查看: 21997|回复: 20
求助 ORCAD生成allegro网表出现警告,什么意思啊
    难过
    2020-12-10 15:47
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2013-6-4 10:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    Configuration File:, a  k( v3 w) b. ~) s
    C:\cadence\SPB_16.5\tools\capture\allegro.cfg
    / L( t: r( E; J; l; f( ~
    5 ^( o4 a" d9 Z. c& r' l8 r6 g3 a4 ?9 ?% ASpawning... "C:\Cadence\SPB_16.5\tools\capture\pstswp.exe" -pst -d "d:\cadence\infrared\infrared.dsn" -n "D:\CADENCE\INFRARED" -c "C:\Cadence\SPB_16.5\tools\capture\allegro.cfg" -v 3   -l 31 -s "" -j "PCB Footprint" -hpath "HPathForCollision"3 @5 ?. m' p1 K. t1 r$ A
    #1 WARNING(ORCAP-36006): Part Name "INDUCTOR_L-9_0S_PASSIVE_INDUCTOR" is renamed to "INDUCTOR_L-9_0S_PASSIVE_INDUCTO".
    ( a; q- ~. b- ]  X5 A2 O#2 WARNING(ORCAP-36006): Part Name "LM2575D2T-12_936A-02_LM2575D2T-5" is renamed to "LM2575D2T-12_936A-02_LM2575D2T-".
    / s! |1 D: t* j1 V) d& M#3 WARNING(ORCAP-36042): Pin "GND" is renamed to "GND#3" as visible power pin of same name already exists in Package LM2575D2T-12 , U19: New Controller, New Contorller.SchDoc (142.24, 200.66).
    4 \/ M" |, P# u6 }  _5 U. F7 v#4 WARNING(ORCAP-36042): Pin "GND" is renamed to "GND#6" as visible power pin of same name already exists in Package LM2575D2T-12 , U19: New Controller, New Contorller.SchDoc (142.24, 200.66).
    1 {  t& D% Z5 @4 [% m) C" Q#5 WARNING(ORCAP-36042): Pin "VSS" is renamed to "VSS#6" as visible power pin of same name already exists in Package LPC2119 , U2: New Controller, New Contorller.SchDoc (121.92, 30.48).6 b, A5 V2 {# K
    #6 WARNING(ORCAP-36042): Pin "Vss" is renamed to "VSS#42" as visible power pin of same name already exists in Package LPC2119 , U2: New Controller, New Contorller.SchDoc (121.92, 30.48).
    ; ^0 o4 t7 G: ]8 m8 J0 g' m9 a: j2 B
    #7 WARNING(ORCAP-3604
    ) {( m: Z% @0 R2 t2 [2): Pin "V3" is renamed to "V3#43" as visible power pin of same name already exists in Package LPC2119 , U2: New Controller, New Contorller.SchDoc (121.92, 30.48).* ^4 D, i2 D5 V6 t+ D: d5 v
    #8 WARNING(ORCAP-36042): Pin "V18" is renamed to "V18#17" as visible power pin of same name already exists in Package LPC2119 , U2: New Controller, New Contorller.SchDoc (121.92, 30.48).
    & E  v; {: }- M3 V+ O3 b#9 WARNING(ORCAP-36042): Pin "Vss" is renamed to "VSS#18" as visible power pin of same name already exists in Package LPC2119 , U2: New Controller, New Contorller.SchDoc (121.92, 30.48).
    6 k0 B) W$ R2 m# T! Y- s4 }" J#10 WARNING(ORCAP-36042): Pin "V3" is renamed to "V3#23" as visible power pin of same name already exists in Package LPC2119 , U2: New Controller, New Contorller.SchDoc (121.92, 30.48).
    & N  Z4 J4 M+ S3 j, _  O#11 WARNING(ORCAP-36042): Pin "Vss" is renamed to "VSS#25" as visible power pin of same name already exists in Package LPC2119 , U2: New Controller, New Contorller.SchDoc (121.92, 30.48)., T3 `+ I2 i. h, D
    #12 WARNING(ORCAP-36042): Pin "V18" is renamed to "V18#49" as visible power pin of same name already exists
    1 w6 Z/ F; k& x% s in Package LPC2119 , U2: New Controller, New Contorller.SchDoc (121.92, 30.48).
    , l: L5 R1 J4 p9 k$ w#13 WARNING(ORCAP-36042): Pin "V3" is renamed to "V3#51" as visible power pin of same name already exists in Package LPC2119 , U2: New Controller, New Contorller.SchDoc (121.92, 30.48).
    * [7 p7 s. j. _. z/ o5 T$ `7 i' q#14 WARNING(ORCAP-36042): Pin "OUT" is renamed to "OUT#2" as visible power pin of same name already exists in Package REG1117-5 , U7: New Controller, New Contorller.SchDoc (86.36, 264.16).7 M" J, K# J# [+ o7 G% G5 [/ e
    #15 WARNING(ORCAP-36042): Pin "OUT" is renamed to "OUT#4" as visible power pin of same name already exists in Package REG1117-5 , U7: New Controller, New Contorller.SchDoc (86.36, 264.16).
    ! Z2 x# m7 Q1 l. QScanning netlist files ...5 z! _( E" y" o, p3 Z
    0 q- b" [  Z6 Q( V
    Loading... D:\CADENCE\INFRARED/pstchip.dat% C, ?+ g4 e  P0 {  G/ B7 [) y
    - Z' \( N. z' l# S+ A- [- B; Y4 z
    8 ]/ a4 r: O1 H8 F$ `$ |7 c8 K, u* n8 m0 P2 F+ m
    Loading... D:\CADENCE\INFRARED/pstxprt.dat- _- f7 ]" F/ A) U; H& s6 F. F
    4 @4 `0 i2 g6 iLoading... D:\CADENCE\INFRARED/pstxnet.dat0 n5 q0 t8 t' `+ e
    packaging the design view...
    推荐
    发表于 2014-10-24 10:36 | 只看该作者
    part name太长了,   Device/Net/Pin name char limit 里面的值改一下就好了。如附件
    问一下大师, 图片上这种情况 只能缩短封装名称吗?有没有其他方法可以解决呢?(这种情况是:ORCAD 做原理图,出网表时后缀加了“,VALUE”,网表导入PADS9.5就出现这堆问题了,在不出VALUE时 ,是完全可以正确导入  详情 回复 发表于 2015-10-27 17:55
    推荐
    发表于 2015-10-27 17:55 | 只看该作者
    hanbingchong 发表于 2014-10-24 10:36
    ; Z. g4 r) [9 q, x; x" a4 apart name太长了,   Device/Net/Pin name char limit 里面的值改一下就好了。如附件
    ' V( q$ l9 H6 b( J# Q
    问一下大师, 图片上这种情况 只能缩短封装名称吗?有没有其他方法可以解决呢?(这种情况是:ORCAD 做原理图,出网表时后缀加了“,VALUE”,网表导入PADS9.5就出现这堆问题了,在不出VALUE时 ,是完全可以正确导入的)
    / }  N# u' x8 |( r
    allegro里面的user preference里面也是可以设置的, 你搜一下allegro _long_name_size, 可把这个值最大改为255  详情 回复 发表于 2016-3-11 20:34
    推荐
    发表于 2014-11-5 10:25 | 只看该作者
    boychb 发表于 2014-11-5 10:18
      b7 a5 w# E, K. f" o8 V: o2 d, Q3 P我用的16.6S038怎么找不到这个Setup啊
    ( P2 A5 w) Q1 h7 T& X0 u
    打开capture,  选择菜单tools--create Netlist....,  在弹出的窗口中的PCB Editor的选项卡,  选择setup。  你就会看到之前提到的窗口了。
    难过
    2020-12-10 15:47
  • 签到天数: 3 天
    [LV.2]偶尔看看I
     楼主| 发表于 2013-6-4 10:12 | 只看该作者
    它为什么要rename啊?
    发表于 2013-8-9 09:43 | 只看该作者
    我遇到同样情况,楼主如何解决的 啊,求方法,谢谢啦
    发表于 2014-10-22 09:58 | 只看该作者
    目前没有看有人支招
    发表于 2014-10-22 12:04 | 只看该作者
    这些都是警告啊 错误在哪里\、
    发表于 2014-10-22 12:06 | 只看该作者
    这些都没有错啊 ,意思都是说这个原理图有脚名字一样,编号不同就没事啊
    发表于 2014-10-22 13:02 | 只看该作者
    U2/U7 有名稱相同,改掉OrCAD中的名稱就可以8 N! S" t4 @& h: B2 m0 x5 l- F
    发表于 2014-10-22 13:50 | 只看该作者
    orcad里只允许power属性的引脚可以重名
    发表于 2014-10-22 23:25 | 只看该作者
    电源属性管脚重名也要产生警告,不过不影响网表生成
    2019-11-29 15:00
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2014-11-5 10:18 | 只看该作者
    " \! z& X( w7 Z3 R4 w; Spart name太长了,   Device/Net/Pin name char limit 里面的值改一下就好了。如附件
      ?6 F+ K" b, {8 ]
    我用的16.6S038怎么找不到这个Setup啊: A/ M3 O5 m6 S8 m
    2019-11-29 15:00
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    13#
    发表于 2014-11-5 10:59 | 只看该作者
    hanbingchong 发表于 2014-11-5 10:25  p& Z% A2 ~+ S2 z" N8 t! q
    打开capture,  选择菜单tools--create Netlist....,  在弹出的窗口中的PCB Editor的选项卡,  选择setup ...
    + n% @* Y" S; x十分感谢,平时都没注意这个问题,嘿嘿,多谢多谢。" ^5 G2 @. x2 R" N  V9 X7 I
    14#
    发表于 2014-11-5 18:45 | 只看该作者
    hanbingchong 发表于 2014-10-24 10:36* a' s8 v1 l: @% K' z, V  }! M
    5 h; Z3 i. Y: Q* x; {+ K; B问一下!为什么要把31数值改成255数值呀!5 r0 U% }' L0 }5 \" j6 v9 J
    31的意思就是你的网络名最多有31个字母这么长,干成255就可以有255个字母那么长,好多因为命名太长而被重命名的网络在255这个条件下就不会被重命名  详情 回复 发表于 2022-8-9 14:19
    15#
    发表于 2015-1-15 14:35 | 只看该作者
    & u8 ~" \- y3 o; E4 s" N/ H3 ~打开capture,  选择菜单tools--create Netlist....,  在弹出的窗口中的PCB Editor的选项卡,  选择setup ...
    7 i1 u# n' u& m/ R之前不知道,现在知道了。非常感谢你!
    GMT+8, 2025-11-5 11:59 , Processed in 0.171875 second(s), 29 queries , Gzip On.
