本帖最后由 wangeRFeng 于 2013-9-8 14:55 编辑 : z9 b; P4 h8 [5 c; I+ J
y: G2 y6 \ T+ r; G% NEE 7.9.5 Update6 发布了!
' p2 q* S/ E! c# e+ }6 L! k) T u7 H
# ]/ r4 o6 Y. q5 Y! Z7 I
- ~! ]: g- V; z/ g1 d- T- n
现在,EE 7.9.5 Update 6 可以通过Support Net 的以下链接下载:$ w* l9 Z8 z2 l1 o1 ]9 S
8 C, {( x, Q8 |- P3 Y. O9 H% Ahttp://supportnet.mentor.com/por ... 07-S114-G192-P10287. j* c L3 l ~
4 P3 E, [3 i/ G( i/ F5 d ( e: D1 @: J: J9 q/ }; I
3 f1 u( [7 N; R* d1 P7 \
% H" Z7 s4 h4 n7 [) W# V3 l0 m. N+ [
在这个补丁中修改了以下问题:) m3 ~6 z* y2 i: A
4 A4 m2 b6 r% q1 J* Rl DxDesigner
) Q& o! N _7 ~9 r t8 o: I& B# g5 ?# P3 F6 |2 t
dts0100942921 - Scout removing nets and components from the design even after updt 6 installed
! x( V7 ?2 G1 X! R
3 Q4 U2 n/ v4 _. Mdts0100960220 - Schematic Objects, Cross Reference texts and symbols disappear.5 g. o4 }& u% O; W; A3 m6 H, U2 H
8 i" C2 a& E$ r% [' ?5 i6 hdts0100724738 - Display points of bit number are different& Y7 @9 N1 |+ z# s' x& f& z3 O$ R& h# v
$ _0 E, L& S7 W1 q6 P/ W \0 h" zdts0100972244 - Scaling design elements in update 7 or greater causes elements to be placed off grid
+ w* s' h: ~) E" }% R# H. |
( y U) g( k: dl DMS Librarian
5 I( R8 Q- X' O0 s2 q O' B
- q* m1 l6 q% n5 a; s2 v7 cdts0100950654 - Librarian Flow Manager tool stops when another user submits a Part Request (using PRM, DMS Desktop or XML-Console)
2 N& n- u: \4 p) O6 z2 N
0 U; v% j( G- q: y$ B. T- d$ xdts0100963475 - DMSLibrarian does not reflect access rights on DMS characteristics level& a# ^' p t" N A
& p; R# @$ T9 R2 Q M+ P* a
l DMS
* u7 J$ E& l3 h7 U" R% s* _! m
: a+ }) Q; E- Q, g3 J) Vdts0100977435 - Provide configuration option to define if pads can be overwritten in DMS without warring. DMS 7.9.4 & 7.9.5 release only. For VX.1 dts0100710723 with different solution applies.
: c$ z/ k8 `6 m% Q- v3 ~% x) P7 Y0 p& |
l Expedition PCB8 ]* [% [- \+ F1 {+ a
+ f$ F2 y) j5 E" v* @7 ^, S
dts0100964513 - ODB++ via automation is missing contours (rout layer) when only "No Tool Contour" hole is used* U5 i8 W+ \+ G3 ~) K7 g
; W# {3 I2 b7 w d' l4 ldts0100965689 - ODB++ form does not load ODBSetup.ocf file correctly in EE7.9.4 Update 11
; c; O" U }) u! a3 J$ R! {1 p6 o! z0 q* J/ R: A! I* ?4 z p2 E8 E
dts0100974660 - Automation for Bus Paths (Access to Bus Paths)/ R3 p* S1 W( y: Z3 e
& \, r# E% O6 i$ y' Q: S- |
l EDMD Collaborator9 d8 R1 F4 G8 L6 h# {
8 N% ?! l3 H2 D0 V4 k$ Zdts0100947514 - EDMD 3.0 release required
/ r3 p' n( r5 z5 c9 D) i- r, U3 B! U
l Installation
: M; A) y4 p3 R
/ x4 ?( W- @, w: f3 Fdts0100945337 - The patch check utility is complaining of unsupported kernel version- | r, a, l0 r% T( _1 r
, `+ [" K0 m! d: W4 xl EDX9 N# ~" N6 E* \$ V {, ^2 F
C. X. P" u1 x
dts0100926312- Exporting big number of components fails
; K6 T6 z( M8 }% c
6 r9 v& X. o: y# i8 N
' D! q2 Y" y! m& ]- m
1 n0 W! V1 X( u. K
- `: u# v( J3 G0 E4 R- D8 DEE7.9.4 Update 17发布了!' p- @- s9 b$ ^( I; D" L/ `" h
. U2 T( d( e0 Q# P8 C现在,EE7.9.4 Update 17可以通过Suppornet的以下链接下载了!
5 x$ d2 V# `0 I& \: Y% ?
* M2 P% A: P: Mhttp://supportnet.mentor.com/por ... 07-S114-G192-P10287% h5 a7 U+ B3 {9 F
\4 S: q5 I# o" E7 V$ U4 F* H% m 2 p- z9 d# T: E% S+ L
在这个补丁中修改了以下问题:& T" l% d% n; F* l4 B2 ^0 w) H
l DxDesigner; O) q3 n' v6 l% X& e0 R6 M U
. ]+ O7 j3 I+ k. r+ u. t( F) t6 B% b
0 g: a& Y" r; w/ H& Q5 J
: \ }6 _8 f& U+ r3 b; C; Rdts0100960220 - Schematic Objects, Cross Reference texts and symbols disappear.
5 j' L- u6 @9 G. j; z8 Y+ P& [# p# l4 W
$ ~# J S; X$ \6 B0 Q7 ]% ]8 h7 a! l
6 M2 O- H) P. r' ^7 [6 Gdts0100972244 - Scaling design elements in update 7 or greater causes elements to be placed off grid6 [7 o* H; q. R
K D5 \+ u& b: o+ N! w" I* \ W/ ^! u9 J' P! L
, I* G' a7 ^9 ]2 ]" A) ^* c/ f; e2 bl DMS Librarian% f- D/ T0 {2 R2 a. Y% k
3 g5 ~" Q5 x; F/ A3 pdts0100950654 - Librarian Flow Manager tool stops when another user submits a Part Request (using PRM, DMS Desktop or XML-Console)
0 ^, [6 X5 c' i$ b0 K$ ~
) T: J! l/ a1 M- g, ndts0100963475 - DMSLibrarian does not reflect access rights on DMS characteristics level( z. Z3 x; X, @3 d' h% i
' W- R F. d0 A3 R+ _& n) H) N& m
$ l! O3 D9 j, l1 X" \6 F* D0 r; H5 Y* @0 m3 t' _
l DMS6 Y. v$ n$ S1 T, _; K
6 d- ^8 W! F2 g# Gdts0100977435 - Provide configuration option to define if pads can be overwritten in DMS without warring. DMS 7.9.4 & 7.9.5 release only. For VX.1 dts0100710723 with different solution applies.# Y# x. z) y) B$ Y" E- q# d; T
2 i: h# S6 F$ s4 X- U$ l
& p, J2 [/ m# |; J, K8 _; a" X2 o1 T% M
l Expedition PCB9 d) Y3 o" b o$ y
7 |6 }) t* L$ X0 [/ }dts0100964513 - ODB++ via automation is missing contours (rout layer) when only "No Tool Contour" hole is used
7 N0 f: W9 u4 L4 x1 p6 m3 t9 r
' [) t1 L4 @+ edts0100965689 - ODB++ form does not load ODBSetup.ocf file correctly in EE7.9.4 Update 11# q, \ X: j' m
, f& N3 O, R8 \* m/ `& y G0 _5 C
dts0100974660 - Automation for Bus Paths (Access to Bus Paths)$ Q8 O( G: R4 G9 y: Z. M
1 I y5 w2 u' z6 B# u7 [
6 E7 A+ R( y$ S# W4 f$ P$ ?% W1 M
4 R/ H1 d) H) T! z* }
l EDMD Collaborator! f/ J/ c9 O- Y: t
0 D( j3 Y4 U2 g s& a$ s: U7 ldts0100947514 - EDMD 3.0 release required
! u" p. e- N5 C' a% t1 T5 J% I: p0 G; V8 B9 u: H: k& [
, s/ n w/ m# a" [, [5 k; Q+ ~& ~' l5 X# a
l Installation# Y, `% R- T: h; F, F+ g6 g+ M) x7 }# K
q% K% a3 I. W/ X" Q: wdts0100945337 - The patch check utility is complaining of unsupported kernel version6 _6 |( X% s0 d. i& ]( B9 E
( H: g) W% Y+ r; @0 _6 }/ ~9 s% J
( L3 w/ k i6 ]+ p
% p/ k5 n( V) M5 L( D0 U% u; N3 K0 ^: G9 J/ h9 h
