查看: 4021|回复: 2
求助,microwave office 2009 安装
发表于 2014-5-14 11:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
大哥," s. `$ i) A/ a; e4 x* J0 H& n
     我的电脑(win7 32bit)安装microwave office 2009 ,步骤如下,crack完后提示license有问题,是win7不兼容还是别的什么原因呢?
- S4 D' S' A2 e  {# f- G0 b9 t5 P  ^3 R; k& ]3 l3 X
安装步骤:
; N3 K6 t! {% {- t( ^1)First install the set up ---> AWR_Design_Environment_9_0_4830_1. l/ C9 k9 S1 E8 R( [
# L( x. f1 _/ _6 u, L+ a4 s2)Than open the file where you install the AWR like ----> (C:\Program Files\AWR\AWR2009)- Q: k  @" E- a- P
3 V( ?, H) p4 H0 S$ B% ?, n
3)Find the "MWOffice" file and remove the read only tick from the properties
7 H4 m/ B  n% q; j6 [3 I7 o6 }% o, }+ B' w4 x
4)Add Crack files in the zip file(awr2009_4830fix) to your installing directory and run the patch2009
9 E5 }3 f% `3 e6 I5 n
7 o0 l3 y, Z! V9 ~$ Y. n% N5)Run MWOffice ----> choose option "Prompt for features when the application is run"
: M" s/ J" L4 Z7 v0 E1 D7 M1 E+ F1 Y4 h6 D% b
6)When the program start open ---> File --> License --> Configuration --> Set Location
$ ?& F  V$ {% R6 F! a4 E! L' Y
( E! c1 b7 [& v/ H' y7)Browse the "awrd.lic" file in your installment directory and click ok
. [) i. J* Q8 R- x+ a3 x
* r* ]5 I# S1 V) C, g3 O8)Than restart the AWR and choose that option ---> Always run with the selected features- H* H# c4 t; B( |  s9 D2 H
& {  O* @! ~  t- |
AWR Microwave Office ready to work with licence
1 l: F# P  V- ]* G* ]$ I
9 R0 m2 o, C3 o! pMay it be easy!
3 B. V" ]# t0 [+ m- U# s0 |* j4 H
5 l' }; s& A' |4 r3 I4 t
* a8 y! w( @% zcrack完后提示如下:# J6 r' C/ V* x% R
8 `. i' J+ R: b; k  A
! [3 O% V' r4 z( `1 X! D
 楼主| 发表于 2014-5-14 15:07 | 只看该作者
装了个2012,可以了。
哪里找安装包啊,谢谢  详情 回复 发表于 2020-11-26 11:45
发表于 2020-11-26 11:45 | 只看该作者
sshddu 发表于 2014-5-14 15:07
; h7 I3 |* o) O0 ]3 A% |4 Y' u装了个2012,可以了。
0 `: R8 p/ ^% q, l
哪里找安装包啊,谢谢6 Z! x2 x0 M& Q) w3 _/ c
GMT+8, 2025-9-11 01:26 , Processed in 0.140625 second(s), 30 queries , Gzip On.
