这些都是2-6块钱的货,看看哪个好买就用哪个吧:
& @; i g s* L5 V, u" C& h1 _: @/ J4 @- P6 j7 _) X
Alpha & Omega Semiconductor Inc AOZ1284PI IC REG BUCK ADJ 4A SO8 0.44111 3 V ~ 36 V
9 i* P, s, D! y7 UAlpha & Omega Semiconductor Inc AOZ1284PI-1 IC REG BUCK ADJ 4A SO8 0.44111 3 V ~ 36 V, T3 i( z. K- K2 k& X, y- d
Alpha & Omega Semiconductor Inc AOZ1253PI IC REG BUCK SYNC ADJ 3A 8SO 0.537 4.5 V ~ 26 V$ [4 g# F) |; U+ Y! H' N' O& z7 N
Alpha & Omega Semiconductor Inc AOZ1254PI IC REG BUCK SYNC ADJ 4A SO8 0.57536 4.5 V ~ 26 V
2 B1 o9 _( f1 _ o) b9 kRohm Semiconductor BD9876EFJ-E2 IC REG BUCK SYNC ADJ 3A HTSOP8 0.60732 7 V ~ 42 V* r3 I2 b" \4 c9 A. @& E' V
Allegro MicroSystems, LLC A8698ELJTR-T IC REG BUCK ADJ 3A 8SOIC 0.65527 8 V ~ 25 V- F4 u9 g( R. D7 u% b( Z
Sanken NR111E IC REG BUCK ADJ 4A 8ESOIC 0.7192 6.5 V ~ 31 V
& ~( \6 S& B- F; L; z! g7 ^- ASanken NR110K IC REG BUCK ADJ 4A 8HSOP 0.72879 8 V ~ 31 V/ n- f ?, R! }
Allegro MicroSystems, LLC A8697ELJTR-T IC REG BUCK ADJ 4A 8SOIC 0.73518 8 V ~ 25 V
0 \- @) G0 s" a' r; D5 V& f3 [. W% qAlpha & Omega Semiconductor Inc AOZ1212AI IC REG BUCK ADJ 3A 8SOIC 0.74637 4.5 V ~ 27 V
" M( a) r* X& q8 H2 D* K* AAlpha & Omega Semiconductor Inc AOZ1242AI IC REG BUCK SYNC ADJ 3A SO8 0.74637 4.5 V ~ 32 V
) d& z8 J. B9 y- u* wDiodes Inc AP3003S-5.0TRE1 IC REG BUCK 5V 3A TO263-5 0.7584 Up to 32V* g9 e: B1 T3 k0 A* J, N. z* w
Diodes Inc AP3003S-ADJTRE1 IC REG BUCK ADJ 3A TO263-5 0.7584 Up to 32V) S" L2 u. Y/ |
Alpha & Omega Semiconductor Inc AOZ1212DI IC REG BUCK ADJ 3A 8DFN 0.78313 4.5 V ~ 27 V! y r1 s2 n2 w. w) }! A, M- y
Allegro MicroSystems, LLC A8447SLJTR-T IC REG BUCK ADJ 3A 8SOIC 0.78313 8 V ~ 50 V- G& e+ I2 J% u4 G( y
Alpha & Omega Semiconductor Inc AOZ1242DI IC REG BUCK SYNC ADJ 3A 8LDFN 0.78313 4.5 V ~ 32 V8 U8 w( I0 S- v6 O' n( ~/ W8 X C
Allegro MicroSystems, LLC A8498SLJTR-T IC REG BUCK ADJ 3A 8SOIC 0.78313 8 V ~ 50 V! q" E5 T Z/ |6 a3 m
Sanken SI-8005Q-TL IC REG BUCK ADJ 3.5A 8HSOP 0.80482 4.75 V ~ 28 V
) [( d! l" N/ A6 q( F! WTexas Instruments TPS54331DR IC REG BUCK ADJ 3A 8SOIC 0.85619 3.5 V ~ 28 V& V* x, N0 K( m5 u
Texas Instruments TPS54331DRG4 IC REG BUCK ADJ 3A 8SOIC 0.85619 3.5 V ~ 28 V
% C1 B- c$ X; i# x5 w+ p { Z! TTexas Instruments TPS54331GDR IC REG BUCK ADJ 3A 8SOIC 0.85619 3.5 V ~ 28 V8 ]# m2 X6 M4 W9 d$ [" J
Semtech SC4525CSETRT IC REG BUCK ADJ 3A 8SOIC 0.92468 3 V ~ 28 V
+ Z- d) g7 C+ q2 Z: Y) S: mTexas Instruments TPS54331DDAR IC REG BUCK ADJ 3A 8SOPWRPAD 0.92754 3.5 V ~ 28 V& x$ K* `3 _+ [
STMicroelectronics L7981 IC REG BUCK ADJ 3A 8VFQFPN 0.92931 4.5 V ~ 28 V6 q* V, e8 R# s3 j% ~
