查看: 3931|回复: 3
[Cadence Sigrity] Trace No Reference
发表于 2013-11-12 14:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Trace No Reference,为什么我的板子上有那么多+ T1 N- ]4 q$ [) w  Y1 I& R
WARNING [Trace No Reference]: Trace11393:RAM_BA2 There is no plane or patch (top or bottom) covers the trace segment.
. [) B3 c1 \3 q; p3 A8 bWARNING [Trace No Reference]: Trace11536:RAM_BA2 There is no plane or patch (top or bottom) covers the trace segment.
7 P% {1 g+ n5 EWARNING [Trace No Reference]: Trace11725:RAM_BA1 There is no plane or patch (top or bottom) covers the trace segment.( J4 D0 j5 N7 H' ?
WARNING [Trace No Reference]: Trace11731::DRAM_BA1 There is no plane or patch (top or bottom) covers the trace segment.) [( X" d1 {+ A0 \2 A+ c+ n4 L+ L3 W
WARNING [Trace No Reference]: Trace11761::DRAM_BA0 There is no plane or patch (top or bottom) covers the trace segment.
" a9 W1 f$ z! R7 H0 J& x6 AWARNING [Trace No Reference]: Trace11868::DRAM_BA0 There is no plane or patch (top or bottom) covers the trace segment.
0 P4 C* t0 J: DWARNING [Trace No Reference]: Trace232 There is no plane or patch (top or bottom) covers the trace segment.* M& ^* R' k. {
WARNING [Trace No Reference]: Trace233 There is no plane or patch (top or bottom) covers the trace segment.& `+ O  U/ `1 y% m8 {4 K( y* I! L
WARNING [Trace No Reference]: Trace4303::DRAM_A5 There is no plane or patch (top or bottom) covers the trace segment.
4 E& Q: O: {  ~! L4 h+ DWARNING [Trace No Reference]: Trace4304::DRAM_A5 There is no plane or patch (top or bottom) covers the trace segment.% @% @# p  h$ w! L' `
WARNING [Trace No Reference]: Trace4464::DRAM_A5 There is no plane or patch (top or bottom) covers the trace segment.
' t7 S* [+ @9 H; v* W- G) mWARNING [Trace No Reference]: Trace4721::DRAM_A3 There is no plane or patch (top or bottom) covers the trace segment.- \, f4 ]: N6 {& n4 d7 c5 B! H' h2 S
WARNING [Trace No Reference]: Trace4888::DRAM_A3 There is no plane or patch (top or bottom) covers the trace segment.3 D* |: F$ f$ D) R; M6 J+ W- O$ |
WARNING [Trace No Reference]: Trace4969::VDD_COREA12 There is no plane or patch (top or bottom) covers the trace segment.7 _, v& R" l  l; n6 j4 `
WARNING [Trace No Reference]: Trace5235::DRAM_A6 There is no plane or patch (top or bottom) covers the trace segment.
: o! u& b& Z5 @WARNING [Trace No Reference]: Trace5239::DRAM_A6 There is no plane or patch (top or bottom) covers the trace segment.
* {$ Y) Y0 g/ n/ |6 ?1 f) ?WARNING [Trace No Reference]: Trace5476::DRAM_A4 There is no plane or patch (top or bottom) covers the trace segment.! J1 C% Q3 t+ V8 T* b8 V' C
WARNING [Trace No Reference]: Trace5521::DRAM_A4 There is no plane or patch (top or bottom) covers the trace segment.
, {5 x; _& }+ {& v4 c- ~WARNING [Trace No Reference]: Trace5872::DRAM_A1 There is no plane or patch (top or bottom) covers the trace segment.
$ |! R5 @* b- l$ A; f7 y% HWARNING [Trace No Reference]: Trace5873::DRAM_A1 There is no plane or patch (top or bottom) covers the trace segment.: l. X/ {3 ^2 y/ R+ f# `0 N( t! f1 x5 x
WARNING [Trace No Reference]: Trace5953::DRAM_A8 There is no plane or patch (top or bottom) covers the trace segment.* O' r+ d% _; t# j, V
WARNING [Trace No Reference]: Trace5954::DRAM_A8 There is no plane or patch (top or bottom) covers the trace segment.
/ n8 x7 A( \: `' ]9 ]: b" OWARNING [Trace No Reference]: Trace5955::DRAM_A8 There is no plane or patch (top or bottom) covers the trace segment.
# U$ r! m4 n, }+ ]/ o! mWARNING [Trace No Reference]: Trace5956::DRAM_A8 There is no plane or patch (top or bottom) covers the trace segment.
" B7 e& |9 Z& F+ m7 ^WARNING [Trace No Reference]: Trace6097::DRAM_A14 There is no plane or patch (top or bottom) covers the trace segment.
- O6 ~" k0 S! A5 c* lWARNING [Trace No Reference]: Trace6148::DRAM_A14 There is no plane or patch (top or bottom) covers the trace segment.# t* v# f' N* Z
WARNING [Trace No Reference]: Trace6341::DRAM_A13 There is no plane or patch (top or bottom) covers the trace segment.
, H( C. N; W- P2 LWARNING [Trace No Reference]: Trace6385::DRAM_A13 There is no plane or patch (top or bottom) covers the trace segment.
3 g! j) w1 M% U# dWARNING [Trace No Reference]: Trace6389::DRAM_A13 There is no plane or patch (top or bottom) covers the trace segment.
* E& Q  w' N" i$ H; Y5 wWARNING [Trace No Reference]: Trace6390::DRAM_A13 There is no plane or patch (top or bottom) covers the trace segment./ o1 {6 k- ]1 V  u  \) W
WARNING [Trace No Reference]: Trace6391::DRAM_A13 There is no plane or patch (top or bottom) covers the trace segment.
: {0 p! P' z2 @# C3 YWARNING [Trace No Reference]: Trace6392::DRAM_A13 There is no plane or patch (top or bottom) covers the trace segment.
% X+ K3 A0 R5 ^  LWARNING [Trace No Reference]: Trace6405::DRAM_A13 There is no plane or patch (top or bottom) covers the trace segment.7 P* Q0 i: b# b7 L/ p7 ^
WARNING [Trace No Reference]: Trace6406::DRAM_A13 There is no plane or patch (top or bottom) covers the trace segment.9 k: d0 j: O5 ~
WARNING [Trace No Reference]: Trace6495::DRAM_A9 There is no plane or patch (top or bottom) covers the trace segment.
0 ^. v* W5 f7 Q+ rWARNING [Trace No Reference]: Trace6501::DRAM_A9 There is no plane or patch (top or bottom) covers the trace segment.' k# Q* ?' S+ y: m4 I1 U" B
WARNING [Trace No Reference]: Trace6537::DRAM_A9 There is no plane or patch (top or bottom) covers the trace segment.
) ~  q$ m- r' _* g- [/ YWARNING [Trace No Reference]: Trace6538::DRAM_A9 There is no plane or patch (top or bottom) covers the trace segment.  B& {6 B" S. U$ r
WARNING [Trace No Reference]: Trace6539::DRAM_A9 There is no plane or patch (top or bottom) covers the trace segment.( i! R( R. N4 Q  j' ^+ `9 i& d
WARNING [Trace No Reference]: Trace6540::DRAM_A9 There is no plane or patch (top or bottom) covers the trace segment./ }" A4 b/ a. f+ {* w: N
WARNING [Trace No Reference]: Trace6541::DRAM_A9 There is no plane or patch (top or bottom) covers the trace segment.
: {$ x0 U* d, z: {4 |) lWARNING [Trace No Reference]: Trace6542::DRAM_A9 There is no plane or patch (top or bottom) covers the trace segment.
( F. y" }. d7 z3 P# M  _/ ?0 C9 z" bWARNING [Trace No Reference]: Trace6550::DRAM_A9 There is no plane or patch (top or bottom) covers the trace segment.
8 [+ g" o8 [5 ZWARNING [Trace No Reference]: Trace6558::DRAM_A7 There is no plane or patch (top or bottom) covers the trace segment.
9 A1 ?6 [: ]7 N$ d: v5 @WARNING [Trace No Reference]: Trace6559::DRAM_A7 There is no plane or patch (top or bottom) covers the trace segment.
' O  j" l- _: G; ^9 a& Z& [WARNING [Trace No Reference]: Trace6619::DRAM_A7 There is no plane or patch (top or bottom) covers the trace segment.
7 z5 L, s4 ~9 NWARNING [Trace No Reference]: Trace6620::DRAM_A7 There is no plane or patch (top or bottom) covers the trace segment.
% j8 T1 e1 O$ zWARNING [Trace No Reference]: Trace6674::DRAM_A7 There is no plane or patch (top or bottom) covers the trace segment.
; w. L! g8 t2 \& ?' @WARNING [Trace No Reference]: Trace6860::DRAM_D2 There is no plane or patch (top or bottom) covers the trace segment.: ]' M+ B% t) M, |$ g
WARNING [Trace No Reference]: Trace6863::DRAM_D2 There is no plane or patch (top or bottom) covers the trace segment.
. k$ o6 \* N5 ^0 w8 X8 ?" OWARNING [Trace No Reference]: Trace8640::DRAM_D3 There is no plane or patch (top or bottom) covers the trace segment.9 N, |* ]- `( {# K" ^" K9 r
WARNING [Trace No Reference]: Trace8643::DRAM_D3 There is no plane or patch (top or bottom) covers the trace segment.% z  N2 e% T0 T- s
WARNING [Trace No Reference]: Trace8646::DRAM_D1 There is no plane or patch (top or bottom) covers the trace segment.# E/ l/ j  y' g/ i7 Y5 G5 Y9 N
WARNING [Trace No Reference]: Trace8647::DRAM_D1 There is no plane or patch (top or bottom) covers the trace segment.
' @: _) o6 j. C( x6 _& `WARNING [Trace No Reference]: Trace8648::DRAM_D1 There is no plane or patch (top or bottom) covers the trace segment./ b/ z# E" f: ?
WARNING [Trace No Reference]: Trace8649::DRAM_D1 There is no plane or patch (top or bottom) covers the trace segment.
- X$ b' _4 K4 T0 g$ ZWARNING [Trace No Reference]: Trace8720::DRAM_D1 There is no plane or patch (top or bottom) covers the trace segment.
8 ~/ [* A8 ?' A" M9 _* h1 nWARNING [Trace No Reference]: Trace8724::DRAM_D5 There is no plane or patch (top or bottom) covers the trace segment.
' m% s# o1 O! B- K* KWARNING [Trace No Reference]: Trace8753::DRAM_D5 There is no plane or patch (top or bottom) covers the trace segment.
, j2 j0 M4 [8 AWARNING [Trace No Reference]: Trace9038::DRAM_D7 There is no plane or patch (top or bottom) covers the trace segment.
! |8 R0 H4 I. H9 X3 M" i( {; Y. |7 @WARNING [Trace No Reference]: Trace9039::DRAM_D7 There is no plane or patch (top or bottom) covers the trace segment.) e8 Y# G4 Y8 _% w3 D2 L, ?' X
WARNING [Trace No Reference]: Trace9040::DRAM_D7 There is no plane or patch (top or bottom) covers the trace segment.
- n: x7 {$ r; N( Z$ L; BWARNING [Trace No Reference]: Trace9041::DRAM_D7 There is no plane or patch (top or bottom) covers the trace segment.
& Y1 O' [1 O5 _, g$ E' L我的叠层如下:5 ?2 j# t# o" r0 s
$ Y1 o1 H9 `7 n  H9 ~: C
为什么会出现没有no plane or patch的提示呢
发表于 2013-11-13 15:58 | 只看该作者
应该是信号线上的node缺少参考面,可以定位某一个(例如Trace9041)信号线段,仔细分析一下看看该线的上下参考面是否完整,例如过孔反焊盘切割plane而造成的参考面不连续。
 楼主| 发表于 2013-11-13 16:01 | 只看该作者
qingdalj 发表于 2013-11-13 15:58
2 e9 ]$ H9 C; S- b. v' t' P6 Z4 m1 L3 d3 d应该是信号线上的node缺少参考面,可以定位某一个(例如Trace9041)信号线段,仔细分析一下看看该线的上下 ...
, w, _( q& @& N1 j7 C% X0 c9 l楼上理解正确,对应到问题查看了一上,下面的确是一块不完整的铜皮。
发表于 2013-11-13 16:05 | 只看该作者
用这套软件经常遇到各种问题,多多留心就好了
GMT+8, 2025-9-27 14:15 , Processed in 0.125000 second(s), 28 queries , Gzip On.
