查看: 2138|回复: 5
求助---有关SP339EER1-L的问题
发表于 2013-9-9 16:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 wunai 于 2013-9-9 17:15 编辑 9 Y* b6 {8 z5 g& `, Q: A& @( N' L) b
# \7 \/ v. ^; y: j
请问SP339EER1-L芯片的17号脚和12号脚有什么作用
SP339EER.pdf
1.05 MB, 下载次数: 29, 下载积分: 威望 -5
发表于 2013-9-10 11:17 | 只看该作者
請針對看不懂的部份提出。
! R1 v! K, c# J! Z3 n' `% o4 p' p8 p7 N0 Z
{:soso_e132:}
SP339E Pin 1 to Pin 20 Description.jpg (104.47 KB, 下载次数: 7)
发表于 2013-9-10 11:28 | 只看该作者
这个片子我用过。我是用来把uart转成RS422和RS232输出。
 楼主| 发表于 2013-9-10 13:30 | 只看该作者
bluskly 发表于 2013-9-10 11:28; G% L/ _1 ?4 _
3 f3 X0 f. x, a: Z! D3 w
我需要用这个芯片实现RS232,RS485,RS422的自适应选择,我想问问17号脚要拉高还是拉低
 楼主| 发表于 2013-9-10 14:02 | 只看该作者
超級狗 发表于 2013-9-10 11:17
" W3 c: i& f0 Y4 d) \請針對看不懂的部份提出。
3 Q9 J6 K1 c+ v! R7 z
发表于 2013-9-10 17:29 | 只看该作者
本帖最后由 超級狗 于 2013-9-10 17:38 编辑 9 P, d0 [6 K: b( G+ Y* ]7 h/ J
2 o. f7 K( ^4 w" q( r. k踢哀(TI)RS-422/RS-485 技術資料
0 }$ R' M* l6 ?! ^0 A( e6 r( M" W& a* a0 Z+ T
Selected RS-422 Electrical Specifications' W9 }$ m7 _: N$ y6 @+ S4 ?( n
The balanced-voltage digital interface is shown in Figure 1. The driver (or generator) is labeled D, the receiver is labeled R, and the termination impedance is ZT. The termination impedance should be equal to the characteristic impedance of the cable, Zo, and is used only once at the end of the cable. Because matching termination impedance to Zo often is difficult to achieve and is application dependent, typically, ±20% is sufficient. Also, up to nine additional receivers can be placed along the cable from points A and B to points A' and B', respectively. No restriction on maximum cable length is imposed by the RS-422 standard. Taking this into account, systems of up to 1 km are not uncommon, with signaling rates no higher than about 100 kbps. Speed and cable lengths work against each other. In other words, the longer the cable, the slower the signaling rate must be, while data can be transmitted faster on shorter cables. As a rule of thumb, the data signaling rate (in bps) multiplied by the cable length (in meters) should not exceed 108. For example, a system with a cable measuring 500 m should not transmit data at speeds$ x& x3 A# v! [) i7 y/ m
greater than 200 kbps (108/500).. j& M% V7 A/ N7 X8 g1 ?( i6 F
  b* O- s! d  q3 z9 u4 @解乎?8 j/ x- f4 Q1 O/ ?
  ?  ]0 p/ `' s. f
{:soso_e116:}
RS-422 Termination.jpg (47.04 KB, 下载次数: 2)
RS-485 Termination (Multi-Point).jpg (79.65 KB, 下载次数: 8)
GMT+8, 2025-9-20 16:09 , Processed in 0.125000 second(s), 27 queries , Gzip On.
