本帖最后由 超級狗 于 2013-8-29 00:08 编辑 7 Y$ G3 ~1 U, T/ _1 `+ t
/ P) ~7 J* [+ A, H% X( w
3 d. o, C7 l |& C7 d
呵!呵!想考倒我?以為我不知道嗎?
# K# _: W% B2 }9 s6 y0 y' h! {
.............我真的不知道!4 ^/ {) J* y+ Q
- D% g* B$ \- t& `( f6 d
{:soso_e127:}
8 |8 i' G# `) _( A5 I: E+ W9 l1 n) i; p9 L- E- ^
還好有 50GB 的過期狗糧倉庫。
3 a. @* r) B$ L9 \% c' A8 J3 F% ? v- D6 P; G, A
{:soso_e110:} # ]( H) E2 l& t- d$ d
6 R! W2 i8 h0 n9 w& ?6 x5 b
Negative Power Supply to Increase Threshold Voltage: The use of a negative gate voltage to safely turn-off and block the IGBT is typically used in an application with nominal current above 100 A. Due to cost, negative gate voltage is often not used in an IGBT application below 100 A. Figure 3 shows a typical circuit using a negative supply voltage.
! [# u0 E8 z( a1 N! ^/ K* R0 E( n/ o2 _' ~8 a, }4 G
{:soso_e166:}
; C) q# j& |5 I$ w; G/ M0 F% ~6 l7 j; [8 g# B; r h- y0 e, P
