jacklee_47pn 发表于 2013-6-10 19:23 4 T6 X% |! V( ? c. ], [2 v" I
狗版主這是為什麼呢? DATASHEET 根本沒有標示啊! 5 J9 N/ | Z" y8 e: c( X* G
+ d1 i5 B6 L; q- E是不是 DATASHEET 裡面所說 Output-pulse rise ti ... 2 d1 G: o, g% b( y
Manufacturers specify the maximum total resistance that may be used with their particular variant of the 555, and these maximum values are usually around 10 to 20MΩ, however using such high values can increase the error between calculated and actual frequencies, so for many uses a 1MΩ maximum can be recommended. The minimum total resistance value for the combination of R1 and R2 depends largely on the value of R1. The junction of R1/R2 is connected to pin 6 and to the trigger input pin 2. If the value of R1 is less than about 1KΩ, there is a danger that the trigger input may not be able reach a low enough voltage to trigger comparator 1, and so oscillations cannot take place." T* q1 m/ N) e0 k
: _0 ]3 w1 [: x3 R- @
From this it can be assumed that if R1 must be 1KΩ or above and R1 + R2 should be kept below 1MΩ; a 10nF capacitor would allow a suitable total resistance of around 100KΩ to be calculated. ~) d( M) B- C5 Q) X! L
L1 ~$ d# \) s+ B5 i3 M9 B: ]. g" N
{:soso_e162:}
; [, }+ t0 L4 s: J0 r- [0 {8 i; |, H6 r+ y
; b+ Z. R4 l8 Q9 D8 `
