查看: 2042|回复: 10
我的快捷键。求补充,求推荐
发表于 2013-12-3 13:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
alias Pgdown zoom out# C2 w, s4 \/ s- R( i! K' q
alias Pgup zoom in
- V6 C- b0 ^2 H/ s# d+ d5 h# V0 a2 Aalias End redisplay
2 `2 Q1 ?7 \' ]alias Del delete) k, N. Z# q, Z5 B# {, C" |) U; G* ]
alias Home Zoom fit% f2 ], l5 G3 u3 U4 N. s
alias Insert Define grid
9 ]0 P5 `& T9 y% P0 V
% ^( i. l! X7 e9 v1 I  d  r' P6 jfunckey ' ' iangle 907 Y) b+ `, J' W" a+ W
funckey q shape add
( Y5 Q% @! A: q) ofunckey w shape select& I% l4 v$ ?, y7 {5 \
funckey e shape edit boundary
, m) u8 P1 @: T) \! vfunckey r mirror# v" P- [: V+ z5 `
funckey t done
9 y' w1 T/ J0 D* |! g
# n6 O0 }* f* Ifunckey a add connect
8 T) C/ Q. E: l7 W5 o4 Lfunckey s slide$ c* L2 d2 ?4 M* s% |
funckey d delete
' c8 [. R  c3 @/ Ufunckey f fix
! I2 |* P/ {- J& W# k+ a$ l4 Y4 Mfunckey g oops/ f8 X7 O; m! R
) i( ]- d8 `+ v, ]% ]( f
funckey z add line$ t& X0 M2 ]7 n9 L' d& q
funckey c copy2 [! x! c/ s3 L; F
funckey v next0 I+ |" F# p  J6 D5 m* G+ q* V
funckey b cancel
' W" a) z$ v! e: z; h/ J
3 y8 Q% w  h2 ?funckey m move& L: z% |4 a6 a! q8 {
" K1 r& V7 C  L. }) Z- Cfunckey h hilight
+ m% m1 @, r8 o& jfunckey y assign color; D* O* u/ x) _' x: z7 ^4 ]
funckey u dehilight
, E1 C" u- h1 s$ Z4 S" [' \& P* G, |1 J( q5 x+ U: j
funckey j rats net
4 M7 D% u% z3 {; t1 ]- X2 j2 _! f4 {. X, a
alias ~W pop shape update% R, D! T5 o( j: S# `
funckey p place manual( \' m) r6 s1 N% ~/ F, d- W
$ h" Q, q, ^' B' O/ z/ L) zfunckey 1 'pop bbdrill;pop swap;subclass top'+ d' V, ]) D7 t5 [% K
funckey 2 'pop bbdrill;pop swap;subclass bottom'
0 z! S0 E3 c3 r; }) f  k. ifunckey 3 'pop bbdrill;pop swap;subclass top;+'
8 p, w0 g" l9 O. {0 jfunckey 4 'pop bbdrill;pop swap;subclass top;+;+'3 s" F( U6 B. J7 \8 `% u
funckey 5 'pop bbdrill;pop swap;subclass top;+;+;+'1 w, p" {( L; F, @  z
funckey 6 'pop bbdrill;pop swap;subclass top;+;+;+;+'5 Q3 @& Q8 B- ^# v' Y6 I
funckey 7 'pop bbdrill;pop swap;subclass top;+;+;+;+;+'
* D) \, W1 I* J$ Z; G4 |funckey 8 'pop bbdrill;pop swap;subclass top;+;+;+;+;+;+'
发表于 2013-12-9 16:56 | 只看该作者
最后的funckey 8 'pop bbdrill;pop swap;subclass top;+;+;+;+;+;+'这部分是什么意思?
发表于 2013-12-9 20:26 | 只看该作者
动感时代 发表于 2013-12-9 16:56
6 {$ c& \+ x! ~) O5 T2 d最后的funckey 8 'pop bbdrill;pop swap;subclass top;+;+;+;+;+;+'这部分是什么意思?
( K+ @% V& o. p+ s- d切换层面的!
发表于 2013-12-9 21:07 | 只看该作者
来来来,看看哥哥的。
. s. u0 w# E6 g& D) |! N
7 N" g+ E- V9 }2 E  H$ b% E
, s! N# j( f1 v1 `' Y, w5 m) W$ j6 U5 J* ?! ]* K% m  \
alias Home hilight
6 T% _* M7 d$ r6 x* Ealias End dehilight  ~( E1 U+ X- |; m) p0 t, K$ f
alias ~T replay show_silk_top/ @% [" q' U3 ?. d
alias ~B replay show_silk_bot
; |: G, h% n" r' `4 L1 V1 }alias ~D replay show_drc$ K) e4 |: A' b2 j. o; R! e
funckey [ prmed+ S  N" a, d* O
funckey ] status  {8 ]7 A' V$ f6 a0 A4 |# d) P
funckey g define grid
2 o& S7 l, e- D: d4 w0 R1 Sfunckey ~d replay grid40
+ X5 Z& d0 G2 m' y0 Dfunckey ~e replay grid53 |  K+ c9 W3 v/ e" O0 |
funckey ~a replay grid1
  x2 G, r# n  M+ Y7 A0 Rfunckey w cmgr
, [+ [! u# G' M# K: Gfunckey q color1926 c5 ?! V2 ]0 x
funckey p property edit
5 A6 Y& V. G) j) P8 V) p2 e) F9 Ifunckey o shape global param
" Z" Q7 f) s* M- q9 Q1 ffunckey f pop finish  ^6 J1 K9 Y5 v, Q
funckey del replay del_net
* N5 I" E% w1 I9 Jfunckey 7 dxf in9 m/ E! W# X* M8 X* s3 ~
funckey 8 netin
% N7 i! p2 x$ J$ h2 T( T. f. ifunckey 9 plot setup  Q7 e( C7 l0 B4 X# N! x9 @% y
9 O, ~: q6 o  V! ~alias F9 ncdrill legend; S% X) |8 ^# c6 `1 O' \1 `
alias F10 ncdrill param
2 T5 R2 I8 t( r1 s  ^# |% balias F11 nctape_full
& v/ b) M+ ^9 @- E9 m) g2 L% q9 }funckey F12 ncroute* O1 [, X- ~  i0 \0 P0 v  x8 s
alias Insert artwork. ~3 t/ n' I+ L3 F1 `
alias SF12 replay componment_report/ J8 B' E" b$ j$ F' C/ C
alias SF11 replay un_pin_report
! v" w) q% n7 g: v# ^( ?) nalias Esc cancel
, b( `3 F! G+ @, a$ q+ Y. W* falias F2 add connect
# W( f, F/ q' O1 O3 \" v- }alias F3 slide
: x% U1 w) \: p6 Salias F4 show measure
* D, z. E# ^* O& d: s# N; xalias F5 show element
6 m# K2 a* J# J8 m% Ialias F6 text edit! v# J7 W7 Z  X1 Z4 M1 M
alias F7 change
* \% u" f) K% t) F; C5 Q8 v; Yalias F8 mirror
, J4 \6 `2 X1 tfunckey v vertex
% z9 T5 g' d  ~2 w  Q! m1 Sfunckey c copy
6 n3 b# z5 N( E& F" N3 ^' G9 Ualias Del delete
# \  k# C0 [/ I/ s  Y" T5 Efunckey s custom smooth* s* J1 d1 @$ l
funckey t toggle" r5 M3 h, N6 o: a8 c
funckey e pop neck
% N- g( W/ G4 `+ x! bfunckey m Move
& |5 k- K; j  j  _7 f; r) p! s2 h+ `funckey ' ' angle 90
! H. K+ B: ^$ |7 C* u2 O# Pfunckey , 'setwindow form.find;FORM find all_off;FORM find symbols YES;setwindow pcb'
, B) F3 l# R2 ^
; y3 E3 X! \% g% y" g3 K
: z! j1 u' H8 N--------------------------jmx89
发表于 2013-12-9 23:04 来自手机 | 只看该作者
楼主快捷键设置得很好,请教—下,你把12345678数字用于层面切換,那走线时要改变线径的快捷键是如何设置或其它方式来进行的呢?谢谢
    2023-2-12 15:39
    发表于 2013-12-10 08:30 | 只看该作者
    JIMDENG 发表于 2013-12-9 23:04
    $ I2 }! ?/ q  P' w& h$ O0 {楼主快捷键设置得很好,请教—下,你把12345678数字用于层面切換,那走线时要改变线径的快捷键是如何设置或 ...
    ! m4 x$ c% Q+ f+ e' a# L
    改变线径?宽度么?; l# ?1 {; S, {+ u
    funckey w6 Options acon_line_width 6
    发表于 2013-12-10 12:44 来自手机 | 只看该作者
    好,谢谢指教!
    & L' }+ `+ ]$ @, i7 U$ _
    发表于 2013-12-16 09:44 | 只看该作者
    zn383462925 发表于 2013-12-9 20:26
    " H9 b1 n+ j8 T' W0 I# Z' }  q# s切换层面的!
    4 w7 {- R: S2 V" U3 @. o8 |谢谢,我试了,很好用。
    2019-11-20 15:15
    发表于 2013-12-16 23:14 | 只看该作者
    个人意见:. O* L  z; ~7 S3 M# R$ \
    右手操作鼠标,左手操作键盘# ]4 H/ P% _7 o1 k! Y. b0 d2 R# L
    那么asdf 按照我们左手的按键习惯来说; S% J8 o& z- b6 ?! ?! D' V( P- w
    f和d是相对较多的
    ( n/ O, U$ A7 [5 o; r! V8 e, c0 t6 M因此可以将 f 设为比较常用的add connect  设为fix 太浪费了 fix这个功能一般就用那么几次而已
    : d# W, _8 g7 N( S- o. @% z) V( o再说 d  你既然意见将del 设为delete了 那么d再设置的话,就是浪费按键了
    ; w+ }" k0 f  u9 H建议将d设为toggle 这个折线功能配合 f 的 add connect 可以提高你的操作效率
    : k. e) |, o6 r- z: W7 H同时将V设为移线
    ! v, ]6 P& g! I: F  m0 j2 s这样基本的走线功能键都集中在你的食指附近了! a# D+ _- K& @3 ]
    2019-11-20 15:24
    发表于 2013-12-17 08:35 | 只看该作者
    COPY的东西后面怎么乱七八糟的?搞死人去了
    GMT+8, 2025-9-30 19:23 , Processed in 0.140625 second(s), 23 queries , Gzip On.
