Cadence SPB16.6下载(Hotfix025已发布) + X! p8 |6 ]" @8 w+ C5 g
c3 }3 a2 n. }1 d$ n
Cadence SPB16.6已经推出,需要的朋友可以点击下面的链接下载:& J$ ~2 L& U- V
http://dl.vmall.com/c0zau2e8ao
5 n% I% }: w2 t7 u* H3 }; [2 W* B+ s
DATE: 03-13-2014 HOTFIX VERSION: 025+ a, J, W# l( G5 I; j `4 M0 |
===================================================================================================================================& r3 S! |9 J, J+ Z/ i
1 N0 n9 x. H: G3 t" y
CCRID PRODUCT PRODUCTLEVEL2 TITLE
1 i0 L8 _) X0 p; N: T, Z# k" e; [+ i: N! z6 d' P7 S* \
( L8 s* j" t* D+ B3 W. @! _% J3 a% {+ g6 D( x1 _2 q/ X
1194646 CONCEPT_HDL GLOBALCHANGE Global Update > Global Component Changedoes not work
4 B) ^* f9 m7 t( |9 O
4 K/ V1 s8 }* J+ _0 H+ q* C1227843 SIG_EXPLORER EXTRACTTOP Cannot extract the topology correctly.
+ S; G' i2 r. n m
7 B3 `/ v7 |- H/ L5 j N1231510 ALLEGRO_EDITOR INTERFACES IDX exchanges with CREO 5.0 issues! m T l$ D; h/ \6 Y" L
8 P( i7 O {: i, D8 V
1233030 SIG_INTEGRITY GEOMETRY_EXTRACT Net Parasitic of groundConnection
# k' b1 h2 f$ _- H! ? b/ L- }0 ?
1236961 SIP_LAYOUT OTHER Moving component using Place Manual-H causes mirror_geometry.
. I; G7 ~0 Q3 S) ` S( O
! i; J% t. t0 O1 P1241456 ALLEGRO_EDITOR EDIT_ETCH When creating Die pins or changingtheir attributes an oval is placed on the pin
* S* X( H5 D; A4 ~2 f2 e. S3 l: ^
* v# w7 t# H* [) E; W: Y1 F) c1242461 SIP_LAYOUT OTHER SiP Layout - DIE is being mirroredwhen placing8 U2 a* J9 H" ?+ h' R4 r
- a0 J' r- a2 F$ C& S; {7 S2 W1242682 CONCEPT_HDL PDF PDF Pubisher crash DEHDL ondesign
R, P8 b5 T9 m& P% j
" O7 I6 e' U% C6 t) ~; V+ u1242685 SIG_INTEGRITY SIGNOISE Incorrect net name wasdisplayed/output if the net include consecutive underscore.1 u5 ~' O+ Z/ e. @
9 _0 S, q" b& c3 i9 ]6 V! @2 Z1243357 ALLEGRO_EDITOR INTERFACES Ability to add any new name
% J4 c9 [4 f2 g% m) w
7 H, t) [! O1 s8 k; ]. K8 @1243758 ADW COMPONENT_BROWSE I don't see anoption to switch between database and cache mode; j4 \2 w& p$ a* z" l! ]" t: P
' B" k5 |8 ^ z' M
1244325 ALLEGRO_EDITOR INTERFACES Merge all the BOMItems with same partnumber into one single entry in IPC2581B.
' P5 Z! m8 G' W' T& s, Q
6 P* k$ }) _ ]1245363 CONCEPT_HDL CORE Design Entry HDL program crashesupon save
' o8 r: H: g9 J! `# A9 w- l R3 Z
1245790 ALLEGRO_EDITOR PADS_IN Bug: PADS Translation with 16.6s023gives parse error7 p1 [ H" p/ H6 a& g( w D R
6 x" X3 y: X0 W- |
1246343 ALLEGRO_EDITOR SKILL axlAirGap command is broken in s0220 C# {8 o. H. ^+ ]; s4 W
) z( J2 a L! g4 f$ Z1246419 CONSTRAINT_MGR OTHER Netrev fails with SPMHGE-268 on existing design: A1 P+ g8 _0 T& ?# c; b
7 ^9 B8 B3 w+ j! R2 ]5 i+ W+ P7 x
1246878 CONCEPT_HDL CORE Changing Symbol in Variant Editormakes schematic page crash' w# ?2 u2 R, b/ r/ ]. P' N
' l2 l, v3 x, ^* ?1246884 ALLEGRO_EDITOR GRAPHICS Infinite cursor disappears from thecanvas after step package mapping GUI is closed.2 L( b/ L6 X9 R; X N, j$ c- y- b
3 z5 M8 ?& y/ f
1247016 ALLEGRO_EDITOR INTERFACES STEP Model of connector cannot be zoomedsufficiently after mapping it to symbol dra file." i- p) T! }# [4 c
) P$ x0 C* J; D. Y" }# A" t
1247107 ALLEGRO_EDITOR INTERFACES Incorrect Spelling in IPC-2581EntryFillDesc field! L! f0 {- n8 l- i0 X0 L. J
I8 f( r% y! f3 Z+ U
1247177 SIP_LAYOUT WIREBOND Bondfingers not aligning to wire whentack point on the other wire end is moved from center6 t% `2 e2 E2 d' l* g' m: w
5 A: z e; Q' p0 @
1247400 ALLEGRO_EDITOR INTERFACES option to Export optimized PDF in color |
