查看: 5240|回复: 2
orcad传网表到pads所报的错误,怎么改?
发表于 2008-8-22 10:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Reading file --  F:\Program Files\orcad\PS1.asc
* S& E8 G4 e* ~: p5 {4 k*Unspecified or unsupported version of ASCII file$ G# h* \7 v. n) g! X
*pads-PCB*, ?( q$ I4 B' k% s7 v" `
*Not valid pin name for part type C9.P# E+ X; J1 g& j
U2.8 D1.2 C4.1 C9.P
0 F& _8 v* ?0 v0 @' f- \*Not valid pin name for part type C11.N; M* m2 L. s0 N
C13.1 C12.1 C15.1 C14.1 C11.N U8.2 D3.1 D5.1! _' K. Z, n# \# {
*Not valid pin name for part type C17.N
3 O9 @& [3 O/ t. o7 d3 L8 q0 ZJ1.10 J1.2 J1.5 R19.1 C17.N R20.1 ISO1.5 C3.1
, Y4 f' {; u4 k$ L0 P' R: c*Not valid pin name for part type C6.N
6 d% y# _. l% D! o+ ]! UC4.2 C7.1 U2.2 C6.N C8.1 J3.6 J3.10 J3.8* ~5 X& f: j1 U9 X- Z
*Not valid pin name for part type C9.N
% `7 ^) T: j" X7 ^" k5 s7 ?8 wU4.26 U4.27 U4.20 U4.19 U4.28 U4.18 C9.N U7.4( F# J; M6 w" Y# W; l" y
*Not valid pin name for part type C6.P$ h" K2 {4 i- K' d$ {4 k3 F1 h$ o
R21.2 U3.25 U3.9 U3.41 C6.P U2.7 J3.4 C15.2; m4 M, J) \6 \+ R% U( f  x2 h
*Not valid pin name for part type C11.P) S; E, h8 I$ C; F9 p9 S/ W9 W
C11.P C12.2 U4.13 U4.3 U4.23 U5.VCC D9.2 U6.9+ ~/ S7 ?9 [, A$ i# A# p
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal +12V1 i! P. C9 J5 x3 t
*Not valid pin name for part type C17.P
* _5 j; k% `6 p  d8 S9 O, I8 P1 AJ3.5 R3.2 R21.1 C17.P U3.60
% K. C, B. l2 C) w1 AWarning: deleting signal +12V( ]- U) D' B* X) j
**INPUT WARNINGS FOUND**
发表于 2008-8-22 11:59 | 只看该作者
C9.P  C11.N  等不正确的命名,系统没有找到对应的封装....你把封装名重新更改应该就可以了
发表于 2008-8-22 12:42 | 只看该作者
pads中的封装与你在orcad中写的封装不对应
GMT+8, 2025-7-21 02:09 , Processed in 0.125000 second(s), 24 queries , Gzip On.
