查看: 1515|回复: 14
16.6又出23号补丁了,求下载链接。
发表于 2014-2-18 16:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
16.6又出23号补丁了,求下载链接,话说这个更新速度比我的下载速度都快
推荐
发表于 2014-2-18 17:52 | 只看该作者
http://dl.vmall.com/c0fu1auqa8
1 o+ d; Z! H9 V$ \* n2 Z1 K1 n8 G) k( B
6 d0 G. l' K: Q, y
, A+ C7 \7 z3 F" o. q4 N- X6 h
9 p6 D' O3 A# UDATE: 02-14-2014   HOTFIX VERSION: 023  a2 _6 k) H" f4 I$ T8 `4 R
3 E; Z- V& W+ }' ~# I( [2 y) X* eCCRID   PRODUCT        PRODUCTLEVEL2   TITLE
2 {( a* k$ J  _# Q+ @+ t8 L===================================================================================================================================* G" R6 g' Y# s* O  r
1120183 F2B            DESIGNVARI       Variant Editor Filter returns incorrect results.
4 X3 E4 O( D5 `1202715 SPIF           OTHER            Objects loose module group attribute after Specctra
9 G/ _2 C  U* s1203443 ADW            LRM              LRM takes a long time to launch for the first time- m/ j# f1 h. b: f0 G; h
1207204 CONCEPT_HDL    CORE             schematic tool crashed during save all
6 Y8 N9 B0 m+ u  \5 x1222101 CONCEPT_HDL    CORE             Pins are shorted on a block by the Block's title delimiter# [2 c7 x# a# _# U5 e2 Y
1223709 FSP            FPGA_SUPPORT     Need FSP model of Altera 5AGZME3E3H29C4 FPGA
2 A2 y# s8 c# J7 x8 @+ R1224025 ALLEGRO_EDITOR INTERFACES       The 3D viewer when working on a brd file shows package placed on BOTTOM side of my board while it is present on TOP side
/ t0 H( l. g/ U5 C1225591 F2B            PACKAGERXL       Aliased net signals starting with equals sign are not resolved correctly in cmgr
% G$ g5 H3 ~+ S* \8 y0 o; e1226480 ALLEGRO_EDITOR EDIT_ETCH        Routing time is took to double increase when using the Add Connect because DRC is Allowed.) a; h. H% U. Y; _  _
1229234 FLOWS          PROJMGR          Can't open the part table file from Project Setup, W/ U) U) Q9 O) i9 b! B
1229555 ALLEGRO_EDITOR ARTWORK          IPC-2581 not recognizing pin offsets correctly.
9 o0 a/ M% x5 ]9 G1229610 FSP            FPGA_SUPPORT     New FPGA device request - Altera Cyclone V ST: 5CSTFD6D5F31I7
5 c& {$ g! L2 X- }- t/ u& S1229664 ALLEGRO_EDITOR SHAPE            Shape not voiding different net pins causing shorts with no DRC's
0 o/ E% V: y; }/ ^# ]! n" h1232601 ALLEGRO_EDITOR MANUFACT         Cannot add test point to via on trace.  O; N' E. ^/ S; k9 s
1232772 ALLEGRO_EDITOR DATABASE         When applying a place replicate module Allegro crashes2 K2 A6 K% R! D8 K$ g: g
1233216 SIP_LAYOUT     DIE_ABSTRACT_IF  Allow more than 2 decimal places for the shrink facor in the add codesign form; k5 g0 G4 B  r  y$ E( E
1233690 PDN_ANALYSIS   PCB_STATICIRDROP PDN IRDrop: Mesh mode in Report is incorrect.8 c( u8 m( a) X0 o- g
1233977 ALLEGRO_EDITOR INTERFACES       single shape copied and rotated fails to create when importing IDX: X+ n6 m0 ]8 x" i7 L4 C
1234357 SIP_LAYOUT     SCHEMATIC_FTB    DSMAIN-335: Dia file(s) error has occurred.
$ g& K- `9 c/ V/ k1234450 ALLEGRO_EDITOR INTERFACES       clines, pads, etch shapes to be at the same level with the board when viewed in STEP viewer.
3 l  ^; T' ^! T0 }2 t4 [1 g1235587 PSPICE         MODELEDITOR      PSpice Model Import Wizard does not display symbol graphics for DE-HDL Symbol2 a8 O+ ?4 y' P* N/ e) E1 e
1236571 ALLEGRO_EDITOR GRAPHICS         Allegro display lock up and panning issues# @8 B  ^. m) g! g1 Z8 _: m
1237415 ALLEGRO_EDITOR INTERFACES       Multidrill pad is exported with single Drill in the STEP File
2 g6 I" ]+ D' [' Y1237807 ALLEGRO_EDITOR SCHEM_FTB        The line feed code of netview.dat
发表于 2014-2-18 17:09 | 只看该作者
还是等到第30个再打吧.
发表于 2014-2-19 07:59 | 只看该作者
好快的更新速度
发表于 2014-2-19 08:43 | 只看该作者
太快了,是好事情还是坏事情呢???
 楼主| 发表于 2014-2-19 08:46 | 只看该作者
谢谢分享,有人能转存到百度网盘吗?
发表于 2014-2-19 09:11 | 只看该作者
才刚刚下了22,这不到一个礼拜又出新了,神速啊( H+ |( |: j6 z- d2 c/ g
谢谢ning
    2021-3-12 15:23
  • 签到天数: 23 天
    [LV.4]偶尔看看III
    发表于 2014-2-19 09:45 | 只看该作者
    这么快的更新不是什么好事情。。
    发表于 2014-2-19 12:39 | 只看该作者
    Jason022 发表于 2014-2-19 08:464 ~3 B8 \8 c& o4 b6 ~6 m# J; H
    谢谢分享,有人能转存到百度网盘吗?
    ' ?. K, L2 V4 i0 W9 ]' L
    http://pan.baidu.com/s/1eQl7md8
    发表于 2014-2-19 14:27 | 只看该作者
    : c; W' B2 l4 ?9 F看到这一条,必须更新啊。
    2024-2-9 15:00
  • 签到天数: 191 天
    [LV.7]常住居民III
    发表于 2014-2-19 15:33 | 只看该作者
    我觉得下载速度跟不上更新速度
    14#
    发表于 2014-2-21 20:33 | 只看该作者
    更新太快了,坐等hotfix30
    2025-7-30 15:24
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    15#
    发表于 2014-2-24 10:20 | 只看该作者
    频繁更新太累了。
    GMT+8, 2025-9-30 16:28 , Processed in 0.125000 second(s), 24 queries , Gzip On.
