********************************************************************************( I8 m# J h I) S7 _1 B/ ^
*; g" g) v2 K; Y+ k- s4 v
* Netlisting the design
& T& F1 L# g* `" R) H; P3 j; A*
* S1 }, L8 ]! d# p********************************************************************************
6 E F7 M( { [. O. ]3 M; e6 _Design Name: L* E0 h; V, R# k, M
C:\wenjian1\yanli2.dsn" X v% t9 p" L+ T1 T- v: n
Netlist Directory:
# @5 B; {/ r' S6 \C:\wenjian1\allegro
; h5 s' Y4 r' Y$ ~6 \Configuration File:% U. Q5 M$ N8 E" s
C:\cadence\SPB_15.2\tools\capture\allegro.cfg
7 F$ k) E) C( [3 n% |1 W: X- F# d+ w$ M7 J/ ?7 d8 D7 ?/ W9 E
Spawning... "C:\Cadence\SPB_15.2\tools\capture\pstswp.exe" -pst -d "C:\wenjian1\yanli2.dsn" -n "C:\wenjian1\allegro" -c "C:\Cadence\SPB_15.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"2 G5 G( L( t. p% O( Z
#1 Warning [ALG0016] Part Name "CAP_0_CPCYL1/D.300/LS.200/.034_10UF" is renamed to "CAP_0_CPCYL1/D.300/LS.200/.034_".4 `. q7 K4 D7 M M6 q" a6 ?, x3 @9 D
#2 Warning [ALG0016] Part Name "CAP NP_0_RAD/.200X.100/LS.100/.031_30P" is renamed to "CAP NP_0_RAD/.200X.100/LS.100/.".7 K' F2 w9 m- K7 }
#3 Warning [ALG0016] Part Name "CAP NP_1_RAD/.200X.100/LS.100/.031_30P" is renamed to "CAP NP_1_RAD/.200X.100/LS.100/.".' x, l) \- Z) B c |
#4 Warning [ALG0016] Part Name "4 HEADER_0_SIP/TM/L.400/4_4 HEADER" is renamed to "4 HEADER_0_SIP/TM/L.400/4_4 HEA".) |: b7 h9 w: K( q# K. x+ G7 y
#5 Warning [ALG0016] Part Name "8 HEADER_0_SIP/TM/L.800/8_8 HEADER" is renamed to "8 HEADER_0_SIP/TM/L.800/8_8 HEA".. Z; P3 d, l; ]& ?1 Y$ U6 C
#6 Warning [ALG0016] Part Name "SW PUSHBUTTON_0_RAD/.400X.200/LS.300/.034_RESET" is renamed to "SW PUSHBUTTON_0_RAD/.400X.200/L".
( P: {: L* j$ ~! `2 o1 E#7 Warning [ALG0016] Part Name "8051_DIP.100/40/W.600/L2.050_8051" is renamed to "8051_DIP.100/40/W.600/L2.050_80".
* ?7 M; O8 O$ Q2 Z1 |#8 Warning [ALG0016] Part Name "74LS373_DIP.100/20/W.300/L1.075_74LS373" is renamed to "74LS373_DIP.100/20/W.300/L1.075".
5 q8 Q& n6 Y' ]8 }#9 Warning [ALG0016] Part Name "27512_DIP.100/28/W.600
2 }( t" @: @1 t _# M3 G/L1.400_27512" is renamed to "27512_DIP.100/28/W.600/L1.400_2".
; D; H6 S# i! `0 I#10 Warning [ALG0016] Part Name "CRYSTAL_0_RAD/.400X.150/LS.300/.034_12M" is renamed to "CRYSTAL_0_RAD/.400X.150/LS.300/". t6 F+ i8 L) E) s4 J0 Z" y
Scanning netlist files ...% K, f3 S& ^' t" u5 Z+ J, j
Loading... C:\wenjian1\allegro/pstchip.dat
( E1 X4 P5 g8 q9 E* KLoading... C:\wenjian1\allegro/pstchip.dat# W; W3 @( H; i0 L- z8 h
Loading... C:\wenjian1\allegro/pstxprt.dat
4 h3 `) ^; |1 \0 ?/ S7 iLoading... C:\wenjian1\allegro/pstxnet.dat0 t1 C( Q0 K0 e& [4 t" }0 g W% L: [
packaging the design view...
f8 `! m# }: _# K- N* D Z# O) |4 j( ]+ {. o2 Y5 g3 h \8 }
Exiting... "C:\Cadence\SPB_15.2\tools\capture\pstswp.exe" -pst -d "C:\wenjian1\yanli2.dsn" -n "C:\wenjian1\allegro" -c "C:\Cadence\SPB_15.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"9 L# i/ r. M$ j+ n; U3 D
- ]: @) ]3 m; v8 h/ h& o+ a
' k4 [& w! h+ K1 L. u*** Done ***" r r2 v3 s( X8 n/ ~' q
: v- b/ ~6 ~: b% }. n; J! c********************************************************************************
+ A- _5 p; W% E( l6 E6 o** g/ n& k9 i9 } U+ h' p( B: r
* Updating Allegro Board
2 Q8 Y* E4 d. S V: ~*: j" Z+ _% i4 T* s' Q$ @, s3 L
******************************************************************************** o4 ^$ G w8 |5 \# w, ~
Netlist Directory:
" c( S* o$ L1 T' z5 q2 n0 DC:\wenjian1\allegro# ]( K( O; \4 L7 ^9 T
Input Allegro Board:2 I8 \8 o6 A& s4 h& B8 {& p
C:\wenjian1\allegro\yanli2.brd2 w; p/ V; {/ h
Output Allegro Board:0 Z) S1 v$ p) Q& W) f6 P$ t/ Q
C:\wenjian1\allegro\yanli2.brd y' [1 h$ A8 I6 V
9 X# k& T- w! E0 q$ ~8 k6 D- P4 D
Spawning... netrev.exe -5 -y 1 -n -i "C:\wenjian1\allegro" "C:\wenjian1\allegro\yanli2.brd" "C:\wenjian1\allegro\yanli2.brd"% P( ]2 R+ C) C8 m% Z# E) N3 V1 u
Reading File : C:/wenjian1/allegro/pstchip.dat 8 A2 q5 P; U! H2 N1 w2 O" Z; I
(00:00:00.00)
* F: D$ n: X ?0 c3 kReading File : C:/wenjian1/allegro/pstxprt.dat 2 p1 w1 W/ c9 n# k% V
(00:00:00.00); _/ j. H4 u# x- D/ m
Reading File : C:/wenjian1/allegro/pstxnet.dat ! `* {* ]; j8 I, O u" z' S
(00:00:00.00)
( a6 i2 O* V7 A8 a2 A ]3 bStarting to process component instances; ~# v" G) ?* u3 c+ w* k7 f
; G$ g5 \6 x. j+ V x9 Hnetrev run on Aug 29 17:10:17 2008& Z2 w& v0 k% M
DESIGN NAME : 'YANLI2'2 k0 l& ^% s0 B
PACKAGING ON Apr 6 2004 19:58:387 o" \! P7 L X/ S/ E) J% f
, B3 \9 `! n1 P- a
) {; I. F% B! v6 M: O12 errors detected8 B3 U4 E& o, I
No oversight detected
' T8 }) q$ B" {: ~3 _No warning detected/ ~/ C7 z" n1 d. T
1 X+ \$ t: S U- P
cpu time 0:00:12
1 t1 \! a2 q: i: u* `elapsed time 0:00:00
+ G! y2 M! }5 d9 u! Q# r& E0 V& S S2 w7 S8 O2 q- _
( }0 ^! P; N& A A7 {2 \2 c' c/ W8 C) c
Exiting... netrev.exe -5 -y 1 -n -i "C:\wenjian1\allegro" "C:\wenjian1\allegro\yanli2.brd" "C:\wenjian1\allegro\yanli2.brd"! V! E* g7 \% B/ y e
Cadence Design Systems, Inc. netrev 15.2 Fri Aug 29 17:10:17 2008# w6 ^1 M; h- @. n- O
(C) Copyright 2002 Cadence Design Systems, Inc.) T: ^. U9 r: W, K) g% {0 g& f
! R/ E( `' f+ c5 I. B
------ Directives ------2 w8 p% r8 Q) K5 ?6 p" x) U
( E6 ? |8 R' h
RIPUP_ETCH FALSE;, J/ I4 V7 n2 ^1 U( |: @* G
RIPUP_SYMBOLS ALWAYS;9 [" X9 N& Z Q5 V/ r( u: m& m
MISSING SYMBOL AS ERROR FALSE;
" V0 |; u7 G5 m1 A/ {SCHEMATIC_DIRECTORY 'C:\wenjian1\allegro';4 L6 `* m& v; \1 }9 T2 S
BOARD_DIRECTORY '';
- _; \* r& Y7 zOLD_BOARD_NAME 'yanli2.brd';2 v- g3 j7 B8 I; x% L8 `4 L& T! D
NEW_BOARD_NAME 'yanli2.brd';% ~% Y4 \" [( H5 D: d
& m. x7 ]7 v) o( K' `CmdLine: netrev.exe -5 -y 1 -n -i C:\wenjian1\allegro C:\wenjian1\allegro\yanli2.brd C:\wenjian1\allegro\yanli2.brd& Y1 U' D8 G: x. K/ j. C; j
: R/ B0 C" c, u) w------ Preparing to read pst files ------
2 ]3 x/ ]5 S" T, T, Q8 a9 k
/ a6 X+ X# B* b Y! |Starting to read C:/wenjian1/allegro/pstchip.dat
" R. n9 S9 \; v8 n2 N Finished reading C:/wenjian1/allegro/pstchip.dat (00:00:00.00)
& v6 D: w: u5 W$ o( ?4 f0 IStarting to read C:/wenjian1/allegro/pstxprt.dat
3 s3 S; v! d7 P Finished reading C:/wenjian1/allegro/pstxprt.dat (00:00:00.00)) s! \, ^. j; m
Starting to read C:/wenjian1/allegro/pstxnet.dat
& i5 f) ~5 Y! k, Y( ~+ D+ ~ Finished reading C:/wenjian1/allegro/pstxnet.dat (00:00:00.00)! x2 a R# n% l9 A2 k
5 \' ^, _1 r" {0 X5 L: T% N9 Z------ Oversights/Warnings/Errors ------
# o8 B, g; G( D
7 z# H' o. S8 e. K% l6 G6 w& Z7 ?% {5 ^1 f+ U9 P; t, [/ [' Y) n
#1 ERROR(302) Device library error detected.
6 v8 n9 w7 A I- Q+ ~$ ?+ w, Y' ?! w5 b' E% M3 X0 t3 r
Problems with device 'CRYSTAL_0_RAD/.400X.150/LS.300/'. JEDEC_TYPE property 'RAD/.400X.150/LS.300/.034' is illegal: 'Package name is not legal.'.
2 E4 u4 u9 H% j3 `6 R9 f
6 q. b( W+ R$ h( g9 I% RDevice 'CRYSTAL_0_RAD/.400X.150/LS.300/' has library errors. Unable to transfer to Allegro.
1 P" h- V, J% I, O, H) C/ E1 h- c. S( b' T2 n
#2 ERROR(302) Device library error detected." j6 d/ }! D& U. y+ p
0 D2 S- ~# N( j" k
Problems with device '27512_DIP.100/28/W.600/L1.400_2'. JEDEC_TYPE property 'DIP.100/28/W.600/L1.400' is illegal: 'Package name is not legal.'.
; A2 h" z' X" N" m, p% E* R; y# Z8 f1 q: _/ u
Device '27512_DIP.100/28/W.600/L1.400_2' has library errors. Unable to transfer to Allegro.7 L, `0 }1 F# X+ G
; E: N; V3 ]- V; ?& N* [. Y# B5 G#3 ERROR(302) Device library error detected.4 L* Z* U& |, y: \( n
9 K9 ?& B1 y2 O0 q
Problems with device '74LS373_DIP.100/20/W.300/L1.075'. JEDEC_TYPE property 'DIP.100/20/W.300/L1.075' is illegal: 'Package name is not legal.'.
. L6 g8 @3 [8 [2 I/ ~2 t+ y
( a! V# Z' k( xDevice '74LS373_DIP.100/20/W.300/L1.075' has library errors. Unable to transfer to Allegro.
* M) E2 w5 @5 [: l4 I1 |; D0 C4 a7 B4 N# }; H( @& i% g
#4 ERROR(302) Device library error detected.
* _! k, K R- O) C. [. R6 N: L! t# b6 X4 j. ^& D
Problems with device '8051_DIP.100/40/W.600/L2.050_80'. JEDEC_TYPE property 'DIP.100/40/W.600/L2.050' is illegal: 'Package name is not legal.'.
. ^& Q% q R/ K$ [# |- L( r& B9 F
* {; Z4 f }7 j% N, y( W4 IDevice '8051_DIP.100/40/W.600/L2.050_80' has library errors. Unable to transfer to Allegro.
5 E; t1 Z0 g! O- ~
: L8 B/ |) `9 ?8 D! z#5 ERROR(302) Device library error detected.
6 v- A# X$ n) m# j3 U7 N* I& g( J1 P4 m* t0 b( ~& {6 \% ]9 q
Problems with device 'SW PUSHBUTTON_0_RAD/.400X.200/L'. JEDEC_TYPE property 'RAD/.400x.200/LS.300/.034' is illegal: 'Package name is not legal.'.
& z \# h% I4 V
8 g4 a) a) G2 p- u; T" U |Device 'SW PUSHBUTTON_0_RAD/.400X.200/L' has library errors. Unable to transfer to Allegro.
- @, D/ P; J3 b6 x: G& F, c
3 c) K0 [7 W" W/ ? t, P2 k#6 ERROR(302) Device library error detected.6 E% w- ?+ R& l1 w3 m$ m
% M$ b4 Y B4 ~# ?2 YProblems with device 'R_0_AX/.400X.100/.034_10K'. JEDEC_TYPE property 'AX/.400X.100/.034' is illegal: 'Package name is not legal.'.! [) A# B, H! j2 ^7 ?% b. y
; N1 h4 r* A$ M& GDevice 'R_0_AX/.400X.100/.034_10K' has library errors. Unable to transfer to Allegro.
0 B* U1 Y* P; S J8 u, _, A
( _' v9 k+ x9 A2 T" A! |3 |#7 ERROR(302) Device library error detected.* i- y v" e5 | v$ b- a, d7 d i
" _& [* a& @4 i$ t0 Y/ f
Problems with device '8 HEADER_0_SIP/TM/L.800/8_8 HEA'. JEDEC_TYPE property 'SIP/TM/L.800/8' is illegal: 'Package name is not legal.'.
% l: {9 Q4 [ I1 R! ~
: M: S I1 m2 Z' `3 E XDevice '8 HEADER_0_SIP/TM/L.800/8_8 HEA' has library errors. Unable to transfer to Allegro.
& ~% |2 g7 e: k
- T a+ K/ a& n- ]$ l% W8 P#8 ERROR(302) Device library error detected.7 t# E' p0 u1 L
, l2 c+ m) o( DProblems with device '4 HEADER_0_SIP/TM/L.400/4_4 HEA'. JEDEC_TYPE property 'SIP/TM/L.400/4' is illegal: 'Package name is not legal.'.
9 w1 C+ \" ^! h* D' I1 R9 \; A5 Y$ v( Q* W0 G# j' X/ R
Device '4 HEADER_0_SIP/TM/L.400/4_4 HEA' has library errors. Unable to transfer to Allegro.; a8 r) |' V9 U6 [% R; \
4 s$ o1 ]8 U, W- Z* p6 `( }3 _5 y8 f
#9 ERROR(302) Device library error detected.
4 |/ O6 a! U$ F8 i5 n! k
0 ~3 `& b) z: J. XProblems with device 'CAP NP_1_RAD/.200X.100/LS.100/.'. JEDEC_TYPE property 'RAD/.200X.100/LS.100/.031' is illegal: 'Package name is not legal.'.$ \4 N( S, j/ p; ] D: x
% l5 r7 P6 R$ Z1 }; L9 ^* RDevice 'CAP NP_1_RAD/.200X.100/LS.100/.' has library errors. Unable to transfer to Allegro.: `9 { ~& G9 W. g# O1 | y9 K9 c
: u! f8 K# W( s1 z2 Z
#10 ERROR(302) Device library error detected.
1 ^( d9 ?' M6 u6 v, b% `- J
6 ~" A+ l/ @5 w& ~( L2 iProblems with device 'CAP NP_0_RAD/.200X.100/LS.100/.'. JEDEC_TYPE property 'RAD/.200X.100/LS.100/.031' is illegal: 'Package name is not legal.'. n& D* V0 _$ U, n) n/ d2 f0 v
; g6 A7 d# j. W2 ^- RDevice 'CAP NP_0_RAD/.200X.100/LS.100/.' has library errors. Unable to transfer to Allegro. J4 _# a* I- H& Q$ Q0 ^
0 V6 X' [, L& Y2 v. P& T$ M4 p' a#11 ERROR(302) Device library error detected.
8 D v8 `* y8 p! R9 P3 T
. |2 D* q$ s7 aProblems with device 'CAP_0_CPCYL1/D.300/LS.200/.034_'. JEDEC_TYPE property 'CPCYL1/D.300/LS.200/.034' is illegal: 'Package name is not legal.'.
6 |7 k8 M# n% Y) C5 P8 ^
; A" |1 I& n6 P$ t4 {0 vDevice 'CAP_0_CPCYL1/D.300/LS.200/.034_' has library errors. Unable to transfer to Allegro.
+ [5 k" | U P6 C) W9 O3 K
; j+ `0 ^1 _$ g# Z; I------ Summary Statistics ------
6 l% O# C# P6 I0 q2 R4 T: j: h6 @1 i+ O4 `
! L5 B* W- z9 ~7 o6 U% X( \# L. l#12 ERROR(102) Run stopped because errors were detectedへ* n1 |: n- g4 O) t$ b+ D
! w% N& d# x* R: G% M+ j
2 A9 p$ B$ @5 L7 I K: I$ ?( M; [netrev run on Aug 29 17:10:17 2008; S0 U2 ]! C6 J, T7 \
DESIGN NAME : 'YANLI2'$ m1 W. z9 W3 A2 I. b) K
PACKAGING ON Apr 6 2004 19:58:38; k: M& y& R5 a! ^
7 S8 }; ]7 R1 g/ M
COMPILE 'logic'# K8 ~. l- ~) C& q% ~ H5 D
CHECK_PIN_NAMES OFF
* Z' p& V7 e" }1 [8 l8 y9 A CROSS_REFERENCE OFF% G0 A* o5 h! ~7 }+ `: o6 t9 V* ^
FEEDBACK OFF
. i8 r; g# [( ~/ a INCREMENTAL OFF
1 Q( e+ Z: y( A; v INTERFACE_TYPE PHYSICAL( Y& }, V0 @2 S: G y& t) L- S3 }
MAX_ERRORS 500
8 L5 p4 @6 d: F6 D MERGE_MINIMUM 5) H) O* U# L8 f6 ^. Q
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
3 A( [: d/ b2 Y! J NET_NAME_LENGTH 24
, G% K9 g8 @ s2 n OVERSIGHTS ON3 D: q& N: n4 S. j! d. o+ D
REPLACE_CHECK OFF' U. n, t* K; o. Y" M E. z
SINGLE_NODE_NETS ON
2 \+ S, U* A6 l/ f( o! F( f6 o F. q SPLIT_MINIMUM 0* |$ Q H4 H% u3 T
SUPPRESS 20: G0 \6 X2 g4 ^ b2 c4 Y- u
WARNINGS ON
9 {' }6 w! d' I6 n. l4 i, `8 I1 S% h" s9 q9 G
12 errors detected: w& E& i9 J3 _8 M! O1 i# C
4 Z a! K" w9 ?" d4 Q5 g* b) u; yNo warning detected9 ~9 L# k6 T. A( g$ C
1 K+ v6 Z( J/ N+ ?$ z
cpu time 0:00:125 @: Z! Z$ i* H
" _6 E: i: E( c: J s4 T% x
: i( l9 v* j7 n; e( _6 M: f; ` Y" z$ D
, z9 t3 q1 s$ @0 i) g! @
*** Done ***
7 @4 W) x- W9 h% x' r& |+ D
) L' {4 P; E! e$ F% h$ m) s********************************************************************************
; w3 n" C4 y) e; i+ O% g*
S& ?5 Z' R. `" Y* Spawing Allegro
- N; b/ z( e. _: S*
! \# f( E( G8 T( N" ?: O. w********************************************************************************
( _+ a# D6 n% i1 b4 {8 C* ZSpawing "C:\Cadence\SPB_15.2\tools\pcb\bin\allegro.exe" -mpssession Administrator "C:\wenjian1\allegro\yanli2.brd"
" e: N4 X% Q0 q! y2 N3 a. |3 o
2 L& I( X7 N8 Q: f*** Done ***
3 Z3 a6 t* B6 Y- [! {怎么回事4 |" Q. p. k3 v4 @. T
7 A! O: i$ d1 Y' k$ B6 r, j5 K4 ~5 E- v; ]' l9 @9 m; j2 I- O. ?
| | # s. E% Y3 x% v, |/ p
