7 H2 V9 `6 f+ b8 O2 t
最好自己写网表,不会太难的。简单例子
& E5 v) _+ p1 o) W; A$ n2 b, w! B$ G6 I8 i
* Use IBIS model without package RLC& K( j9 }4 ^& q' Y
) j. _, }( i! \* D- b: B- Q.option post probe dcon= 11 l, s. ?$ J S4 X! ]4 P
.parameter Bit_Rate='1600meg' UI='1/Bit_Rate'
) N$ ]% `0 j: S) `4 O3 N+ J! n" Z) p" W
vPRBS CA_in1 gnd LFSR (0v 1v 0p 100P 100P 'Bit_Rate' 3 [5, 2] rout=0.1)2 B2 V' K; e+ Y# ?% E2 y2 D8 h
5 k- ^ V6 ?% e$ dB_CA1 pup pdown CA_pad1 CA_in1 pwr GND7 W7 |7 [# c6 u
+file = '\Proj\lib\ddr3.ibs'- m7 N) |5 K8 L; W0 F' A
+model = 'A_34'+ M2 @/ R! M Q* M8 N
+typ=typ power=on buffer=output interpol=1
/ Z( h, o, J+ y7 K( q+ \& s( ]3 m. O
B_DQ1 pup pdown DQ_pad1 DQ_in1 en1 DQ_id pwr GND
+ `& H" t: N% f8 i7 m+ O+file = '\Proj\lib\ddr3.ibs'
2 F" j# y' N1 b' m2 [6 j+model = 'DQ_34_ODToff'
]0 g8 K3 `" l \+typ=typ power=on buffer=input_output interpol=11 d2 d8 t. S3 }( w; Q
$ e. x; X7 |; g4 q! F( Yven1 en1 gnd 0v
' U; t; }, D8 r* i: Ft1 CA_pad1 GND DQ_pad1 GND z0=50 TD=100p
/ `1 R7 @3 J7 p+ |) [, ?9 u% ~! d: J4 X3 G
.tran 10p 50n
; B# k* y. J* J' E$ _7 C% e.probe v(*)$ P6 [/ M& ^0 O* A' x
9 T' |4 X2 t. G$ [4 B
.end |
