查看: 4215|回复: 0
大家 来看这个SKILL怎样安装好---autosilkUtils
发表于 2013-11-30 16:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Silkscreen Utilities Help Information
This utility should work for PSD14.2 through to SPB16.3
Setup Tab
'cadence Silkscreen Setup' - Equivalent to selecting 'Silkscreen...' in the Manufacturing menu.
Spacing Constraints:
'Text Spacing' - Spacing from each text string character to a solder mask object.
  Use the "D" button to reset this value to the company default (10mils)
'Faster Text Check' - Check using a bounding box around the whole "word" rather than each vectorised character.
'Shape Spacing' - Spacing from a shape to a solder mask object.
'Line Spacing' - Spacing from a line to a solder mask object. Can be quite slow.
'Reference Text Locations' - Check that each reference designator is closest to its own parent symbol.
  Checks components of the same class only.
'Note:' - These values are maintained between sessions
Solder Mask Objects to be Checked:
'Pin pads' - Select this check box to check objects against solder mask pads on pin pads
'Soldered Pads Only' - Select this check box to only check objects against solder mask pads on soldered pins.
  This will exclude pads on the non-soldered side of a leaded device.
'Vias' - Select this check box to check objects against solder mask pads on vias
'Shapes' - Select this check box to check objects against solder mask shapes
AutoSilk Layers Shapes Copying:
'Check Spacings button' - PeRForm drc checks on the Soldermask objects selected in the above group
'Ignore Fixed Status Option' - Ignores the fixed status of objects or their parents when copying shapes
  (by deleting any existing AutoSilk layer shapes and replacing them).
'Copy button' - Copy BOARD GEOMETRY and/or PACKAGE GEOMETRY silkscreen shapes to the AutoSilk layers.
  Useful for pin 1 markers etc.
Check tab
Use Films:
'Use Films to determine layers to check' - Selected by default if one or more films containing a silk layer is found
Use Silk Layers:
'Auto suggested layer selection' - Selected based on existance of objects on these layers
'Classes' - Only class/subclass combinations with spacing rules objects present are selectable
'Subclasses' - Only one subclass, that has spacing rules objects present, is selectable
'Check sides' - Only check the sides that have been selected
User Selection:
'Class' - User selectable class
'Subclass' - User selectable legal subclass for the selected class
Checking:
'Check in Window button' - Start checking in the current window.
'Check All button' - Start checking. This may take a several minutes on a large design
General:
'View Log button' - View the list of DRCs created
'Quit button' - Quit this utility
'Help button' - Display this file
最新的.zip (225.68 KB, 下载次数: 4)
如果 用论坛的加载器,要怎样安装 好,谢谢!!!
GMT+8, 2025-8-5 01:14 , Processed in 0.140625 second(s), 28 queries , Gzip On.
