查看: 3769|回复: 2
尝试用PADS9.5转换Allegro,skill运行生产如下错误记录,请帮忙分析
发表于 2013-6-11 12:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ERROR: Techfile conversion failed!
) T3 z$ {- g/ V. I) ~WARNING: layer BOTTOM not found in layer table.  Check the allegro cross-section!3 n# B5 b8 e' g5 ^# O
WARNING: layer NONAME_2 not found in layer table.  Check the Allegro cross-section!
: g% H. j/ m# _+ G( B4 TWARNING: layer TOP not found in layer table.  Check the Allegro cross-section!4 ]& f3 A: R- _7 M
WARNING: layer NONAME_1 not found in layer table.  Check the Allegro cross-section!" G( z, w- M/ a7 M/ E
ERROR: no data issued for clearance DEFAULT
/ C  H4 f3 ^, \2 DERROR: no data issued for clearance DEFAULT|0.2
" e4 z. Z7 m5 jWARNING: layer SOLDERMASK_TOP not found in layer table.  Check the Allegro cross-section!
4 A, U$ s7 G( i1 q2 u% R2 FWARNING: layer SOLDERMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
7 ?- A4 p$ E- t; K8 U; E5 F& j6 f) tWARNING: layer PASTEMASK_TOP not found in layer table.  Check the Allegro cross-section!  L, ^& ]& x! ?  Q
WARNING: layer PASTEMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
  X+ r( w1 t0 t# f8 e2 wWARNING: layer FILMMASKTOP not found in layer table.  Check the Allegro cross-section!
! v" S3 j4 I! C% L& X; R* cWARNING: layer FILMMASKBOTTOM not found in layer table.  Check the Allegro cross-section!
* g5 C8 k/ Y+ ]9 X7 gERROR: Unable to issue shapes for padstack MSMDR00250X01700T - layer problems
% \; A' z- f  v. j* B5 yERROR: Unable to issue shapes for padstack MSMDR01700X00250T - layer problems
/ e0 t4 c: v2 {; j: KERROR: Unable to issue shapes for padstack MSMDR00600X02200T - layer problems
, C5 c% l  ^" \, z6 Q. n" {ERROR: Unable to issue shapes for padstack MSMDR00600X02100T - layer problems
9 [3 p$ I6 q4 o/ _' W$ ]ERROR: Unable to issue shapes for padstack MSMDR00600X01550T - layer problems0 H, ?2 V3 C. {( `8 X' m/ n
ERROR: Unable to issue shapes for padstack MSMDR00600X01100T - layer problems6 {2 m+ K2 S5 c: m
ERROR: Unable to issue shapes for padstack MSMDR01800X00600T - layer problems
7 I& l8 ]3 X0 s, B% P2 zERROR: Unable to issue shapes for padstack MSMDR01600X03300T - layer problems
  o" w0 n' B8 Y6 e/ G+ ?ERROR: Unable to issue shapes for padstack MSMDR01000X01600T - layer problems6 q9 A8 @9 z3 m: Y( J
ERROR: Unable to issue shapes for padstack MSMDR01400X01200T - layer problems3 ^% L3 c5 d  i, I0 [3 f
ERROR: Unable to issue shapes for padstack MSMDR00800X00900T - layer problems
! H/ g5 @% a% V4 T; pERROR: Unable to issue shapes for padstack MSMDR00900X01300T - layer problems+ G& D( T4 J/ C4 c, ]
ERROR: Unable to issue shapes for padstack MSMDR00600X01000T - layer problems; q  c3 }5 I6 l2 T! m: X# H# q9 j% W
ERROR: Unable to issue shapes for padstack MSMDR01000X01800T - layer problems. v2 L. {+ D7 @8 c9 r. \$ y
ERROR: Unable to issue shapes for padstack MSMDR02160X02700T - layer problems8 S! C( o- I7 c  K
ERROR: Unable to issue shapes for padstack MSMDR01400X01800T - layer problems
+ [% A/ l5 i9 O  O6 t* yERROR: Unable to issue shapes for padstack 1_00SQS - layer problems
& g2 |1 n7 _4 A1 f8 a& dERROR: Unable to issue shapes for padstack MSMDR01700X02500T - layer problems" M4 x  k3 Z3 r, O- e+ b3 x: L
ERROR: Unable to issue shapes for padstack MSMDR01150X02900T - layer problems5 `1 M! v. @7 S! c' j8 R' f8 @
ERROR: Unable to issue shapes for padstack SHAPE - layer problems
; C( Z8 |1 @+ D, Y, \, `ERROR: Unable to issue shapes for padstack MSMDR00700X01400T - layer problems
) @# h) p" s2 ?6 R1 QERROR: Unable to issue shapes for padstack MSMDR00350X01750T - layer problems  c: T. g- L; e; h/ X
ERROR: Unable to issue shapes for padstack MSMDR01100X02800T - layer problems/ n/ Y; S$ p" r/ F- |
ERROR: Unable to issue shapes for padstack MP1000CA - layer problems
$ ~% u" s6 p8 r" ]3 `' M& a1 FERROR: Unable to issue shapes for padstack MP0900CA - layer problems! g# v, Y% t0 O
ERROR: Unable to issue shapes for padstack MPS0900CA - layer problems
: S# ?- [) R- x7 e* kERROR: Unable to issue shapes for padstack MP3450CA - layer problems
: ?7 ]$ D% N* Q( t. AERROR: Unable to issue shapes for padstack MPS1100CA - layer problems& |8 o: R4 |% l- y
ERROR: Unable to issue shapes for padstack MP1100CA - layer problems
9 J6 J: @. J- @& n8 d/ EERROR: Unable to issue shapes for padstack MP1500CA - layer problems; Y/ p) Y5 X+ F3 D. Y$ h. o6 Q% j
ERROR: Unable to issue shapes for padstack MP0400X0950OA - layer problems
. O( |( d: W0 w/ AERROR: Unable to issue shapes for padstack MP1500SA - layer problems
6 k# \6 B4 h* k. C5 G$ M6 sERROR: Unable to issue shapes for padstack MP0800CA - layer problems
8 R1 k: v) U$ k6 J* xERROR: Unable to issue shapes for padstack MP0950CA - layer problems
) N' P6 {+ I; ~. ~$ A' uERROR: Unable to issue shapes for padstack MP0950SA - layer problems0 s+ w' u* h. W/ V+ @3 c
ERROR: Unable to issue shapes for padstack MP1200CA - layer problems( g3 |, x+ m% ]; T' k3 M0 D
ERROR: Unable to issue shapes for padstack MP1200SA - layer problems; P6 f. Z8 L) T. O
ERROR: Unable to issue shapes for padstack MP0700CA - layer problems
2 F2 j* y$ u7 y0 k3 b; D" pERROR: Unable to issue shapes for padstack MP0700SA - layer problems
/ m5 H( Z% x& E" g: r) J! ?6 U& z+ b# wERROR: Unable to issue shapes for padstack MP2300CA - layer problems
0 `8 z5 Y$ E( N" D6 uERROR: Unable to issue shapes for padstack MP1000SA - layer problems
7 E$ S" H6 G3 y  o& ^8 |0 X0 R3 C3 CERROR: Unable to issue shapes for padstack VIA - layer problems( U: q& O; g* \! H9 c* l! O
ERROR: Unable to issue shapes for padstack 005 - layer problems
9 q% r6 ^. ~! a1 }% P7 o' TERROR: Unable to issue shapes for padstack MARKT - layer problems
( C  B0 X- @$ P3 l& U1 dERROR: Unable to issue shapes for padstack MP0600X120OA - layer problems
1 p& e1 e% B3 C) EERROR: Unable to issue shapes for padstack MP1100SA - layer problems
1 [" W( K+ ~! a/ Q9 Y1 sERROR: Unable to issue shapes for padstack VIA - layer problems) e! ~5 x" L/ v$ G
WARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!+ U; G" b- j  B! `' d8 J  `
WARNING: layer ~TSM not found in layer table.  Check the Allegro cross-section!8 M$ }/ S, R# f  Q$ F3 Q
WARNING: layer ~BSM not found in layer table.  Check the Allegro cross-section!2 N0 k! d! d; {: j, m( v% B5 o( D& \
WARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!
+ X9 F: H" V: u1 x* bWARNING: layer ~BPM not found in layer table.  Check the Allegro cross-section!( l5 ~- G4 s+ A! V" y0 \
WARNING: layer ~TFM not found in layer table.  Check the Allegro cross-section!3 Q7 {- x2 m7 D: N
WARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!
4 x# ?! g% @6 q- S
发表于 2013-6-19 14:20 | 只看该作者
问题解决了吗?/ B" a5 @( v# C: ~
碰到同样的问题了
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    发表于 2013-6-22 17:21 | 只看该作者
    把PCB降低版本到15.x再试试。
    GMT+8, 2025-9-20 10:45 , Processed in 0.125000 second(s), 24 queries , Gzip On.
