( w5 p
1141751 ALLEGRO_EDITOR INTERFACES Allegro Crashes with Export IPC2581.
5 v& j q7 G) x, v* t/ B$ w" E1142478 CONSTRAINT_MGR INTERFACE_MAPPER adding constraint to netgroup causes CM & PCB SI to crash% z! K7 y; K6 H+ b; G1 v; w
1142884 ALLEGRO_EDITOR OTHER Boolean type user defined property doesn't export to the PDF7 ~' _7 r1 E- a; h c* ^, D
1143199 SIP_LAYOUT DIE_EDITOR Enable bump remastering
+ Y' m6 B4 A! w) R u1 A1 G/ Y1143654 SIP_LAYOUT DIE_EDITOR Add X&Y offset when adding or moving a pin in die editor& e# ]% [6 e- l4 O7 P/ s' ^2 P
& L( b1 w# m4 t: r0 q' L2 hDATE: 05-9-2013 HOTFIX VERSION: 0098 a$ m# ?( w. X S0 T
===================================================================================================================================) d6 H9 m: u! i$ b) d; j
' T& k3 P* T+ {2 `: P Z' ~===================================================================================================================================$ c5 D8 g2 h4 U+ q# \
961420 ALLEGRO_EDITOR PLACEMENT Regardless of the aspect ratio for room of side The QuickPlace by room command could be placed comp
( I8 s8 j9 O% I" ]! p6 k' Z+ S& O1079862 ALLEGRO_EDITOR SKILL Ability to create IPC2581 layer mapping file by Allegro Skill function
8 o, c3 E0 O* t: I1080734 CONCEPT_HDL CORE Repainting of grid lines during pan or by moving window show as solid white lines instead of gray da
" N" v( u! Q4 M7 F" Z+ k: S; P+ j' x1104145 ALLEGRO_EDITOR SCHEM_FTB User defined properties do not appear in PCB
9 C$ ?: y, o1 P& B1107547 SCM OTHER v15.5.1 tcl/tk code not recognised in 16.68 p' v! c2 R' E, e! Y
1110209 CONCEPT_HDL OTHER We can move symbols and wires off grid despite the site.cpm grid lock
. v% ~3 i2 Z6 Z$ u0 s! B1117825 CONCEPT_HDL OTHER SHOW_CONSOLE_ON_LAUNCH throws an unrecognized directive warning in the schematic editor
. `5 O O% L3 q# u4 w6 [1118874 ALLEGRO_EDITOR INTERFACES Oblong pad shapes are not shown with correct orientation after DXF export from Allegro0 @5 B5 a6 p$ R, G9 f
1121873 ALLEGRO_EDITOR INTERFACE_DESIGN Importing Bundles from Net Groups does not allow any further editing.& J/ J+ _- N) S& s' |
1122933 CONCEPT_HDL CORE Newly added Toolbars are getting invisible after re-staring Concepthdl. |2 S+ V6 n8 q m/ P' F
1124587 ALLEGRO_EDITOR INTERACTIV The Shape Expansion/Contraction command should also be available in EE mode.5 V e; |0 b" O( u
1125895 SIP_LAYOUT LEFDEF_IF Tool crash while moving the slider in the Filter options Macro tab form of the co-design die library manager9 X% Y3 H. D5 G+ u" B$ t
1125962 F2B DESIGNVARI Custom Text in Variant Details dialog box is inconsistent1 i( L3 J! [0 E' o' m/ N) d
1126096 SCM REPORTS Two nets missing in report& I7 A& Q- N/ I* [8 F
1126134 SIG_INTEGRITY GEOMETRY_EXTRACT Attempting to extract topology hangs APD
8 q9 g' r- K- u8 e1126182 ALLEGRO_EDITOR DRC_CONSTR Shape fillet DRC in same net thru via to thru via was removed after update DRC.' |, A$ {3 Y/ m3 A5 G9 ?3 B5 j. j
1130280 ALLEGRO_EDITOR MANUFACT stream_out command in 16.6 seems hard coded to look for a design called stream_out.brd
" }1 g' C7 g6 ~# ~1 N" Q/ N# \1130737 F2B PACKAGERXL Error - pxl.exe has stopped working3 K- D1 n* O" \' R3 B( ]- ^2 h
1131650 ALLEGRO_EDITOR PLOTTING PDF Publisher doesnot display few component defination properties in Property parameters0 n8 P7 f0 m0 D4 Q _
1131764 ALLEGRO_EDITOR EDIT_ETCH Line segment will not slide using the New Slide.1 }4 l! o- b0 p. ^& {. A! D
1132638 ALLEGRO_EDITOR DFA 'dfa_update' crashes when running the utility on the attached foder.! o6 W( I$ @9 k/ m: K/ F
1133311 ALLEGRO_EDITOR SKILL ?origin switch is not working correctly with axlTransformObject while rotating shapes
' u+ E' @& c( ?% u* v1133893 SIP_LAYOUT IMPORT_DATA netlist-In Wizard crashes& n) g! |/ J" L
7 c9 D" f5 C/ l) X5 R
DATE: 04-26-2013 HOTFIX VERSION: 008: ~. n S+ M/ v- K
+ F* \" V3 x" N, q: TCCRID PRODUCT PRODUCTLEVEL2 TITLE1 @- f! j8 F. K% A u- M
===================================================================================================================================/ ]. M; \. K. m8 v& }6 p0 } K8 h2 l
876711 ALLEGRO_EDITOR GRAPHICS Mouse wheel will only zoom out using Win7 64 bit8 {& D- M' a; e0 s- C( ~1 m# m
1080386 CONCEPT_HDL CORE Unable to highlight netclass on every schematic page using Global Navigation7 ^7 T' M& j- A) |) a
1082587 FSP FPGA_SUPPORT Support of Xilinx's Zync device
( \; J0 [! G* m1105286 FSP DE-HDL_SCHEMATIC FSP crashes while creating board in Schgen if it does not find any available license.$ S8 P% g5 c! m4 F3 i
1105461 ALLEGRO_EDITOR DRAFTING Dimension Enviroment deletes Diameter symbol whenever we add anything to Text section9 g' I1 }4 }1 I# M1 t
1105504 PCB_LIBRARIAN CORE PDV on Linux Move pins by arrows does not stop when release arrow key but keeps on running
# w# k- W7 }' p& W1110126 ALLEGRO_EDITOR GRAPHICS Display Hole displays strange color.- a C: T. K7 Q0 P- H+ k
1113518 CIS DESIGN_VARIANT Incorrect Variant information in Variant View Mode for multi-section parts with occurrence
" R9 f+ w, o# t4 P1117580 SCM OTHER DSMAIN-335: Dia file(s) error has occurred.( ~/ _8 w' F& m* r( `
1117845 FSP DE-HDL_SCHEMATIC Schematic Generation fails without a reason
+ G- M/ h. x! {, C; v Y1119864 FSP TERMINATIONS Auto-increment the pin number while mapping terminations.0 t- x7 u- F( D' m# `* b1 g
1120250 ALLEGRO_EDITOR MANUFACT Why is the parameter File altered?
2 p1 R. h) S }2 n; |1120414 ADW LRM TDO Cache design issue
% H4 l$ h% d* A2 T" T7 J1121044 SIP_LAYOUT SKILL axlDBAssignNet returns t even when no net name is assigned to via
( \( R' X; {4 j) |- O- W' s1121148 ALLEGRO_EDITOR PLACEMENT Ratsnests turns off when moving symbols with Net Groups$ Q. {: y7 q9 v$ N# J: y( m1 o
1122440 ALLEGRO_EDITOR DATABASE Cannot unlock database using the password used to lock it K# ^( f* S+ n6 J
1122449 ALLEGRO_EDITOR DRC_CONSTR Uncoupled length DRC for diff pair shows different actual length value between show element and CM.- c/ ~! Q' B2 u/ b7 v I
1122990 ALLEGRO_EDITOR INTERACTIV RF PCB Symbol which is part of Reuse Module cannot be replaced. k3 \2 L( p2 S8 V. Y
1123083 ALLEGRO_EDITOR PLACEMENT Saving after mirroring a Place replicate mdd create a .SAV board file./ E! ]' ?5 m+ A7 ^4 W5 l
1123257 SIG_INTEGRITY SIMULATION some of the data signals at the receiver are not simulatable
( U0 N1 z; f3 B* P4 m1123764 CONSTRAINT_MGR OTHER Allegro crash while importing DCF file; P C; E L: P4 s" i
1123816 CAPTURE PART_EDITOR Movement of pin in part editor0 C' |% q {1 ^# G7 ^ u% B" j- k
1124183 ALLEGRO_EDITOR EXTRACT Output from EXTRACTA gets corrupted with refdes 50
$ n7 @; ^% ^; h4 G, s j, v# j) J; p$ \+ p8 y
DATE: 04-13-2013 HOTFIX VERSION: 007
# T M- l' A% C9 h' R===================================================================================================================================
" A$ t! T2 g3 H1 A5 | N! _$ GCCRID PRODUCT PRODUCTLEVEL2 TITLE3 V* p Q, x2 _2 C7 F8 b
===================================================================================================================================4 G+ e( G, e" U2 o& p
1107397 SIP_LAYOUT PLACEMENT Place Manual-H rotates die- Z* x @4 g7 d
1111184 ALLEGRO_EDITOR PLACEMENT NO_SWAP_PIN property does not work in 16.6! L6 u1 \% \2 Z% e9 j# k' F
1112295 APD DXF_IF Padstacks� offset Y cannot be caught by DXF.- L6 g5 ]( o7 m9 m1 T# V; h
1113284 ALLEGRO_EDITOR INTERFACE_DESIGN Rats disappear after moving components# n1 u6 O1 E+ Y! ~
1113317 CONCEPT_HDL SKILL skill code to traverse design not working properly* [" h3 q( E. |' @5 P( ]
1115491 ALLEGRO_EDITOR SKILL telskill freezes command window( b+ Z" u- k" N, w0 U, a7 G
1115625 ALLEGRO_EDITOR SKILL Design extents corrupted when axlTrigger is used.3 T+ V# W& j3 r! T& t
1115708 ALLEGRO_EDITOR INTERFACES Export DXF is outputting corrupt data on one layer.
$ I# Z% c# Q- f1115850 ALLEGRO_EDITOR GRAPHICS Text edit makes infinite cursor disappear& n' X) d( J0 V+ j
1116530 ALLEGRO_EDITOR MANUFACT Import artwork show missing padstacks
* |7 B* u; R0 K. X0 G6 a1117498 ALLEGRO_EDITOR DATABASE Why does dbstat flag LOCKED?
$ Q8 q/ X6 F( U j4 ] i: }1118407 SIP_LAYOUT DIE_EDITOR net connectivity is getting lost when running die abstract refresh
3 Z' r0 f! _6 Y# d4 i) a+ r& M0 J4 O) A6 R1118413 SIP_LAYOUT DIE_EDITOR pin number is getting changed when running die abstract refresh
e6 f7 M* T' J1118526 CONCEPT_HDL CONSTRAINT_MGR Upreved design now has Constraint packaging errors! f8 ^; v! a2 g
1118830 ALLEGRO_EDITOR SHAPE Performance issue when moving/refreshing shapes in 16.6
) a8 ~6 C/ a! g! q. K% C8 T1119784 ALLEGRO_EDITOR INTERACTIV ipickx command gives drawing extent error inconsistently
& q" e1 \& a% [9 c1 `8 K1120469 SIP_LAYOUT DIE_ABSTRACT_IF use different padstack for different, but look-alike bumps* z/ Q ^8 R E; P6 Q
1120669 CONCEPT_HDL CORE DEHDL crash on multiple replace of hier blocks
. ?% |0 p- f& t/ ~. g1120810 ALLEGRO_EDITOR EDIT_ETCH Cannot slide cline segment.; m" p) E0 L0 V( M5 L/ C5 g
{' Q# e! z0 R; a9 g1 i6 `
DATE: 03-29-2013 HOTFIX VERSION: 006; O% t5 u) g$ N- d) ~7 U
1 }2 S2 X3 X6 S. v' ^2 ~CCRID PRODUCT PRODUCTLEVEL2 TITLE
7 z$ |: V% x& s( m* p===================================================================================================================================
4 |) R" m |; l625821 CONCEPT_HDL CORE publishpdf from command line doen not work if temp directory does not exist." r& H1 a+ V2 B, B H# T2 z# [0 h
642837 PSPICE SIMULATOR Option to disable Bias Points when Primary Analysis in Active Simulation Profile is DC Sweep
# r# O9 c6 ]6 ]* i650578 ALLEGRO_EDITOR SHAPE Allegro should do void only selected Shape without "Update Shape".
" m4 @9 ] H+ K! |+ n$ b9 n( s653835 ALLEGRO_EDITOR MANUFACT Double character drill code overlaps with "cross" in NC drill legend
/ x) R) l& y4 q# {( U687170 SIP_LAYOUT DRC_CONSTRAINTS Shape to Route Keepout spacing DRC display incorrect) [: s. f3 f& J a5 R, H ^- q8 d
787041 FSP DE-HDL_SCHEMATIC FSP Refdes inconsistency when gen schematics
, j! K1 Y- `; E! r( ]/ q9 r7 f6 J9 f825813 CONCEPT_HDL CORE HDL crashes when copying a property from one H block to other3 S3 K2 O7 I7 g
834211 ALLEGRO_EDITOR SHAPE Constant tweaking of shape oversize values is time consuming
( J/ m8 Z- v& K: k835944 ALLEGRO_EDITOR OTHER Customer want to change for Jumper symbol by other Alt symbol.& [" o& W4 ~1 I/ [, d" S
868981 SCM SETUP SCM responds slow when trying to browse signal integrity9 Q: x: _( |$ M/ ? w' E5 z
871899 CONCEPT_HDL CORE 'Multiple:' column of Grid window in DE-HDL option is too wide L$ @6 C1 b$ r6 u+ d$ J/ P0 R
873917 CONCEPT_HDL CORE Markers dialog is not refreshed
9 Q$ r% {& r, s! m887887 CONCEPT_HDL CORE Option to find unconnected Pins/Nets with DEHDL L License
3 G3 ?: V9 G' y( o! B9 `888290 APD DIE_GENERATOR Die Generation Improvement$ _/ ^/ x+ k$ u* [! K8 G
892857 CONCEPT_HDL CORE packager treats R? as a unique reference designator; F9 X" Q1 n+ d8 i( E
902908 PSPICE SIMULATOR Support of CSHUNT Option in Pspice G7 i- i5 v$ W
908254 ALLEGRO_EDITOR INTERACTIV Enhancement request for DRC marker to have a link to CM, h+ [$ K. F7 `/ y( w
922422 CAPTURE NETLIST_ALLEGRO Netlist errors when using mix of convert and normal symbols0 O1 A! ?& J0 P* `4 D, Q; M
923361 ALLEGRO_EDITOR INTERACTIV Stop writting PATH variables in env file if no modifications are done using User Preferences
3 E3 r( P$ L9 Z/ |" ? r935155 CAPTURE DRC No any warning messages listed in the On line DRC window even executed "Check & Save" to on line DRC. B# m, `# j( x/ ]! X6 r
945393 FSP OTHER group contigous pin support enhancement# V9 N2 o$ ^1 H
969342 ALLEGRO_EDITOR DATABASE Enhanced password security for Allegro database
3 d% e8 n0 N9 G; P: k& Y1005078 CAPTURE ANNOTATE Copy paste operation does not fill the missing refdes
. t: P1 ?) S' i% e- n1 S( J, w1 O1005812 F2B BOM bomhdl fails on bigger SCM Projects
$ X4 Q( Z4 Y" [1010988 CAPTURE OPTIONS ENH: ADD ISO 8601 Date Time format to Capture) b; v) `$ n; }4 D8 r# D0 G& p
1011325 ALLEGRO_EDITOR PLACEMENT Placement replication creates modules with duplicate names
J. z8 V7 A0 S; \1016640 ALLEGRO_EDITOR PLACEMENT Error/Warning Message for not finding or unmatched mechanical symbol or fiducials or which are not on a net
) J& |# Z) o8 T! y: b2 a7 r v6 h1018756 CONCEPT_HDL CONSTRAINT_MGR Match Groups with Pin Pairs are not getting imported into the schematic CM during Import Physical3 H- K' n2 _' z; F
1032387 FSP OTHER Pointer to set Mapping file for project based library.
r/ ~3 _1 s- w1032609 FSP IMPORT_CONSTRAIN Import qsf into FSP fails with 縋LL PLL_3 does not exist in device instance�
1 |3 Z' [5 n; u1 U$ b& ?) w; V& D1040678 ALLEGRO_EDITOR MANUFACT Text spacing is inconsistant for top and bottom SM layer in xsection chart
; N3 q0 r9 N4 Q, I8 m: q& K& q: K* q1042025 APD WIREBOND Order placement of power rings for power/ground rings generation with using Perform Auto Bonding% Z$ H1 A; V! X* F
1045500 CONCEPT_HDL CORE Why Search results does not display the correct Physical Pages.3 ~% S. l$ G* o( Z
1047259 CIS EXPLORER Sorting in CIS Explorer is not Numeric even for columns which are of Numeric data type" o2 g: k* s/ ]6 D4 `
1047756 CAPTURE NETLISTS Not adding user defined properties in netlist generated by orDump.dll
! e2 U7 g7 n( E1052455 RF_PCB DISCRETE_LIBX_2A RFPCB IFF Export to fix port direction for ADS for footprint having the same pin rotation" _3 a, a& K I" [- }
1054314 CONCEPT_HDL CORE Zoom of custom text is different from other schematic objects
& ~2 o2 X; \% f2 L3 R; J1061529 CONCEPT_HDL CORE Space can be included in LOCATION value and cannot be checked by checkplus* P- q) q1 T2 F
1064035 CONCEPT_HDL COMP_BROWSER Component Browser crashes on part number search using a library containing >23K parts# y. c4 s3 j3 Q
1064604 ALLEGRO_EDITOR MANUFACT Enh - Include ability to add slot notes to designs
( Q4 t5 n8 [9 v* ?' h1065636 CONCEPT_HDL OTHER Text not visible in published pdf4 q3 o+ n3 K$ Y8 n: {
1065843 CIS PART_MANAGER time stamp on library from different time zones triggers part manager lib out of date warnings0 y, }6 c9 w4 P5 y. v, c
1066701 ALLEGRO_EDITOR OTHER Missing padstack warnings not in Symbol refresh log summary% n6 G* u# m7 [4 H4 y
1067283 SCM PACKAGER ALLOW_CONN_SWAP does not work for lower level schematic parts9 V4 w/ t- J( ]) G' c1 [
1067400 CONCEPT_HDL CORE ERROR(SPCOCD-171): Port exists in symbol but not in the schematic/ ~% U( S/ f2 W1 |) O2 B# ~
1068878 CONCEPT_HDL CORE Rotating symbol causes the pin name to be upside down
4 S' g# v* q8 `/ K1069896 ALLEGRO_EDITOR EDIT_ETCH Cline changes to arc when routing even when Line lock is set to Line 45
2 o' U0 b- w: S. V" E1070465 CONCEPT_HDL CORE Why does ConceptHDL crash on renaming a Port Signal
7 B4 k* d1 D7 R) L6 {9 X7 R1071037 PSPICE SIMULATOR Provide option to disable Index Files Time Stamp Check9 R# t* q/ g: |( P
1072311 CONCEPT_HDL OTHER Schematics are incorrect after importing design.
8 w+ g! Z5 F0 O, d6 G0 c0 ~+ K; l1072691 CONCEPT_HDL CORE Customer has the crash from Run Script of DE-HDL 16.51 again(#3)8 e4 L1 A4 y/ S0 C3 f
1072859 SIP_LAYOUT DIE_EDITOR padstack selection window crash from Die Editing: Component editing of Co-Design Die& n& u7 M% e l. x' Y0 Z
1073354 CONCEPT_HDL CORE Bubble defined on symbol pin is not visible on the schematic# w2 F; b3 b6 b& o2 W3 G& Q
1073837 ALLEGRO_EDITOR GRAPHICS Some objects disappear on ZoomIn ZoomOut+ |/ O7 N: o; s- D, S$ T* Y9 ?
1074243 ALLEGRO_EDITOR GRAPHICS Allegro WorldView window does not always refresh after dehighlight of objects2 P& A+ c) ]& j7 ?
1074606 ALLEGRO_EDITOR INTERACTIV Enh - Cosmetic change in Filter Option UI of Replace padstack to indicate multiple pin entry format
) j, H# A$ f' J1074794 ALLEGRO_EDITOR REPORTS add commonly reguested via reports to Allegro and ICP reports. Via per net, via per layer per net
2 t3 |! c8 `3 m1075587 CONCEPT_HDL PAGE_MGMT Unable to insert page in schematic# s! x& M" f/ V: g: j9 H
1076117 PSPICE PROBE Copy & Paste text/label in probe window changes font size and later gets invisible
8 C( U% \8 q; g* L0 u2 M7 N1076145 SIP_LAYOUT DIE_ABSTRACT_IF Issue message in Add Codesign and Refresh Die Abstract if Pin Numbers from Die Abstract exceed 31 chars.
X8 h7 O7 E5 y9 [' a4 D( A1076566 ALLEGRO_EDITOR EDIT_ETCH Sliding diff pair cline that has a min/max prop rule displays the HUD meter inconsistently.2 _& n: F4 q3 t
1076604 ALLEGRO_EDITOR SHAPE Sliding via in pad corrupts surrounding shape and generates false DRC Errors0 d G* l# h9 c7 ?
1076820 SPECCTRA FANOUT Fanout fails to stack vias in bga pads.* P' x8 W, M* l* A* z9 c
1076868 ALLEGRO_EDITOR PARTITION Symbols become 'read only' inside a design partition9 r0 b- l4 s' b/ D2 c8 ~6 n
1076879 GRE IFP_INTERACTIVE Plan Column should not be present in Visibility tab for Symbol Editor+ t' W8 O$ [) r
1076898 CONCEPT_HDL CORE User can not increase logic grid size value continuously using Up button on Design Entry HDL Options+ Z9 M6 o5 h) ?# n% U1 ~* q4 c
1077026 CIS LINK_DATABASE_PA fonts changes while linking db part in 16.57 V' }0 l( _$ X! ~" j
1077187 ALLEGRO_EDITOR DATABASE DBDoctor appears to fix database but nothing is listed in the log file.
! t/ b( p) J" \- V5 E+ F1 `; G1077527 CONCEPT_HDL CORE ConceptHDL net with name U cannot be found using Global navigate5 @3 M) g! z& ^5 t3 m
1077621 CONCEPT_HDL CORE DEHDL crashes when saving page 3
6 P R2 H* D2 q8 I( }1 p" S1078270 SCM UI Physical net is not unique or not valid
% J5 G. ?! A+ f; E) e% M0 X( ]3 A1079616 CONSTRAINT_MGR CONCEPT_HDL Packager error in 16.5 which is resolved when system is re-booted
: g" C) h5 I0 [, D! r: W1079821 CONCEPT_HDL CORE Project Setup does not respect $TEMP variable for temp_dir and creates a directory in project calle
4 e9 ?; B/ A5 C/ G9 l5 }) C& |- L" n1080142 CIS CONFIGURATION peated entries in Allowed Part Ref Prefs) \, k' k$ n: D# a! d
1080207 ALLEGRO_EDITOR INTERACTIV Separate the 2 types of SOV violations."Segments over voids & Segments with missing plane coverage"
- W- U+ U0 K o& ]. V: e7 ?' w/ k# U1080261 PSPICE SIMULATOR Encryption support for lines longer than 125 characters, Y0 i {7 v x
1080336 CONCEPT_HDL CORE Backannotation error message ehnancement
# h: J! x7 h$ m) t; A1081001 ALLEGRO_EDITOR PLACEMENT Package boundary is not visible while manually placing a component when using OrCAD license
p+ E, s7 R9 @6 p3 r& ^1081237 ALLEGRO_EDITOR PLACEMENT Place replicate > apply does not apply component pin properties stored in .mdd) M& M% V6 \- m, _ O% L
1081284 MODEL_INTEGRIT TRANSLATION Space in the file path will create a bogus error
( n" X0 T$ U/ T$ j1081346 ALLEGRO_EDITOR INTERACTIV With Place manual, rotation of the symbol is not updated.4 q$ S( R+ j& y8 {7 I- p: D
1081760 FSP CONFIG_SETTINGS Content of 縁PGA Input/Output Onchip termination� columns resets after update csv command9 o! c6 r) V1 }2 P4 R4 I( v
1082220 FLOWS OTHER Error SPCOCV-3530 S% E/ e2 w( y$ O) D) N; R
1082492 ALLEGRO_EDITOR PLACEMENT Place replicate create does not highlight symbols./ n. _" S' S' e9 F( B
1082676 ALLEGRO_EDITOR EDIT_ETCH HUD meter doesnot display while sliding / add command
W2 F: N. \' ~( [: ?1082737 CAPTURE GENERAL The 緼rea select� icon shows wrong icon in Capture canvas.9 @" }2 V$ k* w' v7 A
1082739 CAPTURE OTHER The product choices dialogue box shows incorrect name! k7 E% g% Q) j. N; l
1082785 CONCEPT_HDL CORE DE HDL should clean the design with non sync properties in some automated way1 J8 o5 z0 i$ t& a7 M8 c' d
1083761 CONCEPT_HDL OTHER AGND text missing from PDF Publisher
9 Z8 o# Y2 U* e1083964 CONCEPT_HDL OTHER Do not display Value and other attributes on variant parts which are DNI
; U1 F/ N& K: m0 Q, N1084023 PSPICE MODELEDITOR Model Editor is slow/unresponsive while opening a Model by double-clicking on .lib file
/ f' C% C" k) P: }# V p1084178 ALLEGRO_EDITOR SHAPE Spike create on dynamic void.
& E) [+ a# m7 |( b- q# j3 P7 a& B1084637 ALLEGRO_EDITOR INTERACTIV Enhancement: Pick dialog should automatically be set to enter coordinates
; w2 g4 U+ X1 ^4 @1085010 CONCEPT_HDL CREFER Crefer crashes if the property value in the dcf file has more than 255 characters/ I$ A+ X6 Y$ ^0 _/ i3 d6 h0 O
1085347 CAPTURE SCHEMATIC_EDITOR Replace cache results is loss of net graphic changes.4 S8 C+ ~. i+ d7 c; X1 }( ^7 B
1085522 ALLEGRO_EDITOR INTERACTIV Allegro add angle to Display->Measure results$ v/ D! n: D, A' j# o& }
1085791 CONCEPT_HDL CORE Publish PDF can not output Constraint Manager properties into PDF file.7 k3 z4 t- i- _' l2 |9 d
1085891 ALLEGRO_EDITOR INTERACTIV about DRC update+ ~! a5 m* D/ t3 {' Y; d, F
1085990 CAPTURE DRC B1: "ERROR(ORCAP-2207) Check Bus Width Mismatch" should be INFO3 Q d4 e' R& h( C: S
1086514 CONCEPT_HDL COMP_BROWSER Component Browser placement restrictions not working6 z' I: m0 q$ z0 Y1 O# Z2 @0 g4 {
1086576 CONCEPT_HDL CHECKPLUS CheckPlus hangs when running Graphic rules.
9 H5 V5 y" W% h, ~* y9 y( _6 E$ L$ a1086671 PSPICE SIMULATOR SPB16.6 pspice crashes with attached design
6 A: \" d4 g4 \+ C2 B4 F% m1086749 ALLEGRO_EDITOR MENTOR mbs2brd: DEFAULT_NET_TYPE rule is not translated
. i8 h0 m, n, t3 V6 J& F) S1086886 CAPTURE PROPERTY_EDITOR "Is No Connect" check box in property editor doesn't work for power pins6 x; `, T4 M/ @$ i+ T! S
1086902 CONCEPT_HDL INFRA Problems occurred while loading design connectivity
% f: L) U3 M8 G2 F k1086937 PSPICE ENVIRONMENT PSpice Color map getting doubled leading to crash after colors are modified number of times." o' Y1 g; ~5 J& C/ B
1087221 CONCEPT_HDL OTHER Part manager could not update any parts.
" \0 G/ ~$ t# W" P. ^$ d6 a- ^! `1087223 CAPTURE CROSSREF Cross Probing issue when login into system with user name containing white space5 w# K* @" j0 g% K
1087295 SIP_LAYOUT EXPORT_DATA Enable "Package Overlay File for IC" for concurrent co-design dies too2 J5 w$ E( s6 D2 w3 J4 ]- L8 {
1087658 CAPTURE PRINT/PLOT/OUTPU Lower level design pages are getting print twice
/ d7 C ]3 M7 I6 f/ @1088231 F2B PACKAGERXL Design fails to package in 16.5
1 h. C1 c. m2 W5 `0 S) _. I1088252 CONCEPT_HDL CORE Menu commands grayed out after Save (with 16.5-s035) when launched from ASA.5 a5 U- g, h4 Q* j3 \
1088606 ALLEGRO_EDITOR INTERACTIV Pin Number field do not support Pin Range for Symbol Editor6 ~/ W) I `+ I, h
1088983 CONSTRAINT_MGR CONCEPT_HDL Units resolution changed in 16.6 Constraint Manager3 ?) H7 u5 k- g P
1089017 ALLEGRO_EDITOR SHAPE What is the cause of the shape not filling?
$ `5 ?( z* E- F" w" B3 i) T1089259 SCM IMPORTS Cannot import block into ASA design
( y' q, ]% ~: s# V, D3 O: B2 X1089356 SIP_LAYOUT DIE_EDITOR Distributed co-design : launching die editor taking more than an hour to bring up edit form6 Z% k/ c) I+ k0 V! ?8 S9 d$ v
1089362 PSPICE STABILITY Pspice crash on pspice > view simulation result on attached project2 L# O. Y, H. Q: z
1089368 SCM OTHER Can't do Save - cp: cannot stat ... No such file or directory: s$ {/ D* d3 C! I; T
1089605 CONCEPT_HDL CONSTRAINT_MGR Power net missing from the CM opened from DEHDL Schematic editor./ L" [8 d+ }7 v' \. F5 d
1090068 ALLEGRO_EDITOR SHAPE shape priority issue in SPB165
6 D. b6 r3 P5 q7 b5 ]1090125 ALLEGRO_EDITOR DATABASE Q- The rename resequence log file is not giving correct message.
; W# B3 E+ |# \. W; E1090181 GRE CORE AiDT fails for the nets with errors SPGRE-21 & SPGRE-22& y2 S: r+ E* ^2 j; O; b0 J
1090930 CONSTRAINT_MGR CONCEPT_HDL DEHDL-CM does not retain customized worksheet.
2 r. b* v- H1 r2 q& ]# F, Y1091335 CONCEPT_HDL OTHER Color change cannot remain in some situation.
2 K# @" D+ `4 G: K* J6 Z# C2 e U1091347 CAPTURE TCL_INTERFACE The Project New link on Start Page doesn't work when Journaling is enabled/ @3 L, r) u* ~& _2 Q* L
1091359 CAPTURE GENERAL Toolbar Customization missing description
. l8 u# `+ B) ~% d& O \( J1091662 CONCEPT_HDL CORE Incorrect behavior with the SHOW_PNN_SIGNAME directive9 J7 Z' w2 x: c! m
1091714 CAPTURE PART_EDITOR More than one icons gets selected in part editor at the same time
4 X j8 f- Z3 I2 g; \ e1092411 CONSTRAINT_MGR INTERACTIV In v16.6 CM multiple net name selection under net column is not working as in v16.5: N' D4 k1 N3 q# {+ l, w
1092426 CONCEPT_HDL CORE Getting ERROR(SPCOCN-1993) while saving a Hierarchical Design
" `! Z" l/ ] I- b" e, B1092874 CONCEPT_HDL CORE DEHDL wire short during move not detected with check enabled; P6 o8 ?3 I* t0 }9 p
1092882 ALLEGRO_EDITOR EDIT_ETCH AICC should be removed from orcad PCB Designers design parameters; H% k5 ^! A4 O3 |) L5 J7 b
1092918 CAPTURE GENERATE_PART Generate part functionality gives no/misleading information in sesison log in case of error: j+ J! i! Z" r3 `! o
1092933 CONCEPT_HDL OTHER PDF Publisher saves the pdf generated in the previous project folder, x- J& f2 a9 f& r& ]7 D, s
1093327 CONCEPT_HDL OTHER Getting error SPCODD � 369 Unable to load physical part in variant editor
$ g/ T. c( q! K" F1093391 CONSTRAINT_MGR OTHER Setup > Constraints > (domain), doesn't open correct worksheet with OrCAD PCB Editor Professional license.
: Z, T* g4 @9 u/ E+ k1093886 SPECCTRA HIGHSPEED Pin delay does not work in PCB Router when specified in time
r. g5 p+ R! i) }8 Y( M1094223 CAPTURE PROPERTY_EDITOR CTRL+S does not work in Property Editor but RMB > Save.
6 _8 w# X7 Z7 a" y1094513 CONCEPT_HDL CORE How to display $PNN for which SIG_NAME is not visible?# j5 Y1 n; G! F! [4 R
1094611 CAPTURE PROPERTY_EDITOR E1: 'Tools->Update Properties' should list parts which are present in .UPD, but not schematic2 ^1 `" f: ^+ n- |' g0 i2 b& {- ^
1094618 CONCEPT_HDL INFRA Unable to uprev the design in 16.5
@$ w7 _0 y7 D2 |" _# ?1094867 CONCEPT_HDL CORE Page Up / Down Keys are hard-coded assigned to Next /Previous Sheet
" J! k ~$ n) z: ^) ]1095449 SIP_LAYOUT LOGIC Allow netlist-in wizard to work on a co-design die/ ?% @; s5 ~, C& `
1095701 CONCEPT_HDL CORE Replace part in replicated block only preserves the Refdes in 1st instance of the replicated block
* S; s4 P7 n- D& _1 y) W2 {2 }# v1095705 CONCEPT_HDL CREFER Cref_to_list not updated on repl icated blocks in 16.5 release worked fine in 16.3# o. h, O$ x" o+ k* S5 W
1095861 F2B BOM Using Upper-case Input produces incorrect BOM results
. m& }. m' g1 {+ \8 @1096318 ALLEGRO_EDITOR INTERFACES IDF import not removing MCAD tagged objects during import
5 I$ e# \8 H5 ?% t1097241 CONCEPT_HDL CORE Concepthdl - zoom in to first object in Find result automatically# v" a1 Y$ Z6 S/ O+ {' V; X, |
1097468 ALLEGRO_EDITOR INTERACTIV Need ability to hilight and assign color to vias& z7 j0 m u1 P
1097675 CAPTURE ANNOTATE Enhancement:Option to have Incremental reference Update to be checked at all times when we click on Tool>Annotate
6 E' q4 R2 \/ U# j3 f( N1099151 SIG_INTEGRITY SIMULATION All Neighbor crosstalk numbers reported when there are no aggressors
* N5 v% g& @ A4 c7 z1099175 CONCEPT_HDL CORE CPM directive that enables the Command Console Window in DE-HDL
. Z. y; T3 J* i- }4 Z/ f1 J1099838 CAPTURE TCL_INTERFACE TCL library correction utility is not working correctly.& C$ K. `0 V9 W4 @( W" |
1099903 ALLEGRO_EDITOR PLACEMENT Mirror and rotating component places component mirror side
7 r# _( _2 X4 @3 [; v) O- S1099941 ALLEGRO_EDITOR PLACEMENT Problem in rotating bottom components when using Place Manual or place manual -h command4 P% d! l& V6 J/ N& e" ^+ y
1099998 CONCEPT_HDL CHECKPLUS CheckPlus marker file not locating signal when signal name includes the # character.
7 W' T- E: q' a, q9 f3 p0 Q1100018 CONCEPT_HDL COPY_PROJECT CopyProject gives errors about locked directives0 G9 }+ k3 Z0 U: P
1100449 ALLEGRO_EDITOR ARTWORK Pad with Net_short property and shorted to shape supressed wrongly with Pad Supression in Artwork
+ N. Z- {* t j8 X1100758 CAPTURE LIBRARY Import properties does not update pin numbers of multi section parts
3 Q4 c4 n( O, s: \: T, T4 X1101009 CONCEPT_HDL CORE Cursor stays as arrow after performing File > Save Hierarchy. h8 |/ c0 @ M9 b( f* _2 b
1101497 ALLEGRO_EDITOR UI_FORMS Allegro PCB Editor crashes using attached script when working with RF PCB Clearances.
# r9 f' ^& t! R3 @6 r# c: S7 @1101813 SIP_LAYOUT DIE_ABSTRACT_IF Support die abstract properties& u; T! C! B6 u
1102531 ALLEGRO_EDITOR GRAPHICS Allegro graphics distortion infinite cursor 16.6
2 [- v+ r9 E9 J: c; B; \0 \6 N1102623 ALLEGRO_EDITOR SHAPE Strange void around the pad
* A4 y# X+ j- O1103246 FSP FPGA_SUPPORT New FPGA request - Arria V - 5AGXMA1D6F31 - IN2P3
6 h9 I- s$ c& B! G5 n1103631 MODEL_INTEGRIT OTHER Model Integrity license when using orcad; Y$ ]; H- ?2 J" i c8 [
1103703 F2B DESIGNSYNC Toolcrash with Design Differences# N; S. R( r2 W \
1103712 CONCEPT_HDL COPY_PROJECT Copy Project crashes on customer design attempting to update symbol view; H# K3 \+ Z1 D9 U. B
1104068 CAPTURE DRC "Check single node connection" DRC gets reset in 16.6
1 H7 A( l N& }* Q3 K1104121 PSPICE AA_OPT 縋arameter Selection� window not showing all the components : on WinXP$ h1 s6 }' e! R5 v0 m2 T: ~( P7 V
1104575 CONCEPT_HDL CORE Allign does not allign offgrid symbols correctly
5 i* l' G+ @. k9 \8 l, q. w# _- u) ?; ]* y1104727 CONSTRAINT_MGR SCM Net Group created in sip does not transfer to SCM6 H% k3 D6 ?- W7 V6 J. _
1105128 CONSTRAINT_MGR DATABASE Import dcf does not clear out user defined schedule.
2 j; A! V( S2 X8 Q7 Q1 y- \1105195 SIP_LAYOUT WIREBOND Request that Tack points default to a "fixed" position after Generate Bond Wires.
5 ]6 F7 ?# \2 o! @1105249 ALLEGRO_EDITOR OTHER PDF out--- component user defined prop doesn't list the prop selection form/ _' m. m4 a8 Z+ D2 n: U! E$ v9 U% n# h
1105443 PSPICE AA_OPT Parameter selection window in optimizer does not list param part
: ]1 z! f1 e- H8 u, e1105818 ALLEGRO_EDITOR INTERACTIV Menu-items seperators are clickable and menu goes away when clicked
' X1 N$ M5 D& Y1105822 ALLEGRO_EDITOR SCHEM_FTB Netrev failing with compact pin syntax
$ G# B. R4 u' D8 {1105993 SIP_LAYOUT LOGIC Import netlist no longer works with co-design die in SiP 16.6
6 k7 T, B/ {+ @& v9 ~( f& K" E1106332 SIP_LAYOUT OTHER sprintf for axlSpreadsheetDefineCell writes characters in upper case only
- o2 r& X5 v6 z1106786 CAPTURE SCHEMATICS Bug: Pointer snap to grid6 [! [$ j* O9 R9 @* h% K. P% J
1107132 FSP OTHER Altera ArriaV (5AGXMA5GF31C4) support.8 O) E1 y3 \( r& j e# ~
1107151 ALLEGRO_EDITOR ARTWORK Shape filling removed when changing artwork format to RS274X in Global Dynamic Param& g4 F5 F# r3 R) }. y8 {. P' [
1107237 SIP_LAYOUT WIZARDS Updating a Die using the Die Text In Wizard will error out and not finish
% @# e. P; R. t |5 W8 X1 R/ ~( w1107371 ADW COMPONENT_BROWSE ADW preset Warning filter is spelt incorrectly. (Wraning).
' l6 `$ k: U5 n0 q6 e* N- P2 X1107599 CAPTURE STABILITY Capture 16.6 crash when trying to invoke
; z3 A/ Z% ~5 ^5 f* F' }, V1108118 ALLEGRO_EDITOR OTHER PDF Publisher pad rotation messed up with flashed pad.
6 e9 M' q4 {$ Z2 U3 N1108574 ADW COMPONENT_BROWSE LifecycleStatus functionality does not work when in Metadata mode. Work correctly in PPT Mode
0 D6 |9 q% h, R u1109095 SIP_LAYOUT WIREBOND Bondfinger move in hug mode create drcs3 _# q3 D" o3 S& {8 m F
1109113 ALLEGRO_EDITOR DATABASE Allegro Netrev crash with SPB 16.6: W% w' z, k" F% h- t5 F
1109622 SIP_LAYOUT DATABASE In a wirebond design, the ratsnests with 'Closest Endpoint' should not point to the die pins.
G/ J7 L0 P* y9 s& }! h& }1110077 ALLEGRO_EDITOR DRC_CONSTR Duplicate Drill Hole DRC's are not shown for Pins overlapped in same symbol unless "Min metal to metal" DRC is turned ON
% @1 b8 ?& v" K1110256 ALLEGRO_EDITOR SHAPE Auto void on dynamic shape is not correct in 16.61 v+ f3 X) j$ r2 u. Z* V
1110264 RF_PCB FE_IFF_IMPORT IFF Import in DEHDL has component offset# I) U7 @9 T) y" s$ g. C' d& t
1111226 ALLEGRO_EDITOR DATABASE Name too long error with Uprev command when output file name exceeds 31 characters
8 S% w% P' v) m N- E" v1111234 ALLEGRO_EDITOR MANUFACT Double digit drill character overlaps with figures triangle, hexagon and octagon in NC drill legend
8 Q/ h2 U. A. Y2 B9 X1112431 SIP_LAYOUT COLOR Frequent crash while working with latest version of CDNSIP
. z) U0 W/ v' E3 d2 Q/ w1112493 ALLEGRO_EDITOR DATABASE Customer does not like 16.6 Ratsnest points Closest Endpoint
: y1 _, `0 ^0 j* j( s6 j1112774 GRE CORE Allegro GRE not able to commit plan after topological plan [8 A# M% T' D
1113908 ALLEGRO_EDITOR COLOR Dehilight command fails to remove highlight pattern on a cline, without removing net custom color.+ Z h0 {1 v( n* e( ~
1114815 ALLEGRO_EDITOR OTHER Q1: Switchversion error when reading -fa file
& X7 S0 U$ E' d7 |0 S$ K+ h1114994 ALLEGRO_EDITOR DATABASE Getting an error after upreving components to 16.6
* W w! J! e! x8 U! Q+ o
3 b, f% v! s- o# ^4 u9 x7 gDATE: 03-7-2013 HOTFIX VERSION: 005+ e* O, B7 K' Z' A1 E
===================================================================================================================================' p0 c3 x T* x2 X
8 P6 e3 F) E9 b. r( J2 @===================================================================================================================================. Y- m; n. R; O- X( R* c) {8 _( h
1067770 IXCOM-COMPILE COVERAGE Assertion failed: file ../covToggleCoverageXform.cpp, line 1102% r+ F$ J4 J+ \+ e \0 L
1100442 ALLEGRO_EDITOR PLACEMENT Placement queue shows components whichs are already placed! @- q0 r. J0 x9 F8 e
1101555 ALLEGRO_EDITOR DATABASE Allegro Crash frequently
5 q, j: Z/ X% Z" S3 J1104011 ALLEGRO_EDITOR DATABASE Place replicate move group of a modules leaves traces behind
" l, D/ ]/ i; p" `& I: {4 \1104065 SCM NETLISTER SCM 16.6 has problem generating Verilog with existing sym_1 view
# H2 K! K) W" v, ?! X1104605 F2B PACKAGERXL Pins of function swapped part in block not displayed
) B& A% Z5 V. ~5 k) ]' M1104790 SCM IMPORTS Corrupt data once SiP file is imported into SCM
2 g; X \! }+ _1105066 APD IMPORT_DATA Import NA2 worked in 16.5 "035" but fails in 037 and 16.64 ]3 o& b6 N" E, D0 _, J& |9 U. i
1106323 ALLEGRO_EDITOR PLACEMENT Unable to locate specific placed symbol on this board as it becomes invisible after placement.1 [; I8 H% U' H& m
1108032 CONCEPT_HDL CORE 'Find' option does not list all Components in the Design7 E9 C/ F% q' U5 Q' s9 |' |
1109080 ALLEGRO_EDITOR OTHER Window DRC is not working in OrCAD PCB Editor Professional
! B0 d7 `1 `' k A% f* N9 c$ k& C% J& K5 x( P. T8 D
DATE: 02-22-2013 HOTFIX VERSION: 004
+ G/ n0 }" S X0 `===================================================================================================================================' _- Z: u4 j6 p% u) t
CCRID PRODUCT PRODUCTLEVEL2 TITLE, z( P I$ G' {1 ~# I7 E6 X
===================================================================================================================================- D Q$ h" F* [- e( ]' ~2 c
1081026 ALLEGRO_EDITOR GRAPHICS 3D Viewer do not show the height for the embedded component correctly
/ _$ ~/ a$ {% } r# \; G4 }1095225 ALLEGRO_EDITOR EDIT_ETCH The Constraint option does not work from right mouse click>Options>Line Width > constraint during interactive routing
, X I/ h$ N% X7 m, M4 A1096356 ALLEGRO_EDITOR DATABASE Cannot Analyze a Matched Group in CM
6 m- t2 {* l+ W( }9 o1 c8 H1097481 ALLEGRO_EDITOR INTERACTIV Allow replace padstack command in design partition" k' ?( k4 r1 x- F1 Y
1098252 ALLEGRO_EDITOR MANUFACT Double digit drill character overlaps with figure "circle" in NC drill legend" a/ r# S9 g, F- q1 L6 u* S% J6 R5 }4 q
1099958 ALLEGRO_EDITOR PAD_EDITOR Library Drill Report producing an empty report; V' b! V+ S" j) p0 V) z" j& e
1100401 ALLEGRO_EDITOR OTHER Invalid switch message for "m" for a2dxf command
8 u, H2 I) O8 F, [1101026 ALLEGRO_EDITOR OTHER utl_perftune hanging in fpoly_RemoveVerySmallSegments(), causing shape degassing never to exit.
" F, z5 E. W- v& N( t" Q1101064 SIP_LAYOUT SHAPE 'Shape force update creates a rat: D7 o* v4 N5 {4 y# R- D1 |3 Z
1102798 SIP_LAYOUT OTHER Stream out puts offset pad in wrong position if pad is mirrored but not rotated.$ ^- Q) G1 ?5 l! S) B2 Z
/ j2 V# Z1 S/ c1 M# ] L0 N
DATE: 02-8-2013 HOTFIX VERSION: 003
) v4 H3 Z+ b5 A2 h! ]7 I/ T$ L3 P===================================================================================================================================# t; O, } ]& s' h
: x9 t! C9 Q0 {8 u6 P, N) w3 N===================================================================================================================================5 z+ }) Z* \% n) R( s& x8 _
1077728 APD EXTRACT Extracta.exe generate the incorrect result
" m5 d; ~! Y7 y- d$ Z9 w: A1084711 APD DXF_IF Padstacks with offsets cause violations in Export > DXF$ B7 q5 u, Y. d4 \4 c
1090369 SIG_INTEGRITY LICENSING Impedance value not updating in OrCAD PCB Designer
* ]$ H9 l* c0 L4 ?7 E9 f: e1093050 ALLEGRO_EDITOR DRC_CONSTR Taper trace on diff pairs not checking to min line spacing.$ g9 U: N6 ]- n8 r
1093563 SPECCTRA ROUTE PCB Router crashes with reduce_padstack set to on
+ P" p: O$ W: E6 d' S$ v! D- ?4 ~1093717 APD DATABASE Design is crashing in Tools > Update DRC and in Dbcheck but seems inconsistent
: C. G, J# W ?' f6 B1094788 SIP_LAYOUT WIREBOND Wirebond edit move command
4 X0 f! Y$ P( i Z& n1095786 ALLEGRO_EDITOR DRC_TIMING_CHK Allegro PCB crashes when running DBDoctor M! R, ^& O& u5 W y2 @
1096234 ALLEGRO_EDITOR DFA Via pad connected to shape didn縯 show up after 縎uppress unconnected pads� option.- R) X' K( Y! A! R& v+ w
1096313 RF_PCB LIB_TRANSLATOR Allegro Discrete Library to Agilent ADS Translator offsets in the CDNSsymbo.iff
( n3 n, F5 {2 i& R1096613 ALLEGRO_EDITOR INTERACTIV Enh-While moving parts silk ref des should remain visible; r" C1 g# I# ^" b( b% Y% o6 V2 V
1096676 CONCEPT_HDL CORE SPB 16.5 HF36 breaks designs that workded fine in HF35+ }+ S- O) f) [' }: V
1096913 APD IMPORT_DATA Import > NA2 fails to bring in the Y1 component.: ~% V+ U0 @0 E4 @$ G
1097751 ALLEGRO_EDITOR DATABASE Import CIS netlist crashes.# ~, H! ]- f$ Z' k& C$ f
1097889 ALLEGRO_EDITOR DRC_TIMING_CHK Allegro crashes when routing from a via to a pin using High Speed option license.$ x- b8 ~1 C0 m
T. D: @6 J: Y f/ RDATE: 1-25-2013 HOTFIX VERSION: 002$ {7 n8 ~1 R* K: e, q
===================================================================================================================================4 y& \2 r5 t. \
CCRID PRODUCT PRODUCTLEVEL2 TITLE& m6 k3 n) Z; k4 }- u
& v8 u/ I2 O/ e! `# D! d491042 CONCEPT_HDL SECTION Prevent PackagerXL from changing visibility on SEC attribute
8 ^8 V) A$ z5 c" T) ?6 A6 Q# u! i- k863928 ALLEGRO_EDITOR INTERACTIV Segment over void higlights false "nets with arc"; ^( o D8 D6 T" _9 Y& {( A9 o/ x
1067272 PCB_LIBRARIAN CORE Unable to retain the symbol outline changes
& e. h0 z+ h* b1074820 ALLEGRO_EDITOR GRAPHICS losing infinite cursor tracking after selecting the add text command with opengl enable
) d7 m4 B8 `3 w5 T/ @7 }1075622 CONCEPT_HDL CORE PDV Edit Symbol in DE-HDL all editing functions disabled since Hotfix 33
' w7 F' O+ E8 F) }, x) R1076986 APD WIREBOND Wirebond Adjust Min DRC does not maintain the finger position in the same sequence
, X1 \2 c: S) g( Z1078031 SIG_INTEGRITY REPORTS Requesting improvement to progress indicator for report generator) U/ X$ ~) \, E5 m
1080213 SIP_LAYOUT WIREBOND Wrong behavior of Redistribute Fingers Command5 t2 b2 E9 W3 i: h/ v
1080667 ALLEGRO_EDITOR GRAPHICS Allegro lines with fonts not displayed correctly in 16.6
* M; o+ h+ H" X1080982 CONCEPT_HDL CORE Crash of Allegro Design Entry during a copy of a note.
- m3 t$ ]5 M- E- k' J J3 d1081200 CONSTRAINT_MGR OTHER In the DIFF_PAIR worksheets various Analysis seem to take a long time to complete.
3 W0 s" F/ t7 w& ]9 {# V1081553 CONCEPT_HDL OTHER Model Assignment can not translate M (Milli-ohm) property value of DE HDL.& W# i$ l$ _( {6 u7 F. F x
1081696 ALLEGRO_EDITOR INTERACTIV Compose shape not working when radius is set to 1.0* j% X6 b! H- d) n- i8 ?+ x! D
1082595 ALLEGRO_EDITOR COLOR Infinite cursor remains white even we change background to white
8 w* H! C* O g- s* y! J5 l! Q1082704 ALLEGRO_EDITOR GRAPHICS infinite cursor disappears when using Display>Measure
; K% k3 ^- W% H. [9 V1082715 SIG_EXPLORER INTERACTIV Single line impedance for BOTTOM Layer is not calculated in cross section upon changing the thickness of dielectic layer
% ?% }' U$ `- R# m: t1082774 ALLEGRO_EDITOR TECHFILE Import techfile command terminates abnormally when importing a generic techfile.
1 d. q$ E) ^2 O, _/ R1082820 CONSTRAINT_MGR UI_FORMS The configure generic cross-section pull downs do not work.
. K: L) k) @. P: G1083133 SIP_LAYOUT INTERACTIVE SiP will crash when using the beta Pad Rename command to change a BGA pads name.6 w4 V+ a6 O. q* D1 s4 n( B
1083158 ALLEGRO_EDITOR GRAPHICS The cursor chage to Arrow head for Shape Select is more sensitive to location in SPB 16.6
6 a6 X( a' D# B1083533 CONCEPT_HDL CONSTRAINT_MGR Bug -Net-count under few of the netclasses are not in sync between Schematics & Layout" U7 `3 |& u' U a
1083637 PCB_LIBRARIAN CORE Save As is not renaming the NAME in the symbol.css file* H* V0 l6 L5 Q% S& P; Y3 n
1083934 ALLEGRO_EDITOR PAD_EDITOR Error(SPMHUT-41): File selected is not of type Drawing.
" B7 Y0 ?* W* \% b3 s/ l1084148 CONCEPT_HDL CHECKPLUS The CheckPlus hasProperty predicate fails in the Physical environment.. g0 L" f/ }- r: }$ X
1084166 SIP_LAYOUT DIE_ABSTRACT_IF Updating sip layout with new die abstract doesn't properly update IC_DESIGN_CELL* properties1 R/ j& G6 [. s" Q* B+ Q/ t
1084285 CONCEPT_HDL INFRA Corrupted dcf was never fixed and caused PXL error4 ?; [: z- \' C2 E" u& s# ~
1084441 CONCEPT_HDL CORE Assigned net property value changes to numeric
6 R: w* y% \8 H: I9 o1084542 ALLEGRO_EDITOR DRAFTING Dimensions associated with frect doesn't rotate with the symbol.6 o3 v/ o5 w) L2 }& @- \/ j L) C
1084736 APD IMPORT_DATA Import SPD2 file from UPD-L shape Pad and text issue
5 p6 P" u2 k8 I; q, V1085008 ALLEGRO_EDITOR INTERACTIV Relative (from last pick) option in the Pick dialog not working for pick command! t& ]1 ^4 K: r7 o5 Y* L: Q' _) A
1085139 ALLEGRO_EDITOR GRAPHICS Infinite Cursor disappear during Add Connect if Infinite_cursor_bug_nt is enabled
* c8 V' X _) p1085187 SIP_LAYOUT INTERFACE_PLANNE netrev with overwrite constraints fatal error" V2 L e0 L2 A
1086402 ALLEGRO_EDITOR GRAPHICS Infinite cursor dissapear when using command like add connect or Place manually with opengl enabled.) I5 ~* [* @; I/ s6 X& }
1086905 PSPICE SIMULATOR PSpice crash while simulating circuit file with BREAK function0 i$ n, l7 c6 R
1087770 ALLEGRO_EDITOR EDIT_ETCH Allegro crashes on a pick with the slide command.
% m8 ~2 Z( s# {4 y' a1088412 SCM CONCEPT_IMPORT why reimport block adds _1 to the netnames?
% W1 m' w5 Y; S1 w2 @9 ]1088958 CONSTRAINT_MGR INTERACTIV annot create Differential Pairs out of nets that belongs to a Net Group
3 q) P3 }4 L* |! _2 I2 w1089336 ALLEGRO_EDITOR GRAPHICS infinite cursor and pcb_cursor_angle+ J$ K6 a! T# ?$ o! W2 T
1090689 ADW LRM LRM: Unable to select any Row regardless of Status
8 ^0 Q7 G4 J- C+ [4 y# M1090955 ALLEGRO_EDITOR OTHER Cancel command crashes PCB Editor when add rectangle7 J+ @# }. \ e; P: q8 q! i
1091047 ALLEGRO_EDITOR REPORTS The "Dangling Lines Via and Antenna� report seems to be missing vias that are antennas.
u8 M7 S$ o$ z0 [- \1091218 ADW LRM LRM is not worked for the block design of included project
( ^4 s1 y) V. } A0 Y1091443 ALLEGRO_EDITOR OTHER Crash when toggling suppress pads7 x9 s& u/ T" @3 P/ I" c
1091706 ALLEGRO_EDITOR EDIT_ETCH Allegro crash while routing after setting variable acon_no_impedance_width' z3 W: M k! _" o$ u& G( W' ~
1092916 CAPTURE OTHER Capture crash
* [; o5 G) R, H1093573 ALLEGRO_EDITOR DATABASE team design opening workflow manager crashes allegro. possibly corrupt database
$ V. f( L4 b! J% U' }
0 k( c6 I( P K7 c& xDATE: 12-18-2012 HOTFIX VERSION: 001" N# ]1 E+ g& Z0 ?, j6 E. n
===================================================================================================================================; p, f2 d* y8 ?8 ~ E/ \9 V
CCRID PRODUCT PRODUCTLEVEL2 TITLE5 L( U" m( D" i! t
& q; u5 H9 I/ T. Z8 ^7 F% M! c, s- g501079 ALLEGRO_EDITOR MODULES Enhancement for Module swap function similar to component swap$ K: r3 X. n; t9 }+ }0 w9 O* }6 z
745682 CONCEPT_HDL CORE Attributes window requires resizing each time DEHDL is launched
3 J9 X! R4 S: O) \825846 CONCEPT_HDL CORE The module_order.dat file gets corrupted" H' S) |# [0 c& j
871886 CONCEPT_HDL CORE Browse button in Signal Integrity window of DE-HDL option causes program crash
- {- j, S; ?+ d) `891439 ALLEGRO_EDITOR INTERACTIV moving cline segments
, x- D+ X" f+ }7 o898029 CAPTURE PRINT/PLOT/OUTPU ENH: TCL:To show net alias clearly in print out if alias has underscore% g! x4 E% e7 _& ?
923210 CONCEPT_HDL CORE Search with multiple properties does not show all properties
@' f1 n5 @4 l938977 CONCEPT_HDL CORE Properties attached to standard/DRAWING symbol does not propagate to parts placed in the schematic' p8 M: n- T' \; w" I5 O i
947451 ALLEGRO_EDITOR INTERACTIV Allow the tool to select multiple shapes when assigning a net to more than one shape.# [) _: D% @, ] X& L g7 p% x; E
968646 ALLEGRO_EDITOR EDIT_ETCH The Cline to Pad spacing not followed for Multidrill pad it is more then minimum spacing
+ b, m2 s$ e, l2 [ ~/ W( J% U' i976723 ADW MODEL_MANAGEMENT SI DML Model has to be provided the Auto Generate function for discrete components on DBeditor6 K& i0 m' f9 w: H; E7 q
981767 SCM UI Add series termination in ASA will crash if both output and input pins are selected.
' s& J8 z2 I) ?+ p& Z/ R982273 SCM OTHER Package radio button is grayed out
% v4 {6 T' l- n( C1 l: r988438 CONCEPT_HDL CORE Visible constraint disrupts MOVE command0 `$ y8 A- b0 F* f3 ~( p4 C5 i+ E
989471 ALLEGRO_EDITOR INTERACTIV Functionality to zoom to the selected object in Pre Select Mode
4 C# Q$ L; Z0 \4 L) ]. g6 j993562 CONCEPT_HDL INFRA After upreving the design save hierarchy is leading to WARNING(SPCOCD-34).+ @8 \* b8 L( ^
996577 SPECCTRA ROUTE Specctra not routing NET_SHORT connections, i" S2 c- A! ?; T$ ]0 h
997992 CONCEPT_HDL CORE Why are Page Numbers not enumerated correctly when multiple TOC Symbols are used?1 @7 C' A- J7 r( c% o7 \6 [
1001300 PSPICE MODELEDITOR BUG: Simserver crash with encryptedm model& D4 ?# c6 H! b% d0 [
1010124 PSPICE SIMULATOR Monte Carlo summary doesn't list all the runs in case of Convergence error in one of the runs
8 g2 ~0 E* a8 B a% c! Z1013656 SCM OTHER create diff-pair should honour diff-pair setup or ask user for positive negative leg8 l6 Q5 @( p9 D* E( f, Z
1013721 ALLEGRO_EDITOR EDIT_ETCH Routing near a 2x3 multi drill padstack does not maintain the spacing constraints.
7 R& _7 t& v v) x& Y+ Z1016859 SCM REPORTS dsreportgen exits with %errorlevel% M# P* b: F; S( }8 u# c, Z' ]2 m1 B
1018506 ALLEGRO_EDITOR INTERACTIV Edit copy with retain net of via will assign net to pin. o' a, s1 ~) D5 \
1020746 CONCEPT_HDL OTHER PDF Publisher tool behavior inconsistent between OSs
, p% D: `+ K! ?9 w8 z1020798 SIP_LAYOUT SHAPE Shape not voiding on layer 2 causing shorts7 S' M$ b, B& b C! I7 g1 a
1023051 SCM UI Wrong and incorrect message is generated while adding connectivity in SCM matrix view � DSTABLE-140% I5 R" F3 C4 I- R# R
1023774 APD WIREBOND After "xml wire profile data" is imported it isn't reflected to actual wire.2 m( W3 t& p6 x
1023807 SPECCTRA GUI Unable to close SPECCTRA using File > Quit or by clicking on standard window red close cross button8 c5 q; V' C; W$ R# x
1024239 ALLEGRO_EDITOR INTERFACES DXF pin location is moved when I execute DXF out
+ t3 H" q6 z) G/ z( y0 O1028237 CONCEPT_HDL HDLDIRECT Error binding design when generating simulation netlist p( R2 t7 Y! y
1030591 CAPTURE LIBRARY Library Correction utiltiy locks the library and deosn't frees it even after being closed! U4 v% L- |. Z- c1 t$ x# w
1035624 CONCEPT_HDL CORE Options pre-selected when launching base product
& r1 k3 B' Q3 i; x+ `4 N8 e1035896 SIP_LAYOUT ASSY_RULE_CHECK Rule Wire Length under Wire on line in Assembly Rule Checker doesn't work correctly
v$ P& c ~0 R( F" @) @* X5 I& i/ g) x4 Z1036580 ALLEGRO_EDITOR MODULES Module created from completely routed board file has lot of missing connections in it.
- ?. h% {; w% B2 w, c1037345 ALLEGRO_EDITOR INTERACTIV Enhance Allegro's Snap-To tools to select the origin of a sub-drawing(clip file)
! i$ a' g$ F9 o3 c1 P1038180 ALLEGRO_EDITOR DRC_CONSTR BGA escapes not being calculated in phase tol- q: W# l. N4 K4 k0 Y" ^9 [% y" G- L1 Q
1038285 SCM UI Restore the option to launch DE-HDL after schgen.* ?* k/ X( x* n
1038371 ALLEGRO_EDITOR INTERFACES Import > IDF fails with error "(SPMHDB-187): SHAPE boundary may not cross itself."
6 z& w1 B- L2 ^2 P0 p3 p. c5 @* d1038577 ALLEGRO_EDITOR DATABASE Modifying Void crashes Allegro9 `! E( {7 G5 ?
1039112 ALLEGRO_EDITOR ARTWORK Antietch and Boundary layers deleted when Match Display selected
' }0 Y& Q' {, \1039147 ALLEGRO_EDITOR COLOR Need an option to change color of Text marker and Text select in Display listing9 V) l" _/ G8 T, J: P- P5 |& c4 X
1040653 ALLEGRO_EDITOR DATABASE Cannot update netlist data, ERROR(SPMHDB-121): Attribute definition not found.
3 i" Y. o, [! q1041368 APD DEGASSING The Degas_No_Void properties assigned to Cline does not work.2 _: j% G& N. c2 j# M
1041864 ALLEGRO_EDITOR MANUFACT Allegro crashes when opening the Backdrill setup menu
# l" O: [6 \( r9 B9 A- I$ F. a1042199 SIG_INTEGRITY SIMULATION Waveform list was not refreshed by switching tab.; ?! h$ I8 a# \3 k# P8 p" U- c
1042348 SIP_LAYOUT STREAM_IF GDSII export includes the full refernce path, breaks CATS flow
" [& p; ^9 W9 {6 ^) i- {, P1043861 SIG_INTEGRITY REPORTS Derating values are NA in bus simulation report when derating table is not in working directory
( G! u: [; B, l, I, Z1043903 GRE GLOBAL This design crashes during planning phases in GRE.
" j& U9 n- Z' d$ b) K! B% ~/ j1044029 PSPICE ENCRYPTION Encrypted lib not working for attached
+ ^+ p; |) E' I) C+ \' d1044222 ALLEGRO_EDITOR INTERACTIV Capture Canvas Image changes working directory
( N/ q: p0 R \0 [% K/ B1044264 PSPICE SIMULATOR Why does the 'ORPSIM-15009:This device scales to 0.0 at this Temperature' Error occur.( t5 l% k6 N$ ~5 }( Z
1044577 GRE CORE Plan > Topological either crashes or hangs GRE
7 _0 t9 E3 B; q( d3 i# }0 \* K1044687 TDA CORE tda does not get launched if java is not installed
3 P2 T& l, z* q( x1044754 SIG_INTEGRITY SIMULATION Incorrect waveforms when simulating with stacked die
! I/ g; }9 F, Z1045607 ALLEGRO_EDITOR OTHER Component get placed even after Cancel IDF in form., V0 N8 x1 E& S3 x" J0 `( ~
1045694 CONCEPT_HDL INFRA Why to package the design twice to pass the net_short property to the board?
S+ C$ O+ s/ S1 G8 T' t1045863 CONCEPT_HDL INFRA Customer had the crash several times when they run script with SPB16.51.$ a$ j1 F3 z( |4 t5 ]; P
1046929 CONSTRAINT_MGR OTHER Unable to create physical of spacing cset after rename the default cset in design entry.
, k- r( Z* Z, f+ f0 I6 H7 Y1047590 ALLEGRO_EDITOR SCHEM_FTB Buses created in Allegro-CM are deleted by netrev in traditional flow
0 C3 `: Q0 Z! |, h1047823 CONSTRAINT_MGR OTHER acPutValue predicate text not being displayed at bottom of Constraint Manager window.
# q4 k: A( c+ Z* u/ e/ E4 ?1048403 ALLEGRO_EDITOR SKILL Allegro crashes opening more than 16 files with skill! B9 Z" J: x- O) A) A+ i. R3 F
1049262 ALLEGRO_EDITOR OTHER APD and extracta crash owing to Wirebond.
# Y+ g+ \$ t. ~1049303 CONCEPT_HDL CORE Block rename deletes schematic data immediately in 16.5
& U4 a( Q: x N1049317 CONCEPT_HDL OTHER bomhdl with scm mode not working on RHEL in 16.5
* I. T$ t; }9 @/ x% l1049399 SIG_INTEGRITY OTHER Toggling z-axis delay in CM shows the same value
) I+ K) ]; G6 l2 K3 p y2 S1049956 ALLEGRO_EDITOR DATABASE BUG:dbdoctor deletes fillets as design is migrated from old version/ i) I4 H) n" @5 b' n
1050408 APD DXF_IF Symbol has 45 degrees rotation in mcm but DXF doesn縯.
( L) @, T! L" h& T6 \: \1050483 ALLEGRO_EDITOR DRC_CONSTR DRC has been waived but after updated DRC system generated a new DRC.
+ g: n/ d% P) R4 _- Q1050918 ALLEGRO_EDITOR MANUFACT Testprep Automatic generate testpoints with wrong padstack Itype in SPB165S026.
3 Q% J1 O6 R) V. g. N( y6 t$ T1051588 ALLEGRO_EDITOR PAD_EDITOR Pad_Designer library drill report omits some drill holes
+ ?- O* M9 k- P1 y3 v6 }1052005 SIG_INTEGRITY OTHER Huge difference in Z-Axis delay with the latest hotfix for 16.5 that did not exist in older ISR's of 16.5.' m& m1 U3 r n( E6 U0 g; R
1052045 ALLEGRO_EDITOR OTHER Bug - Thermal relief connects not sustaining 15 degrees component spin in version 16.5 unlike v16.3
% X( [& [6 ~1 G) G1052449 CONCEPT_HDL COPY_PROJECT Copy Project does not update all relative paths in the cpm file
, A; P8 `- `0 Z5 j' i1052600 ALLEGRO_EDITOR SHAPE Adding a specific cline causing shape errors
% R3 F8 ^' w: ^& g! l1052753 ALLEGRO_EDITOR DRC_CONSTR Allegro showing soldermask drc only when the symbol is rotated.
B# F t/ ~! _: z+ H1054235 ALLEGRO_EDITOR PLACEMENT Cannot place alt_symbols for mechanical parts.9 D b1 h- C0 v, `8 ^% I
1054269 ALLEGRO_EDITOR MANUFACT Backdrill Setup and Analysis crashes on attached design( m- H4 R h( x$ Z& c; z# U" P8 U. s
1054351 ALLEGRO_EDITOR SHAPE Shape voiding fails for board having diffpairs with arcs
- a1 J! F: E4 ?3 H& y; @. D# Q3 S1054456 ALLEGRO_EDITOR MENTOR mbs2lib incorrectly translates refdes label$ n1 H# D1 ^" N6 ^ R2 F& Y! m
1055273 ALLEGRO_EDITOR INTERFACES DXF exported from Allegro has an offset in pad location for Y- direction.
3 Y/ I! Y Z& h1055328 CONCEPT_HDL COPY_PROJECT Project Manager - Project Copy0 D* \9 l3 d3 h6 s& O0 {
1055481 APD SHAPE keepout does not clear shape unless it's picked up and dropped down
; z z# e; x' m( C1055729 CIS GEN_BOM Standard CIS BOM per page is not working correctly with option Process Selection
3 V* i. q% ^$ s5 P5 ^' [, |1056418 ALLEGRO_EDITOR OTHER PDF exports the blank text markers whether or not the markers are visible., ?. u& ^2 A. I R- J
1056579 CAPTURE OTHER Ability to define custom variables for titleblocks that update for specific variant views
/ P& P" j' D* n9 S1057003 ALLEGRO_EDITOR SHAPE Z-copy to create RKI does not follow board outline
" w! @8 O/ t% ?, Q/ U/ L1057976 ALLEGRO_EDITOR DRC_CONSTR No Same net Spacing DRC on attached design.0 E T. q' b. v! E' t, G2 z
1058002 SIG_INTEGRITY SIMULATION Incorrect Xtalk sim netlist was created.
& G/ O$ V9 K* w$ x8 ]( ~* ]1058364 ALLEGRO_EDITOR SKILL axlTransformObject() is moving refdes text when only symbol pin is selected for move: P# _+ b, e! B7 b- w1 p
1058940 ALLEGRO_EDITOR INTERFACES IDF(PTC) out command output wrong angle value7 |) c% S3 n: n+ G7 [% A8 Q9 m: L$ {
1059037 CIS PLACE_DATABASE_P What enables the Refresh symbol libs option under hte update menu in CIS explorer( Y0 I8 K7 b, l, Z) ~# x/ o) D
1059389 ALLEGRO_EDITOR MANUFACT about back drill analisys report
# H) M9 |4 ^/ n+ y6 ^7 m9 N1059901 CONCEPT_HDL CORE Global Property Change and <<OCC_DELETED>> property value.
3 I9 X7 W( `3 i, D1060428 ADW DESIGN_INIT ADW Flow Manager Copy Project fails to complete
6 Y! p+ ^' N* l U$ [# f' f1060589 F2B PACKAGERXL Packager Fails with ERROR(SPCOPK-1053): Cannot find a ppt part that matches the instance properties.
4 w9 b( C/ P' l7 i( L1060977 F2B DESIGNSYNC back annotate in 16.5 does not bring in already placed nets as global nets
@! ]. D e, }& [3 J8 h$ q1061223 CONCEPT_HDL CHECKPLUS What determines a passthru pin?, y+ v8 b7 F2 `6 J$ I' L
1061424 CONCEPT_HDL CORE Customer creates <<OCC_DELETED>> property values.
1 k% i6 ?1 S3 C7 d4 A: U3 c6 p# ]2 H1061572 ALLEGRO_EDITOR INTERACTIV Shortcut keys wont work after "Edit Text" command is finished.1 d: V/ Z2 I9 u1 i! p2 ?
1061659 ALLEGRO_EDITOR DATABASE Unable to return drawing origin to 00( i( X/ Y c0 _9 J* N1 @: K% h
1062558 APD DXF_IF If set both in X and Y offset DXF only get one and not get absolutely value in 45 degree rotation- o7 [* P5 i {1 k
1062982 ALLEGRO_EDITOR MODULES Module containg partitions has been imported to the main design and cant be refreshed.
: t+ r' e5 j0 K) i% Q1 Z- \1063284 PCB_LIBRARIAN OTHER PDV Save As is broken
3 ]6 A7 P1 ~: x1 u, L; L! J* R9 r1063658 ALLEGRO_EDITOR SCHEM_FTB Allegro Import Logic does not remove library defined diffpairs
r. D. g% |2 J2 h& w1063778 CONCEPT_HDL CHECKPLUS The hasSynonyms CheckPlus predicate is not returning true for all global signals.* q- u( l7 G' |4 X1 {
1063924 CONCEPT_HDL CONSTRAINT_MGR Highlight the net between DE-HDL 16.5 and Constraint Manager.5 X, t5 a8 W7 Y- @4 @0 u
1064707 CONCEPT_HDL CHECKPLUS Rules Checker core dumps on design
5 R" I8 V. L7 z& j& B& m) f1065124 PCB_LIBRARIAN SETUP PTF properties cannot be deleted from the setup in PDV
/ }( }2 i9 N- ^2 s( b1065618 CONSTRAINT_MGR ANALYSIS DRCs on board but Constraint Manager shows the columns as green.
( [- P4 h& w& l- s+ ^8 I M1065641 PCB_LIBRARIAN CORE PDV symbol editor is crashing when deleting a group using delete or CTRL+X* d% z& e& b& I2 K, J" R. _2 @
1065745 SIP_LAYOUT DATABASE The logic assign net command crashes the application
7 }2 Q, z5 F: P6 _% H1065860 ALLEGRO_EDITOR REPORTS Design crashes when running a padstack usage report
5 B% c1 |0 {% }1 e; p! M+ n1066051 ALLEGRO_EDITOR TESTPREP Auto Testprep generation creates TP with Testpoint to Component Locatin DRC* C6 K9 p) i# v& h) P) d
1066318 CONCEPT_HDL CREFER Issue with LOCATION visibility in flattened schematic$ O4 y- k/ V+ T7 c8 v* j
1067339 CONSTRAINT_MGR ANALYSIS Relative Propagation Delay analysis in the Partition file seems very inconsitent.& O( p0 { X7 q( m5 P9 p
1067984 SIP_LAYOUT OTHER layer compare batch fails with write protected file- T2 ~$ j; d3 k6 S
1068425 F2B DESIGNVARI Out of memory message in Variant Editor while 縞hange properties� command) ]; r/ M, _6 N& I8 |2 ^3 Q# C
1068547 ALLEGRO_EDITOR EDIT_ETCH Outward Fanout is not fanning out this 4 sided part as intended
9 g+ l) `# p$ c5 ]0 ?- \. J% ]$ V1068966 SIP_LAYOUT DRC_CONSTRAINTS DRC update aborts on this design with ERROR -30000674 Y& _! }2 B- U5 n( ?
1069215 CAPTURE DATABASE Capture Crash on usnig a TCL utltiy to correct design
0 ]6 ?" Y6 K" O$ ]- d1069517 SIP_LAYOUT DIE_EDITOR change die abstract pins tab default action from delete to modify
! X( h' G+ H5 q3 \8 W, R1 J3 `1 D1069915 ALLEGRO_EDITOR EDIT_ETCH Allegro hangs with when doing spread between voids
8 d+ y. Q( P2 o. ~1070007 ALLEGRO_EDITOR PLOTTING Export IPF omits drill figure characters for backdrill holes! o# M i d- O* C: H
1071722 SIP_RF DIEEXPORT Virtuoso SiP Architect not writing out pins to the .dra needed for LVS flow1 }+ X7 c1 [0 e; o Z* G7 h
1072067 APD EXTRACT When expoting using Extracta oblong pads with anyangle are abnormal" N: E0 m) Y4 E7 X0 D
1072791 ALLEGRO_EDITOR DATABASE Database check cannot fix error and keep report the same issues cause artwork cannot export.
2 f% O7 b; [ C* a* o4 u( |1072806 CIS EXPLORE_DATABASE Query tab in CIS explorer doesn't show searh fields in 16.6
9 L+ g, V. X, ^4 h1072843 ALLEGRO_EDITOR PLACEMENT The move command that was present in the right mouse pop up menu during manual placement is missing in 16.59 v" F5 V# x' p& Q& x5 G: c
1072904 SIP_FLOW SIP_LAYOUT Probe pins not being mirrored in Die Editor correctly in Chip Down mode.
2 S5 ]* S& ]6 `1 z! d1073237 SIG_INTEGRITY GEOMETRY_EXTRACT Some nets has no result at Bus Simulation and Comprehensive simulation.% ~0 _6 o, w* n7 B& Q
1073445 ALLEGRO_EDITOR GRAPHICS 'infinite cursor graphics fail -ghost copies as you move cursor7 h% O! a& L" l$ k0 B
1073464 SCM SCHGEN Schgen never completes.
! |7 i* U5 t; z [6 K8 M3 K5 f" b1073587 SIP_LAYOUT OTHER axlSpreadsheetSetWorksheet command clears the cells in memory' v/ }. J) h4 _# o! m
1073745 CONCEPT_HDL CORE Import design fails0 q! K/ P# P& P b/ o. W
1073852 ALLEGRO_EDITOR INTERACTIV While doing a Copy Via use the last 'Copy Origin'# V) _: V* L2 e
1074279 ADW DSN_MIGRATION Design Migration fails purge if there are cells with BODY_TYPE
|/ L: E* ]: Y1074791 CONCEPT_HDL HDLDIRECT User gets port exists in schematic but not on symbol message even though the port does not exist6 B% b5 r2 e5 z
1075135 ALLEGRO_EDITOR DRAFTING Ability to edit dimension text block in Instance Parameter8 | c# z3 ~2 `, f+ E
1075151 ALLEGRO_EDITOR SHAPE Cannot change global shape parameter back to thermal width oversize after having used fixed thermal
$ Q( ^0 F; N! _/ Q- ?4 r& E1075256 ALLEGRO_EDITOR OTHER Import > IPF in 16.5 is dropping data.
, d0 r G7 o9 f4 M0 `' J1 o1075853 ALLEGRO_EDITOR REPORTS please add "PART_NAME" at Extract UI
; S0 w$ g2 n, f! `) o2 Z( {! Y1075934 ALLEGRO_EDITOR DRAFTING Able to Changing Dimension Text Block
& p$ y5 m8 s- q) W$ y/ z1075955 CAPTURE SCHEMATIC_EDITOR ZOOM in 16.6 using key "I" on keyboard in not centered on mouse pointer: z; j6 c- P$ m
1075964 ALLEGRO_EDITOR SHAPE Shape voiding is not consistent in conjunction with odd angle and arc traces
* S) M/ J/ U0 E/ M2 r- Y# d1076086 SIP_LAYOUT IMPORT_DATA missing wirebond after import SPD2: Q/ {, m' C4 a: `) B
1076202 ALLEGRO_EDITOR EDIT_ETCH Allegro add connect causing crash after Hotfix
: |! |/ s, `- J7 ?# `# s9 \1076205 CAPTURE PRINT/PLOT/OUTPU : Printing of User Assigned RefDes% j* h5 x7 K0 B7 q) d4 S* K
1076536 ALLEGRO_EDITOR DRC_CONSTR Embedded component which protrude out toward Top do not create DRC with Place Keepout on Top0 |! [, I; ]. P/ W; w. H
1076538 CONCEPT_HDL CORE Property visibility changes in attribute form not updated in schematic canvas.
! d8 E' h( ]% F9 d1076655 APD DXF_IF Dxf does not get offset value if die symbol padstack has offset value, D# s* S5 o5 O' Y& i# t: Y( u1 ]
1076846 ALLEGRO_EDITOR EDIT_ETCH Grid snapping broken after slide in 16.6
: C1 e* Z- G b1076891 ALLEGRO_EDITOR INTERACTIV Symbol rotation not displayed correctly when defined as a funckey
& B Z) u- G# S1 ^/ h2 e5 ]1076909 ALLEGRO_EDITOR DRC_CONSTR Allegro crashes while placing modules from database9 `% x7 D, x2 E; N4 O/ a
1077084 CAPTURE NETGROUPS Crash on selecting bus when Enable Global ITC is unset9 f) Q6 M+ w) d8 K6 f% `5 u# f. F
1077169 APD SHAPE Shape > Check is producing bogus results.
8 O0 M$ q' n% |% X! z- @3 p1077572 ALLEGRO_EDITOR DATABASE Mechanical symbol created with 16.6 cannot be placed on board.2 a [4 l* X- L: o- @7 j/ Z
1077879 ALLEGRO_EDITOR SKILL Allegro Skill axlDBCreateFilmRec fails when 15th argument missing "draw hole only" for the first tim+ r( V6 B# B) r1 W4 o. y% q1 ]& A
1078380 SCM OTHER Custom template works in Windows but not Linux4 r0 g; M, b+ m
1078497 ALLEGRO_EDITOR INTERFACES Import DXF does not seem to work correctly.
5 W9 Y/ J; W4 q: V1078682 ALLEGRO_EDITOR DRC_CONSTR Unaccetable slowness with Slide
1 F& N6 u- D5 D4 q1079082 ALLEGRO_EDITOR PLACEMENT Swap components, gives error SPMHGE-616, when symbols instead of components are selected for swapping
* l, ]9 j4 C9 y2 K1079533 ALLEGRO_EDITOR PLACEMENT Swapping components in 16.6 results in Error "E-(SPMHGE-616): Symbol and layer embedding requirements do not match"
- }; i3 ~" U- A, x6 A; }1079937 CAPTURE SCHEMATIC_EDITOR ZOOM in 16.6 is non uniform on text" D- e% H/ S/ d
1082582 ALLEGRO_EDITOR GRAPHICS Allegro hangs on a given testcase using the MMB zoom control! A) H7 w" S4 L3 M. t/ o9 Q! _
1082981 ALLEGRO_EDITOR SKILL Allegro crash while change the new symbol type as mechanical.: d( r F/ J2 D4 V
1083230 SIP_LAYOUT SHAPE Shape fill in 16.6 releaase not fillilng shapes as good as it did in the 16.5 release./ ~ O ?! | |0 {. J' n
