请求个人高手,如何使用pads 9.3 的make like reuse 功能?我在创建reuse 的时候为什么老是报错,所有的器件都不匹配!* v- e( `. Q. i& `4 {( `
5 p. m% T8 V8 v {最好给出详细步骤!下面是我截取的 错误信息!5 W* j0 J2 |, O1 t5 ?+ a4 M9 }# m
, m+ v+ N" ^! P0 [: S. Z
3 r4 Z! f8 i5 d; R6 T. J Make Like Reuse Report -- Sat Jul 13 12:48:15 2013# j2 M! z% J0 N. i, s' d
" b& S. I! \1 Z$ e7 @=============================================================. [5 S+ f% L5 D; g5 G$ _" X
Design File : im6ddr3-2013-07131225DRC.pcb
) B- @: U$ D. g9 Q# [1 e Reuse File : & b W$ w$ W" Y) Y/ Q- p
Reuse Date : Sat Jul 13 12:37:25 2013
, p: y) p; R- l$ R3 Y: h: h: K8 D; f Reuse Type : ddr3: C' K# J8 n- A
Reuse Name : DDR3_1/ j) v$ h3 T! o" a5 c
2 R n0 \+ @+ D' ]8 R# }
=============== Summary ===================================, T4 Z p) n6 V+ o
( I# a9 ~5 v% x3 k Operation Mode : Make new reuse from ALL available components
; |+ w( c/ S/ G! b* Y( l : Use reuse definition from the design
$ {, k' h) C i% ~7 V, H$ S* |' Y6 W
Matching Mode : Part Types MUST match
{5 l; b& r5 V: Y : Decal Types MUST match
$ g. e7 ~1 M- R- p9 L* s; V' { ] : Value/Tol. MUST match! `4 m" j1 b# E5 z9 e% \
! v9 c; Q% F4 {. W2 _& W4 t6 {- N Results: MAKE LIKE REUSE FAILED ( unmatched components: 84 of 84, unmatched nets: 130 of 130 )
, d6 Y# v8 F8 q* x. k) P
( _5 v* g$ ?! W Reason for failure: Shortage of available components in the design ( need extra 9 components )
' c8 k/ w+ l, c) J (See 'Component Matching Types' section for details.)
i+ j: c; J0 o- d5 X! \, s- a
, T3 ^" K" m) N( G$ Z& K=============== Reuse Statistics =========================
( b- d+ T7 Y7 ^7 a. t& q8 d. }. b& ?# D
Components : 84; Z$ M: c: p8 t) n2 p
Component Matching Types : 104 d6 f0 Y1 r4 Y2 Q
Nets : 130
/ ~& y0 r. H, U0 C
. ^3 z9 U- V3 D=============== Design Statistics =========================- [6 j$ P' O6 R4 |- ^5 Y0 v
9 U- Y5 p) v+ A$ [ Components : 795' c; k. S: O) e# i
Available Components : 287 ( available for making like reuse ). _# ]' Q% M: P8 N: w. K3 e& n
Nets : 566
8 T/ D z- x+ V Available Nets : 236 ( available for making like reuse )6 }% r* x7 \4 o2 K! G! \( r/ y
5 c1 X5 r7 ?# e& E+ p H- a$ b
=============== Component Matching Types [ 10 ] ============! m& k( c6 ~; E& P6 V
+ @0 k# |' f" ]Type Id Required Available Part Type Decal Value Tolerance
2 X9 L2 W& e- S) C0 ?0 M9 Z in Reuse in Design
! t# y3 z# V" G7 y, Z
/ n. i# ]5 M2 \; ]* G cmt01 1 48 C100N-0402-16-X5R-10-M CAP0402 '100nF' '' $ m3 U1 X3 B' v, c& s# p" H
cmt02 57 66 C220N-0402-10-X5R-10-M CAP0402 '220nF' ''
3 O" g A' K2 S4 Y4 e* N' F cmt03 4 80 R0-0402-5-Y RES0402 '0R' '' 5 C" J9 }& p3 P# }8 j% W0 v
cmt04 5 1 *** R240R-0402-1-Y RES0402 '240R 1%' ''
9 n/ i7 O: W" N cmt05 4 0 *** 4G_DDR3_SDRAM_128MX16_96P FBGA96_0P8_14X10 'MT41K128M16JT-125:K' ''
2 y# F; I% ?( C+ a1 v( O& ]- n cmt06 1 0 *** MCIMX6U6AVM08AB BGA624_0P8_21X21 'i.MX 6DualLite_MCIMX6U5DVM10AB' ''
1 m Z* O* c2 }1 q( e( d: ?- a! y4 D cmt07 1 2 R200R-0402-1-Y RES0402 '200R 1%' ''
6 E5 T( y+ a* R cmt08 1 11 C1U-0402-10-X5R-10-M CAP0402 '1uF' '' 4 \3 m. e" Y; |- b6 s& u- v. \
cmt09 2 49 R10K-0402-5-Y RES0402 '10K' '' & L, b {: p" O/ ], R1 M8 p
cmt10 8 30 C22U-0805-6.3-X5R-10-M CAP0805 '22uF' '' - R3 a/ u- r; b2 e
' Z Y1 `7 {3 Y/ L. c! V4 w8 D O1 d4 g======== Reuse Components [ 84 ] ( ordered by RefDes ) =====
0 {* m8 U( G; y/ @9 A# K5 s, ]- J4 E9 U8 ^- m& |: C6 h
#NN. RefDes Part Type Decal Value Tolerance Subcircuit& j# u4 d* {9 S! x8 e) t6 ]
& ]! t3 G, [1 ^9 q t# ~: @5 ]: R 1. C0228 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1+ |7 Q1 `$ K2 E
2. C0229 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1 e, d( ~1 ? l) T
3. C0230 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 17 N7 l7 T2 k( b- p
4. C0231 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 19 c* w0 Y( I/ p
5. C0232 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1 v0 z, v, k' V
6. C0233 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
; ~: f3 |9 X2 y4 O% R+ [ 7. C0234 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 13 M: A( H6 U+ A, O' L
8. C0235 C22U-0805-6.3-X5R-10-M CAP0805 '22uF' '' 1+ X- P; p; O9 `1 \# e
9. C0236 C22U-0805-6.3-X5R-10-M CAP0805 '22uF' '' 15 v0 C/ w m3 E4 E5 m
10. C0237 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 15 X) x. X2 I. v2 h/ ]* W! X
11. C0238 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
2 w/ ^3 b/ z8 C5 y" q* j" F0 M 12. C0239 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 10 V% {$ _3 U( N0 V- J: D
13. C0240 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
( e1 M: X6 h* P. Q, N. s/ j( G7 @ 14. C0400 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
; N; k5 O7 p4 s- B( \, o 15. C0401 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
! S, `# O3 d% ]( | 16. C0402 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
/ b* D, P9 [6 o4 \2 g5 ]- q7 V% k 17. C0403 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1/ ]! R( e% ]/ H2 H8 N$ Y
18. C0404 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
8 F0 p4 y7 k$ ?8 q4 t! W: h: b) z4 q 19. C0405 C22U-0805-6.3-X5R-10-M CAP0805 '22uF' '' 1; Y* I, g$ A% J/ N, T" T! A
20. C0406 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
' L9 j* c" I8 i4 q7 a0 K 21. C0407 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 15 w6 Q" |6 j& g9 v; r+ f1 W
22. C0408 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
! e" s7 i. d4 V+ a$ y 23. C0409 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
; x( K" U" E: d$ a! C 24. C0410 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 12 H8 H; M2 B. J$ k1 P& f
25. C0411 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
- ^" g1 I) R% b. R a* {8 x" G/ u# {8 a 26. C0412 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1& F6 l3 D+ }; P0 g
27. C0413 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
; u4 o2 I. @# z" N: X+ b 28. C0414 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 19 \7 i7 }: w. f. Q0 v
29. C0415 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 16 l2 P) f3 W* N: ~, `9 _' p
30. C0416 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1& o: C+ n: l( a% N: t8 \
31. C0417 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1* S }6 j' b( t* M# k5 [( E
32. C0418 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
z! T9 p8 M$ m7 A$ y8 S0 ` 33. C0419 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1: j' m2 q3 g/ U
34. C0420 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1$ g; \) I0 i7 d g
35. C0421 C22U-0805-6.3-X5R-10-M CAP0805 '22uF' '' 1; T4 O& f5 h7 f
36. C0422 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1$ B% w; A) M7 H6 A
37. C0423 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1, u9 G- @: Q! y2 f
38. C0424 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 13 y. H9 c! V4 p% F' J
39. C0425 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
+ d$ ~. x- c/ D* o 40. C0426 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
( y4 p( i. n' g- {- n, [. x 41. C0427 C22U-0805-6.3-X5R-10-M CAP0805 '22uF' '' 1
, O& [6 Z% _5 B g: v( V& {6 W) u 42. C0428 C100N-0402-16-X5R-10-M CAP0402 '100nF' '' 1: c( f8 \6 b; O8 Q9 _" D
43. C0429 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1& A# S8 o, R+ L+ ~% [! m
44. C0430 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1( y% I: [9 w7 b1 F
45. C0431 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 12 g2 r \9 }8 V3 L2 t& R# v4 W
46. C0432 C22U-0805-6.3-X5R-10-M CAP0805 '22uF' '' 1
% f3 h. n+ N3 { I) z 47. C0433 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
: H/ R/ C) i% G" b' I 48. C0434 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
; {' g" Q3 @5 @6 f5 {" G$ y 49. C0435 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
# F1 S( n4 g# b. J4 O. [6 q 50. C0436 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
5 S: P3 W# w1 @- R1 D 51. C0437 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1( \3 v2 M, Q& o h& l G
52. C0438 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
}( | H$ @5 e& A$ V& \0 k' S 53. C0439 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
) C. h& V9 E& J) k7 b* V8 s% Y3 s) a 54. C0440 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
" Y0 ~! t, S, s+ `$ O 55. C0441 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
, {4 X& f* V' i: O 56. C0442 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
8 W+ V6 l' U7 r/ Z) R" w 57. C0443 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
6 K5 B) ~7 z( P H3 g w 58. C0444 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
0 u* g0 h G- V! r 59. C0445 C22U-0805-6.3-X5R-10-M CAP0805 '22uF' '' 1
; g$ n# h1 X5 A- o0 H) g' Y& V 60. C0446 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
5 f9 ~9 n' }1 c6 z 61. C0447 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
3 k) P4 ] x' s2 n Z9 k 62. C0448 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1
+ U) P3 N9 R' } 63. C0449 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1- b M- |0 b" u' |( w |0 |$ A a
64. C0450 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 12 v* T8 |1 o2 a [8 |' G
65. C0451 C220N-0402-10-X5R-10-M CAP0402 '220nF' '' 1- o1 A& J) }; L$ I5 M4 U9 y
66. C0452 C22U-0805-6.3-X5R-10-M CAP0805 '22uF' '' 1
- K, q7 ]0 d9 z. x! k8 T r 67. C1009 C1U-0402-10-X5R-10-M CAP0402 '1uF' '' 1
5 \" S( ?9 M* p* L1 j; T 68. R0400 R0-0402-5-Y RES0402 '0R' '' 1
. ]( r1 H8 c$ C n2 j [ 69. R0401 R0-0402-5-Y RES0402 '0R' '' 15 U8 u. f$ h; j/ b9 u
70. R0402 R0-0402-5-Y RES0402 '0R' '' 1
( ]8 Z3 B, |6 A: L 71. R0403 R0-0402-5-Y RES0402 '0R' '' 16 D- a7 c' Q2 b0 B3 a6 j
72. R0404 R10K-0402-5-Y RES0402 '10K' '' 1
) a6 d1 S- ]4 o# y6 D 73. R0406 R240R-0402-1-Y RES0402 '240R 1%' '' 17 I5 u H( U: x
74. R0407 R240R-0402-1-Y RES0402 '240R 1%' '' 1 ~& I( p" e1 J5 e3 ?5 }: I: \8 `: I. s
75. R0408 R240R-0402-1-Y RES0402 '240R 1%' '' 1
/ O3 m* s3 s0 ? C: C 76. R0409 R240R-0402-1-Y RES0402 '240R 1%' '' 11 m/ U, q" b/ J( M6 V
77. R0410 R240R-0402-1-Y RES0402 '240R 1%' '' 1
2 `1 ~) d3 G. V- a% y 78. R0411 R10K-0402-5-Y RES0402 '10K' '' 1$ t4 X+ E% z6 ~+ W! L
79. R0412 R200R-0402-1-Y RES0402 '200R 1%' '' 1- x+ x' z& _& [1 M3 X9 m5 y0 r
80. U0200 MCIMX6U6AVM08AB BGA624_0P8_21X21 'i.MX 6DualLite_MCIMX6U5DVM10AB' '' 1
5 L. R! ~; f" [1 f8 I 81. U0401 4G_DDR3_SDRAM_128MX16_96P FBGA96_0P8_14X10 'MT41K128M16JT-125:K' '' 1- D0 Y' d9 F0 u( e; Z
82. U0402 4G_DDR3_SDRAM_128MX16_96P FBGA96_0P8_14X10 'MT41K128M16JT-125:K' '' 1
. a& O6 `2 [' p! l 83. U0403 4G_DDR3_SDRAM_128MX16_96P FBGA96_0P8_14X10 'MT41K128M16JT-125:K' '' 1' k# \' O. a& U( q- u# \- y3 W9 X
84. U0404 4G_DDR3_SDRAM_128MX16_96P FBGA96_0P8_14X10 'MT41K128M16JT-125:K' '' 1* H& W1 _3 O5 Q. x* B2 E8 M0 H1 x8 B
# i1 J8 Y* P: R# @
========== Matched/Unmatched Components ( ordered by matching type) ==========
3 f9 q. a3 _- G+ B1 V! R B+ \) {: U& G5 K
Type Id Reuse Design Pin Net Net Matched* o& I) t8 F) [) o+ w$ g- T
Component Component Num/Count in Reuse in Design <yes/NO>/ h1 q( t; H# ~; ?* B9 T8 N# C
$ m4 ~3 M" e* N6 r1 F- D" `-------------------------------------------------------------------------------------------------! o, A9 G# n; {* l1 e
cmt01 C0428 ***** [ 2 ] NO- ]( Q8 N" Q1 O" g! L9 a7 k
cmt01 ***** C0704 [ 2 ] NO
" ]4 `$ w9 ?# h cmt01 ***** C0705 [ 2 ] NO" E9 ~0 y6 X1 k" ^7 y7 M4 P
cmt01 ***** C0706 [ 2 ] NO
% n8 m% k' q4 U7 P Z# h% k cmt01 ***** C0708 [ 2 ] NO. J+ j4 Z/ t0 I; R7 u
cmt01 ***** C0709 [ 2 ] NO3 h* B, I2 T5 z6 N6 c; v; ]
cmt01 ***** C0807 [ 2 ] NO
% y' `0 W" t8 Q) I8 L4 Z( P0 y cmt01 ***** C0813 [ 2 ] NO
: D9 }- T6 b) c; `# b E cmt01 ***** C0814 [ 2 ] NO* T8 E- a: l6 m3 a- U" v. b$ Y
cmt01 ***** C0820 [ 2 ] NO
+ Q1 g" k; C) i ]) M, @ cmt01 ***** C0823 [ 2 ] NO' N+ a( j- s$ k( ~" O( v; e% C
cmt01 ***** C0827 [ 2 ] NO
7 r# ^, L; B7 v# R. J- X9 { cmt01 ***** C0901 [ 2 ] NO
/ K( ]" Z. T& b+ b* d9 J; d8 ] cmt01 ***** C0904 [ 2 ] NO T" H0 r% T" o2 p
cmt01 ***** C0909 [ 2 ] NO
5 A3 W4 P9 ~0 i! V( q. V/ V cmt01 ***** C0912 [ 2 ] NO4 ^9 x* _) Z7 c2 c( @
cmt01 ***** C0919 [ 2 ] NO
. u* h g& D2 y cmt01 ***** C1000 [ 2 ] NO3 L6 I& L [" e) C, R0 M
cmt01 ***** C1001 [ 2 ] NO, N% I) B4 G3 q6 X. h( D9 S
cmt01 ***** C1002 [ 2 ] NO
8 [! k2 _( f7 ~( V, j+ w cmt01 ***** C1003 [ 2 ] NO
2 N8 h T. k/ Z+ D s2 p+ D0 ` cmt01 ***** C1004 [ 2 ] NO
! v0 V! |5 L7 D cmt01 ***** C1005 [ 2 ] NO
- `0 Z0 l) m, S2 X7 U( { cmt01 ***** C1010 [ 2 ] NO+ _- Y4 Z4 ?' p, R O6 O6 e
cmt01 ***** C1011 [ 2 ] NO
& V0 V# m* p @; a5 d$ C cmt01 ***** C1039 [ 2 ] NO
g1 {% |1 A* `" q cmt01 ***** C1043 [ 2 ] NO
* Z; ~- t, p0 S1 x cmt01 ***** C1109 [ 2 ] NO
5 ^ p' ^; f5 H& f8 O$ |3 u cmt01 ***** C1112 [ 2 ] NO- M! o- M0 S8 Q' D% E" e
cmt01 ***** C1115 [ 2 ] NO" Y. g" e: t- m
cmt01 ***** C1116 [ 2 ] NO9 i) [+ J/ n' Z3 {: g
cmt01 ***** C1119 [ 2 ] NO
2 `; A9 A, }1 E1 p$ Q cmt01 ***** C1206 [ 2 ] NO
. y6 C- X+ m1 D% K: _0 W cmt01 ***** C1208 [ 2 ] NO
% r/ {! e0 S) i3 I3 | cmt01 ***** C1212 [ 2 ] NO- H! g: `7 D0 e" ^# m
cmt01 ***** C1213 [ 2 ] NO
1 d; ?& \* d1 D i* u+ b cmt01 ***** C1215 [ 2 ] NO
- H# F& F4 a& M# z cmt01 ***** C1302 [ 2 ] NO$ {1 X: o9 [" A, r8 \5 J
cmt01 ***** C1303 [ 2 ] NO
1 a7 d+ x+ s# |# K( n9 s& v, i cmt01 ***** C1400 [ 2 ] NO. [& ?7 ~0 R5 t |4 v5 l0 [
cmt01 ***** C1401 [ 2 ] NO
, S+ N4 V7 \7 o2 V& O% r" Y cmt01 ***** C1402 [ 2 ] NO; _6 u m3 K" h* u' w8 i5 Z
cmt01 ***** C1403 [ 2 ] NO+ i$ d' E" J, {. Q, D e9 J0 J
cmt01 ***** C1406 [ 2 ] NO
+ ]5 {" r# J+ [2 s y5 p9 N9 x cmt01 ***** C1407 [ 2 ] NO
! V! F9 { y2 e2 r7 M cmt01 ***** C1408 [ 2 ] NO0 C/ u/ G5 z% }6 I' I- H" G
cmt01 ***** C1412 [ 2 ] NO
: z: H& T' a2 F3 C' ?5 s, Z cmt01 ***** C1500 [ 2 ] NO$ V2 y% R4 u' M. a) G$ ?; r9 w
cmt01 ***** C1607 [ 2 ] NO
/ Y# j# t1 p2 h; c-------------------------------------------------------------------------------------------------
( O% {1 c$ _) G9 U( Y9 e cmt02 C0228 ***** [ 2 ] NO
; n i1 o7 K' N. Y! f1 S cmt02 C0229 ***** [ 2 ] NO
' t0 c' J5 D/ K& }# L, a8 |7 i/ v, J cmt02 C0230 ***** [ 2 ] NO
2 ?* u! x. F4 O' Z8 j1 R cmt02 C0231 ***** [ 2 ] NO
$ M2 Z4 n B' {, l0 x* v- N cmt02 C0232 ***** [ 2 ] NO
" u1 |. F/ w6 z3 r& B cmt02 C0233 ***** [ 2 ] NO0 o; G5 f& s, Q$ ^" a7 t
cmt02 C0234 ***** [ 2 ] NO
0 F+ t2 m: x2 b! [ cmt02 C0237 ***** [ 2 ] NO5 V$ G9 t8 K1 P) B& w
cmt02 C0238 ***** [ 2 ] NO6 O3 i1 Y8 {- W" K2 L7 Q; G* n
cmt02 C0239 ***** [ 2 ] NO; h8 E" E/ `: g1 T% b
cmt02 C0240 ***** [ 2 ] NO' L4 }, @% q9 j6 H# t+ s, S9 `
cmt02 C0400 ***** [ 2 ] NO, r; ~1 K: h. g5 d! |+ H; h5 v
cmt02 C0401 ***** [ 2 ] NO! s: y7 I6 _/ x* g+ {
cmt02 C0402 ***** [ 2 ] NO* o* m) s# ^1 s9 H
cmt02 C0403 ***** [ 2 ] NO
4 _/ a5 q2 @# o cmt02 C0404 ***** [ 2 ] NO4 i0 j7 h* Z+ M
cmt02 C0406 ***** [ 2 ] NO
& `' @0 C5 J( v3 u. x6 o cmt02 C0407 ***** [ 2 ] NO
, |* u+ S% B K# \# y cmt02 C0408 ***** [ 2 ] NO# X1 T( c" t* L7 y$ S6 J
cmt02 C0409 ***** [ 2 ] NO# L; h0 W& L5 X8 X% h, j8 m9 ?
cmt02 C0410 ***** [ 2 ] NO
- p3 @: K- P. i4 T cmt02 C0411 ***** [ 2 ] NO
: d* b* m0 t1 ?5 z' F cmt02 C0412 ***** [ 2 ] NO
% [: a0 l8 z: z/ G6 @+ b0 [- p; z cmt02 C0413 ***** [ 2 ] NO
# T: T9 { B" p# z& Y0 l( g1 f cmt02 C0414 ***** [ 2 ] NO
8 ^$ L" D% m/ x0 ]6 l4 }! m cmt02 C0415 ***** [ 2 ] NO: G/ }$ M- C0 l% v0 n8 y& h- J+ H
cmt02 C0416 ***** [ 2 ] NO% I( c$ n+ ?1 t" j: m. m7 T3 D/ k
cmt02 C0417 ***** [ 2 ] NO7 n7 i( I3 O% @
cmt02 C0418 ***** [ 2 ] NO( G# ` p) O' Q) W0 k+ ~# V
cmt02 C0419 ***** [ 2 ] NO `8 M/ X0 H5 I) K, P6 b& B" F) a
cmt02 C0420 ***** [ 2 ] NO
, C' X( K0 f6 V* Q$ h! B! f6 T cmt02 C0422 ***** [ 2 ] NO
! L' x* _3 a! F" k cmt02 C0423 ***** [ 2 ] NO
# |; U8 I+ y( j F N3 N; v cmt02 C0424 ***** [ 2 ] NO6 _* |, {. J% ~+ d4 j$ B, r" ~, I7 C
cmt02 C0425 ***** [ 2 ] NO7 T& x/ k- Y: p* h- G& F& \2 S
cmt02 C0426 ***** [ 2 ] NO' K- H% L1 a3 X
cmt02 C0429 ***** [ 2 ] NO
: h ]+ ^ z5 u7 u5 @2 Y, I cmt02 C0430 ***** [ 2 ] NO
6 S! u0 g, ~7 G0 z0 N+ s cmt02 C0431 ***** [ 2 ] NO6 e3 C8 `) b: p5 f$ W
cmt02 C0433 ***** [ 2 ] NO
- G5 L I8 M$ H3 D4 w. V" u, R2 I cmt02 C0434 ***** [ 2 ] NO$ q" ]. s0 y# q: f
cmt02 C0435 ***** [ 2 ] NO
* R, |1 r$ }) b2 M cmt02 C0436 ***** [ 2 ] NO
- L0 L# Q$ s2 @/ r) m cmt02 C0437 ***** [ 2 ] NO4 ]% P# o# k6 W; U# P& p+ |
cmt02 C0438 ***** [ 2 ] NO
' }8 K, P/ _. [ cmt02 C0439 ***** [ 2 ] NO- }, Y# J3 F2 f z+ n# \5 J
cmt02 C0440 ***** [ 2 ] NO( D9 Y$ N& [& g
cmt02 C0441 ***** [ 2 ] NO$ ]! E1 M N% y% u5 L
cmt02 C0442 ***** [ 2 ] NO
* W" U* d% E1 y8 f/ h8 K+ i( u cmt02 C0443 ***** [ 2 ] NO2 R6 F6 Z' h9 I1 x
cmt02 C0444 ***** [ 2 ] NO
: K6 b( @) |: G0 ] cmt02 C0446 ***** [ 2 ] NO4 \! d! c, I7 C( D( g) C9 }% x
cmt02 C0447 ***** [ 2 ] NO
/ ^& |# A: X/ ~. k! C) v9 m2 C9 G cmt02 C0448 ***** [ 2 ] NO6 k. Z6 K) d" V+ B$ d5 ?/ p. [
cmt02 C0449 ***** [ 2 ] NO
1 O: [% k. q+ Z cmt02 C0450 ***** [ 2 ] NO
5 M* H X) _9 A1 z V/ z* v5 n cmt02 C0451 ***** [ 2 ] NO
% ]- y: U3 c8 p/ I7 `* u" \+ O8 m( y, t cmt02 ***** C0202 [ 2 ] NO
7 u, m- D0 t" U4 F, Z cmt02 ***** C0203 [ 2 ] NO( N* s+ b$ P& L$ l
cmt02 ***** C0204 [ 2 ] NO4 ^+ G3 r/ i7 X. o
cmt02 ***** C0205 [ 2 ] NO) D) H7 I8 |, |5 c
cmt02 ***** C0206 [ 2 ] NO% [4 O( Z& a' \; B# T
cmt02 ***** C0207 [ 2 ] NO9 c/ a( f- _, V4 e$ C# q5 O
cmt02 ***** C0209 [ 2 ] NO
8 E/ y% `: K3 m \0 q cmt02 ***** C0210 [ 2 ] NO& [1 b3 L% j- ], ~$ m
cmt02 ***** C0211 [ 2 ] NO
u0 T7 U7 a9 ]6 C- l cmt02 ***** C0212 [ 2 ] NO
& w# K5 k% b4 M( f+ }9 l cmt02 ***** C0214 [ 2 ] NO% R5 G' U. L( `* ~7 k
cmt02 ***** C0215 [ 2 ] NO
1 q& T, e4 l2 e. ?! L# G* i cmt02 ***** C0216 [ 2 ] NO/ v5 ?$ l6 Z" M1 s# w6 J
cmt02 ***** C0217 [ 2 ] NO
$ z0 ?7 b) `( }" c5 }0 T* q cmt02 ***** C0218 [ 2 ] NO J5 B+ @: b& L! j% r
cmt02 ***** C0219 [ 2 ] NO
5 f9 a6 z* N; O1 O' r& b% h0 _ cmt02 ***** C0220 [ 2 ] NO0 s! U4 X0 l8 L9 U* m, X
cmt02 ***** C0221 [ 2 ] NO
6 l( e+ ?9 j! {! a cmt02 ***** C0225 [ 2 ] NO
& c) ?7 G! ~2 R5 m. J0 U cmt02 ***** C0227 [ 2 ] NO* p" Y# y# B3 o' D( `, M2 ~
cmt02 ***** C0241 [ 2 ] NO
! ~: t7 \( A" ?- G/ B$ b2 J, W cmt02 ***** C0243 [ 2 ] NO
# {7 b# U1 g" m7 ?; K0 A: w% r9 C5 F; w cmt02 ***** C0244 [ 2 ] NO& S5 J$ J( x* b1 X) w
cmt02 ***** C0245 [ 2 ] NO
! T* L; i0 n2 X% P9 U- g+ ?& w cmt02 ***** C0246 [ 2 ] NO
: K4 E" d9 M1 R% R. \ cmt02 ***** C0247 [ 2 ] NO
# s& G( x3 n0 i) u, P( Z cmt02 ***** C0248 [ 2 ] NO* P# Q+ H6 M0 w( y. z: H/ ?
cmt02 ***** C0249 [ 2 ] NO( ~ W9 [9 B4 [# \" B
cmt02 ***** C0251 [ 2 ] NO
$ I. G: |- ]; R t cmt02 ***** C0253 [ 2 ] NO
1 m' S( l6 o( C* u5 q+ t9 ` cmt02 ***** C0254 [ 2 ] NO3 ?1 P# v/ a9 e* [2 U- O
cmt02 ***** C0255 [ 2 ] NO
3 f1 {0 \. M ? cmt02 ***** C0256 [ 2 ] NO
: l- M. i5 l0 [5 ~7 [6 i cmt02 ***** C0257 [ 2 ] NO) c( {% c+ a. b& D; S( w
cmt02 ***** C0258 [ 2 ] NO
# ^9 B. ?: w4 B' K cmt02 ***** C0259 [ 2 ] NO( g6 S' E7 a$ J' g/ l3 }
cmt02 ***** C0260 [ 2 ] NO) D/ s& _0 I9 c8 \4 n6 A! J, H7 D
cmt02 ***** C0261 [ 2 ] NO1 b3 P# l& D- Y% m3 c- W- R
cmt02 ***** C0262 [ 2 ] NO
3 B2 f: U- E% I9 z' ~ cmt02 ***** C0267 [ 2 ] NO
% q. v* k! Q3 `7 k cmt02 ***** C0269 [ 2 ] NO7 O) b% b4 W6 g: b( H# J p; F$ q
cmt02 ***** C0271 [ 2 ] NO
6 y; ^% H9 _3 a: ]1 N cmt02 ***** C0272 [ 2 ] NO7 [/ N& ?2 j* a2 W9 c% ^) R. g6 X7 e
cmt02 ***** C0273 [ 2 ] NO7 t" {+ F& Y1 ~, d3 a
cmt02 ***** C0274 [ 2 ] NO% [0 b) G" @7 X: t; S/ G4 w
cmt02 ***** C0275 [ 2 ] NO( [+ F) h+ g& u" E2 `) H
cmt02 ***** C0276 [ 2 ] NO
1 t1 U5 _4 L, J+ e# X: O cmt02 ***** C0277 [ 2 ] NO/ b" f c- s8 q, q& f5 ]& B
cmt02 ***** C0279 [ 2 ] NO
8 E. k5 h! v8 z- m7 T; w; k1 m cmt02 ***** C0280 [ 2 ] NO1 ~7 X# B' ]9 k: M$ Y* {6 ~
cmt02 ***** C0281 [ 2 ] NO; u. }- k8 C3 K! }1 O5 k
cmt02 ***** C0282 [ 2 ] NO
. Y/ j$ s3 Q9 M cmt02 ***** C0283 [ 2 ] NO) h& N! g [- X4 X Z
cmt02 ***** C0285 [ 2 ] NO
M: K2 [5 f) Y0 {3 X cmt02 ***** C0287 [ 2 ] NO3 n$ @* q, n! H5 N
cmt02 ***** C0601 [ 2 ] NO- {, h2 T+ ?7 S
cmt02 ***** C0602 [ 2 ] NO
% `* ]6 p2 _% d4 G$ G- I cmt02 ***** C0700 [ 2 ] NO) W" r4 y b0 ~& j5 n3 E% e
cmt02 ***** C0701 [ 2 ] NO9 W9 }1 w7 h. E& w0 O; v
cmt02 ***** C0800 [ 2 ] NO o- S9 V8 X. c' M7 m9 Z7 L9 B
cmt02 ***** C0810 [ 2 ] NO+ t! D) J R" M U5 P4 I" ]3 e) M5 |
cmt02 ***** C0811 [ 2 ] NO
* M" Q, d" A6 t5 c cmt02 ***** C0917 [ 2 ] NO! Q2 ?& k: i' T0 C$ e/ W. k
cmt02 ***** C1047 [ 2 ] NO/ K5 R* R3 L$ P6 v& t6 `6 m
cmt02 ***** C1100 [ 2 ] NO
( A" x& f* q% _& F, s' a; Y cmt02 ***** C1101 [ 2 ] NO
3 q- \$ W+ s2 `$ m2 Q2 v-------------------------------------------------------------------------------------------------0 P) q" G1 Q8 A% F0 N& N
cmt03 R0400 ***** [ 2 ] NO0 k: p7 S- T- C
cmt03 R0401 ***** [ 2 ] NO
i$ x) y. _! j# d9 `: n4 H4 J cmt03 R0402 ***** [ 2 ] NO
2 K) V# L4 d- K- G: M cmt03 R0403 ***** [ 2 ] NO
: O7 ~. O- A W& X cmt03 ***** R0200 [ 2 ] NO w+ `$ |9 l- U
cmt03 ***** R0201 [ 2 ] NO0 ^ ]% t# M3 }+ w% U
cmt03 ***** R0202 [ 2 ] NO% r) f6 `$ ` M
cmt03 ***** R0203 [ 2 ] NO8 i9 k4 e1 z( d' Y
cmt03 ***** R0204 [ 2 ] NO' K: C- z; R7 ]4 M( l
cmt03 ***** R0206 [ 2 ] NO4 R& G5 Y: p- t- O1 [5 z; d" }! `
cmt03 ***** R0207 [ 2 ] NO
: a! X& p+ p5 s cmt03 ***** R0208 [ 2 ] NO5 q- c2 r" L. q- I6 w0 c
cmt03 ***** R0211 [ 2 ] NO/ b0 k, I5 Y ?
cmt03 ***** R0213 [ 2 ] NO
! L( X! R b8 L: k' K ^8 B cmt03 ***** R0301 [ 2 ] NO
+ |9 I) J$ B# z* i) g7 @$ O! a cmt03 ***** R0302 [ 2 ] NO7 R( K S) N* k J0 m- h. Y' V
cmt03 ***** R0303 [ 2 ] NO6 d% u8 q% }: x( ~' o" s5 h
cmt03 ***** R0305 [ 2 ] NO
- Q% }7 A" q( u& s& K( r cmt03 ***** R0306 [ 2 ] NO6 z( J1 H1 D" U( L' [/ N3 ?
cmt03 ***** R0307 [ 2 ] NO7 C% W0 U6 k' r: P# Q
cmt03 ***** R0502 [ 2 ] NO! c: u- f6 H# b1 `
cmt03 ***** R0503 [ 2 ] NO6 E; X$ K5 _1 M$ i ~7 M
cmt03 ***** R0504 [ 2 ] NO
. P- O/ J) H0 H- v: x cmt03 ***** R0600 [ 2 ] NO+ X% V8 j( F9 |% z& u/ O3 ~& `3 Q
cmt03 ***** R0700 [ 2 ] NO9 b2 `. O$ R6 O3 m# e3 @
cmt03 ***** R0701 [ 2 ] NO
1 ?- h. g+ t m+ Z6 K: R cmt03 ***** R0703 [ 2 ] NO
3 T% E& {9 L0 S8 G, i- C. K) D cmt03 ***** R0710 [ 2 ] NO
; i7 t/ i1 V5 F D cmt03 ***** R0711 [ 2 ] NO
3 V9 f `/ ~6 ` cmt03 ***** R0800 [ 2 ] NO
& y B& |1 e* m: n9 B8 N cmt03 ***** R0805 [ 2 ] NO4 I" ^6 q' s9 P3 H8 N% q; X+ `
cmt03 ***** R0806 [ 2 ] NO
6 G% @' H& D) S1 {# e$ | cmt03 ***** R0827 [ 2 ] NO- P; e3 m* Z: r: F7 n" q
cmt03 ***** R0829 [ 2 ] NO
j2 `5 [( R: r9 _6 C cmt03 ***** R0830 [ 2 ] NO
! ^. g% _7 p5 g cmt03 ***** R0900 [ 2 ] NO
! X* X) s6 w c' ]% R cmt03 ***** R0901 [ 2 ] NO" _: y" r9 N# X0 S3 h
cmt03 ***** R0902 [ 2 ] NO
! |! T. K& C1 J7 i4 c5 b; i cmt03 ***** R0903 [ 2 ] NO, j& G' H+ U1 B# `' _
cmt03 ***** R1001 [ 2 ] NO
e7 m! F% \: C# y+ `; V cmt03 ***** R1003 [ 2 ] NO
n2 _' \$ r8 r+ { cmt03 ***** R1009 [ 2 ] NO
! K! k! k* r. z$ m L1 ^ cmt03 ***** R1015 [ 2 ] NO9 n$ T: P! e2 X5 s
cmt03 ***** R1016 [ 2 ] NO
) U! u- d- u; j& d: L0 J9 R cmt03 ***** R1102 [ 2 ] NO/ [& R1 ]0 i o5 E
cmt03 ***** R1103 [ 2 ] NO
1 n' h$ b5 G& a6 a K& k. T( q! P cmt03 ***** R1104 [ 2 ] NO5 v7 ~1 E9 {/ R- S' G4 ? ]- O: I7 v
cmt03 ***** R1105 [ 2 ] NO- o2 s; ~! m4 q
cmt03 ***** R1115 [ 2 ] NO
* H( Z5 G+ F; L' t5 u/ k cmt03 ***** R1201 [ 2 ] NO2 [: V% A( Z4 C. G
cmt03 ***** R1202 [ 2 ] NO7 k9 Z+ v( w! d$ W `2 a
cmt03 ***** R1216 [ 2 ] NO& X4 i/ H+ r4 W# b) N3 k8 A5 V
cmt03 ***** R1217 [ 2 ] NO0 i: _' y! @, y7 U. q1 T# k/ ?- Y6 ^
cmt03 ***** R1232 [ 2 ] NO, a! @! N' K0 _' Z2 N% O/ T
cmt03 ***** R1236 [ 2 ] NO
5 Z+ p r# `2 z _ cmt03 ***** R1303 [ 2 ] NO6 \! z1 `7 N) U/ k2 c8 g. | R
cmt03 ***** R1306 [ 2 ] NO& M2 z& ~$ B% Y; {5 }. i1 v6 R
cmt03 ***** R1309 [ 2 ] NO
: w% A, H3 [9 p+ ]7 w. q cmt03 ***** R1311 [ 2 ] NO4 \7 y( x! r7 x1 ~% O' g
cmt03 ***** R1320 [ 2 ] NO
* D( R! m8 K9 A8 s: U. j cmt03 ***** R1321 [ 2 ] NO( ?" Y% s+ \- ^7 k9 k
cmt03 ***** R1322 [ 2 ] NO6 U* K! R8 O @+ e% H
cmt03 ***** R1323 [ 2 ] NO
3 j/ S0 F( { i( s, J/ g9 A7 Z cmt03 ***** R1325 [ 2 ] NO
W* @: @# ]- l/ e cmt03 ***** R1327 [ 2 ] NO: X9 v: J3 V6 c$ Z+ {( @& v2 c
cmt03 ***** R1330 [ 2 ] NO# ?" d1 h. N4 E9 r7 G) L2 k& G
cmt03 ***** R1331 [ 2 ] NO
9 C1 f/ d8 r4 F- E7 ^+ ^ cmt03 ***** R1600 [ 2 ] NO
0 q; q# |$ L- @( g+ f. V cmt03 ***** R1601 [ 2 ] NO U# p+ [! {3 j, ?
cmt03 ***** R1602 [ 2 ] NO
D8 p4 b$ n6 Q cmt03 ***** R1603 [ 2 ] NO! ?4 {4 {4 W m) _
cmt03 ***** R1604 [ 2 ] NO3 l! Y8 g* U1 z0 B& e. E) p
cmt03 ***** R1605 [ 2 ] NO
: E Q" L6 V( S$ y+ G# S$ D cmt03 ***** R1607 [ 2 ] NO0 d. Q7 I2 ^9 e9 c% A! J
cmt03 ***** R1608 [ 2 ] NO
4 m) j/ p4 w+ {5 V# ~ cmt03 ***** R1609 [ 2 ] NO1 \7 `) S9 l2 B2 A7 @! `8 I
cmt03 ***** R1610 [ 2 ] NO! ?; J/ l7 | d! H" _) B0 c+ n
cmt03 ***** R1611 [ 2 ] NO7 n$ H( ~' l1 g; ?, q6 `/ E, U
cmt03 ***** R1613 [ 2 ] NO5 }$ u5 Q' C# e
cmt03 ***** R1614 [ 2 ] NO9 ] Y: @5 B/ Y( s" ~
cmt03 ***** R1615 [ 2 ] NO
6 a- a) G b9 x* | cmt03 ***** R1616 [ 2 ] NO
( t$ M6 d" }! k* P cmt03 ***** R1617 [ 2 ] NO
7 ]$ d b7 l" |9 h- w3 { cmt03 ***** R1618 [ 2 ] NO1 }' Z$ }& j- B- l1 d
/ c e. f9 s% J6 G cmt04 R0406 ***** [ 2 ] NO5 h. u' A S. d
cmt04 R0407 ***** [ 2 ] NO
2 F# z. @( r- U# s+ U cmt04 R0408 ***** [ 2 ] NO
# a( ?( q. a& S! p/ [( ` cmt04 R0409 ***** [ 2 ] NO, t$ c K- u! s m4 A. r1 u
cmt04 R0410 ***** [ 2 ] NO
' X. j7 I- e. K/ ^ cmt04 ***** R1007 [ 2 ] NO
; q {/ c& t8 Y& ]- E0 ~" F) x-------------------------------------------------------------------------------------------------8 {- ~3 B+ q; {7 h0 S. ^
cmt05 U0401 ***** [ 96 ] NO
$ |+ P, c% y5 J cmt05 U0402 ***** [ 96 ] NO
5 W9 C3 j" R1 ?, U0 d# { cmt05 U0403 ***** [ 96 ] NO
E+ R; |. J) [. m3 M cmt05 U0404 ***** [ 96 ] NO
" _ L2 a% \( A' [) D6 ^( n-------------------------------------------------------------------------------------------------
; L5 [! A |; E- j6 v1 { cmt06 U0200 ***** [624 ] NO
I8 o) S+ y9 _$ p% K% Y* }8 M) v2 F-------------------------------------------------------------------------------------------------; v6 h* a( c& p) G8 Y/ Y8 X
cmt07 R0412 ***** [ 2 ] NO! h; @" Q5 s. w2 y( A: Q! h! {& g
cmt07 ***** R0405 [ 2 ] NO. m8 B8 o- I9 E8 q, y1 x$ v
cmt07 ***** R0802 [ 2 ] NO
( r9 }% v7 Z; H% W# j+ u% M9 K-------------------------------------------------------------------------------------------------
2 J3 B* D2 C# s9 w cmt08 C1009 ***** [ 2 ] NO+ n4 W1 ]5 [3 q
cmt08 ***** C0900 [ 2 ] NO8 ?2 R F0 o& R; S
cmt08 ***** C0908 [ 2 ] NO3 q/ ~. v$ a& P! i! ?
cmt08 ***** C0913 [ 2 ] NO) K a( b$ {* y$ H5 r+ t
cmt08 ***** C1044 [ 2 ] NO
" _! \$ N( a% K( i B) ^0 [! D: |) E cmt08 ***** C1046 [ 2 ] NO
) S4 h) {# I' ]3 p cmt08 ***** C1048 [ 2 ] NO$ x6 l7 @! M0 A/ H8 _5 Q, l
cmt08 ***** C1404 [ 2 ] NO# w' |- h0 |, R$ F2 k! z6 ~" w% E
cmt08 ***** C1409 [ 2 ] NO
9 I9 V1 w6 l; x/ g8 r0 k6 K8 O cmt08 ***** C1501 [ 2 ] NO- Q* Y) M6 I" k
cmt08 ***** C1601 [ 2 ] NO
+ s" O3 p" I5 s: _( }' ~( ^7 H4 i cmt08 ***** C1602 [ 2 ] NO" m- o5 v% y) s
+ P/ E, T' o+ ]1 q cmt09 R0404 ***** [ 2 ] NO
7 M) z( Y3 q4 ?; n5 V8 w, { cmt09 R0411 ***** [ 2 ] NO
5 c3 Q( ^. m7 G7 W cmt09 ***** R0707 [ 2 ] NO$ u5 A$ a' H- Q" N: S C
cmt09 ***** R0712 [ 2 ] NO
0 v# e/ A* h* C: Q cmt09 ***** R0807 [ 2 ] NO; [+ o8 D$ g) j4 `( s( O
cmt09 ***** R0813 [ 2 ] NO: Z+ j, ` I. O0 Z
cmt09 ***** R0819 [ 2 ] NO" L' t& K9 b0 U
cmt09 ***** R0821 [ 2 ] NO
. `$ w2 H/ {1 o1 D$ E cmt09 ***** R0822 [ 2 ] NO$ I: m. g; _" a) h" a2 A" v$ Q
cmt09 ***** R0826 [ 2 ] NO
+ q0 a5 a* s C% m9 ~. E; O cmt09 ***** R0831 [ 2 ] NO9 }% O3 Y; e4 K) ~/ ^" X
cmt09 ***** R0833 [ 2 ] NO
+ q! a. ?$ ^& f+ { cmt09 ***** R0905 [ 2 ] NO
8 k5 l Z& h% I: I, p1 Z* D cmt09 ***** R0908 [ 2 ] NO; ]% {( J: h* U+ a
cmt09 ***** R0915 [ 2 ] NO
; j+ a7 @+ ^6 E, r7 E1 t cmt09 ***** R0926 [ 2 ] NO+ b6 @9 B) m) ~/ ?8 V8 \) \ O8 B6 f
cmt09 ***** R0933 [ 2 ] NO! K' O p; j3 n/ ~& E$ a
cmt09 ***** R1005 [ 2 ] NO! x9 g8 o6 Q, C/ I8 |+ ?8 A
cmt09 ***** R1010 [ 2 ] NO2 f! K3 C$ a$ g% v; o
cmt09 ***** R1013 [ 2 ] NO' N; Q$ l( z) i) h
cmt09 ***** R1100 [ 2 ] NO
1 }% h9 }# ]0 t: E8 ~. ` cmt09 ***** R1101 [ 2 ] NO. r* v' J* W: _) N; _
cmt09 ***** R1108 [ 2 ] NO$ s/ @( f" I1 R! N
cmt09 ***** R1208 [ 2 ] NO
. [# {, \$ w# s) e p& n) V cmt09 ***** R1219 [ 2 ] NO
$ P$ Q8 [, ? { cmt09 ***** R1220 [ 2 ] NO9 A0 H! g8 I) h1 v
cmt09 ***** R1226 [ 2 ] NO- O: S+ N' V" q7 G% X8 ~
cmt09 ***** R1227 [ 2 ] NO
& W, ]8 p6 P' e5 b: p0 o% _: i% D cmt09 ***** R1228 [ 2 ] NO( Y4 Z5 V+ E* _& K& g; z8 S
cmt09 ***** R1229 [ 2 ] NO/ w" @: I4 A# A r2 w4 Z
cmt09 ***** R1234 [ 2 ] NO0 T: L$ L- J' s+ g: S# Y
cmt09 ***** R1235 [ 2 ] NO7 F- a( {6 Q3 P; I* z' k7 ^
cmt09 ***** R1301 [ 2 ] NO4 j- G' \7 ]2 U0 J ^$ Q$ T
cmt09 ***** R1527 [ 2 ] NO5 b* \$ R2 x& S8 a- X
cmt09 ***** R1529 [ 2 ] NO4 X0 a6 ]" ]$ |$ {
cmt09 ***** R1530 [ 2 ] NO
" n0 z8 X* i" E8 R4 @ cmt09 ***** R1535 [ 2 ] NO# L' s8 l- F$ y# W- Z# y$ {+ v
cmt09 ***** R1536 [ 2 ] NO
& s+ `7 h, P9 r' o" K cmt09 ***** R1538 [ 2 ] NO2 t" B+ E' c4 d
cmt09 ***** R1539 [ 2 ] NO
2 Z; T8 w0 w8 E$ |+ a N. ?* u cmt09 ***** R1544 [ 2 ] NO
J0 _: @- v9 P2 ?+ i2 f$ ` cmt09 ***** R1545 [ 2 ] NO
: p! l0 x G/ H9 w' W, J cmt09 ***** R1548 [ 2 ] NO
" q B% ~7 n" B: r cmt09 ***** R1551 [ 2 ] NO+ m# U7 W; j! y0 u) @& c/ X
cmt09 ***** R1552 [ 2 ] NO
9 q1 ]& \. y2 y2 V) N0 R cmt09 ***** R1553 [ 2 ] NO
" B3 @& m8 x. _$ a5 ?. q" H cmt09 ***** R1554 [ 2 ] NO
5 F: F: Z6 L+ h' W G8 t cmt09 ***** R1557 [ 2 ] NO
1 y, S% w* U/ a3 c) M1 R( I6 O cmt09 ***** R1559 [ 2 ] NO3 g* ~, A, x$ n" {9 o9 D8 @+ Q
cmt09 ***** R1560 [ 2 ] NO
$ k# t( G# C8 l4 | cmt09 ***** R1612 [ 2 ] NO
9 k$ g& f0 K; b+ {5 N0 }5 x* j- i7 U1 _-------------------------------------------------------------------------------------------------! K( D5 W. m8 |- k; T, v& a8 q
cmt10 C0235 ***** [ 2 ] NO
& G7 u! i8 H6 ?1 G+ a% l6 H cmt10 C0236 ***** [ 2 ] NO
+ F1 z6 V4 r. H9 c. @ cmt10 C0405 ***** [ 2 ] NO
2 X Y, Y' V! ]( y; I# d cmt10 C0421 ***** [ 2 ] NO& r& w1 B- \4 M7 l2 y, ]
cmt10 C0427 ***** [ 2 ] NO7 i1 k2 l( \, I, h- d8 B2 C
cmt10 C0432 ***** [ 2 ] NO- _5 k0 h" a y+ R6 @6 G
cmt10 C0445 ***** [ 2 ] NO
% S& K Q- C* | Z. A/ ` cmt10 C0452 ***** [ 2 ] NO
& g+ d: S: e: D; w- k6 f% r cmt10 ***** C0201 [ 2 ] NO
. m$ y' Y* c' r1 r, t* N cmt10 ***** C0208 [ 2 ] NO
8 a/ u# N1 K& E5 |& X cmt10 ***** C0213 [ 2 ] NO
& ^7 `9 p! O# \, s cmt10 ***** C0222 [ 2 ] NO% n) t3 ~& ?. g' j4 j1 g& J
cmt10 ***** C0223 [ 2 ] NO
/ P/ m1 w/ o( d: f/ d. p cmt10 ***** C0224 [ 2 ] NO6 ?* z8 h! S7 _ j3 @7 e
cmt10 ***** C0226 [ 2 ] NO5 u, t# {5 G2 `& ` w/ Y
cmt10 ***** C0242 [ 2 ] NO- A! N7 Q. N. S. a3 a( D
cmt10 ***** C0250 [ 2 ] NO
% c6 A+ f5 A9 ~3 ? cmt10 ***** C0252 [ 2 ] NO8 Z2 z* ?/ V. P$ r
cmt10 ***** C0263 [ 2 ] NO
+ r8 y5 G8 u3 W( C cmt10 ***** C0270 [ 2 ] NO
% U* g/ M, L l. j7 Z4 Z/ b cmt10 ***** C0278 [ 2 ] NO
& f9 g/ s, |5 M( b! D8 ~+ b cmt10 ***** C0284 [ 2 ] NO
; z, v i2 c* x7 i, D* Z! a cmt10 ***** C0286 [ 2 ] NO2 p: [" j6 p7 ], o
cmt10 ***** C0903 [ 2 ] NO6 Q5 I* |# R0 e8 u N" n# m! P% ]
cmt10 ***** C1021 [ 2 ] NO
# s$ x( F6 V* {4 f cmt10 ***** C1022 [ 2 ] NO
' _: l( I$ Y6 u- p$ E cmt10 ***** C1023 [ 2 ] NO, O Y* E/ I- M) D
cmt10 ***** C1024 [ 2 ] NO; U) \% p \3 h$ F
cmt10 ***** C1027 [ 2 ] NO
2 n/ g5 w( d6 ? cmt10 ***** C1028 [ 2 ] NO) c4 r6 J% q- y- W/ O* C2 U6 z
cmt10 ***** C1030 [ 2 ] NO
8 v- F) [: e+ E& C cmt10 ***** C1031 [ 2 ] NO& e' |/ O/ q) f: X" k
cmt10 ***** C1033 [ 2 ] NO) b- e2 _3 S/ {8 G, L( I
cmt10 ***** C1034 [ 2 ] NO9 W- _& U' `8 W9 t# C
cmt10 ***** C1035 [ 2 ] NO
* l+ c2 I/ s2 S+ I) n4 w cmt10 ***** C1036 [ 2 ] NO$ C6 X% y6 M/ s: Q" U
cmt10 ***** C1040 [ 2 ] NO
2 @1 u v) `5 h- l# o% F, Q; j cmt10 ***** C1041 [ 2 ] NO
0 z$ B$ B0 ?- r( |" U
$ b3 O. [( @2 s$ N9 D" K0 f- W& M, ^/ x5 d* R/ J
===============================================================2 S% T" q! W5 ]' H/ W1 P4 ^
Unusable Design Components [508 /795 ] ( ordered by refdes )
/ B' o$ l9 {* ~) D1 F; z) N. b/ e5 \/ k; v, x& p/ x3 q
; a. k3 R. X* q RefDes Usable/ T, B d- d$ n4 M
C0200 NO - part type mismatch ( C1U-0603-25-X7R-10-M )6 Z. X# ^3 z6 ]1 O
C0228 NO - member of reuse ( DDR3_1 )+ c7 ?% e9 G" r" a- b- n, U
C0229 NO - member of reuse ( DDR3_1 )
U* O5 S' v, `& p C0230 NO - member of reuse ( DDR3_1 )
# x: N; p4 j- X6 O C0231 NO - member of reuse ( DDR3_1 )4 c2 _4 u! `) B# l
C0232 NO - member of reuse ( DDR3_1 )
( I4 j; d) t/ m- h C0233 NO - member of reuse ( DDR3_1 ): C: ], F1 O: B# I6 n; l6 Q
C0234 NO - member of reuse ( DDR3_1 )$ i6 J6 ]2 |. c- Q8 g# J7 r
C0235 NO - member of reuse ( DDR3_1 )
4 W/ B" G7 g9 G C0236 NO - member of reuse ( DDR3_1 )- J7 A- J/ t8 y/ Q1 P
C0237 NO - member of reuse ( DDR3_1 )
# U' y( Q7 m% o8 V3 C6 N) W C0238 NO - member of reuse ( DDR3_1 )0 `8 L5 B& M- Y# n3 e4 j
C0239 NO - member of reuse ( DDR3_1 )- l1 d. J: x; ]
C0240 NO - member of reuse ( DDR3_1 )
! C( r7 C% i8 q2 s4 s8 d. ] C0264 NO - part type mismatch ( C1U-0603-25-X7R-10-M )
4 Y0 C: E f; j/ ? C0265 NO - part type mismatch ( C1U-0603-25-X7R-10-M )
2 }3 g/ B h. Q/ z C0266 NO - part type mismatch ( C1U-0603-25-X7R-10-M )
+ O4 L W3 M j3 t( \ C0268 NO - part type mismatch ( C10N-0402-16-X5R-10-M )
3 G( C+ r. I! I C0300 NO - part type mismatch ( C18P-0402-50-C0G-5-M )
3 G! |. q( Y' u' W+ }( I2 s7 O5 x C0301 NO - part type mismatch ( C18P-0402-50-C0G-5-M )
_! l# K1 ]% o* l C0302 NO - part type mismatch ( C18P-0402-50-C0G-5-M )- g% e4 Z2 ?6 v" z
C0303 NO - part type mismatch ( C18P-0402-50-C0G-5-M )
2 P, h9 D$ u' {% d C0400 NO - member of reuse ( DDR3_1 )
9 R$ J( D1 L! F* e" p C0401 NO - member of reuse ( DDR3_1 ): M) B1 N- p" Y1 x! p
C0402 NO - member of reuse ( DDR3_1 )
6 B8 d2 \; c2 x7 P* |# \ Z C0403 NO - member of reuse ( DDR3_1 )$ K, _' M2 e3 U7 r
C0404 NO - member of reuse ( DDR3_1 )" D) A2 @, I( t2 `0 h' ~( d& y
C0405 NO - member of reuse ( DDR3_1 )
2 H: V' |# X! z6 C: Y C0406 NO - member of reuse ( DDR3_1 )3 {5 r; j3 k) v/ q
C0407 NO - member of reuse ( DDR3_1 )
7 R1 @4 {1 F! B0 o9 t$ u C0408 NO - member of reuse ( DDR3_1 )
6 }! [) P& h6 z( S6 h* w C0409 NO - member of reuse ( DDR3_1 )2 T1 h' W* q) q
C0410 NO - member of reuse ( DDR3_1 ). B s0 j, a6 _6 I: m/ Y
C0411 NO - member of reuse ( DDR3_1 )( \+ R0 |4 d8 x+ p$ Z3 R
C0412 NO - member of reuse ( DDR3_1 ). O$ Y& Y/ Z9 o8 h3 \9 K
C0413 NO - member of reuse ( DDR3_1 )% p2 q# z" z! `/ f/ ^
C0414 NO - member of reuse ( DDR3_1 )
1 l* `$ |/ z3 Y) B' _0 ` C0415 NO - member of reuse ( DDR3_1 )) A& u4 y+ [* [9 ~/ W" N: i
C0416 NO - member of reuse ( DDR3_1 )4 }9 |* C9 E0 y3 F5 `3 o
C0417 NO - member of reuse ( DDR3_1 )
4 @( `% W' X" P# ? C0418 NO - member of reuse ( DDR3_1 )
* z. e" B6 Y( p; T C0419 NO - member of reuse ( DDR3_1 )1 N& @' n+ h# |7 ^: _/ M
C0420 NO - member of reuse ( DDR3_1 ). J# c2 t0 X# k- a' `8 C
C0421 NO - member of reuse ( DDR3_1 )
6 s' a1 Q7 B) D; t C0422 NO - member of reuse ( DDR3_1 )# L( }: y- r5 Y6 {) S3 S g/ `
C0423 NO - member of reuse ( DDR3_1 )9 y3 g4 f- r& e1 S
C0424 NO - member of reuse ( DDR3_1 )) d5 Y) T% K. O; m
C0425 NO - member of reuse ( DDR3_1 )* s* a* c' J0 z
C0426 NO - member of reuse ( DDR3_1 )) {$ j$ H: \. [3 A3 b; n+ X
C0427 NO - member of reuse ( DDR3_1 )2 R, q, A! g" C8 `& B1 k% D. R& X% p, j
C0428 NO - member of reuse ( DDR3_1 )" P$ F0 n5 F" m2 b5 N" @
C0429 NO - member of reuse ( DDR3_1 ); m4 I# a5 Y/ ~6 |' B
C0430 NO - member of reuse ( DDR3_1 )1 J% d+ J7 Y5 b3 i. h- ?0 X' D9 d
C0431 NO - member of reuse ( DDR3_1 )
, G' M4 N+ S; n6 _% G- Q/ x6 W C0432 NO - member of reuse ( DDR3_1 )) @% v. P' A" l8 e
C0433 NO - member of reuse ( DDR3_1 )
6 r8 T% a# g! H, }- h C0434 NO - member of reuse ( DDR3_1 )
& T; t) S: n2 l$ u5 f C0435 NO - member of reuse ( DDR3_1 )
" ]; ^+ r/ Q- ^ C0436 NO - member of reuse ( DDR3_1 )2 P9 C- K0 ~. J+ y
C0437 NO - member of reuse ( DDR3_1 ). M+ e7 n# W: y
C0438 NO - member of reuse ( DDR3_1 )5 ^. |: r$ ]- u }, G/ o" _
C0439 NO - member of reuse ( DDR3_1 )
9 Q5 |) z3 f' U6 v C0440 NO - member of reuse ( DDR3_1 )
5 C: W; J' \0 }- |, P: Q( \/ h8 ^' N C0441 NO - member of reuse ( DDR3_1 )
/ g' k7 ^$ ^7 I; V1 _: }+ N C0442 NO - member of reuse ( DDR3_1 )
- z& Y7 E1 Y" v$ y. y; o% i C0443 NO - member of reuse ( DDR3_1 )) c6 G- [4 l, N
C0444 NO - member of reuse ( DDR3_1 )
. Y. ]1 c3 W0 b, ? C0445 NO - member of reuse ( DDR3_1 ), }: d4 `- J9 B$ R
C0446 NO - member of reuse ( DDR3_1 )
/ G* R, e# h" Q4 \* E$ b0 k$ E0 L C0447 NO - member of reuse ( DDR3_1 ), |! r2 C! ^3 Q. P) Q P" V) f
C0448 NO - member of reuse ( DDR3_1 )9 r% A, @! A* _" z
C0449 NO - member of reuse ( DDR3_1 )! I3 ^8 a+ G/ f+ f N8 Z( F! a
C0450 NO - member of reuse ( DDR3_1 )
6 P% `; W. I% T" X$ t" c8 e6 p/ t C0451 NO - member of reuse ( DDR3_1 )' I" R' J: c1 Y7 G) w' b
C0452 NO - member of reuse ( DDR3_1 )
# I& C1 Q) {$ @- m& y C0600 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )
+ Y! d& z4 s6 Q$ a! ] C0702 NO - value/tol. mismatch
& w ~* C! W1 x9 Y( X C0703 NO - value/tol. mismatch ; D" L% E2 {4 W0 R: Q* t, e+ W
C0707 NO - part type mismatch ( C10U-0805-10-X5R-10-M )
! N3 @8 S' n8 y/ n$ Y C0801 NO - value/tol. mismatch
" G' z7 r! j7 F3 S0 M w5 \0 \ C0802 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )
^1 M' H' K$ E# R" ^+ e C0803 NO - part type mismatch ( C10U-0805-10-X5R-10-M )
* W& e9 |0 W" Z3 Q C0804 NO - value/tol. mismatch
4 ~& t9 |. m2 V7 L, i C0805 NO - part type mismatch ( C4.7U-0805-25-X5R-10-M )2 o% X8 I, @8 r& M* t% y( X
C0806 NO - part type mismatch ( C4.7U-0805-25-X5R-10-M )$ j: N. Q u6 u# N3 {
C0808 NO - part type mismatch ( C10U-0805-10-X5R-10-M )" P" B: z% h8 {( H% z! u! z
C0809 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )
! k7 q, |8 C2 L# D7 w4 q C0812 NO - part type mismatch ( C10U-0805-10-X5R-10-M )# `9 P1 q) @0 V. W9 C
C0816 NO - part type mismatch ( C4.7U-0805-25-X5R-10-M )
# P1 Y9 a9 I) [0 I: R+ p C0817 NO - part type mismatch ( C4.7U-0805-25-X5R-10-M )
% U0 d+ h% B K+ k) r C0819 NO - part type mismatch ( C4.7U-0805-25-X5R-10-M )
3 l% `5 W2 M: ?" t. v" F7 v) `" | C0821 NO - part type mismatch ( C1U-0805-25-X5R-10-M )
' b: Z; w3 r9 S C0822 NO - part type mismatch ( C4.7U-0805-25-X5R-10-M )0 E& y! i! F7 A9 i
C0824 NO - part type mismatch ( C1U-0805-25-X5R-10-M )
% H- V8 V: J( |9 V6 d C0825 NO - part type mismatch ( C4.7U-0805-25-X5R-10-M )
9 l6 o7 e8 a+ a+ B2 t/ I0 U C0826 NO - part type mismatch ( C4.7U-0805-25-X5R-10-M )
, s, ]$ y9 N Y* ?- n% F! v C0902 NO - part type mismatch ( C10U-0805-10-X5R-10-M )
+ o. s: I# d& G7 E! K* ~ C0905 NO - part type mismatch ( C10U-0805-10-X5R-10-M )
Q8 Y! G' h# j! @6 g& ] C0906 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )$ O2 S# j* V% T& o7 y1 D
C0907 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )& Q& A& [$ I- [- H8 c
C0910 NO - part type mismatch ( C10U-0805-10-X5R-10-M )
- v1 w0 [5 ~5 {) j C0911 NO - part type mismatch ( C10U-0805-10-X5R-10-M )
: R$ a2 |7 E* e- J$ j& I& I C0914 NO - part type mismatch ( C10U-0805-10-X5R-10-M )
) g# w& K. z9 c7 I J' _! n C0915 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )
" ~6 v- ?* D+ ^, O4 M# \ C0916 NO - part type mismatch ( C10U-0805-10-X5R-10-M )" R( `: F _( H2 w+ X& q
C0918 NO - part type mismatch ( C10U-0805-10-X5R-10-M )
* t4 q- h. h- M$ E- N C1006 NO - part type mismatch ( C470N-0402-16-X5R-10-M )
# W6 W: ^6 M- {' O C1007 NO - part type mismatch ( C470N-0402-16-X5R-10-M )
: R" k. ^& T! s1 q C1008 NO - part type mismatch ( C470N-0402-16-X5R-10-M )
1 M- g0 {7 @* m' Z! p C1009 NO - member of reuse ( DDR3_1 )
% N. Q4 i2 d, I0 |( b1 s$ ~4 W C1012 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )
$ ^" v* |, V; S; |4 L4 x C1013 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )
$ `9 Q# ^/ n# w% B t' j$ f0 y C1014 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )8 ^0 O3 j, H6 I3 Q
C1015 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )6 P) X. r* B9 N
C1016 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M ); H, l9 O1 J/ `. `* z7 v
C1018 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )- x5 ^" Y8 Y$ H1 `
C1019 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )% j+ @7 O) t i8 i6 D2 B
C1020 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )
; ?. R* P6 f0 b$ J+ b C1025 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )
7 j# P$ A$ A5 z& ~2 p0 s C1026 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )( ~9 J. H. H. R, m4 Z
C1029 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M ): Q' P: S+ c. z7 d; H/ T
C1032 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )
5 M2 g) S9 k- n! m C1037 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )
: D% A1 K5 H3 ]: X8 ] C1038 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )2 l/ ^, w% ?) W6 q: ~3 P( V
C1042 NO - part type mismatch ( C10U-0805-10-X5R-10-M )+ U- T; {- R$ @+ l. p. M
C1045 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )
# f6 @8 r( A) O. L C1049 NO - part type mismatch ( C10U-0805-10-X5R-10-M )
; E* y$ t3 s) e* l9 y C1106 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )2 [0 l7 G/ l( @3 d. D; K
C1107 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M ). ^+ h" {5 w+ q1 F" n. F! f! O
C1108 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )
% B. L* G$ d( a2 E- A) a( s2 L C1110 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )
3 ^5 B3 K; E2 T) U9 `: b C1118 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )
9 N. o( L, e- a* {' R9 c C1120 NO - part type mismatch ( C33P-0402-50-C0G-5-M )1 M I+ c' U/ m, _, W7 B% E1 E& `
C1121 NO - part type mismatch ( C33P-0402-50-C0G-5-M )
; r2 d' e5 u! f3 Z C1122 NO - part type mismatch ( C33P-0402-50-C0G-5-M )
/ u7 \$ H6 v8 v5 C1 D. n C1123 NO - part type mismatch ( C33P-0402-50-C0G-5-M )! M" W: t0 ?7 f
C1124 NO - part type mismatch ( C33P-0402-50-C0G-5-M )
2 P. D0 j5 F B$ ~- _+ M, o' w C1125 NO - part type mismatch ( C33P-0402-50-C0G-5-M )
) a. b1 E9 g/ W4 k C1126 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )6 I1 z" `2 Y/ S' G# y: I
C1127 NO - part type mismatch ( C18P-0402-50-C0G-5-M )
4 d: Q0 ~1 F4 a: N5 @" e! D$ K6 t: m C1128 NO - part type mismatch ( C18P-0402-50-C0G-5-M )7 p+ Z& O4 _% G* p- `
C1200 NO - part type mismatch ( C1P-0402-50-NP0-5-M )
' R$ w6 T- _5 w$ x. Y) ` C1201 NO - part type mismatch ( C1P-0402-50-NP0-5-M )- [6 ]! t8 Z5 O" ~2 Z+ o4 z9 F
C1202 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )9 V/ l# A/ a' M9 j$ h- k0 e9 Q
C1203 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )
8 ~; u/ A( p6 N$ o C1204 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )
3 Z8 t- Q- y+ T3 p* R, r C1205 NO - part type mismatch ( C10U-0805-10-X5R-10-M )
' U3 X1 @+ F6 f4 k! n C1207 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )- O6 k6 F! A7 F) ]9 Q
C1209 NO - part type mismatch ( C18P-0402-50-C0G-5-M )
; y; v) P9 z. A- R2 P C1210 NO - part type mismatch ( C18P-0402-50-C0G-5-M )% T& V, Z! B, V* h6 r% |$ v2 Y: f. x' E8 R
C1211 NO - part type mismatch ( C18P-0402-50-C0G-5-M )
( p- c9 P. L4 }" e C1300 NO - part type mismatch ( C1P-0402-50-NP0-5-M )- G& }& C) e: x
C1301 NO - part type mismatch ( C1P-0402-50-NP0-5-M )4 l% {6 I0 Q. p# N/ s8 [
C1305 NO - part type mismatch ( C10U-0603-6.3-X5R-20-M )( ]8 I2 [/ A R6 l- V f' A
C1600 NO - part type mismatch ( C4.7U-0603-6.3-X5R-10-M )$ b/ w. ?- p) K
C1603 NO - part type mismatch ( C1P-0402-50-NP0-5-M )- p0 |) C% _& m. L
C1604 NO - part type mismatch ( C1P-0402-50-NP0-5-M )6 w+ B. h' F h$ g) ?3 P
C1605 NO - part type mismatch ( C1P-0402-50-NP0-5-M )0 d6 @( H: T5 a/ i
C1606 NO - part type mismatch ( C1P-0402-50-NP0-5-M )3 G4 C2 [' N# j0 D4 f
D0200 NO - part type mismatch ( DIODE_SCHTKY-40V-1A ). S' f6 S$ A# g3 o f
D0800 NO - part type mismatch ( D-RSX101VA )7 G4 X# a) m: @
D0801 NO - part type mismatch ( D-RSX101VA )# d+ F# b. y( g a' X/ e
D0900 NO - part type mismatch ( ESD-ESD9B5.0ST5G )* B) J, n- m1 c4 u1 J8 T' ]
D0901 NO - part type mismatch ( ESD-ESD9B5.0ST5G )
' L& ?/ }3 n% j2 k D0902 NO - part type mismatch ( ESD-ESD9B5.0ST5G )( g! h3 o! ?" Y( u0 ]/ ?- k
D0903 NO - part type mismatch ( ESD-ESD9B5.0ST5G )
/ `3 ]1 a w" Z' m$ I+ ? D0904 NO - part type mismatch ( D-RSX101VA )
9 Q! y+ r" {# z" [& ] D0905 NO - part type mismatch ( D-RSX101VA ); \* W0 ~4 U% `. [" O
D1000 NO - part type mismatch ( DUALDIODE_CC_SOT23 )
. t9 z3 l+ z" N+ x# R D1001 NO - part type mismatch ( DIODE_SCHTKY-40V-1A )
5 ~7 L+ w# p! y: z: ^- X$ t# Q" O D1100 NO - part type mismatch ( ESD-ESD9B5.0ST5G )
4 i A! D: z1 I! b: r' ` D1101 NO - part type mismatch ( ESD-ESD9B5.0ST5G )0 m5 w0 N2 n) h' X
D1102 NO - part type mismatch ( D-RSX101VA )
8 j* B: O" O3 e" w* ] D1200 NO - part type mismatch ( ESD-ESD9B5.0ST5G )! w' o* j \- X' ~. F n8 N
D1201 NO - part type mismatch ( ESD-ESD9B5.0ST5G )) p+ m w# ?) D6 `$ B
D1202 NO - part type mismatch ( ESD-ESD9B5.0ST5G )& M2 T3 h# f T! q) l
D1203 NO - part type mismatch ( ESD-ESD9B5.0ST5G )
7 c! E- b5 [# L& C! z# I D1204 NO - part type mismatch ( ESD-ESD9B5.0ST5G )3 ?0 O. b# O m8 c* o) k- B- h
D1205 NO - part type mismatch ( ESD-ESD9B5.0ST5G )) T. [3 {% k0 d3 T
D1206 NO - part type mismatch ( ESD-ESD9B5.0ST5G )
6 z! }' d K P. `) Z. l D1207 NO - part type mismatch ( ESD-ESD9B5.0ST5G )' }( g6 A3 R2 K3 X5 I* Y
D1208 NO - part type mismatch ( ESD-ESD9B5.0ST5G )
. ]9 L ?" x+ T D1209 NO - part type mismatch ( ESD-ESD9B5.0ST5G )" |, p0 u9 @" B U( M% n
D1210 NO - part type mismatch ( ESD-ESD9B5.0ST5G )
) r# y, U1 a9 |" `, M" Z9 K D1300 NO - part type mismatch ( D-RSX101VA )+ O. K- ~! m) t% l) a
J0700 NO - part type mismatch ( HDMI_F_19 )
8 V# m$ ]5 N& V4 m& ]* H% M5 ? J0801 NO - part type mismatch ( FPC-0.5MM-40PIN )
$ d' [( Q& H/ ?9 R6 H/ P+ O! I9 p J0900 NO - part type mismatch ( USB-MICRO-B-SINK-USB05_8278 )
, S1 A* z/ I' H! P0 H J0901 NO - part type mismatch ( DS-210 )
* _+ L1 P, p, `/ G( l J0902 NO - part type mismatch ( BAT )8 [6 y5 `+ u/ s5 z; O, `7 @
J1001 NO - part type mismatch ( CON-0.5-8PIN-UP )6 g. n! y1 X, g; ?) e$ }
J1100 NO - part type mismatch ( ATOM010070020001 )
* _- G% \& s/ f) c J1101 NO - part type mismatch ( ATOM010070020001 )
* m+ b- @. X3 ]) N9 o2 j J1102 NO - part type mismatch ( ATOM010070020001 )
. u0 b2 _6 a8 }. L( D) d J1200 NO - part type mismatch ( TF-PP-ATOM_MR01A_01202 ), F: e" [1 U$ Z# j) U' b
J1201 NO - part type mismatch ( HOST_USB_JACK )
' u4 l. P. p/ B- | J1202 NO - part type mismatch ( CON_ANT )
- L- G' n9 B6 u' Z% w1 V* d N! U% G J1300 NO - part type mismatch ( CON_ANT )
3 c' t4 F) r" [0 s; ]4 a b J1301 NO - part type mismatch ( TP4-2P54 )
8 e' u9 s2 u& M, f5 R5 r J1600 NO - part type mismatch ( CON_ANT ); X; r. e3 O( v+ V; C2 D7 B# A
J1601 NO - part type mismatch ( CON_ANT )' E6 y( N, a4 z' M+ ^" c
K1000 NO - part type mismatch ( KEY-4PIN-EVQP7C01K )
- G1 c8 n" S& P8 o F4 L) U K1500 NO - part type mismatch ( KEY-4PIN-EVQP7C01K )9 h/ @% g4 c' j; M) f
K1501 NO - part type mismatch ( KEY-4PIN-EVQP7C01K )4 o4 k+ _: S* [0 j. B
K1502 NO - part type mismatch ( KEY-4PIN-EVQP7C01K )/ B# q: u g9 j* t
L0800 NO - part type mismatch ( COMMONCHOKE-90OHM )6 y/ k( H$ Z" t
L0801 NO - part type mismatch ( COMMONCHOKE-90OHM )1 Y0 Q, Y- a7 p
L0802 NO - part type mismatch ( COMMONCHOKE-90OHM )
. z2 W+ g- v$ i L0803 NO - part type mismatch ( COMMONCHOKE-90OHM )! o( V5 p3 m2 b: g9 v3 U
L0804 NO - part type mismatch ( FB-120R-100MHZ-2.7A-0603 )9 x _3 N6 ]! l2 }8 `2 _
L0805 NO - part type mismatch ( L10U-3X3-100K-700MA-20-T )
8 A2 C2 z$ E; d, g- w L0806 NO - part type mismatch ( L10U-3X3-100K-700MA-20-T )
! k( n1 h% z6 k. Y L0807 NO - part type mismatch ( COMMONCHOKE-90OHM )! h4 S6 i: G- j8 }1 Y
L0900 NO - part type mismatch ( LED-BLUE-0603-19_217BHC )
8 U& Z# S* X$ F% {. i) M0 R L0901 NO - part type mismatch ( LED-BLUE-0603-19_217BHC )3 [; b8 y3 H1 |3 [3 @
L0902 NO - part type mismatch ( L1.8U-4.8X4.8X1.8-100K-2.4A-20-T )
+ W; Y( H2 i- D7 h L0903 NO - part type mismatch ( FB-120R-100MHZ-2.7A-0603 ); v3 [4 R) N: M! l* @( N% w6 U$ ?
L0904 NO - part type mismatch ( FB-120R-100MHZ-2.7A-0603 )
1 x; C( o' r+ s L1000 NO - part type mismatch ( L1.0U-4.8X4.8X1.8-100KHZ-2.65A-20-T )
Y1 }+ d+ e; ]; ^6 |: h& X L1001 NO - part type mismatch ( L1.0U-4.8X4.8X1.8-100KHZ-2.65A-20-T )
# r0 p: ]! S7 _. P, p) y L1002 NO - part type mismatch ( L2.2U-3015-600M-1.5A-20 )
5 s8 {0 b# z9 V L1003 NO - part type mismatch ( L1.0U-4.8X4.8X1.8-100KHZ-2.65A-20-T ); I7 N- o7 v- ]$ G" c
L1004 NO - part type mismatch ( L1.0U-4.8X4.8X1.8-100KHZ-2.65A-20-T )
) h8 e1 p; v1 ~- z+ s2 L L1005 NO - part type mismatch ( L1.0U-4.8X4.8X1.8-100KHZ-2.65A-20-T ): @0 e4 I6 o$ G6 C" k
L1006 NO - part type mismatch ( LED-BLUE-0603-19_217BHC ). q9 r, g9 L( t% y9 T
L1100 NO - part type mismatch ( FB-120R-100MHZ-2.7A-0603 )
# l+ F; u3 R& V& ?$ y7 G# | L1102 NO - part type mismatch ( FB-120R-100MHZ-2.7A-0603 )
5 z& x/ [/ K0 P+ C2 S L1103 NO - part type mismatch ( FB-120R-100MHZ-2.7A-0603 )
# p3 z: E( e; R% a0 a L1106 NO - part type mismatch ( FB-120R-100MHZ-2.7A-0603 )* j. d& Y0 [- e/ s ~5 ^/ m
L1107 NO - part type mismatch ( FB-120R-100MHZ-2.7A-0603 )4 j: n+ w" s: I
L1200 NO - part type mismatch ( FB-120R-100MHZ-2.7A-0603 )
) H, T% _( L, g4 ? L1201 NO - part type mismatch ( L4.7N_0402 )7 n O1 g9 x' Q" f# o' m/ t
L1300 NO - part type mismatch ( L4.7N_0402 )3 u8 X- r8 {) ?( U0 k
L1400 NO - part type mismatch ( FB-120R-100MHZ-2.7A-0603 )- e+ w; b% J. E
L1401 NO - part type mismatch ( FB-120R-100MHZ-2.7A-0603 )
2 F9 ~ u5 {% N* e, i# }. H L1500 NO - part type mismatch ( LED-BLUE-0603-19_217BHC )
3 k$ h9 y( @1 F L1600 NO - part type mismatch ( L4.7N_0402 )" u4 b: j! |3 }# k
L1601 NO - part type mismatch ( L4.7N_0402 )
* [( B6 [) S8 B7 F( r* b2 e Q0800 NO - part type mismatch ( MOS-P-DMP2215L-D )7 M/ H6 j4 t/ g0 H& V+ a
Q0801 NO - part type mismatch ( Q-NPN-2N5551S-SOT23 )2 b' o7 C# [# j3 Q! f/ P ?
Q0900 NO - part type mismatch ( MOS-P-DMP2215L-D )$ {5 d H" p0 [+ Z9 Q5 t, j
Q0901 NO - part type mismatch ( Q-NPN-2N5551S-SOT23 )
4 F$ ]9 x7 D1 y. F: i) J Q0902 NO - part type mismatch ( MOS-P-DMP2215L-D )
1 y( q$ @7 _: i( `* H Q1000 NO - part type mismatch ( Q-NPN-2N5551S-SOT23 ) H( |! h9 y3 O4 ^! ~
Q1001 NO - part type mismatch ( MOS-P-DMP2215L-D )/ Z! ]! E8 Q0 I( ?! \
Q1100 NO - part type mismatch ( MOS-P-DMP2215L-D )
0 Z- ?, }7 D* m# {4 I Q1101 NO - part type mismatch ( MOS-P-DMP2215L-D )
8 |8 m, P: j+ F" ^: F Q1102 NO - part type mismatch ( MOS-P-DMP2215L-D )" n$ A) S% F8 W, [
Q1103 NO - part type mismatch ( Q-NPN-2N5551S-SOT23 )
) _6 d2 ~' u0 B4 _+ C! `# | Q1200 NO - part type mismatch ( MOS-P-DMP2215L-D )
3 C+ U" N5 ?( V3 A ]! \ Q1201 NO - part type mismatch ( MOS-P-DMP2215L-D )
- x$ N! e- X' e4 I' u' h Q1202 NO - part type mismatch ( Q-NPN-2N5551S-SOT23 )- K/ `" l2 ]1 g; Q @/ @! [6 w
Q1203 NO - part type mismatch ( Q-NPN-2N5551S-SOT23 )
: X( \3 X" b* | z0 A: e2 @ Q1300 NO - part type mismatch ( MOS-P-DMP2215L-D )
8 X, ^6 v& C' o& n; v; Q Q1301 NO - part type mismatch ( Q-NPN-2N5551S-SOT23 )
. K7 x1 o& H+ X2 b5 ?/ S" o1 Q Q1302 NO - part type mismatch ( Q-NPN-2N5551S-SOT23 )# K+ u! l2 q2 W# W! }) f
Q1500 NO - part type mismatch ( Q-NPN-2N5551S-SOT23 )8 y" p- P0 e( ?; r
R0205 NO - part type mismatch ( R0.02-0805-5-Y )
; A& v6 N0 H+ s8 ] R0209 NO - value/tol. mismatch / v5 @) S. N9 p
R0210 NO - value/tol. mismatch ; Z8 A/ g& l3 \) l I- _7 @
R0212 NO - value/tol. mismatch - C( R' r; z0 E9 ]
R0214 NO - value/tol. mismatch
! B a3 F( M7 p7 L2 Q R0308 NO - value/tol. mismatch
- G u$ T/ A& Q- j) ? V R0309 NO - value/tol. mismatch
8 F9 S2 h* X" H- [/ i! c0 g$ P R0310 NO - part type mismatch ( R2.2M-0402-5-Y )
4 a+ e" t8 _: _- P. }- u R0314 NO - part type mismatch ( R10M-0402-5-Y )1 Y k3 y) u2 @' c9 w% k3 | l
R0315 NO - part type mismatch ( R10M-0402-5-Y )
2 S; \- O( y6 d( J8 e R0400 NO - glued
2 j; L9 ^# x$ K1 o R0401 NO - glued
1 z' g7 A; x! n: g R0402 NO - glued/ Y0 @6 V* R" a/ L+ o; R
R0403 NO - glued
& M! Q1 w, Z0 S R0404 NO - member of reuse ( DDR3_1 )
( b& T0 `2 Z C# C/ @1 M R0406 NO - member of reuse ( DDR3_1 )' @- m/ `1 p" S7 t
R0407 NO - member of reuse ( DDR3_1 )0 `+ [! K! z/ T
R0408 NO - member of reuse ( DDR3_1 )
) U6 j( U7 z5 s0 @ R0409 NO - member of reuse ( DDR3_1 )
& |: c1 q2 P/ J- P( O3 ]! n' Z# T% } R0410 NO - member of reuse ( DDR3_1 )
4 v& o% K9 k" w$ ` R0411 NO - member of reuse ( DDR3_1 )! ^" Z: |1 \% H# v, A
R0412 NO - member of reuse ( DDR3_1 )
8 L3 \ J G4 S7 g; d5 L y R0500 NO - part type mismatch ( R6.04K-0402-1-Y )
! i3 q1 C" l0 R, f% x# p- v R0501 NO - part type mismatch ( R6.04K-0402-1-Y )5 n7 X3 ^1 j, f9 J- Q$ h
R0505 NO - value/tol. mismatch
0 ?: N% X9 j8 f* s- R6 v( W R0506 NO - value/tol. mismatch
0 }4 s& e2 k( G: s) F R0702 NO - part type mismatch ( R1.6K-0402-1-Y )" J% M. u# b r6 {1 K: c
R0704 NO - value/tol. mismatch
2 d9 s, r& \( ] R0705 NO - part type mismatch ( R56K-0402-5-Y )
& P7 x+ Z/ K- @6 W R0706 NO - part type mismatch ( R56K-0402-5-Y )
( I f3 @8 [3 k% T$ f& H R0708 NO - part type mismatch ( R56K-0402-5-Y )4 ] w, X! N j1 f% d b
R0709 NO - part type mismatch ( R56K-0402-5-Y )0 o0 ?1 s9 }2 t* h# ?/ c* W
R0801 NO - part type mismatch ( R100K-0402-5-Y )
0 g- n& E' ?% B$ g7 h) K* Y R0803 NO - part type mismatch ( R4.7K-0402-5-Y )
# Z: |) s$ d9 q) S% v. H; c- C R0804 NO - part type mismatch ( R4.7K-0402-5-Y )
% }4 V1 I9 C7 j R0808 NO - value/tol. mismatch
: [; L8 B! b0 n+ E4 J R0809 NO - part type mismatch ( R82K-0402-1-Y )
5 v- g7 W4 u# i5 a/ y; [ R0810 NO - part type mismatch ( R1.6R-0805-1-Y )" ?& \/ A& J% U5 k7 ~% I
R0811 NO - part type mismatch ( R20K-0402-1-Y )
! B& `, y6 g/ g/ S6 }- N7 k R0812 NO - part type mismatch ( R100K-0402-5-Y )2 N+ S3 E- Y k7 y8 }
R0814 NO - part type mismatch ( R4.7K-0402-5-Y )5 d+ K: V) Q4 I9 v
R0815 NO - part type mismatch ( R100K-0402-5-Y )7 P) {5 Q/ e' D) X/ s8 h
R0816 NO - part type mismatch ( R100K-0402-5-Y )
2 M h2 H$ V0 h( o$ R/ M R0817 NO - part type mismatch ( R8.2K-0402-1-Y ) A+ P* ~+ w3 Q0 ^" x- h
R0818 NO - value/tol. mismatch : p2 w `8 G$ \' [3 F4 G4 T2 }4 c
R0820 NO - value/tol. mismatch
z. K5 T1 \8 u+ m3 s2 o R0823 NO - part type mismatch ( R47K-0402-1-Y )
( } L$ V$ C* }# h' `* u$ N R0824 NO - part type mismatch ( R5.6K-0402-1-Y )+ N: {2 L% V; \! R0 ^# ^
R0825 NO - part type mismatch ( R100K-0402-5-Y )* C/ v' A0 g) b- ?
R0832 NO - value/tol. mismatch
5 p7 E( j: a$ R2 z L( l R0834 NO - value/tol. mismatch
: s: W# p: v0 J+ l! ^5 f R0904 NO - part type mismatch ( R100K-0402-5-Y )
+ B$ \# @5 v* m R0906 NO - part type mismatch ( R0-0805-5-Y ), g6 {+ {5 |. G+ H! Z7 g8 {2 m. g
R0907 NO - value/tol. mismatch
) v- E9 H4 V8 Y) B. C( A6 S3 u R0909 NO - part type mismatch ( R100K-0402-5-Y )& Z- X% [; G8 ^' ?% t
R0910 NO - part type mismatch ( R1K-0402-5-Y )8 d& I9 _; ^! D; U& w$ s6 {
R0911 NO - part type mismatch ( R1K-0402-5-Y )
: c' K- N, ?% t* s3 \ R0912 NO - part type mismatch ( R8.7K-0402-1-Y )
. u) C. R# O9 H" |, _3 u8 W R0913 NO - value/tol. mismatch
2 X& t/ Z% m' ~- b7 A' A& L R0914 NO - part type mismatch ( R82K-0402-1-Y ); f* O( `8 x2 h# U
R0916 NO - value/tol. mismatch & e4 S- C: Y5 e, S/ c* ~
R0917 NO - part type mismatch ( R0.05-0805-5-Y )
6 I& b |4 h, L3 K" u5 f/ h R0918 NO - part type mismatch ( R10-0805-5-Y )
( _ B, k; C( c0 p8 p R0919 NO - part type mismatch ( R47K-0402-1-Y )
: X& j5 V0 t" p! I' e3 {2 `$ u R0920 NO - part type mismatch ( R8.2K-0402-1-Y )
! F0 U! a1 ^" ] R0921 NO - part type mismatch ( R30K-0402-1-Y )3 _! g8 H4 [ c/ i5 e) ?
R0923 NO - part type mismatch ( R4.7K-0402-5-Y )* o0 B( v/ ]1 C3 I
R0924 NO - part type mismatch ( R150R-0402-5-Y )1 `. B( `% C: h1 O% g
R0925 NO - part type mismatch ( R150R-0402-5-Y ). X8 `4 i% C$ x1 R2 B
R0927 NO - part type mismatch ( R100K-0402-5-Y )* {* M4 X& H1 c
R0928 NO - part type mismatch ( R4.7K-0402-5-Y )
' F. ~6 \# a* u! ? R0930 NO - part type mismatch ( R8.7K-0402-1-Y )! o D, A) M; n# _9 O4 h
R0931 NO - part type mismatch ( R4.7K-0402-5-Y )
4 I* f- t' i7 w/ p: F. T; c* ` R1000 NO - part type mismatch ( R100K-0402-5-Y )/ K% W7 y8 Z/ |( ^0 V$ n
R1002 NO - part type mismatch ( R56K-0402-5-Y ) h1 U8 w, d0 Y% S8 i1 }5 D! c
R1004 NO - part type mismatch ( R100K-0402-5-Y )+ j+ w8 I+ d! _. g* @
R1006 NO - part type mismatch ( R1K-0402-5-Y )
: ^" S* l3 c0 p R1008 NO - part type mismatch ( R56K-0402-5-Y )( H0 o: K! q# z9 f9 L- o
R1011 NO - value/tol. mismatch
- M% M6 B: [! Z: A4 \& D G R1012 NO - value/tol. mismatch
6 s9 a% j# n4 I9 Z' M9 W R1014 NO - part type mismatch ( R100K-0402-5-Y )! G% Q, C8 Y8 K' B n$ I1 ?1 P
R1017 NO - part type mismatch ( R100K-0402-5-Y )
3 Q- G0 E4 _" M" V, A R1107 NO - part type mismatch ( R22-0402-5-Y )1 _6 \, I P8 Q# l; B
R1109 NO - part type mismatch ( R1K-0402-5-Y )
- s+ }( u3 z7 l# N: Y R1110 NO - part type mismatch ( R1K-0402-5-Y )
: P3 a% {+ t9 v& g R1113 NO - part type mismatch ( R1K-0402-5-Y )
) t7 E6 b8 z. j r R1114 NO - part type mismatch ( R100K-0402-5-Y )
: w* N8 y- E0 k; p R1116 NO - part type mismatch ( R1K-0402-5-Y )1 |4 m2 P$ J* s3 I- _7 Z7 }
R1117 NO - value/tol. mismatch 6 J. Q- K* }5 Z- h) Y
R1118 NO - part type mismatch ( R4.7K-0402-5-Y )
1 t, m; { z3 D! ]. C R1200 NO - part type mismatch ( R100K-0402-5-Y ) [8 l3 y) S1 p% |
R1209 NO - value/tol. mismatch
- O. M, t/ R/ G! x' W R1210 NO - part type mismatch ( R20K-0402-1-Y )
. L" B3 D4 T- |/ T" t& e" J' E R1211 NO - value/tol. mismatch
/ v! e/ Z; G* h; W& d( l7 L R1212 NO - value/tol. mismatch ! z2 n% Y0 M3 G8 ? g
R1213 NO - value/tol. mismatch : h+ e+ N2 n4 {& p. J. B
R1214 NO - value/tol. mismatch " T; `7 A: |$ E2 H
R1215 NO - part type mismatch ( R30K-0402-1-Y )
+ w6 f$ L. N' Y$ j' y* A4 v7 o% l R1218 NO - part type mismatch ( R22-0402-5-Y ): K5 _6 [! `: _2 n6 j# D% P
R1221 NO - part type mismatch ( R22-0402-5-Y )2 u, r& n' o( P0 N6 N
R1222 NO - part type mismatch ( R22-0402-5-Y )
& }3 o+ _( t3 } R1223 NO - part type mismatch ( R22-0402-5-Y ): x* ~/ ^) W/ v/ x+ P6 X
R1224 NO - part type mismatch ( R22-0402-5-Y )/ t% a# G- T) D: F& r
R1225 NO - part type mismatch ( R22-0402-5-Y )
' B* n/ O+ \& F" A2 M" v* K- w R1230 NO - value/tol. mismatch
& F) t O' j* v. m, s R1231 NO - part type mismatch ( R100K-0402-5-Y )+ c# @( J! l( m
R1233 NO - value/tol. mismatch 1 o; K- W1 v. C/ f% E- m
R1237 NO - part type mismatch ( R33R-0402-5-Y ); n3 \. P1 }2 b e1 g
R1238 NO - part type mismatch ( R33R-0402-5-Y )
! {3 F& t2 s9 N+ ?! m R1239 NO - part type mismatch ( R33R-0402-5-Y )* ^2 ~ z/ Z9 `, y. d
R1240 NO - part type mismatch ( R33R-0402-5-Y )! b# Q$ Y5 y3 v, ?- b2 L
R1241 NO - part type mismatch ( R33R-0402-5-Y )
1 M z# }) O$ v$ {0 C R1242 NO - part type mismatch ( R33R-0402-5-Y )9 t2 L: d% o' v4 S& ]
R1243 NO - part type mismatch ( R100K-0402-5-Y )# h# w9 _, x1 u
R1244 NO - value/tol. mismatch
7 |0 ]) Y3 h6 x, \% k) E- D1 L& r R1245 NO - value/tol. mismatch * t9 Q3 d6 Z) B' ^% H
R1246 NO - value/tol. mismatch
z' g% n8 D0 { H* |8 z R1247 NO - value/tol. mismatch
/ K0 h! \/ X( s4 m3 _ R1248 NO - value/tol. mismatch
) v; [0 D. M+ w R1249 NO - value/tol. mismatch
4 ?9 n: n3 ?4 Y R1250 NO - value/tol. mismatch 6 D% \3 l$ X; t5 J m
R1251 NO - part type mismatch ( R22-0402-5-Y )5 l0 I% O, h9 ?) s0 J# Z
R1300 NO - value/tol. mismatch ) b- ?0 J, C, B+ f9 C8 V! O
R1302 NO - part type mismatch ( R100K-0402-5-Y )
, B% X& U; p; w R1304 NO - part type mismatch ( R4.7K-0402-5-Y )
1 x# V, a% K6 }4 x- q R1305 NO - value/tol. mismatch 9 z0 k$ p& [/ y! `9 z2 W
R1307 NO - part type mismatch ( R4.7K-0402-5-Y )6 N" Q& O' p$ `$ L5 B) s: \6 B+ A
R1308 NO - part type mismatch ( R4.7K-0402-5-Y )
8 V. S3 H1 w: f+ a, i: ^! h$ c6 d7 n) { R1310 NO - part type mismatch ( R4.7K-0402-5-Y )
" _4 D: ]6 Y; E7 h. r" { R1312 NO - value/tol. mismatch
, `, F. ^# n( p! z0 v% j/ w* f R1313 NO - value/tol. mismatch
) I0 V, {& c( ^# Q5 X. C R1314 NO - value/tol. mismatch $ D6 {; T/ L. Q0 t
R1318 NO - part type mismatch ( R100K-0402-5-Y )
$ W3 r! v% l- G! T' e( m4 {! s3 \, D R1319 NO - part type mismatch ( R1K-0402-5-Y )9 ^1 N' F& q: u" A2 n
R1324 NO - part type mismatch ( R4.7K-0402-5-Y )' ^+ e5 r+ q, J8 u
R1326 NO - part type mismatch ( R4.7K-0402-5-Y )6 ~) y z0 t7 u6 O+ W& S
R1328 NO - part type mismatch ( R4.7K-0402-5-Y )
" o9 X$ J5 F$ g9 G \5 o; l* b R1329 NO - part type mismatch ( R4.7K-0402-5-Y )
+ x# ]6 v# N7 D+ L ^ R1332 NO - part type mismatch ( R4.7K-0402-5-Y )3 c5 y9 M& v% j: j8 @
R1400 NO - part type mismatch ( R56K-0402-5-Y )
+ y: i2 Y6 r2 k R1401 NO - part type mismatch ( R56K-0402-5-Y )
- V! B, }6 N. [" @& p& o$ S+ ^ R1402 NO - part type mismatch ( R56K-0402-5-Y )' X3 B8 ^$ r3 m( I( W2 ^
R1403 NO - part type mismatch ( R56K-0402-5-Y )
: t4 S6 n, Z" v9 C R1404 NO - part type mismatch ( R56K-0402-5-Y ); o2 q1 p; |6 }- O1 s
R1405 NO - part type mismatch ( R56K-0402-5-Y )
# O1 u$ U1 @( u R1406 NO - part type mismatch ( R56K-0402-5-Y )
4 ?6 K3 y. y3 m: Z R1407 NO - part type mismatch ( R56K-0402-5-Y )
4 O5 }9 O: G8 D+ Q; Z4 H R1408 NO - part type mismatch ( R56K-0402-5-Y )
, H0 g+ @- _6 L R1409 NO - part type mismatch ( R4.7K-0402-5-Y )
3 O) E* U; ~$ l# _/ }2 R R1410 NO - part type mismatch ( R22-0402-5-Y )
; J7 N8 }$ c0 ?( j1 o R1411 NO - part type mismatch ( R22-0402-5-Y )# v* T' n: `( h& i, G" q! N
R1500 NO - part type mismatch ( R4.7K-0402-5-Y )! H+ J [3 P* d+ z q8 f
R1501 NO - part type mismatch ( R4.7K-0402-5-Y )
; L U$ t+ _- `( J# @' l R1502 NO - part type mismatch ( R4.7K-0402-5-Y )4 i) x8 b; P( ^$ a$ z2 h4 m6 b
R1503 NO - part type mismatch ( R4.7K-0402-5-Y ) _7 d6 J3 M8 ?0 O$ ?$ N, T
R1504 NO - part type mismatch ( R4.7K-0402-5-Y )6 ~' K9 S3 \( k7 B) X
R1505 NO - part type mismatch ( R4.7K-0402-5-Y )" j, L5 _. U: e( m. ^! b
R1506 NO - value/tol. mismatch ; _8 G! ]- }. _- R) p2 z! o2 ^
R1507 NO - value/tol. mismatch " h `2 J* X9 U. I& v
R1508 NO - part type mismatch ( R1K-0402-5-Y )
0 n8 N- R; x' J" M& p$ v2 t$ k R1509 NO - part type mismatch ( R1K-0402-5-Y )
+ x# P% T: J. o% i' F R1510 NO - part type mismatch ( R100K-0402-5-Y )
# V7 K4 u" H# ~ R1511 NO - value/tol. mismatch
! k: p4 m3 f8 G R1512 NO - value/tol. mismatch
, }( \) R1 h) \& u) W- }0 y! k+ l R1513 NO - value/tol. mismatch ! ?/ k! t* T* R7 ]# L- W3 |% W
R1514 NO - value/tol. mismatch
, \& R, u3 {( A R1515 NO - value/tol. mismatch , X+ B' x* L# ~. w0 b
R1516 NO - value/tol. mismatch
K! ~+ g) P# U% e; m! ] R1517 NO - value/tol. mismatch
' S' s' A* A1 W2 D R1518 NO - value/tol. mismatch
5 R+ B8 T& G$ k5 w$ }1 ] R1519 NO - value/tol. mismatch " y) |! C1 C) T4 l0 r0 U
R1520 NO - value/tol. mismatch
$ Y) |) ~8 u: j2 v# p4 v. L/ W3 X R1521 NO - value/tol. mismatch ( n0 ]1 U9 [$ u& \
R1522 NO - value/tol. mismatch
! T5 P6 J% ^- U! Q) u& t. N R1523 NO - value/tol. mismatch
0 b/ }4 [/ U7 e( d( _- m! j R1524 NO - value/tol. mismatch
7 ?) j9 ?/ \0 k- v* W R1525 NO - value/tol. mismatch
$ E1 U9 I/ K+ u8 E J& }$ a R1526 NO - value/tol. mismatch + Z$ H4 A! c$ x% Q8 i0 @
R1528 NO - value/tol. mismatch 8 {1 Q6 n" n: n2 Q
R1531 NO - value/tol. mismatch - H* x( D7 T6 H7 P
R1532 NO - value/tol. mismatch 0 Z% b. `% A" u% N; h
R1533 NO - value/tol. mismatch
( R5 [# i& n, F$ s2 y( U B3 L R1534 NO - value/tol. mismatch
6 D- A1 r. H5 O2 g9 i' n0 D R1537 NO - value/tol. mismatch # ?5 [6 {# A" Z5 o
R1540 NO - value/tol. mismatch
3 G* I5 }4 r9 n) L! S: D4 l1 e R1541 NO - value/tol. mismatch . ~! c' G; E% f" b; ^
R1542 NO - part type mismatch ( R4.7K-0402-5-Y )
! {. A9 m2 ?1 f" q* L5 ~8 i R1543 NO - part type mismatch ( R4.7K-0402-5-Y )8 Q, }( n4 h' g- z8 {2 ~3 Y
R1546 NO - value/tol. mismatch 7 \8 q( {! h& F" m( z
R1547 NO - value/tol. mismatch
% U$ I% \: R' d# g+ d R1549 NO - value/tol. mismatch / _- M7 i$ T# z3 q: w
R1550 NO - value/tol. mismatch h; K& {' W3 F4 ~
R1555 NO - value/tol. mismatch
- T2 J1 k* b0 W R1556 NO - value/tol. mismatch
* @* z( R0 Q% T2 m, Z1 K R1558 NO - value/tol. mismatch
* @, E- b- U$ v0 H {. R: z U R1606 NO - value/tol. mismatch
. H# x( S: S7 i: y T0300 NO - part type mismatch ( TP_1MM )- Q2 ^$ `/ s0 ~
T0301 NO - part type mismatch ( TP_1MM )
% C" q: d$ ?# h! i T0302 NO - part type mismatch ( TP_1MM )
0 e8 V$ A* n/ B# R! G5 b, m T0303 NO - part type mismatch ( TP_1MM )7 t/ _7 ~5 x& x7 k9 ?5 d
T0304 NO - part type mismatch ( TP_1MM )
( R1 J V5 N8 n* k$ o) E: ` T0305 NO - part type mismatch ( TP_1MM )
% b+ j) b+ O$ m! B- J' F" M T0306 NO - part type mismatch ( TP_1MM )' y3 k+ Z% U7 q
T0307 NO - part type mismatch ( TP_1MM )
4 W$ s* d' b' }9 R T0308 NO - part type mismatch ( TP_1MM ). P+ u2 M7 S, J: u( A$ j# D
T0309 NO - part type mismatch ( TP_1MM )4 }/ s4 h0 O+ W) {! ?
T0310 NO - part type mismatch ( TP_1MM )
! i$ g* t: \% [9 p T6 E0 U5 q/ D T0311 NO - part type mismatch ( TP_1MM )( H& U5 Q- F+ J+ T
T0312 NO - part type mismatch ( TP_1MM )
7 y. W( y( ^- R4 ` T0313 NO - part type mismatch ( TP_1MM )
4 T, _- F) V: I$ } T0314 NO - part type mismatch ( TP_1MM )6 r2 Q( ?+ P. M2 w. p2 t" {
T0400 NO - part type mismatch ( TP_1MM )7 P. L C* V: F1 Z7 S
T0500 NO - part type mismatch ( TP_1MM )
$ b/ Z5 u# m u, o+ e0 e9 I T0800 NO - part type mismatch ( TP_1MM )9 |3 G# _& Z9 L7 A. G
T0803 NO - part type mismatch ( TP_1MM )3 Y8 c2 \& d6 H+ W9 E
T0805 NO - part type mismatch ( TP_1MM )
+ z: N/ Q& W8 E% F0 D T0806 NO - part type mismatch ( TP_1MM )
* g9 g) z9 l0 |( T3 f T1000 NO - part type mismatch ( TP_1MM )
( Z% s8 ]% t8 j T1001 NO - part type mismatch ( TP_1MM )
0 k4 n; {" R0 h: W T1100 NO - part type mismatch ( TP_1MM )
5 U8 w5 P' M" ^- x# ?- A" ?5 u T1101 NO - part type mismatch ( TP_1MM )
8 A2 G# u4 N5 l+ y6 [% [7 Q4 m T1102 NO - part type mismatch ( TP_1MM )+ c0 T( z V; g8 m/ ~* ]+ @- p
T1103 NO - part type mismatch ( TP_1MM )
4 L% T# `: B) f* v/ Z T1104 NO - part type mismatch ( TP_1MM )
) B8 D+ F H/ T9 ? T1105 NO - part type mismatch ( TP_1MM )
$ N) B, A- A+ P TEST NO - part type mismatch ( TP_1MM ). N6 ^4 |/ h; h9 G+ m+ g6 U+ t; L
TP14 NO - part type mismatch ( TP_1MM )# |' K& N# P. O- C! r! {% Z& n
U0200 NO - glued
$ n3 @. \- ^& i& X$ Y8 m3 C" y U0401 NO - glued% ~/ h. L R5 [- L4 c
U0402 NO - glued
. Z/ G% t4 O, a- |* D' O: l$ r8 k U0403 NO - glued
1 s i. B) u. J1 e, M9 @1 | U0404 NO - glued
S! _: c3 q/ v N; D& A+ ]( i: ? U0700 NO - part type mismatch ( CM2020_TSSOP_38P ); b8 D! O% Y T2 H2 A! G6 ]9 c+ V; O7 v
U0801 NO - part type mismatch ( DC/DC-RT9293B-(20)GJ6 )! K4 T4 M$ J k" R+ [2 }
U0900 NO - part type mismatch ( CHARGE-IC-MP2611 )7 j' ^( ~" R* v4 `1 R) q! i) R
U0901 NO - part type mismatch ( MAX170401-CELL )2 P, u3 L; k v1 a2 H
U0902 NO - part type mismatch ( SY6280AAC-SOT25 )
! S; u0 c! x# [7 h8 S& N E( U0 ^ U0903 NO - part type mismatch ( TL431ACDBZR )+ V# m5 c' H, c: I* @
U1000 NO - part type mismatch ( MMPF0100NPEP_56P )
! f: p- A2 c) q0 v) ?- s: p6 O+ ^ U1001 NO - part type mismatch ( M-P/N-FDC6321C )
: E) u' c3 }! `2 `; J( {" O U1100 NO - part type mismatch ( WM8960_QFN_33P )- G y8 t9 \% R! s
U1102 NO - part type mismatch ( NLSV1T34 )! n, W" c# ~' Z0 s Y
U1200 NO - part type mismatch ( MXC6225XU )8 C% J! y& l# s" w6 q
U1203 NO - part type mismatch ( WIFI-REALTEK-8189ES )1 G# k7 E( C5 j- `. P1 w9 a! ]
U1204 NO - part type mismatch ( LDO-ADJ-SOT23-5-SGM2019 )
& ^' r- Q$ v+ @" }' I U1300 NO - part type mismatch ( RN-42-N )" K2 z+ k- _! i
U1400 NO - part type mismatch ( SDIN5C1-4G ); h7 [" Z7 s" Y5 `, b3 C5 v! ?
U1500 NO - part type mismatch ( NL7SP125 )
& c! X% b5 a3 ] U1600 NO - part type mismatch ( WIFI&BT-W16 )
$ F" r* V1 w1 r! y1 Q X0300 NO - part type mismatch ( XT-32.768KHZ-20PPM-3215 )) H2 M5 F1 N8 v
X0301 NO - part type mismatch ( XT-24MHZ-20PPM-3225 ). h/ e' A* M' M- t
0 A5 v: g/ U# [, W: j" \
