查看: 1259|回复: 0
为什么我在用CCS仿真时,老是出现下面这个问题?
发表于 2014-4-29 19:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Power Failure on Target CPU: Error 0x00001020/-1145 Error during: Execution, Target,  Unrecoverable emulation error  Sequence ID: 16 Error Code: -1145 Error Class: 0x00001020* r5 j- ?0 k) Y3 u8 T4 i
Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint opcodes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging.
" Q: T9 K; B& N9 H0 B哪位高手给指点一下!谢谢!
GMT+8, 2025-9-10 21:22 , Processed in 0.109375 second(s), 24 queries , Gzip On.
