本帖最后由 chenyuanzhi1989 于 2013-5-27 22:44 编辑 * k5 @1 T( E7 p. G' F% e/ d9 j+ v
4 G1 |/ Q: r) ^- G
4 e9 Q' S7 W# S! T& L8 A! l! Y5 U+ L$ y
$ G" B2 v9 J h
4 V8 a0 M9 k- B3 E$ P
About Board Viewer 3 Q2 ^6 S/ K( x- e. m3 u# }" T1 h
# H( @8 \* t6 l3 f% i6 |9 A& g
--------------------------------------------------------------------------------1 I6 m+ U) G) B/ S0 }- P0 @
Board Viewer is a tool to reference the PC board data, panel data, and footprint data for Board Designer. Board Viewer is a tool suitable for visual inspections of design data, because its main feature is that it can make use of Board Designer data directly without depending on the CR-5000 execution environment. - P3 e% P7 y6 R7 J
Board Viewer has the following functions.
: w. n. o4 f7 ?! h
8 @- N( ?: W5 F e/ N2 U: Z& @
! c* N0 a3 X. |7 IReferencing CR-5000 PC board data, CR-5000 panel data, CR-8000 design data, CR-8000 manufacture data, and footprint data without a data server
$ t7 b6 }/ U* E1 R/ y' t& @: eDisplay setting for each layer B5 q$ ^3 c3 t: I
Displayed order setting for each layer % I2 o l h" U' r3 o7 ^
Setting for visible laner groups % X+ {$ F* N) z; v; H$ v z, n- ?
Setting for mirroring canvas 7 z# ?7 H5 T& ^: g9 D6 Z; g9 s$ p
Display setting for each net name " U# R& M y& l( ~! I& [1 Q4 ^6 i
Option settings for displaying footprints . A$ Z7 N$ X" b# {: K: c
Displaying information on cursor coordinates, drawing areas and the origin # [7 L, G. T! O; M
Searching for data from nets, reference designators and terminal names
3 H! s% ?0 I: g7 \ Y8 EQuerying data
0 o' F6 P. ~# S! SMeasuring distances between pieces of data
( V7 W6 t! \& ]' ?Measuring distance between two points (Ruler) ' W U$ D7 J- I, V
Inputting comment strings 2 t* B* I" X# q1 b+ u ], T7 H
Undoing and redoing editing of comment strings ' a2 b, ^9 b" k' o. }
Referencing identical pieces of data at the same time
. ?0 T* W7 e1 P8 f: c! ^ _& hPrint
; f$ i$ l! }: M( D' n) ]: o, O
" w# `0 i$ Q4 L6 @
6 V% d, y- X# R6 u& v/ S% M5 u- u9 L
( F; l* p# q, Y l- X; v8 W) O下载地址:http://www.eechina.com/thread-115491-1-1.html |
