查看: 1485|回复: 4
分享一个自己写的环形链表(环形缓冲区)的代码
发表于 2013-8-22 09:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
由于本人最近用到,所以研究了一下环形链表,之间经高人指导,搞定了这个链表,现在分享给大家# {9 }  O8 @. W
. c- }$ M7 m, `" S$ T2 u$ P
高手发表下意见吧,用了三个指针0 H! s* L+ ~  O( V! F+ s
# g$ S4 _( Q: T# @
/ I. @# V; n/ O2 W9 r: {! D* V- q
; L: N! r3 g: {- E. b1 L5 d5 N2 f) W  E! \% h2 U9 N% `
% E' z9 X  o" C8 O2 l* q#define MAX_UART_FIFO_SIZE  500% ~) A  h7 p* {4 G
#define ONE_ITEM_DATA_SIZE  29
; X+ F: E, C# @#define TURE   1
8 `- ]2 b7 k8 R#define FALSE  0
8 f8 j3 r+ v9 }7 a
! F% \' m% G+ Q: q1 R: otypedef struct9 C7 {7 P/ \& o" T5 f5 C' u
2 q9 L& c# ?2 t/ h4 |5 d    UINT8  Rxbuf[MAX_UART_FIFO_SIZE];
# L( w% V  s. n! q8 g    UINT8  *head;
& M) d3 l9 p( [    UINT8  *head_tail;
: v9 ~$ v! `# O    UINT8  *tail;
+ j0 M( R- d$ U* u% q/ f4 s}UART_BUF_TEST;
# a2 V# A, l2 n* P# h2 |# t5 t0 M) c1 P! _& h
UART_BUF_TEST Circular_FIFO = {0};6 v; ^+ v2 _6 {+ I8 @4 O
void Init_My_uart_Queue(void)# j( U+ B! e0 h* I# v3 o7 V9 M" n- a
{; R) w$ r4 \5 W- U. u
    Circular_FIFO.head      = Circular_FIFO.Rxbuf;
  _4 j; E( q" \' B    Circular_FIFO.head_tail = Circular_FIFO.Rxbuf;
  J; B$ e3 w! Z/ N, U    Circular_FIFO.tail      = Circular_FIFO.Rxbuf;" \$ v! ], k0 G
# Z1 u3 |- P. y% J1 T% Y- e2 B& P9 a9 u$ J4 v* q
8 I4 i4 e7 ?+ ~7 T) R5 p* R. F! [% o) M5 F9 T
/******************************************************************/, C( b/ {+ s  X5 e
void Edge(void)- t* q8 p4 g! B
{6 K# O" q7 F9 Z; F9 e7 l9 d
/*边界判断*/" j* b3 Y. Y. c
    if(Circular_FIFO.head >= (Circular_FIFO.Rxbuf+MAX_UART_FIFO_SIZE))                 //head >= tail+len-12 |8 t2 e  d# r$ Y' i$ S
    {         0 G7 ]  R& M* R; F; y" K+ X
           Circular_FIFO.head = Circular_FIFO.Rxbuf;                                   //如果到达唤醒缓冲区的尾部,将绕回到头部。
9 d) Y* i; E9 X. O  }* F4 N# ^, F; s5 M3 f3 u( \
/*等价于tail -= MAX_UART_FIFO_SIZE-ONE_ITEM_DATA_SIZE*/
/ s7 V* c  ~! w) S9 _) P        if(Circular_FIFO.tail >= (Circular_FIFO.Rxbuf+MAX_UART_FIFO_SIZE))- b1 ^  Q$ M* W3 r; z" d- Q
        {  5 R; ?0 f2 z/ Q* U' h
            Circular_FIFO.tail -= MAX_UART_FIFO_SIZE;  C) g* U# ?! d" E. W; Q
$ b  k/ g$ a7 T}
* x7 d6 T+ _: @1 @$ L  c) H2 P" a! |7 {' E7 K) Y7 m: B: ]
UINT8 test_recive(void)
( `$ y: i& X/ m+ C/ n* D9 V% }{
$ K& V7 W! H2 t& J0 w! t4 m, x    UINT8 UART_sta;
! x" j9 y% W! J, b/*head跑在前面*/
( K4 L, |7 P/ k9 t4 i% @; b6 g    if(Circular_FIFO.tail <= Circular_FIFO.head)" `! t3 [9 T4 L% b1 I( X
    {                ' Z/ d+ R' m# m9 O2 B& Z+ S3 V* n
        if(Circular_FIFO.head >= (Circular_FIFO.tail+ONE_ITEM_DATA_SIZE))   * D; H) ~" l6 Z+ n4 g
0 Q& Q  H7 j- e& b. _' l            Circular_FIFO.tail += ONE_ITEM_DATA_SIZE;           //尾指针后移(len) 打印标识
- d, Z- E9 s( y/ r$ P       UART_sta = TURE;% ^. B7 Q# Z" j) q6 O. @6 k
: d) y1 C; O2 W; M: F+ d    }
5 j; p7 `1 H6 w2 z% L9 a7 ~8 t/*head跑过N圈进入N+1圈,tail还在N圈*/+ M8 m4 |7 w0 W
    else if((Circular_FIFO.tail - Circular_FIFO.head) <= (MAX_UART_FIFO_SIZE-ONE_ITEM_DATA_SIZE))
, ?: ]1 j8 C- b    {            # D1 q  l$ r  C2 e
. Q6 p! p# j$ B3 a, W, E7 s7 F/ U; h' h        UART_sta = TURE;
! J6 A6 h5 r" I3 E4 T    }
0 I6 H! G, E7 I6 K- U* w7 b    else UART_sta = FALSE;
4 A4 y& G: I4 P1 V    return UART_sta;
) ?; D  W( p& i, y) n- S( d: Y' H# d}
9 m2 o+ _  E6 J9 W( f1 \* A4 D7 M: s8 {8 ~3 ?" L/ l  g
void UART_send(void)& _( z* L; I+ q9 I8 x
{- y  x1 R  w# B& y
    if(Circular_FIFO.head_tail != Circular_FIFO.tail)         ///这种判断发送的方法,酱油提醒说主机发送数据很大时会出错; x7 C+ J" w: k
  {: L0 I8 v6 P: j7 I1 [
  //启动发送
8 p5 q7 {- h, g, x; _8 n$ A) D                xU0_THR = *Circular_FIFO.head_tail++;
, }4 g  o  d1 `+ _6 Y                if(*(Circular_FIFO.head_tail-1) == '\0')2 l* r/ U( s& J5 D4 G4 Y
  [$ {# O7 r1 C7 l# V                        xU0_THR = '\n';& _/ E: @) F- \: e6 Z, x* R. x. S$ _
                        xU0_THR = '\r';
0 j: W6 u& v* K- g, l% p7 P                }
* `  ~4 _" [6 J5 e' @        }0 U7 X0 y0 i. k6 L6 V
        if(Circular_FIFO.head_tail >= (Circular_FIFO.Rxbuf+MAX_UART_FIFO_SIZE))          //注意tail刚好加至0的情况会死循环& s/ ~  V$ A0 ^% A4 U
        {  ' r/ h2 g4 o, [
                Circular_FIFO.head_tail = Circular_FIFO.Rxbuf;   //到了末尾,数据还未读完,从开始继续读取$ e3 N9 I' H1 ~. f
        }* a- \0 o2 d7 t. i( B
$ j8 K0 f% O3 D8 x5 ]% `: F* L8 C0 C/******************************************************************/
# B7 @- T+ E# uvoid main()9 T' x! m9 `6 F( Z' O
, S  p1 B1 Y) `    UINT8        KeyIn;
! F* R" U' \% Z" @4 r1 w6 _        init_system();( [3 D8 C0 B# u5 R( r. z
/****************************************************/  I- Z1 }( v( M4 A% i
    Init_My_uart_Queue();
' A# M& m1 M( r9 G) C4 q        while(1)
; j3 D* D" g$ v' e( o- L. _$ ^        {$ Q% U$ `# d2 P8 x
                ZSYS_WDT_SET(10000);
/ i9 ~: h+ x9 `% s        if(ZSYS_UART1_GET(&KeyIn))
* @; X4 k" ^! ]& I: }* y; R- n. g0 C        {
: M( u$ K0 V4 T2 O( K8 Z7 s                        *Circular_FIFO.head++ = KeyIn;" |! r1 v: U! t# J# l
3 L! v. n; I3 i5 B: I: |                if(test_recive())                        //检测接收字节数2 i* Y4 Q3 C0 y  N) ]# u
# L7 N" c0 h) v) d" `% s. E: W* z                        Edge();                                //检测边界- B2 M  b: t+ N4 P& F1 Y& M/ B
                        UART_send();                //启动发送% s# D$ _* O" v/ ]
                }, k( ?: J% p0 y) k1 g+ V
        }, X6 ]3 R0 t- J0 h0 J7 ?
环形缓冲最终.zip
1.14 KB, 阅读权限: 9, 下载次数: 12, 下载积分: 威望 -5
 楼主| 发表于 2013-8-25 03:43 来自手机 | 只看该作者
没人讨论吗?
发表于 2013-11-15 01:42 | 只看该作者
static void Serial0(void)interrupt 4 using 1
1 j( O. `! U5 Y6 p: H1 U{
% m6 Q) n8 s$ o3 J; T, a, E' K    unsigned char temp,head;4 }% P  ]# j; W1 M, a; N
% s4 ^1 y9 K) Y+ P) {. i3 G    if(_testbit_(RI))9 Y% {1 Q: a$ S+ Y
    {' P: W' [. \! j+ e, h
        temp = SBUF;
3 W+ N4 Y* q1 f, x6 }8 M0 r        head = RBUF_NEXT_PT(uart.rx.head,sizeof(uart_rx_buf));
* x+ z4 s8 i$ b3 R$ \        if(head != uart.rx.tail)
3 X1 `; w" W4 p8 j        {
+ b) O& d* P4 B6 x" T            uart_rx_buf[uart.rx.head] = temp;! ~$ V5 _+ |2 A/ A
            uart.rx.head = head;
2 N2 ]( L8 a8 V2 o$ I        }else
) S& U1 g2 ~1 U        {
; Q& Q: G! h; ]' {' {            uart.rx.error = 1;) w) q9 ~2 l5 }" ^: w( @6 h
        }7 X$ r" g! |0 Z/ O( {* p
9 @- u5 B7 l$ C    if(_testbit_(TI))! X6 r2 C: h; W0 K! M, r" h
; P$ w6 z; J% r/ {9 S4 }3 D0 J        if(uart.tx.head == uart.tx.tail)& I) e+ B! `" r3 p; {# z  J* h
        {5 _! j: t" a/ U: A0 Q/ I3 i9 o) c8 a
            uart.tx.busy = 0;/ U' t; L  p; S
        }else9 a  a5 z8 M  I  q0 L# t
        {2 f5 I$ f1 W9 W5 \5 W6 f) ~& G
            SBUF = uart_tx_buf[uart.tx.tail];
. k% M. }- a5 B: O  o            uart.tx.tail = RBUF_NEXT_PT(uart.tx.tail,sizeof(uart_tx_buf));
9 M; q* O+ j# P* f! R7 N. \. C        }3 x! x( B) V: c) F& D$ n, L6 N
 楼主| 发表于 2013-11-15 09:25 | 只看该作者
天才小痴 发表于 2013-11-15 01:42: s- k! ], D$ H9 x5 u! E
" k4 s/ d$ D5 w4 H" z{
+ @  t5 h) ^; T# P, u8 p5 [9 J& C$ U    unsigned char temp,head;
! b* E3 n! X3 ?- K' C
百度:- K8 q0 g; F& q' X
_testbit_产生一个JBC 指令,该函数测试一个位,当置位时返回1,否则返回0。如果该位置为1,则将该位复位为0。8051 的JBC 指令即用作此目的。_testbit_只能用于可直接寻址的位;在表达式中使用是不允许的。
, s% G$ V% u4 c5 b这个函数我之前没用过,主要是不清楚他的用途范围,我看你这么用的话,应该是检测串口有无字符接收的意思吧,接收则为1
GMT+8, 2025-9-10 21:06 , Processed in 0.156250 second(s), 26 queries , Gzip On.
