cadence Design Systems, Inc. netrev 16.2 Tue Aug 13 10:30:45 2013
% s5 R( R* D, ?. `# C(C) Copyright 2002 Cadence Design Systems, Inc.
+ r# l: D# k) d. |( E3 f* ~- s% F/ `$ s
------ Directives ------
4 k+ { \5 j6 U: U! Q# P
, a8 P) J8 Z- h: x' T6 R2 y, H+ g; M1 TRIPUP_ETCH FALSE;
; P& R l, g" \( ~3 l3 QRIPUP_SYMBOLS ALWAYS;
& w% g ^9 g6 f- p5 f) VMissing symbol has error FALSE;8 ~ L& E: r0 `/ t
SCHEMATIC_DIRECTORY 'F:/zgc/DOREAL_DECODER V1.0--20130812/allegro';
6 E# R% u! ]$ Q% S J* xBOARD_DIRECTORY '';
- V" {4 I0 t( {( d! wOLD_BOARD_NAME 'F:/zgc/DOREAL_DECODER V1.0--20130812/DOREAL_DECODER V1.0--2013081201.brd';2 {) o, f- ]: N, \6 r
NEW_BOARD_NAME 'F:/zgc/DOREAL_DECODER V1.0--20130812/DOREAL_DECODER V1.0--2013081201.brd';3 l8 L! I( s: S8 f7 a
4 w. z, d; `7 b6 XCmdLine: netrev -$ -i F:/zgc/DOREAL_DECODER V1.0--20130812/allegro -y 1 -z F:/zgc/DOREAL_DECODER V1.0--20130812/#Taaaaaa04968.tmp! p, F% A3 K+ Z, ^. g
5 ~( z( a" h1 N: z9 P2 V
------ Preparing to read pst files ------/ F# } T5 @; b! ? W. P1 u
3 r* |' J, o9 p0 C3 O4 v
Starting to read F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstchip.dat
4 e8 t& W! n. K0 Z" o8 W( { Finished reading F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstchip.dat (00:00:00.10)$ L8 S& i$ Y- d+ \, _
Starting to read F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstxprt.dat
. u2 K/ ]$ H8 |, h* `$ ^8 Q Finished reading F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstxprt.dat (00:00:00.03)0 m: N* [( V; N; c' w0 y, B
Starting to read F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstxnet.dat + c/ ]5 A% n% F
Finished reading F:/zgc/DOREAL_DECODER V1.0--20130812/allegro/pstxnet.dat (00:00:00.01)- R) \3 P, @3 |8 e
/ [' b6 A% @* \4 a
------ Oversights/Warnings/Errors ------
9 h$ R) _8 O2 B/ \. y, `# J4 C. d3 d% f- [7 y0 y
# I6 Z9 q i. Y- m7 p/ K+ ^& e$ b
#1 ERROR(SPMHNI-176): Device library error detected.
1 @% s/ e$ r- z/ d" L7 n& @" k7 m4 Z% n8 `9 ?" U
ERROR(SPMHUT-115): Pin 'DDR_COMP' for function 'TYPE20' on device 'BCM7581_15X15_BOS_P8MM_35_BGA26' has a swap/pinuse inconsistency.
* O7 U1 |' A+ _5 Q8 R, T! V% J$ t5 \: x
#2 ERROR(SPMHNI-176): Device library error detected.
$ x; c" M: G) E9 }8 t0 `/ M7 B; Z6 @$ T! K& J# O2 @
ERROR(SPMHUT-115): Pin 'DDR_VREF' for function 'TYPE20' on device 'BCM7581_15X15_BOS_P8MM_35_BGA26' has a swap/pinuse inconsistency.+ I4 G; s9 R; G2 D5 _' P% `
! O1 e6 d: R$ I' M5 s1 W
ERROR(SPMHNI-170): Device 'BCM7581_15X15_BOS_P8MM_35_BGA26' has library errors. Unable to transfer to Allegro.; i5 A# E& u, E! B0 {# M$ \; V
! `" P8 T9 y7 ~; J1 Z
------ Summary Statistics ------& Z0 ~9 H4 G, d6 q+ H
3 [7 g' j Z4 k' {; s! a% K) N
, i5 S% g" h: k0 f& z) o4 D; X5 Y* T+ C5 `#3 Run stopped because errors were detected+ G# K G# A( T
9 `' D% u8 i' o; c$ t% P' ?/ ^2 g8 o8 H
netrev run on Aug 13 10:30:45 2013
1 X% `" B# q8 } DESIGN NAME : 'DOREAL_DECV100_20130812A'- I+ Z1 B& X2 P( s6 |/ q, g
PACKAGING ON Sep 28 2008 21:55:151 T2 ?! J- U p
4 |( i, y3 |# D5 z3 c9 `8 p1 X; y
COMPILE 'logic'; w6 g& ?* E& e+ x$ [! e0 c- R6 M6 v
CHECK_PIN_NAMES OFF' m1 A) ?4 J5 `/ a: Y
CROSS_REFERENCE OFF
8 y3 x/ y+ |. ]/ J2 F& \" u FEEDBACK OFF7 Q5 |! V8 C8 q! p
INCREMENTAL OFF
: y6 f ^( y# @' h5 N, D INTERFACE_TYPE PHYSICAL) P3 J! f( z U4 Q9 R0 y- x
MAX_ERRORS 5006 ?! w0 e, t& s' h! n
MERGE_MINIMUM 5
! Q- p& J: \5 ]3 \) ? NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|', L7 e" e7 ?/ [0 u! }
NET_NAME_LENGTH 246 h3 B6 O2 |. I9 l, M
OVERSIGHTS ON* ]. R' n% ?) x. B( V
REPLACE_CHECK OFF
* T+ t) N% ^# K) u0 K5 F. |/ Q3 l O6 {- e SINGLE_NODE_NETS ON+ x' Y* S" @2 b+ o( d
SPLIT_MINIMUM 0( f5 l9 { p/ k& D
SUPPRESS 20
' U* u$ q1 ]- H# r WARNINGS ON4 `6 V1 X$ `# \2 F/ I
6 r/ C' f- {* A+ v' w 3 errors detected
7 G6 }! k- k; C No oversight detected
$ J! d8 X7 j% ~ No warning detected' U0 H g# k4 ~) i( w
* p- } `6 c1 p0 G! J: z4 @1 Icpu time 0:04:11
/ I* t5 ?; P' F ]elapsed time 0:00:01
: N( C% x9 }. z
$ B5 u3 q: f. \3 r$ w7 J a* l |
