查看: 2258|回复: 2
求助:原理图生成网络表的问题
发表于 2008-8-11 14:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
小弟学cadence不久,在用capture CIS绘制了个简单的原理图,就几个电容和电阻,给它们连上了线,
$ n! x4 [6 s& {0 l2 w) S) ?生成网络表时软件提示生成失败,去查看Session Log时,发现所有的错误都是一样的:) g8 ^4 d' f% ~4 c, H
#1 Error   [ALG0031] Pin number missing from Pin "1" of Package R , R14: SCHEMATIC1, PAGE1 (5.00, 2.40). All pins should be numbered.
+ v/ F* _. p) Y0 x' J9 r+ d& p#2 Error   [ALG0031] Pin number missing from Pin "2" of Package R , R14: SCHEMATIC1, PAGE1 (5.00, 2.40). All pins should be numbered.
' S( g6 p3 u. e( @#3 Error   [ALG0031] Pin number missing from Pin "1" of Package C , C2: SCHEMATIC1, PAGE1 (3.20, 2.10). All pins should be numbered.
- v9 M0 V/ I% T* c  E7 o5 D0 f#4 Error   [ALG0031] Pin number missing from Pin "2" of Package C , C2: SCHEMATIC1, PAGE1 (3.20, 2.10). All pins should be numbered.
2 V7 F7 W: ^* `& z#5 Error   [ALG0031] Pin number missing from Pin "1" of Package R , R15: SCHEMATIC1, PAGE1 (5.50, 2.40). All pins should be numbered.& A' s( q/ M1 `4 L9 O
#6 Error   [ALG0031] Pin number missing from Pin "2" of Package R , R15: SCHEMATIC1, PAGE1 (5.50, 2.40). All pins should be numbered.8 W* m- K9 q* v7 e' }2 D
#7 Error   [ALG0031] Pin number missing from Pin "1" of Package R , R1: SCHEMATIC1, PAGE1 (2.90, 1.80). All pins should be numbered.+ w+ u9 S- t0 [. |! f
请大哥们指点一下,这是什么原因啊,小弟在此谢谢了.
发表于 2008-8-11 15:11 | 只看该作者
原帖由 jeremy 于 2008-8-11 14:58 发表 5 N+ D- i( z) Y/ C  n: B; M
小弟学CADENCE不久,在用capture CIS绘制了个简单的原理图,就几个电容和电阻,给它们连上了线,
3 \8 E. v! O2 w3 w! H4 _生成网络表时软件提示生成失败,去查看Session Log时,发现所有的错误都是一样的:$ O' X: K' x7 M$ i/ V6 ~
#1 Error   [ALG0031] Pin number miss ...
! Y& N1 f" Z! j) `! y9 n8 B
所有的引脚除了pin name 还需要pin number
 楼主| 发表于 2008-8-11 16:51 | 只看该作者
还以为从软件自带的库里面调用是没问题的,没想到也出问题了.
6 i! e" p, D% J' ?* D我在库里给器件加上了pin number 现在可以了" N, E4 y- z3 B1 g
谢谢版主
GMT+8, 2025-8-23 13:03 , Processed in 0.109375 second(s), 24 queries , Gzip On.
